查看: 437|回复: 1
亲吻大神,如何用单片机实现呼吸灯?
发表于 2020-6-8 13:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
单片机和tlc5615怎样实现呼吸灯操作? 电路图的LED应该如何连?这是我连的  没敢加电阻 一加就有问题。。。我想通过输出电压控制灯的亮暗
4 j) r- B  {$ ^4 A4 [& q哪位大佬能帮忙看看问题在哪?
6 J% d4 d$ K' f% T- `#include<reg51.h>
' h6 S$ n2 W) p* z1 Q' a#define uint unsigned int
0 _4 [  w) g- `1 |; f; ^: X2 ]#define uchar unsigned char
# {* d# |1 o$ z' D& bsbit TLC5615_CLK=P2^0;
+ m1 t0 Z; r; V/ E5 ~8 c+ ?sbit TLC5615_CS=P2^1;2 l% a3 U8 M, x
sbit TLC5615_DI=P2^2;& |3 X& ?# ]6 x0 b! B
uint code a[]={450,455,460,465,470,475,480,485,490,495,500,505,510,515,520,525,530,535,540,545,550,555,560,565,570,575,8 L: p6 b* r) c/ R/ I) y, ~
580,585,590,595,600,605,610,615,620,625,630,635,640,645,650,655,660,665,670,675,680,685,690,695,700,7 ?/ }, K0 s( S2 i+ M
695,690,685,680,675,670,665,660,655,650,645,640,635,630,625,620,615,610,605,600,595,590,585,580,: v! `! R! b& }' b" S+ P# n
               575,570,565,560,555,550,545,540,535,530,525,520,515,510,505,500,495,490,485,480,475,470,465,460,455,450};- |( R( P( O6 O  y
int main()  @- i# f4 }8 w8 K2 {7 E7 N
{  x+ B  G$ a# W: Z. O. ]$ w& W
        void TLC5615_DAC(uint dat);
. A$ z2 {; J2 g5 q  R5 M5 O  void delayms(uint x);0 R3 E- ?, b' ]- {$ y2 X
        uint m=0;4 z9 t6 g. J  g0 J* W3 T
        while(1)6 {2 I  |2 D, t
) ?) g$ m9 u# ]! D                TLC5615_DAC(a[m]);
8 ~) N: S+ x( M, G                m++;) C1 J! a8 o, x4 L5 E. i$ S! Z
                if(m>100)
# l) Z9 |) @* h! b9 e                        m=0;) F  D, z9 i5 V, Z  I+ I, ^$ I
        }  [; Z/ F' J. Q; P2 F
        return 0;& e" ?+ z- w% R1 K) @
}$ C* ^& R$ {$ l- V
2 |# [& t9 F0 f9 mvoid TLC5615_DAC(uint dat)
, L1 o2 x) c+ A9 b/ Y) a{        % @# |; \1 ^4 T; l  ]1 V1 Y
        uchar i;
7 U3 i2 E- w0 f5 R- u3 N2 [  dat<<=6;                           1 Y" y6 D5 c) `
  TLC5615_CLK=0;
6 G4 V7 `, T5 J4 ^, u5 k, P6 m- ~; }        TLC5615_CS=0;" f0 z" w  E  Z: w0 K
  for (i=0;i<12;i++)      3 M% Z) T: _. T3 L: u+ O
* `7 c7 u& _( i# Z' e3 E( R1 W# x' n             TLC5615_DI=(bit)(dat&0x8000);   ; l7 O( S- I4 H! L! _
             TLC5615_CLK=0;   6 {- \6 _3 h1 B5 d) G
             dat<<=1;
+ J0 v. F. h& b" \             TLC5615_CLK=1;
' o" }( p6 \5 s, U( [  }
9 ^: E9 s( D0 v; R: _8 e  TLC5615_CS=1;
% z' S1 G' \$ a        TLC5615_CLK=0;
8 ?0 g, M8 M* d8 v$ H  L/ L  delayms(200);
( ~: c9 r! f4 W3 j; y9 U}, j+ ~& o/ `" Z* A* A' w# y
; B0 R& F5 G# W
) b% l# d* _* j{3 Y* N( k" k3 S# ]( a+ h7 d
        uchar i;4 D" q2 r, }$ j! g: \
        while(x--);
/ r$ a& B- T; a1 m( e8 ^0 p                for(i=0;i<123;i++);& P) C& V0 e9 g" M
+ s" S; u) e0 F6 B
+ L- g$ `' h! d) H0 t: P; G/ D! m6 G- P. c
4 i' n  g/ e& i+ a- V2 c, E$ s) c% w   p; B8 R; ?* q; X
发表于 2020-6-8 14:39 | 只看该作者
DA输出后加一级三极管驱动,控制电压没必要如此密集,从熄灭到最亮,有4、5个电压就行。
GMT+8, 2025-7-22 08:50 , Processed in 0.109375 second(s), 26 queries , Gzip On.
