Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
8P4R_0603 | 8P4R_0603 | | DISCRETE | 4 | RN16; RN28; RN31; RN32 |
ATXPWR_24P | ATXPWR_24P | | IO | 1 | ATXPWR |
AUDIO_CODEC | AUDIO_CODEC | | IC | 1 | AUDIO |
BAT_2P | BAT_2P | | IC | 1 | BAT |
BGA652_FAN | BGA652_FAN | ICH7/[10HB1-032801-M1R] | IC | 1 | U3 |
BGA1226 | BGA1226 | | IC | 1 | U2 |
C0402 | C0402 | | IC | 138 | AC39; C26; C27; C28; C32; C37; C39; C43; C58; C61; C62; C65; C73; C74; C75; C79; C80; C83; C84; C85; C89; C95; C103; C104; C105; C108; C109; C113; C117; C118; C119; C121; C123; C124; C125; C126; C127; C128; C129; C134; C135; C136; C137; C138; C147; C148; C149; C154; C155; C156; C157; C158; C167; C168; C169; C217; C218; C219; C220; C221; C222; C224; C246; C247; C251; C252; C253; C254; C255; C256; C257; C259; C260; C261; C268; C270; C273; C274; C275; C276; C280; C292; C294; C295; C307; C308; C309; C311; C313; C314; C315; C316; C317; C320; C322; C323; C324; C325; C326; C328; C329; C330; C331; C333; C335; C336; C337; C338; C340; C349; C350; C368; C371; C373; C374; C376; C377; C385; C387; C388; C389; C390; C391; C405; C414; C417; C418; C458; C459; CB5; CB7; CB9; LC4; SC1; SC2; SC3; SC4; SC11 |
C0603 | C0603 | 0.01UF | IC | 213 | BC1; C17; C18; C19; C20; C29; C31; C33; C34; C35; C36; C38; C41; C42; C44; C45; C46; C47; C50; C51; C52; C53; C54; C55; C56; C57; C59; C60; C63; C64; C66; C67; C68; C70; C71; C72; C78; C82; C87; C94; C96; C98; C99; C100; C101; C102; C106; C107; C120; C122; C141; C142; C143; C144; C161; C162; C163; C164; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C206; C207; C208; C209; C210; C211; C212; C213; C214; C216; C223; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C248; C249; C250; C262; C264; C265; C266; C267; C272; C277; C281; C284; C285; C288; C289; C290; C291; C293; C302; C303; C310; C312; C327; C332; C334; C339; C341; C342; C343; C344; C345; C348; C361; C362; C367; C369; C370; C375; C378; C379; C380; C383; C384; C406; C410; C411; C412; C413; C415; C416; C419; C420; C424; C446; C456; C460; C735; CB1; CB2; CB3; CB4; CB6; CB8; CB60; CB61; CB62; CB63; CB67; CB70; CB71; CB72; CB73; CB74; LC5; LC6; LC15; LC16; LC18; LC19; PC34; PC35; SC8; SC10; SC12; SC13; SC14; SC15; SC17; SC18; SC20; SC21 |
C0805 | C0805 | 4.7UF | IC | 22 | C40; C48; C49; C81; C86; C88; C90; C91; C92; C93; C97; C110; C111; C112; C114; C115; C215; C269; C372; C382; C393; CB287 |
C1206 | C1206 | 10UF | IC | 14 | C1; C2; C3; C4; C5; C6; C7; C9; C10; C11; C30; C76; C77; SC22 |
CAP6D3X7 | CAP6D3X7 | | IC | 7 | CE8; CE23; CE26; CE34; CE38; CE55; CE57 |
CAP8X9 | CAP8X9 | | DISCRETE | 6 | PCE1; PCE2; PCE3; PCE4; PCE5; PCE6 |
CAP8X12 | CAP8X12 | 1000UF | IC | 24 | CE1; CE3; CE7; CE10; CE11; CE12; CE13; CE14; CE15; CE16; CE17; CE18; CE19; CE20; CE21; CE22; CE24; CE25; CE28; CE30; CE31; CE32; CE33; CE52 |
CAP10X20 | CAP10X20 | | DISCRETE | 3 | PCE14; PCE15; PCE16 |
CAPN_300 | CAPN_300 | 1000PF | IC | 1 | LHC1 |
COIL_334 | COIL_334 | | IC | 5 | L8; L10; L23; L24; L25 |
COM | COM | | IC | 1 | COM |
DB15M_VGA | DB15M_VGA | | DISCRETE | 1 | VGA |
DB25M_LPT | DB25M_LPT | | IC | 1 | LPT |
DDR2 | DDR2 | | IC | 2 | DIMM1; DIMM2 |
DIP8_300 | DIP8_300 | | IC | 1 | U14 |
DLL34 | DLL34 | | IC | 1 | D10 |
DRILL_150_PAD_300 | DRILL_150_PAD_300 | | IC | 5 | MH7; MH9; MH10; MH11; MH12 |
DTRAN12_100_300 | DTRAN12_100_300 | | IC | 1 | LT1 |
FAN3P | FAN3P | | IC | 1 | SYS_FAN |
FAN4P | FAN4P | LGA775_FAN | IC | 1 | CPU_FAN |
FB0603 | FB0603 | | DISCRETE | 9 | FB20; FB21; FB22; FB28; FB29; FB30; FB31; FB32; FB33 |
FB0805 | FB0805 | 1UH | IC | 17 | FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB12; FB13; FB40; FB58; L4; L6; L11 |
FB1206 | FB1206 | 10UH | IC | 3 | L1; L2; L3 |
FLOPPY_34P | FLOPPY_34P | | DISCRETE | 1 | FDD |
FMARKC | FMARKC | | IC | 6 | FD1; FD2; FD3; FD4; FD5; FD6 |
