查看: 4137|回复: 14
16.2出gerber时总是报错,是没有破解好吗?高手给看下。多谢!
发表于 2010-7-19 20:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
16.2出gerber时总是报错,是没有破解好吗?高手给看下。多谢,见附件
err.rar
5.16 KB, 下载次数: 33, 下载积分: 威望 -5
发表于 2010-7-19 21:46 | 只看该作者
SUMMARY:) c- @' W) o4 _) ]1 c0 U) u) }
        art01 created with warnings
8 V! I5 `4 R2 Y- y9 \2 M: B        pgp02 created with warnings
* ]/ }4 `, Q3 t% u* `. t        art03 created with warnings  X( v7 C6 l9 M* ^. f
        art04 created with warnings
$ J5 u- v* a5 n4 ^        pgp05 created with warnings
$ o6 a) l: W; [+ q8 ?0 q$ `    *** ERROR with art06
1 N+ s- w+ X; E) a+ b7 }* u        pgp07 created with warnings: k/ [1 S1 R4 j3 {$ \
        pgp08 created with warnings' a$ }0 e" L4 O$ k2 I. x6 u0 T
        pgp09 created with warnings
5 z9 F, m; `: ^+ V        pgp10 created with warnings
& S( S9 w9 s& u; b6 s0 @5 f    *** ERROR with art11
! W. P8 R8 ]" W4 k: \        pgp12 created with warnings8 ~/ E, w  Z( K% \
        art13 created with warnings* Z& w7 p6 b; b0 _
        art14 created with warnings8 h0 a% Q/ T/ K4 E! W2 y; j
        pgp15 created with warnings
2 o* F) [* @# a1 Z+ l$ O5 ^        art16 created with warnings
% A/ h4 F9 k5 A        adt created with warnings( R5 e  \0 Q0 e& j1 t/ c0 Y
        adb created with warnings
/ e% d. t+ o- z; s* q* \; C        all created with warnings) k, r* M: u; Q) t6 Y, Y1 u
        silktop created with warnings, a+ ^: z9 C: W9 g9 i
        silkbotm created with warnings* K0 q% u" n! C* P" ~+ H4 s
        soldtop created with warnings
8 O5 J. ~2 Y* R. b$ s2 Y, G        soldbotm created with warnings
3 E1 `, |1 ?: i5 g7 Q% G9 [' _        pasttop created with warnings
$ q  {! P" K: H        pastbotm created with warnings1 j  |9 H. I0 ]8 |
        drill created with warnings
7 F$ X5 E$ o( u; N6 Y! J, \  j( [; Y; N
ARTWORK Error processing film.
! m, d6 n# B8 ^4 H- i  H2 |" H" d: U2 q' c+ Y
有两个shape error
发表于 2010-7-20 11:51 | 只看该作者
主要看一下ERROR
( V2 s% [3 w2 t( x+ v7 _ ERROR: Can't fill shape at (5845.00, 1175.00).
6 E. ^( A% W! j) S9 \" \此處的銅應該太細,需要修正
发表于 2010-7-20 11:52 | 只看该作者
WARNING: Photoplot window exceeds film size (24000.00 x 16000.00)
0 r  t+ r4 ~- \* B          stated in parameter file.
' \$ I  b1 y3 l! |" e4 y# c這種沒有什么問題!
发表于 2010-7-20 11:53 | 只看该作者
還有就是0線寬的也沒有關系
3 I, n! {2 a$ o/ g. u5 p應該是OUTLINE的問題
 楼主| 发表于 2010-7-20 23:22 | 只看该作者
我用15.5做的板子,在15.5上可以出gerber的,16.2的出就报这个错误??惑解?是不是封装还要更新啊?
2 K- c5 E0 j1 n8 O WARNING: DRC OUT OF DATE on this layout.
+ Z; b1 Q4 c: Y! ~0 q2 _4 z: v  H; d ******************************************& o3 K: A1 M" b# S) U- L8 A
/ H  q! Q1 b$ A" B2 I& b8 \- T
---- Photoplot outline rectangle not found ... using drawing extents9 d* A" v, h: f% D/ L  F( T" |1 }
2 f3 s5 N% y! S5 c! F
9 W% h2 l+ w. _2 o; m0 Z
, W8 x/ z0 w. C8 `" F8 }7 b( M- UResults from parameter file ...
  N3 V2 _' a4 K$ P0 U0 e+ P7 j    DEVICE-TYPE           GERBER6X004 v7 u/ a# m: P: t  E+ M
    OUTPUT-UNITS          INCHES4 b/ ~( \' ?& Q; y7 L7 _
    FILM-SIZE             2400000 1600000
3 ?! D4 U! u; M5 n/ h8 }) f4 r' a    FORMAT                5.5; e; I  ~9 n# z/ S
    ABORT-ON-ERROR        NO6 N2 A/ S9 ]3 p3 n$ }. u
    SCALE                 1
2 v9 {, z( E; R" L    G-CODES               NO% m; r. [5 l% d/ g$ Y
    OPTIMIZE              YES
) Q! c; x- u, ^4 k; e# B# |! j  i9 h+ ~    STATIONS-PER-WHEEL    999
! g& m: K+ s" t! n5 O  g) ]( l* L    COORDINATES           ABSOLUTE
' U/ [# N: ~6 g: a4 Z    SUPPRESS-LEAD-ZEROES  YES/ D. E# B- y1 X
    SUPPRESS-TRAIL-ZEROES NO6 I- Q, v: q: L7 c
    SUPPRESS-EQUAL        YES7 P& G% Y% `6 m* D. ?
