引言想做一个自动驾驶的demo,用于算法的验证和展示。 目前完成了车辆平台的搭建和电机控制,后续会陆续更新其他部分:路径规划、激光slam建图与定位,语义地图的构建,控制算法等等。 硬件平台搭建:计算平台 - Jetson TX2
- arduino-uno [- n$ l+ H/ V9 W
车载平台 - RC-car
/ ?* _9 z; _- e) w- T" y! Z1 S
传感器 - velodyne-16
- Razor-9dof-imu
4 d [6 a7 B) _/ o7 l+ a6 ]
整个基本框架是Jetson TX2做上层感知,定位,路径规划的处理,arduino负责底层的电机控制。目标总体框架如下所示: arduino电机控制电机控制代码如下所示: #include <Servo.h>#include <ros.h>#include <geometry_msgs/Twist.h>class Car {public: void initControler(); void ARMControler(); void writeToControler(int, int); float limitMotor(int); float limitServo(int); private: const int MOTOR_PIN = 10; const int SERVO_PIN = 9; const int MOTOR_MAX = 2000; const int MOTOR_MIN = 1600; const int MOTOR_STOP = 1300; const int STEER_MIN = 1100; const int STEER_MAX = 1900; const int STEER_CENTER = 1500; const int noAction = 0; Servo motor; Servo steering;};Car car;int motor_speed;int steer;volatile unsigned long dt;volatile unsigned long t0;ros::NodeHandle nh;geometry_msgs::Twist vel_angular_back;void controlCallback(const geometry_msgs::Twist& ecu) { car.writeToControler(ecu.linear.x, ecu.angular.z); vel_angular_back.linear.x = ecu.linear.x; vel_angular_back.angular.z = ecu.angular.z;}ros::Publisher ecu_back("ecu_back", &vel_angular_back);ros::Subscriber<geometry_msgs::Twist> sub_control("control", controlCallback);/** * ARDUINO INITIALIZATION */void setup() { car.initControler(); car.armControler(); t0 = millis(); nh.getHardware()->setBaud(57600); nh.initNode(); nh.advertise(ecu_back); nh.subscribe(sub_control);}/** * ARDUINO MAIN lOOP */void loop() { dt = millis() - t0; ecu_back.publish(&vel_angular_back); if (dt > 50) { t0 = millis(); // to do } nh.spinOnce();}/** * CAR CLASS IMPLEMENTATION */void Car::initControler() { motor.attach(MOTOR_PIN); steering.attach(SERVO_PIN);}void Car::armControler() { motor.writeMicroseconds(1500); steering.writeMicroseconds(STEER_CENTER); delay(3000);}float Car::limitMotor(int x) { if (x == noAction) { return MOTOR_STOP; } if (x > MOTOR_MAX) { x = MOTOR_MAX; } else if (x < MOTOR_MIN) { x = MOTOR_MIN; } return x;}float Car::limitServo(int x) { if (x == noAction) { return STEER_CENTER; } if (x > STEER_MAX) { x = STEER_MAX; } else if (x < STEER_MIN) { x = STEER_MIN; } return x;}void Car::writeToControler(int motor_speed, int steer) { int motorCMD, servoCMD; motorCMD = car.limitMotor(motor_speed); servoCMD = car.limitServo(steer); //motorCMD = motor_speed; //servoCMD = steer; motor.writeMicroseconds(motorCMD); steering.writeMicroseconds(servoCMD);}" L. {3 u( A4 i: I# w5 g; H/ M
为了完成arduino电机控制与TX2的通讯,需要在TX2上面搭建一些环境: 1 安装arduino sudo apt-get install arduino9 D2 [- N& y) g- ^7 x
2 安装rosserial-arduino 用途:用于arduino的ROS通讯桥接 二进制方式安装在ROS工作站(推荐) sudo apt-get install ros-indigo-rosserial-arduinosudo apt-get install ros-indigo-rosserialrospack profile
* `9 b( T5 y$ M9 u ~6 Y源码方式安装在ROS工作站 cd <ws>/srcgit clone https://github.com/ros-drivers/rosserial.gitcd <ws>catkin_make* l8 b4 U, [. a C$ ?9 A* L$ x4 x
3 安装ros_lib到Arduino IDE开发环境 上面的安装会得到ros_lib,它需要复制到Arduino的开发环境,以启用Arduino与ROS通讯。 linux系统下,生成ros_lib到Linux下的Arduino库目录sketchbook/libraries(一般在用户的home目录下) cd <sketchbook>/librariesrm -RF ros_lib #如之前有,可以先删除rosrun rosserial_arduino make_libraries.py .
0 T$ s1 H" J$ V3 d4 S# Z然后,可以打开arduino IDE,找到file-examples-ros_lib是否存在,如果这一不没安装好的话,会找不到ros.h的头文件 4 运行ROS-arduino 写好arduino的代码之后,就可以试着运行看看 运行roscore roscore
0 k' J9 c% n6 z: n4 `新终端运行,/dev/ttyUSB0为Arduino设备,设备可能是/dev/ttyUSB0,也可能是/dev/ttyACM0,需要自己确认 rosrun rosserial_python serial_node.py /dev/ttyUSB0rosrun rosserial_python serial_node.py _port:=/dev/ttyUSB0 //这个也可以8 @: a) N' z$ D. Y, L8 C, w
然后就可以在ROS中发布转向速度的话题消息,arduino节点接收消息后,完成电机控制。 ( ~" g: e5 O N1 z- b
