FUJIIGBT命名方法
% [# J3 {0 C, @' P$ ]$ e) N6 B& e4 O( `1 B& [0 N3 F7 R9 I! m# j
This instrucfion is applied to all units using 2MBI300NB-060-01. CM200DU-24H-202,2MBI300P-140-03,2MBI400NT-060-01.CM200DY-24H.CM300DY-24H,CM400DY-24NF7 `% t# P3 n6 |0 {2 t
and CM400DY-12H in parallel.7 M1 T6 E: ^0 ?9 h
2 f; ]8 n! I! G0 ?$ R
1) At the fime of connecfing IGBT modules in parallel, use modules of which rank symbols recorded on their module labels are identical. Do not connect modules in
( s% e t; s! T& y/ \1 G3 Fparallel of which rank symbols are different or not recorded.
4 {, P: K0 ~% t {+ b( h7 ]2) Example of parallel connecfion fhwo narallel connecfion) Two IGBT modules connected in parallel in one phase shall have the same rank symbol.
! _4 z/ C% `" v d9 p$ YEach rank symbol among phase U, V and W may be diferent.3 y0 R! B) l2 }! r3 ` |
& D7 |3 V7 L6 e5 z0 F5 `
. k$ [2 W5 @/ t" S( j; l
7 V3 i9 a( P/ u" E) ~+ Q) V/ f |