( a3 }" N4 O5 u! t( v7 V  `% Y
ARTWORK Error reading apertures.
发表于 2010-7-21 07:52 | 只看该作者
如下 Warning:Photoplot outline rectangle not found ... using drawing extents沒有問題,是沒有画photo outline,若出274的gerber要出aperture,若是274x不需要
 楼主| 发表于 2010-7-22 12:55 | 只看该作者
我用15.5做的板子,在15.5上可以出gerber的,16.2的出就报这个错误??  有outline的,不然15.5也会报错的?请高手看看。
  a, ~4 w; i7 A---- Photoplot outline rectangle not found ... using drawing extents
  h. h+ {9 E( I. {
0 {6 v/ g1 d/ g# x8 z  `4 {7 W
5 @6 t4 Q; [  k. h% V) ^4 p! n9 L: n; _' _1 [0 @
) O0 l  W, \" e* A5 u5 A    DEVICE-TYPE           GERBER6X00
$ i- y$ Y) \& q- b2 h' q$ @    OUTPUT-UNITS          INCHES
9 A/ R$ y* ]! D5 C$ X    FILM-SIZE             2400000 1600000/ Z* Z; l2 A" u% P% `, d
    FORMAT                5.5
- \1 h, r# r; y1 X! ?    ABORT-ON-ERROR        NO
. U, V' f4 `! l+ F* s8 ^7 s3 A    SCALE                 1+ g! X' _& T6 G$ {7 Y
    G-CODES               NO$ b3 ?! N) z! m- z9 H
    OPTIMIZE              YES( }6 m2 d0 ?# t2 O. w
    STATIONS-PER-WHEEL    9990 k; ^8 a. y) {! j2 [
9 G! j0 w- I8 I4 n( G5 m/ i    SUPPRESS-LEAD-ZEROES  YES
- |2 Z  W/ ~) S% |! Z4 M8 F, ~. \    SUPPRESS-TRAIL-ZEROES NO
# ?1 e# R4 [9 d+ P    SUPPRESS-EQUAL        YES
# O6 \! ~6 V4 z+ |2 d
( L  u- I2 Y; z, _- z: Q3 rARTWORK Error reading apertures.
发表于 2010-7-22 13:32 | 只看该作者
顶    .... .. . .  要好好学习   我 要更努力
发表于 2010-7-22 13:33 | 只看该作者
是不是一天一个积分的捏?
 楼主| 发表于 2010-7-23 20:54 | 只看该作者
??寻找答案,等待。
发表于 2011-5-31 10:43 | 只看该作者
寻找真正的答案:出274x都试过了还是出现如下报错:" e5 F, m" e" H, p5 Y2 ?" n6 K
Can't open parameter file ... using default values:, g( B/ l2 p& b8 w" I: k  n6 z1 e, O
     DEVICE-TYPE        GERBER6X00' J+ s/ M5 N$ M' M1 o3 |8 C( _2 s
     G-CODES            NO, \8 a7 B& x; ]
     STATIONS-PER-WHEEL 24
# N! T# x$ k! E: r     FILM-SIZE          24000 16000
  e$ D4 C" s6 }  y. V- S     COORDINATES        ABSOLUTE4 K5 B- Q3 w' k% h
     OUTPUT-UNITS       INCHES
* i; k7 ^3 g" k1 k6 J     FORMAT             5.3
8 `( r( b5 Q3 ?' ]) z     ABORT-ON-ERROR     abort film & continue
1 A7 A5 c$ J: q$ [% ]/ t# l     SUPPRESS-LEAD-ZEROES     YES
8 G: m; s; r3 V( l: b: @     SUPPRESS-TRAIL-ZEROES    NO
$ l; v) e- J+ g     OPTIMIZE           YES$ j! L+ u* S1 i  U; I* ^( U$ j
     SUPPRESS-EQUAL     YES
/ j, N; M6 p; m     SCALE              1.0
$ x3 t( w; [$ O+ O0 q% m: a6 l& {/ J* O$ \4 a. H5 l
3 U7 g4 H8 p- [6 P
% s! v4 e# l! {" D0 c WARNING: database resolution exceeds the resolution of the
5 n3 R- O) R. @, I2 J      output coordinates (see FORMAT in parameter file).7 l4 h6 Q1 C' V* P
      Some roundoff of coordinates may occur unless the number) z# j  l0 y4 j) q% w  N) L
      of decimal places in the output file is increased.' ~" ~* O$ z+ @# R" J. V9 ]
; w! r! }- C& h$ ~
( L4 ?5 [+ X& j) b+ v- X/ X ARTWORK Error reading apertures./ t0 w% c5 Y6 G# S9 M
不知何解?高手赐教。
13#
发表于 2011-5-31 13:14 | 只看该作者
把文件 发给我,帮你搞定!
14#
发表于 2013-5-8 17:46 | 只看该作者
说一下方法的,楼上的
15#
发表于 2013-5-8 22:47 | 只看该作者
把shape smooth一下,版本切换,shape很容易出问题
GMT+8, 2025-9-29 02:39 , Processed in 0.140625 second(s), 26 queries , Gzip On.
