TA的每日心情 | 开心 2019-11-20 15:05 |
签到天数: 2 天 [LV.1]初来乍到
FUJI QP242E服务工程师维修手册 [Chapter 1] QP242 Initial Adjustment (1)
. S7 M! h" V! F- Z
6 p. @5 p: h |1 @2 m( Z7 k" L- q/ D( K! @+ D, U8 m
[1-1] Leveling the Machine
' y5 F6 E+ V3 N( n7 j1) At systems with independent modules:. ~; y8 Z, w- f& e
Place a level on the machine base and adjust the 6 leveling bolts (black circles in figure at right) to level the module in the front-back and right-left directions.0 q% s/ t5 I/ p7 S
2) At systems with linked modules:
3 v3 E- a- X2 y/ D4 k$ j * When there are an even number of modules (see figure below), place two levels on the two center modules and turn the leveling bolts (shown as black circles in the figure below) to adjust the overall level. After leveling the two center modules in this manner, verify that each of the modules is level. (The further modules are from the center, the more likely they are to be out of level.' }, x& r1 K3 J" V3 x# i4 t. X
In such cases, further adjust the levels of the modules at both ends of the module row so that their levels are the same, and are close to horizontal.)
6 e, ~( ?) c4 ]2 V- M9 c: g; G, A
/ P& w2 B8 B: X1 x6 o# u
0 K4 A5 } S6 t0 u/ J: T& G2 P: w! C5 G; O/ Q
' h% I/ z9 Q6 T
% X) C( R. |* d; J" C( i+ s( w/ ]3 W
