查看: 3848|回复: 1
求救Orcad Capture CIS生成网表时出现问题
发表于 2010-10-9 22:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#679 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.0 z$ P1 D7 }+ |8 P1 C' [- h
              PAGE
1 G1 d3 M8 j5 f. [0 u5 u. C#680 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.
  ^. V" T( v% J              PAGE0 L  T4 ^0 E: a& V- m
#681 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.
% u* ^" o# G1 ?              PAGE
3 ^4 N/ Y' s: R# b- }; c" L! G#682 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.2 F, e& t# p" Q8 p) t* n
              PAGE
. b2 T" c9 l6 n; `! }#683 Error   [ALG0013] Conflicting values of following Component Instance prope  p& {3 g% }/ u( x+ d% T6 f9 k# W
) W" a' B* _  ?) m9 C              PAGE
  j: O. n  Z& I( m#684 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.; ^# E: e- M  w7 n* N, W
              PAGE
: x' s8 q! }! W1 M$ [( S- @#685 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.
1 Q9 v8 B/ t2 l% |  x4 U. T: \              PAGE
9 I" I0 B5 N; Y1 G" B) v9 P#686 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.% J' t+ a+ Y* F; |# i2 C! l! f. H
              PAGE
, e+ |  L! N4 A9 W4 X#687 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.
* o2 D- d# x& A# T( R. i' {              PAGE
- E; G7 A( d5 A  N#688 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.
& I2 r. c0 _+ m3 Q              PAGE6 ]1 k0 |7 |0 s  x% r* j' c
#689 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U25.4 N9 L, V# u5 L5 g: s
              PAGE; G# _& H- D* D' u
#690 Error   [ALG0013] Conflicting values of following Component Instance properties found on different secti4 W& \% D5 L( g4 ^
ons of U25.6 N/ J" v) b6 A1 o' k) a
              PAGE( y' C6 z7 k) ]8 D* l& y9 k. i4 s- J
#691 Aborting Netlisting... Please correct the above errors and retry.
7 d) e' [; w' D8 F. p2 F0 _6 U; [Exiting... "D:\cadence\SPB_16.0\tools\capture\pstswp.exe" -pst -d "F:\TIADC\Project\sch_ver3\tiadc_ver3.dsn" -n "F:\TIADC\Project\sch_ver3\allegro" -c "D:\Cadence\SPB_16.0\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
  K2 }9 P2 c1 E% V0 G2 b: S  n6 L0 E. Z其中U25是FBGA封装的FPGA:EP3SL150F480.元件库是在ALRERA官网下的。谁能帮我解决一下,谢谢
发表于 2010-10-11 11:31 | 只看该作者
这个一般是因为同一颗零件的不同part,比如part A和part B,同一个属性的属性值不一样,不如属性part number:part A为123,而part B为234,你要做的就是检查零件,把这些问题改掉试试。
GMT+8, 2025-8-3 04:12 , Processed in 0.109375 second(s), 24 queries , Gzip On.
