% F: y8 L6 V6 b
5 q' m% m9 ^0 x/ M! j, s/ xcadence SPB allegro and orcad 17.20.000-2016 HF068 x64 | 3.9 GB | Language: English
. ~0 n0 O5 d2 \: y0 MCadence Design Systems, Inc. , the leader in global electronic design innovation, has unveiled a new of improvements to the Cadence SPB Allegro and OrCAD 17.20 families of products aimed at boosting peRFormance and productivity through improvements features and big fixed issues.
# A- J1 e9 n. c# I=
* `; d! E' q6 E3 f5 J( G3 X3 \CCRID Product ProductLevel2 Title% A; W7 b1 G+ h# i0 ?# w6 k
=4 r2 L$ x& a2 {# b3 Z: X4 t; i/ g& W! e$ ^
2238259 ADW ADWSERVER Designer server is shutting down and cannot be restarted7 X1 O) W1 A/ R. x# V( [9 p& e
2252163 ADW ADWSERVER Designer server has stopped working several times
8 e" y/ v$ R+ t7 ]6 w$ A2241655 ADW DBEDITOR Version uprev of model with every check-in if the model is renamed; A3 e3 t! N" t) B& Q$ S
2238666 ALLEGRO_EDITOR DFM DFF Silkscreen constraints showing DRC even though there is no violation.
$ p5 U9 Z% s4 T" J9 ~2279904 ALLEGRO_EDITOR DFM Design True DFM Wizard crashing9 ]/ y3 @* J+ ]+ A5 C b8 p
2251943 ALLEGRO_EDITOR DXF DXF out result is different between release 16.6 and release 17.2-2016.
) n6 M/ E- F: l( r2263977 ALLEGRO_EDITOR EDIT_ETCH Diff pair disappears when one of the nets is moved
% g4 r7 z1 x# s- Z9 z2268412 ALLEGRO_EDITOR EDIT_ETCH When Sliding a diff pair, one of the legs disappears
& B$ D, ^' ^ ^* m B. d! ^2252802 ALLEGRO_EDITOR INTERFACES Intensity of color changes on subsequent pages with PDF Export in black and white9 p/ z+ J. E/ n. N4 |' B) ~+ y
2267096 ALLEGRO_EDITOR INTERFACES Export PDF is creating different colors for same layer combination" w# U( o( T6 P w- k, R
2267963 ALLEGRO_EDITOR INTERFACES Difference in PDF between HotFix 003 and HotFix 006: Active layer color displayed for assembly layer text
7 }0 S: ~) ]* r+ w2 F( r2269613 ALLEGRO_EDITOR INTERFACES File> Export> PDF does not output panel imposition outlines.9 T T# L! Y( m0 b) r
2270690 ALLEGRO_EDITOR INTERFACES Export PDF: Page Setup tab has settings for Global Text Size but these settings only appear to adjust the text position9 U9 k6 [8 G, @
2270695 ALLEGRO_EDITOR INTERFACES Custom colors assigned in Color 192 used even if 'Hide custom colors' is enabled( f9 \+ M( ?6 y& p
2273868 ALLEGRO_EDITOR INTERFACES PDF Export does not respect layer ordering2 J, g4 ]' v1 _( e: m
2273934 ALLEGRO_EDITOR INTERFACES PDF Export does not respect disabled custom colors/ F7 B% U0 D1 W. @. Q @0 O: A
2240781 ALLEGRO_EDITOR NC Slot drill symbol figure issue: Rotation inconsistent with slot drill symbol figure+ }% Z1 U* s* B* T% s. M: V
2265146 ALLEGRO_EDITOR PAD_EDITOR Cannot save padstack after shape symbol with offset is uprevved from release 16.6 to release 17.2-2016
/ G' O9 Y* Y$ M2 Z2265711 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor creating horizontal oblong padstacks with incorrect figure name OBLONG_X
6 U8 b, k1 e. `% q+ e1 C" q# L2257934 ALLEGRO_EDITOR PLACEMENT Error (SPMHGE-626) on place component: Symbol not valid on any layer! Q5 r5 d7 w8 Z
2265390 ALLEGRO_EDITOR UI_GENERAL Mark device using the same substrate as its parent as a contact device
' ? H ]* s9 g1 h: g" |2259598 CONSTRAINT_MGR OTHER Importing netlist: Error for electrical constraint data (pstcmdb.dat) import
( H1 O/ V ^4 R# Q, q2242028 PULSE SERVER ERROR (SPDWSRV-00077): Unable to start the Allegro EDM server" `& h8 P! }2 e! |
2280836 SIP_LAYOUT OTHER Undefined padstack layer name
/ s9 g5 A3 P$ c6 L2251630 SIP_LAYOUT WIREBOND 'Change Profile' does not change the diameter of wire bond9 r5 F/ O- S3 @4 e) K5 ^+ r/ P& [
2259630 SIP_LAYOUT WLP Advanced WLP: Import PVS DRC results in error
| L2 A K# D9 l$ X9 Y$ }: UCadence Design Systems announced new capabilities for OrCAD Capture, Pspice Designer and PCB Designer 17.2-2016 that address challenges with flex and rigid-flex design as well as mixed-signal simulation complexities in IoT, wearables and wireless mobile devices. This latest release reduces PCB development time by addressing the need to design reliable circuits for smaller, more compact devices., A/ y) r* H q( J. D
This OrCAD portfolio includes new advanced technology enabled for integrated rigid-flex planning, design and real-time visualization, as well as built-in translators that enable direct design imports from select EDA vendors. PSpice Designer now supports system-level simulation using C/C++/SystEMC and VerilogA, via the new PSpice compact model interface. This enables hardware/software virtual prototyping so that electrical engineers can design and simulate intelligent IoT devices. OrCAD is the only fully scalable PCB design solution available in the market that seamlessly transitions from mainstream to enterprise PCB solution with the Allegro environment.# ]4 G3 u0 k* `
To enable a faster and more efficient flex and rigid-flex design creation critical to IoT, wearables and wireless devices, the OrCAD portfolio uses a new multi-stack-up database capability and extensive in-design inter-layer checks, which helps users avoid errors introduced through manual checking. The OrCAD portfolio also features enhancements targeted towards improving PCB editors' productivity and ease-of-use in padstack editing, constraint management, shape editing and in-design DRCs. To address efficiency needs, the portfolio includes an advanced design differencing engine that enables design review with global teams using state of art visuals. Finally, to give designers more control over their design component annotation process, advanced annotation and auto-referencing capabilities are now available.
" y$ }. `7 b$ }0 [Starting with OrCAD and Cadence Allegro PCB - Tutorial for Beginners
$ y5 x+ _1 o. ]6 A+ z
I: P$ J) Y4 j- WCadence enables global electronic design innovation and plays an essential role in the creation of today's integrated circuits and electronics. Customers use Cadence software, hardware, IP and services to design and verify advanced semiconductors, consumer electronics, networking and telecommunications equipment, and computer systems. The company is headquartered in San Jose, Calif., with sales offices, design centers and research facilities around the world to serve the global electronics industry." u% s5 B. s& j4 c) e( i
2 z8 s! d. X) w( u
, b5 z$ z, L, I+ i; S5 Y5 F
Product: Cadence SPB Allegro and OrCAD (Including EDM)
$ o# D; k5 h5 r! H0 xVersion: 17.20.000-2016 HF068
q8 J W" g# PSupported Architectures: x642 ?, d' X+ P) N
附件为墙外网盘,请自备梯子!!!!
+ Z( c. u6 W$ O
8 h: f! u# t/ E. T
( Y: [, P! u# F" z# K |
