Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402C | 0402C | 100nF | DISCRETE | 46 | C1; C2; C5; C7; C10; C12; C13; C14; C16; C23; C30; C32; C33; C36; C37; C38; C39; C40; C41; C42; C44; C45; C46; C47; C52; C53; C55; C56; C59; C60; C61; C62; C63; C69; C70; C71; C79; C80; C81; C82; C83; C84; C85; C86; C87; C93 |
0402C | 0402C | 10pF | DISCRETE | 2 | C4; C6 |
0402C | 0402C | 4.7pF_NPO_-+0.25pF_0402 | DISCRETE | 2 | C48; C51 |
0402R | 0402R | 1K | IC | 5 | R1; R2; R58; R92; R97 |
0402R | 0402R | 100K_1%_0402 | IC | 12 | R3; R9; R15; R18; R21; R24; R67; R68; R69; R70; R71; R75 |
0402R | 0402R | 2K7 | IC | 7 | R4; R42; R44; R52; R56; R59; R60 |
0402R | 0402R | 0 | IC | 8 | R5; R35; R39; R49; R50; R53; R78; R101 |
0402R | 0402R | 4K7_1%_0402 | IC | 3 | R6; R25; R26 |
0402R | 0402R | 100 | IC | 3 | R7; R23; R51 |
0402R | 0402R | 36K | IC | 1 | R8 |
0402R | 0402R | 1K5 | IC | 1 | R10 |
0402R | 0402R | 10K | IC | 26 | R11; R17; R19; R20; R29; R30; R36; R37; R41; R43; R45; R46; R55; R57; R61; R76; R85; R86; R89; R90; R91; R93; R94; R95; R96; R102 |
0402R | 0402R | 680_1%_0402 | IC | 1 | R12 |
0402R | 0402R | 330 | IC | 2 | R13; R14 |
0402R | 0402R | 47K_1%_0402 | IC | 5 | R16; R73; R74; R77; R79 |
0402R | 0402R | 2K2 | IC | 1 | R22 |
0402R | 0402R | 20 | IC | 2 | R31; R33 |
0402R | 0402R | 3K | IC | 1 | R54 |
0402R | 0402R | 3K3 | IC | 1 | R80 |
0603C | 0603C | 1uF | DISCRETE | 12 | C3; C9; C11; C15; C17; C18; C24; C27; C35; C43; C50; C92 |
0603C | 0603C | 10nF_X7R_10%_0603 | DISCRETE | 3 | C8; C72; C76 |
0603C | 0603C | 4.7uF | DISCRETE | 8 | C19; C20; C21; C22; C29; C31; C77; C78 |
0603C | 0603C | 2.2uF_X5R_10%_0603 | DISCRETE | 4 | C25; C26; C28; C54 |
0603C | 0603C | 10uF | DISCRETE | 1 | C57 |
0603D | 0603D | LED blue | DISCRETE | 1 | LD1 |
0603D | 0603D | LED red | DISCRETE | 5 | LD2; LD3; LD5; LD7; LD10 |
0603D | 0603D | LED green | DISCRETE | 3 | LD6; LD8; LD9 |
0603L | 0603L | FCM1608KF-601T03 | DISCRETE | 7 | L1; L2; L3; L4; L5; L7; L8 |
0603R | 0603R | 1K_1%_0603 | DISCRETE | 1 | R47 |
0603R | 0603R | 510_1%_0603 | DISCRETE | 1 | R48 |
0603R | 0603R | 10K_1%_0603 | DISCRETE | 2 | R63; R100 |
0603R | 0603R | 10_1%_0603 | DISCRETE | 1 | R66 |
0603R | 0603R | 620_1%_0603 | DISCRETE | 2 | R81; R84 |
0603R | 0603R | 330_1%_0603 | DISCRETE | 2 | R82; R83 |
0603R-GS | 0603R-GS | 0_5%_0603 | IC | 6 | R27; R62; R64; R65; R72; R99 |
0805C | 0805C | 10uF | DISCRETE | 2 | C68; C74 |
0805R | 0805R | 0_5%_0805 | IC | 1 | R98 |
1206C | 1206C | 2.2uF | IC | 2 | C49; C58 |
1206C | 1206C | 4.7uF_X7R_10%_1206 | IC | 2 | C73; C75 |
1210L | 1210L | 4.7uH 1A 30% | IC | 1 | L6 |
BGA72_0R5_4R5X4 | BGA72_0R5_4R5X4 | WM8994ECS_R | IC | 1 | U7 |
BGA176_0R65_10X10 | BGA176_0R65_10X10 | STM32F723IEK | IC | 1 | U8 |
D0201_21 | D0201_21 | ESDALC6V1-1U2 | IC | 1 | U23 |
DF37NB-10DS-0R4V | DF37NB-10DS-0R4V | DF37NB-10DS-0.4V (5x) | IC | 1 | CN16 |
DFN6_0R95_3X3 | DFN6_0R95_3X3 | LD39050PU33R | IC | 1 | U4 |
DFN8_1R27_6X8_TP4R6X5R3 | DFN8_1R27_6X8_TP4R6X5R3 | N25Q512A13GF840E (MICRON) | IC | 1 | U6 |
DO-216AA | DO-216AA | STPS1L40M | IC | 1 | Z1 |
DO_2SM_1R6X1_21 | DO_2SM_1R6X1_21 | ESDA7P60-1U1M | IC | 1 | U24 |
