I think I might have found the reason. When loading these gerber files, the resolution of the drill file is 2.3 instead of 3.4, which is the resolution of other layers. Once I change that everything goes back to normal.
( s( V X9 s; |/ z1 D5 j- i+ P2 r. ~! ^* c
But the question is, while doing Gerber Setting in Orcad, there is an option regarding output resolution, and I already selected 3.4. How could CAM350 not recognizing this? Where is this information saved? |
