[AD9][4层]100M锁相板(EP3C16E144+MAX3232+74ACT541)原理图和pcb文件
0 P' _3 \1 q% V3 u, o+ Q" j( J
/ P3 g/ C$ }( x+ {文件描述:
7 ^9 g) z& n( G6 w) z4 o% g4 Q# z6 w
1. 作品用途:100M锁相板& [1 |, \$ q0 s4 r1 ?
2. 软件版本:AD9
# j Q' j8 _& t& `9 d! z5 I5 S s3. 层数:4层
, `1 Y* r# P1 n# z Z6 v4. 用到的主要芯片:EP3C16E144+MAX3232+74ACT5417 T/ g6 V# k5 ~
5. pcb尺寸:55.6425*175.01082 MM
* k: I l7 z S
- D9 q8 {1 P! b3 C- `/ U作品截图如下:
) T6 ~6 M$ |4 z, @5 c
8 W3 u% m6 A9 r d; X Q顶层截图:. @; S# S( A: ]) N; p) q
9 N0 ^5 Y+ h, F
底层截图:
: }, @# N, U1 t$ H% C$ T: ^
2 b9 z- r5 @8 A' Y
$ `- X" \# r, F2 d5 }) a2 |% `7 K全层截图:! P. l5 P0 h4 u N) D4 X
/ c9 ]4 x0 u( Q' ?
. b9 i% H# a' ?3 V叠层阻抗信息如下:! E2 j, R) e! U: c# |( s/ c/ g
5 R/ z3 p! C) J2 ?% u
BOM:* [) T+ s- u5 f! a0 _8 v+ r7 ]
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1PPS_OUT | 1PPS_OUT | MCX | 1 | 100MHz_OUT | 100M_OUT1, 100M_OUT2, 100M_OUT3 | MCX | 3 | RS232 | 232_1 | SIP3 | 1 | TEST | 232_2 | SIP3 | 1 | COMPONENT_2 | 3627 | 3627晶振 | 1 | DC-2.54-10 | AS_MODE, JTAG_MODE | IDC10 | 2 | 0.1UF | C1, C2, C3, C4, C5, C8, C9, C12, C14, C18, C20, C25, C26, C27, C29, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C54, C56, C58, C61, C65, C67, C77 | 0805 | 44 | 25V-10UF | C6, C7, C62, C63 | MLL34 | 4 | 25V-10UF | C10, C17, C23, C30, C73, C76, C85, C86, C86_1, C87, C87_1, C88 | 1210 | 12 | 0.01UF | C11, C13, C78, C79 | 0805 | 4 | 25V-2.2uF | C15, C19, C83, C84 | MLL34 | 4 | 1000P | C16, C21, C22, C28 | 0805 | 4 | 10V-10UF | C24, C55 | 1210 | 2 | 1000PF | C53, C64 | 0805 | 2 | 50PF | C59 | 0805 | 1 | 10uF/25V | C66 | 1210 | 1 | DIODE | D1, D2 | 0805 | 2 | GPS_TIANXIAN | GPS_TIANXIAN | MCX | 1 | waimiao(5v) | IPPS_IN(5V) | SMA | 1 | CON8 | J1 | 100MHZ_JZ | 1 | UA7805C | J2 | TO-263 | 1 | CON4 | J3 | SIP4 | 1 | UA7805C | J12 | 78M05 | 1 | 4.7UH | L1 | L7_7 | 1 | GreenLED | LED_DL1 | LED_0805 | 1 | AMS1117-ADJ | N1 | SOT-223/P2.3 | 1 | AMS1117-3.3V | N2, N2_1 | SOT-223/P2.3 | 2 | CON4 | POWER | POWER | 1 | 10R | R1, R24, R28, R30 | 0805 | 4 | 33R | R2 | 0805 | 1 | RES | R3, R17 | 0805 | 2 | 680R | R5, R20 | 0805 | 2 | 1K | R6, R7, R35, R36, R37, R38, R39, R40 | 0805 | 8 | 0R | R8, R9 | 0805 | 2 | 10K | R10, R11, R12, R34, R41, R42, R43, R44 | 0805 | 8 | 4.7K | R18, R19 | 0805 | 2 | 100R | R21, R23, R45 | 0805 | 3 | 240R | R50 | 0805 | 1 | 1分3 | U1 | GONGFENQI | 1 | DAC8531 | U2, U7 | TSSO3X6-G8/X.3 | 2 | LT1715 | U3, U6 | LT1715 | 2 | CAT1025JI-30 | U4 | SO-8 | 1 | MAX3232 | U5 | SO-16 | 1 | ADR445B | U8 | SO-8 | 1 | 74ACT541 | U9 | SOL-20 | 1 | SN74LVC1G34 | U10 | DBV_R_PDSO_G5 | 1 | ICL7660S(-12V) | U11, U12 | SO-8 | 2 | EPCS4 | U13 | SO-8 | 1 | EP3C16E144 | U14 | TQFP144 | 1 | ublox-5s | U_BLOX | GPS-5T | 1 | & m7 W1 @. m3 I) a5 F5 g( ]
; S* A, W4 g) h8 Z9 s* a9 H& F
附件:
5 k; f6 E4 `: P" h ], D原理图和pcb文件如下:
1 r$ c& S" `$ P. r9 W
9 p8 ~3 [0 K3 `+ w) J: k% C+ m0 M |
