1 O( U0 ]2 x3 Z& X[AD9][2层] PLC设计参考设计(MAX232+MC34063+IMP810L)原理图和pcb全套文件
$ s$ B9 V, u% s/ j- H3 H. R2 g: l
1 N' ]9 b; D% V; R* K/ o6 {文件描述:
# `3 c* g* I' U% O B: g: B" _& w5 h& P' U5 y( o) K. j
1. 作品用途: PLC设计参考设计
: \* B- `+ l" S1 l3 V2. 软件版本:AD97 a* _* E- X! I5 N4 [% }6 i/ |
3. 层数:2层+ B. [: N: k$ m/ _8 `: b
4. 用到的主要芯片:MAX232+MC34063+IMP810L
8 t( \3 @1 S# e) Q Z7 v }5. pcb尺寸: 130.2558*100.6602 MM. M8 O( {! n8 D1 A3 H
! W' p. q/ g ]
作品截图如下:: D2 \* Q! R V
- W0 C* n0 G/ T+ [; I, q顶层截图:
2 H3 `7 S" y* v; i
4 @, f: P {& G4 |6 l底层截图:
; i, e$ G; P p' t: J) z; A% c# S: B
) i( j0 v( k1 q" y u全层截图:
0 h; p; t1 A9 N4 e3 }+ ^
" |7 `' a6 C/ r0 v- d5 |* t
5 U1 f$ K, _& {' Q
) h3 S/ M, v: d0 Y9 o
BOM:
" ]0 T! A2 r$ U1 E1 o9 CComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.01uF | C1 | C/B | 1 | 18pf | C3, C4 | C/B | 2 | 0.1uF | C5, C6, C7, C8, C9, C10, C11 | C/B | 7 | 100pF | C12 | C/B | 1 | 4148 | D0, D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D28, D29, D40, D41, D42, D43, D44, D45, D46, D47, D50, D51, D52 | D4148/A0 | 31 | 1N4007 | D18 | D4148/A1 | 1 | 1N5819 | D19 | D4148/3 | 1 | 25V/39uF | ECE1 | EC/G10 | 1 | 6.3V/150uF | ECE2 | EC/G8 | 1 | 100mA | F1, F2 | FUSE/A | 2 | | H1, H2, H3, H4 | FIXH3.0 | 4 | | J1 | CON/20 | 1 | | J2 | CON/15 | 1 | UART0 | J3 | DB9RA/F | 1 | 2mH | L1 | IND/A2 | 1 | PWR | LED1 | LED-3A | 1 | RUN | LED2 | LED-3A | 1 | ERR | LED3 | LED-3A | 1 | X0 | LEDX0 | LED-3A | 1 | X1 | LEDX1 | LED-3A | 1 | X2 | LEDX2 | LED-3A | 1 | X3 | LEDX3 | LED-3A | 1 | X4 | LEDX4 | LED-3A | 1 | X5 | LEDX5 | LED-3A | 1 | X6 | LEDX6 | LED-3A | 1 | X7 | LEDX7 | LED-3A | 1 | X10 | LEDX10 | LED-3A | 1 | X11 | LEDX11 | LED-3A | 1 | X12 | LEDX12 | LED-3A | 1 | X13 | LEDX13 | LED-3A | 1 | X14 | LEDX14 | LED-3A | 1 | X15 | LEDX15 | LED-3A | 1 | X16 | LEDX16 | LED-3A | 1 | X17 | LEDX17 | LED-3A | 1 | Y0 | LEDY0 | LED-3A | 1 | Y1 | LEDY1 | LED-3A | 1 | Y2 | LEDY2 | LED-3A | 1 | Y3 | LEDY3 | LED-3A | 1 | Y4 | LEDY4 | LED-3A | 1 | Y5 | LEDY5 | LED-3A | 1 | Y6 | LEDY6 | LED-3A | 1 | Y7 | LEDY7 | LED-3A | 1 | Y10 | LEDY10 | LED-3A | 1 | Y11 | LEDY11 | LED-3A | 1 | Y12 | LEDY12 | LED-3A | 1 | LVT817 | OP0, OP1, OP2, OP3, OP4, OP5, OP6, OP7, OP10, OP11, OP12, OP13, OP14, OP15, OP16, OP17, OP20, OP21, OP22, OP23, OP24, OP25, OP26, OP27, OP30, OP31, OP32 | OP/A | 27 | | Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q10, Q11, Q12 | TO-92C | 11 | 5K1 | R1, R5, R7, R8, R10 | RA1/8 | 5 | 500R | R2 | RA1/8 | 1 | 10R | R3 | RA1/8 | 1 | 2R | R4 | RA1/8 | 1 | 15K4 | R6 | RA1/8 | 1 | 8K | RP1, RP2 | RP9/A | 2 | 1K | RP3, RP4 | RP9/A | 2 | 5K | RP5 | RP9/A | 1 | 1K | RP6, RP7, RP8 | RP4/A | 3 | 5K1 | RP9 | RP4/A | 1 | 0R | Rx | SHT | 1 | SW-PB | S1 | SW-1A | 1 | S24V | TVS1 | D4148/3 | 1 | D15V | TVS2, TVS3 | D4148/3 | 2 | S5V | TVS4 | D4148/3 | 1 | MC34063 | U1 | DIP8 | 1 | IMP810L | U4 | SOT-23R | 1 | IAP12C5A60S2 | U5 | DIP40 | 1 | MAX232 | U6 | SOP-16 | 1 | RSM485S | U7 | RSM485 | 1 | 32MHz | Y1 | XTAL-T | 1 | 附件:
. ~5 A) `' ^3 } T2 W& q+ C原理图和PCB文件如下:
1 [" H% n4 z/ _6 o$ x: k- s: O3 \$ _0 x1 r3 Y; t/ s
- p" T0 g' U; w/ d# l6 Y |
