查看: 362|回复: 2
Machine Adjustment Tool Operation Manual
    2019-11-20 15:05
    发表于 2020-7-22 11:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    & v/ g* `) e! A' x, M* |, r' e1 r; [
    4 y6 e0 p/ A( _1 P( [/ Z. x$ x3 m! c% {8 n* F
    , n) e) L* f+ h
    1. About the Machine Adjustment Tool
    $ Q3 b2 \- f$ g+ [! X; }This function can be used to check the I/O status and position operations for the conveyor and Tray unit-L on specified modules.+ g4 s8 H0 n. f+ [$ l/ ?5 J* x
    This tool has been designed to help service or maintenance workers remedy problems at the machine in order that production can be resumed quickly.* L8 `9 D+ D, H& G
    2. Requirements7 v; X1 x$ O4 R5 k% \* B
    2.1. Software  y5 l9 r# o$ y
    The following software is required in order to use this function.  B2 k0 E" j3 b2 J1 E+ N
    ●Machine application:   V4.50 and later
    , ~4 A/ S- A( E/ f' a1 U●Machine adjustment tool: Application contained in the CD for V4.50 and later
    , w$ j' o2 W' R( f" K$ b  l# \3. Installing on the Computer
    8 E3 M. }% Q' r2 c% x9 t/ o' z3.1. Installation Procedure
    * h1 X% ?- f2 U6 I) o. Y. xUse the following procedure to peRForm installation.
    : X% N) ?* t9 H8 i" `1. Insert the CD in the computer.
    0 Y! |4 @3 r& o9 N6 s2. Click the [Select the required images and instal] button at the Fmenu“Setup support tools for the engineering panel." ltem.
    7 [1 z3 I. @+ m) W' }" x! |' k+ e9 ^0 }8 O3 J- ]& w% G5 ]
    ) a4 o$ Z) Y3 ?& `4 ?( s7 C/ ?; L; f
    游客,如果您要查看本帖隐藏内容请回复
    1 g1 _9 d* ?( ^: L: T* Y/ f% l
    发表于 2020-7-22 11:22 | 只看该作者
    Machine Adjustment Tool Operation Manual。
    发表于 2022-7-6 04:20 | 只看该作者
    GMT+8, 2025-9-28 09:58 , Processed in 0.140625 second(s), 26 queries , Gzip On.
