' ?" b$ l0 w `0 M9 {
' {1 F' a% O6 L6 M4 n2 eCP643伺服调校
1 s0 H ~4 a: L* S, F& M2 h( K8 G6 f/ d* Z- a4 [
" N- P7 ]; ~, x# z% a% @
The mechanical check software (servo adjustment software) is used to peRForm CP643E's servo adjustment. The servo adjustment procedure using mechanical check software is described below. This procedure below applies only to Servo ROM305 or newer versions.! w* S& I4 u( x. y: F: x/ h
1) Start the mechanical check software by entering the following: [3] (axis selector SW) +[RESET] + [POWER ON]/ ]. B# H" N7 e
2) Use I/O commands to set the cam lever stoppers as follows:. D" w, D2 p6 D
[I/O] (F3)- -> [OUT] (F2) - -> Position the cursor using the [+PAGE], [-PAGE], [▲],[▼]keys -> [ON/OFF] (F5)
* g: F. }% }+ h4 h5 w% ]9 s# ]+ v4 z% M* s# e
5 b/ g3 c; }( I* D
7 r* o- v, L" y' V; V) E, p3 J
