昨天晚上用的好好的,今天早上一打开文件夹便出现这个错误:
0 q; B6 q9 b/ z- @我用的是15.7的g还有16.0精简版的,这两个重装了也不行。
* I5 v2 c5 T& C5 j3 E有没有高手帮助解决一下,注册表我改过了,没有用。
6 ~! g+ {% ] b" y/ ?- R" K/ M6 mthis application, orcad capture, has encounterned following unrecoverable exception, and hence needs to be closed down7 N. n, F& P& @9 @7 {. o
EXCEPTION_ACCESS_VIOLATION::2 F: R0 M) ]: [. h" G0 `3 p
One of the threads has tried to read from or write to a virtual address for which it does not have the appropriate access
2 g; B% k g; @ ] i% HDo you want to save all the open design now before capture closes? |
