查看: 740|回复: 3
BLDC Motor Modelling and Control - A Matlab%/Simulink Implementation
发表于 2020-7-1 13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有关无刷电机的Simulink仿真的一篇论文,此论文来自瑞典一所大学的研究生论文,关于无刷电机的仿真。
2 ]0 J# F  {+ s$ |3 Q- e, ^
: h+ P; _" r/ T7 v
; W5 o9 h' x' _, X
& ^6 u4 _; @, t" J) {
) A. _2 ~- e8 O( ~- RAbstract( |/ E5 ]/ r/ P
This thesis presents a model of a three phase star-connected brushless direct current (bldc) motor. The construction and operation of both conventional dc motors
3 j2 ?4 L9 u# W+ Tand bldc motors is presented and state-space models are derived for each. Matlab@ /Simulink@ models are developed for each motor type and their validity is verified. Torque-, speed- and position control is applied using hysteresis band control, pwm control, and variable dc- link voltage control.% X" F7 q+ l! _( @6 x
The different control strategies are tested on the bldc motor and their peRFor-mance evaluated. The frequency content of the dc link current is investigated for each control method and the impact of commutation delay and switch-ing losses is discussed. Simulations show that all the control strategies work quite well although each method has its drawbacks. The frequency spectrum of the dc-link current shows that hysteresis band control may not be suitable where load variations are large. The variable dc-link voltage method turns out to be the best solution in applications where torque ripples and switching losses must me minimized. Commutation delay is necessary in practice, but
+ ]+ s3 o5 j7 `! |9 \the simulations show that it should be kept as short as possible because it causes increased torque ripples.( N- o! f  b. u- Q* v) j
Keywords: Brushless motors, bldc, modelling, control.9 Z; Q; u; G# Q% `5 o8 l$ p" a
0 q1 _2 U+ H2 P, }) e, ^$ E
游客,如果您要查看本帖隐藏内容请回复
* d! `& Q1 g/ E) z: c4 K
: K/ W' B2 Q% W7 ^. R( Y6 a
    2019-11-29 15:38
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2020-7-1 15:38 | 只看该作者
    有没有中文的?
    奋斗
    2025-7-15 15:17
  • 签到天数: 705 天
    [LV.9]以坛为家II
    发表于 2021-1-22 17:44 | 只看该作者
    感谢分享!感谢分享!感谢分享!
    * e" k0 _: z) I. D
    GMT+8, 2025-8-23 18:12 , Processed in 0.125000 second(s), 26 queries , Gzip On.
