呵呵,不看help还不行,解决了! : U$ a$ J; `( J4 x6 sThe part name. This property is required to use the Place 7 d1 C" }$ O! MDatabase Part command. Only the part name is necessary if- w, }: [7 ~/ m; g; J1 T8 k
the part is stored in the same directory as the custom, m) {7 N* ^0 a* y4 j2 G6 H* I$ V
schematic part libraries (.OLB files) that you configure in" v* F& z" h! n% Z$ l
Capture. (See the OrCAD Capture User’s Guide for more# }- ^3 z( @* O# G F0 p
information about configuring part libraries.)
