查看: 321|回复: 1
XPFMTU 伺服放大器复位资料
发表于 2020-6-28 14:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
XPFMTU  伺服放大器复位资料  a- ^5 k; c6 a- h" i% d
Chapter 13 – Adjusting the MTU-A $ k; H! F: q& U$ [
Supplement – Bypassing the T and U-axis motor brake   g" P( M4 p" N  I+ j2 c7 a
The T and U-axis both have a motor brake to prevent them moving when the servo power is OFF. When adjusting the MTU-A it is sometimes necessary to bypass the brake in order to manually move the axes. The procedure for bypassing the brake is given below.
. S' D. r! l4 }! e, n8 |# W. yWarning! The T-axis will drop down very fast if the 200V servo power is ON when the jumper connector is connected and then the servo power is turned OFF. Always press the EMERGENCY STOP button to cut the 200V servo power before connecting the jumper connector. " P* ^8 E! k& Y5 D
6 E3 d) [3 S6 X! Y& u5 V
游客,如果您要查看本帖隐藏内容请回复
3 [# ?. F6 ]9 r! P
发表于 2020-6-28 16:04 | 只看该作者
没有中文的吗?
GMT+8, 2025-9-29 02:33 , Processed in 0.140625 second(s), 26 queries , Gzip On.