H2X5_USB | H2X5_USB | | IO | 1 | JUSB |
H2X8_PANEL | H2X8_PANEL | | IC | 1 | F_PANEL |
IDE40P_2D54 | IDE40P_2D54 | | IC | 1 | IDE |
IND7D5_10 | IND7D5_10 | | IC | 3 | L7; L9; PL4 |
J2 | J2 | 10K,5% | IC | 1 | SRT1 |
J3 | J3 | | IC | 2 | CLR_CMOS; KB_PWR |
L0805 | L0805 | 10UH | IC | 1 | L5 |
L1210 | L1210 | | IC | 1 | R500 |
LGA775DIP | LGA775DIP | | IC | 1 | U1 |
PCI164A | PCI164A | PCI-E/16X-164P/BK/RIGHT PUSH | IC | 1 | PCIE_16X |
PCISLOT_120P | PCISLOT_120P | | DISCRETE | 2 | PCI1; PCI2 |
PIN2X5_2D54_NC8 | PIN2X5_2D54_NC8 | | IC | 1 | F_AUDIO |
PS2_KB | PS2_KB | | IC | 1 | PS/2 |
PWR_4P | PWR_4P | | IO | 1 | ATX12V |
QFNS48_0D5_1G | QFNS48_0D5_1G | ISL6312CR | IC | 1 | U10 |
QFNS64_0D5_1G | QFNS64_0D5_1G | RTL8111B/8111C/8101E | IC | 1 | U13 |
QFPR128_0D5_3D3 | QFPR128_0D5_3D3 | | IC | 1 | U11 |
QFPS48_0D5_1D6 | QFPS48_0D5_1D6 | ALC880 | IC | 1 | AU2 |
R0603 | R0603 | 1.69K,1% | IC | 497 | AR27; LR5; LR6; LR9; LR10; LR11; LR12; LR13; LR14; LR15; LR16; LR17; LR18; LR22; LR23; PR43; PR44; PR45; PR46; PR47; PR48; R1; R2; R3; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R17; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R46; R47; R48; R49; R50; R52; R53; R54; R55; R56; R57; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R193; R195; R196; R198; R199; R200; R201; R202; R203; R204; R205; R209; R210; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R272; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R285; R286; R289; R290; R292; R293; R294; R295; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R323; R324; R326; R327; R328; R329; R332; R333; R334; R335; R336; R337; R340; R341; R342; R343; R346; R347; R349; R350; R351; R353; R355; R356; R357; R358; R359; R360; R362; R363; R365; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R399; R411; R412; R415; R418; R419; R420; R421; R422; R423; R424; R425; R426; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R464; R465; R466; R467; R468; R469; R470; R472; R473; R477; R479; R480; R481; R482; R483; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R499; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R515; R516; R518; R519; R521; R522; R523; R524; R525; R526; R527; R528; R529; R530; R531; R556; R563; R566; R567; R568; R569; R570; R571; R572; R576; R577; R595; R596; R599; R1206; SR13; SR14; SR17; SR18; SR27; SR36; SR38; SR45; SR56; SR57 |
R0805 | R0805 | 0,5% | IC | 23 | R192; R194; R197; R206; R207; R208; R211; R287; R291; R296; R338; R339; R344; R345; R348; R352; R354; R361; R364; R366; R501; R517; R520 |
R1206 | R1206 | 0,5% | IC | 1 | R86 |
RA0603_8 | RA0603_8 | 2.7K,5% | IC | 23 | RN2; RN7; RN8; RN9; RN10; RN12; RN13; RN15; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN33; RN34; RN35; RN36; SRN2 |
SATA_D_V | SATA_D_V | | IC | 4 | SATA1; SATA2; SATA3; SATA4 |
SDMMELF | SDMMELF | 1N4148 | IC | 5 | D2; D3; D4; D5; D7 |
SO8_50_150 | SO8_50_150 | IS93C46A-3GRLI | IC | 4 | U5; U6; U9; U12 |
SO14_50_150 | SO14_50_150 | LM324 | IC | 2 | SU2; U8 |
SOP20_0D65_4D4 | SOP20_0D65_4D4 | | IC | 1 | SU3 |
SOT23_123 | SOT23_123 | | DISCRETE | 21 | D1; D6; D8; PQ10; PQ11; Q7; Q8; Q10; Q11; Q13; Q20; Q21; Q23; Q24; Q28; Q29; Q30; Q32; Q36; Q38; Q39 |
SOT223 | SOT223 | L1117 | IC | 1 | U7 |
SSOP56 | SSOP56 | ck410_cy28410/ics954101/rev:b | IC | 1 | U4 |
TO252 | TO252 | AOD452 | IC | 16 | PQ1; PQ2; PQ3; PQ4; PQ5; PQ6; PQ7; PQ8; PQ9; Q14; Q15; Q16; Q18; Q19; Q22; Q25 |
TRAN24_50_490 | TRAN24_50_490 | H24102MK | IC | 1 | LU3 |
USB8P_R | USB8P_R | | IC | 1 | USB |
USB_RJ45LED | USB_RJ45LED | | IC | 1 | LAN_USB |
VIA | VIA | VIA | IC | 19 | VIA2; VIA3; VIA4; VIA5; VIA6; VIA7; VIA8; VIA9; VIA10; VIA11; VIA12; VIA13; VIA14; VIA15; VIA16; VIA17; VIA18; VIA19; VIA20 |
XD2 | XD2 | 14.318MHz | IC | 2 | X3; Y1 |
XD4_R | XD4_R | | IC | 1 | X1 |
附件:
