[AD9][4层]5130参考板(EP3C16E144+AD5791+MAX3232)pcb文件( j/ ^5 Z/ R6 I' b1 ]
6 Z! e! h2 Q9 A! A7 ^6 [" a! Y* p文件描述:
$ t/ M. c9 D' M6 Z) t3 G8 N, W9 B$ n P2 v E" ~
1. 作品用途:5130参考板' c! b1 b0 W' R7 J+ ~
2. 软件版本:AD98 I* g2 d i1 a* }; [0 E, `! h/ M( w
3. 层数:4层9 h* |& P6 P' ~
4. 用到的主要芯片:EP3C16E144+AD5791+MAX32326 L% s. R3 N2 O1 Y, t# m
5. pcb尺寸:148.6408*128.5113 MM
. D2 a0 W3 W9 K9 I4 P作品截图如下:
U7 ~' u& P- v3 Z9 X3 P X3 e0 k
6 r' \* B# d7 Y# W顶层截图:
]! W' d5 {/ D' L3 E6 n% i/ Y
6 U6 K5 G9 }# U0 ^底层截图:- x0 n. }" [ G$ h" P0 g+ }
6 R) r6 z4 d4 m: ~. u
* T* T, f6 K; m, h! k: T全层截图:1 s ~% w! V7 [1 \" o) ]5 O5 H
* @; \* S: Y. J) _( j
, x# T4 |2 { I2 l7 G" R8 c8 z9 O- H叠层阻抗信息如下:7 K, F* b, |7 ^
" v' w3 O7 e7 X% ]BOM:9 e( W" R) B: p, ]2 R9 m
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C01, C04, C06, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C25, C26, C27, C29, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C61, C62, C63, C64, C65, C69, C70, C71, C77, C_1 | 0805 | 64 | 25V-10UF | C02, C03, C05, C24, C66, C67, C68, C72, C73, C91, C92, C93, C94, C95, C96, C102, C103 | 1210 | 17 | 1000P | C28, C75, C76 | 0805 | 3 | 10P | C30, C104 | 0805 | 2 | 0.01UF | C60 | 0805 | 1 | 103 | C74 | 0805 | 1 | 10nF | C78, C79, C80, C81, C82 | 0805 | 5 | 25V-2.2uF | C83 | MLL34 | 1 | 2.2UF | C84 | MLL34 | 1 | 25V-10UF | C85, C86, C86_1, C87, C87_1, C88, CA3, CA4 | MLL34 | 8 | 1000PF | C89, CA6 | 0805 | 2 | 0.1uF | C90, C100 | 1210 | 2 | 10V-2.2UF | C97, C98 | 1210 | 2 | 1uF | C99 | 1210 | 1 | AD588 | C101 | DIP-16 | 1 | 50P | C105 | 0805 | 1 | DIODE | D1, D2 | 0805 | 2 | VA | J1 | SMA | 1 | DC-2.54-10 | J2, J3 | IDC10 | 2 | 10MHz_IN | J4 | SMA | 1 | CON4 | J5 | CON4 | 1 | waimiao(5v) | J6 | SMA | 1 | OUTPUT-1PPS | J7 | SMA | 1 | SHANGWEIJI | JP1 | SIP3 | 1 | TEST | JP2 | SIP3 | 1 | J_LED | JP3 | SIP3 | 1 | 100UH | L3 | 1210 | 1 | 150uH | L4 | 1206 | 1 | GreenLED | LED_DL1 | LED_0805 | 1 | AMS1117-ADJ | N1 | SOT-223/P2.3 | 1 | AMS1117-3.3V | N2, N2_1 | SOT-223/P2.3 | 2 | AD5791 | P1, P5 | AD5791 | 2 | AD8676 | P2, P4 | AD8676 | 2 | AD8675 | P3, P6 | AD8676 | 2 | 2N2222 | Q1 | KTO-92 | 1 | 10K | R1, R17, R41, R42, R43, R44, R45, R46, R47 | 0805 | 9 | 10R | R2, R21, R22 | 0805 | 3 | 100R | R3, R8, R9 | 0805 | 3 | 1K | R4, R5, R35, R36, R37, R38, R39, R40 | 0805 | 8 | 620R | R13, R20 | 0805 | 2 | 4.7K | R14, R48, R49 | 0805 | 3 | 8.2K | R15 | 0805 | 1 | 510R | R16 | 0805 | 1 | 2R2 | R24, R25 | 0805 | 2 | 200R | R26 | 0805 | 1 | 50R | R29 | 0805 | 1 | 240R | R50 | 0805 | 1 | | SINE IN | SMA | 1 | LT1715 | U3, U4 | LT1715 | 2 | 74LV14 | U6 | SO-14 | 1 | MAX3232 | U7 | SO-16 | 1 | 74LVC4245 | U8 | 74LVC4245 | 1 | 74541 | U9 | SOL-20 | 1 | SN74LVC1G34 | U10 | DBV_R_PDSO_G5 | 1 | ICL7660S(-12V) | U11 | SO-8 | 1 | EPCS4 | U13 | SO-8 | 1 | EP3C16E144 | U14 | TQFP144 | 1 | CAT1025JI-30 | U15 | SO-8 | 1 | 50 MHz | Y3 | 50_JZ | 1 | 附件:# A! l) m* u6 ?8 N
PCB文件如下:
) q i! I1 X3 z" i2 V% Z# C
8 R- L( p& b8 @) l+ H' J |