FBGA48_0R75_6X8 | FBGA48_0R75_6X8 | IS66WV51216EBLL-55BLI | IC | 1 | U10 |
FH26-29S-0R3SHW | FH26-29S-0R3SHW | FH26-29S-0.3SHW | IC | 1 | CN17 |
HDR_1X2_2R54_RA_11R35 | HDR_1X2_2R54_RA_11R35 | WF25402-06421 | IO | 1 | CN3 |
HDR_1X4_2R54 | HDR_1X4_2R54 | Header 4 | IO | 1 | CN2 |
HDR_1X6_2R54_W | HDR_1X6_2R54_W | BL 1-6 G | IO | 1 | CN15 |
HDR_1X8_2R54_W | HDR_1X8_2R54_W | BL 1-8 G | IO | 2 | CN12; CN13 |
HDR_1X10_2R54_W | HDR_1X10_2R54_W | BL 1-10 G | IO | 1 | CN11 |
HDR_2X4_2R54 | HDR_2X4_2R54 | Header F Straight 4x2H | IO | 1 | CN14 |
HOLE_C6D3R5 | HOLE_C6D3R5 | POSITION HOLE C6D3R5 | IO | 3 | H1; H2; H4 |
JP2_SMD | JP2_SMD | Solder Bridge ON | IC | 19 | SB1; SB4; SB7; SB8; SB9; SB10; SB11; SB12; SB13; SB14; SB15; SB25; SB27; SB28; SB29; SB33; SB34; SB35; SB37 |
JP2_SMD | JP2_SMD | Solder Bridge OFF | IC | 7 | SB2; SB3; SB5; SB6; SB16; SB36; SB38 |
LED2_3528 | LED2_3528 | LD_BICOLOR_CMS | IC | 1 | LD4 |
LQFP48_0R5_9X9 | LQFP48_0R5_9X9 | STM32F103CBT6 | IC | 1 | U2 |
MICRO_USB_B_105017 | MICRO_USB_B_105017 | 1050170001 | IO | 1 | CN1 |
MOLEX_47590001 | MOLEX_47590001 | 475900001 | IC | 2 | CN18; CN19 |
MP34DT01TR | MP34DT01TR | MP34DT01 | IC | 4 | U16; U17; U18; U19 |
OSC_4SM_2R5X2 | OSC_4SM_2R5X2 | NZ2520SB-25.00M | IC | 1 | X3 |
PJ3028B | PJ3028B | PJ3028B-3_BE_3PINS | IC | 1 | CN4 |
PJ3028B | PJ3028B | PJ3028B-3_GR_3PINS | IC | 1 | CN5 |
QFN8_0R5_2R5X1R2 | QFN8_0R5_2R5X1R2 | ECMF02-4CMX8 | IC | 1 | U15 |
QFN16_0R4_2R5X1R7 | QFN16_0R4_2R5X1R7 | STG3692QTR | IC | 1 | U20 |
R0603 | R0603 | 22R | DISCRETE | 4 | R28; R32; R38; R40 |
SIP2 | SIP2 | JP2 | IO | 4 | CN6; CN7; CN10; JP1 |
SOD-323 | SOD-323 | BAT60JFILM | IC | 5 | D1; D2; D3; D4; D5 |
SOIC8_1R27_4R9X6 | SOIC8_1R27_4R9X6 | ST890CDR | IC | 1 | U1 |
SON8_0R65_3X3 | SON8_0R65_3X3 | STLD40DPUR | IC | 1 | U12 |
SON8_1R27_6X8 | SON8_1R27_6X8 | MX25L51245G (MACRONIX) | IC | 1 | U5 |
SOT23-5 | SOT23-5 | STMPS2151STR | IC | 1 | U13 |
SOT23-5 | SOT23-5 | STMPS2141STR | IC | 1 | U14 |
SOT23-6 | SOT23-6 | USBLC6-2SC6 | IC | 2 | U21; U22 |
SOT-23 | SOT-23 | 9013-SOT23 | IC | 3 | T1; T2; T3 |
SOT-23-5L | SOT-23-5L | LD3985M33R | IC | 1 | U3 |
SOT-223 | SOT-223 | LD1117S18TR | IC | 1 | U9 |
SOT-223 | SOT-223 | LD1117S50TR | IC | 1 | U11 |
SQT-110-01-F-D-RA | SQT-110-01-F-D-RA | SQT-110-01-F-D-RA | IO | 1 | P1 |
SSW-106-02-F-D-RA | SSW-106-02-F-D-RA | SSW-106-02-F-D-RA | IO | 1 | P2 |
TACT_4SM_3R5X5R5 | TACT_4SM_3R5X5R5 | SW-PUSH-CMS_EVQP2_BLUE | IC | 1 | B1 |
TACT_4SM_3R5X5R5 | TACT_4SM_3R5X5R5 | SW-PUSH-CMS_EVQP2_BLACK | IC | 1 | B2 |
TAN-A | TAN-A | 4.7uF | DISCRETE | 2 | C34; C66 |
TAN-A | TAN-A | 1uF | DISCRETE | 2 | C64; C65 |
TAN-A | TAN-A | 10uF_POL_10%_TANA | DISCRETE | 1 | C67 |
TC2050-IDC-NL | TC2050-IDC-NL | TC2050-IDC-NL | IO | 1 | CN9 |
TP_C40 | TP_C40 | TP | IC | 13 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP11; TP12; TP13; TP14; TP15 |
TSM-105-01-S-DV | TSM-105-01-S-DV | Header M Straight 5x2H TSM | IC | 1 | CN8 |
XTAL_2SM_3R2X1R5 | XTAL_2SM_3R2X1R5 | NX3215SA-32.768K | DISCRETE | 1 | X2 |
XTAL_2SM_3R2X2R5_H1 | XTAL_2SM_3R2X2R5_H1 | NX3225GD-8.00M | IC | 1 | X1 |
附件:
