[AD9][4层]HT6200锁相板(MAX3232+74ACT541+EP3C16E144)pcb文件; t) w% p* ^- W; n" [ ?
. Q$ }4 S7 N" L3 l+ N6 H
文件描述:
, X! Z% l! t6 c* c
& }8 W, J, }& \7 ~4 ^1. 作品用途:HT6200锁相板
4 g& i6 \) w# }9 [2. 软件版本:AD9, h4 ~+ F, _7 h% m
3. 层数:4层0 B) T' i6 o5 S1 M/ m9 k
4. 用到的主要芯片:MAX3232+74ACT541+EP3C16E144
C# k; @; B7 R5. pcb尺寸:96.39*141.9 MM
# E, ?- Y3 I8 q1 r+ O作品截图如下:4 R( l& R" Y+ y' i+ i: ]
% M+ X, n1 ~$ C0 B) F% G顶层截图:5 R; A, B% i6 K A; y, J
. |3 O$ b7 q% |2 E0 t底层截图:, |3 J; y5 E% [/ z7 f$ E% b2 V
. t5 s6 ^8 ?3 q
( z; g- D' y1 Y! x1 X全层截图:7 `: O+ d- Z5 G5 H- F u
, A6 o" g2 f0 {7 T/ j) A
5 s7 @( n6 ?: u! c$ I5 ?叠层阻抗信息如下:6 p8 p( L0 P. q
: I+ H0 i2 _3 e( ]8 I! B5 u2 L
BOM:' j L) p/ o9 S: n
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1PPS_OUT | 1PPS_OUT | SMA | 1 | DIODE | +5V_LED_1, +12V_LED, D1, D2, D3, D4, LED, LED_1 | 0805 | 8 | 10MHz_OUT | 10M_OUT | SMA | 1 | RS232 | 232_1 | SIP3 | 1 | TEST | 232_2, 232_4 | SIP3 | 2 | | 232_3 | SIP3 | 1 | COMPONENT_2 | 3627 | 3627晶振 | 1 | DC-2.54-10 | AS_MODE, JTAG_MODE, TO_X72, TO_ZHUBAN | IDC10 | 4 | 0.1UF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C18, C19, C20, C21, C25, C26, C27, C29, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C56, C58, C60, C61, C65, C67, C69, C70, C71, C75, C76, C77 | 0805 | 59 | 0.01uF | C16, C74 | 0805 | 2 | 25V-10UF | C17, C23 | 1210 | 2 | 1000P | C22 | 0805 | 1 | 25V-0.33UF | C30 | MLL34 | 1 | 10V-0.1UF | C55 | MLL34 | 1 | 50PF | C59 | 0805 | 1 | 25V-10UF | C62, C63, C72, C73, C85, C86, C86_1, C87, C87_1, C88 | MLL34 | 10 | 1000PF | C64 | 0805 | 1 | 10uF/25V | C66 | 1210 | 1 | 10nF | C78, C79 | 0805 | 2 | 25V-2.2uF | C83, C84 | MLL34 | 2 | GPS_1PPS | GPS_1PPS | SMA | 1 | GPS_TIANXIAN | GPS_TIANXIAN | SMA | 1 | waimiao(5v) | IPPS_IN(5V) | SMA | 1 | CON8 | J1 | 100MJZ | 1 | UA7805C | J12 | TO-263 | 1 | CON8 | JZ | 10MTB | 1 | 100UH | L3 | 1210 | 1 | GreenLED | LED_DL1 | LED_0805 | 1 | CON14 | M12M | M12M | 1 | AMS1117-ADJ | N1 | SOT-223/P2.3 | 1 | AMS1117-3.3V | N2, N2_1 | SOT-223/P2.3 | 2 | CON4 | POWER | CON4 | 1 | 10MHz_IN | PRS10_10M_IN | SMA | 1 | 2N2222 | Q1 | KTO-92 | 1 | 10R | R1, R24, R28, R29, R30, R31 | 0805 | 6 | 2R2 | R2, R3, R25 | 0805 | 3 | 200R | R4, R5, R26 | 0805 | 3 | 1K | R6, R7, R8, R9, R35, R36, R37, R38, R39, R40, R_LED, R_LED_1 | 0805 | 12 | 10K | R10, R11, R12, R17, R34, R41, R42, R43, R44 | 0805 | 9 | 620R | R13 | 0805 | 1 | 4.7K | R14, R18, R19 | 0805 | 3 | 8.2K | R15 | 0805 | 1 | 510R | R16 | 0805 | 1 | RES | R20 | 0805 | 1 | 100R | R21, R22, R23, R27, R45 | 0805 | 5 | 0 | R32, R33 | 0805 | 2 | 0R | R47, R48 | 0805 | 2 | 240R | R50 | 0805 | 1 | 1分3 | U1 | GONGFENQI | 1 | DAC8531 | U2, U7 | TSSO3X6-G8/X.3 | 2 | LT1715 | U3 | LT1715 | 1 | CAT1025JI-30 | U4 | SO-8 | 1 | MAX3232 | U5, U6 | SO-16 | 2 | ADR445B | U8 | SO-8 | 1 | 74ACT541 | U9 | SOL-20 | 1 | SN74LVC1G34 | U10 | DBV_R_PDSO_G5 | 1 | ICL7660S(-12V) | U11 | SO-8 | 1 | EPCS4 | U13 | SO-8 | 1 | EP3C16E144 | U14 | TQFP144 | 1 | ublox-5s | U_BLOX | GPS-5T | 1 | YULIU_1PPS_OUT | YULIU_1PPS_OUT | SMA | 1 | & m: Q' e9 R2 P
附件:
* o0 ~3 i& A' R+ a3 o! lpcb文件如下:* n j& U5 O) w! s- Y
4 L" `6 K9 K2 h F% ^: v |
