JobTestandVisionProcessingTestOperationManual8 j+ a1 `7 i: l- f# X7 e# M# k
1. Introduction
7 [$ N8 o5 F& m$ y1.1. + E* o" Z% U5 W, x3 v( `! e4 S
Overview of the job test function
$ ?6 J A6 v0 G: V9 L8 V* N/ UThe job test function is accessed in MEdit. This function is used to check pick up position and the results of vision processing.
1 d) b; o! C% m( b/ D+ c1 i( eThe job test function can be used for the following operations:: j( t6 [5 C$ D9 I6 g
1. Creating part data in VPDplus0 `+ f7 Z( Y; N1 p9 P, a4 b, ]+ g2 m( A
2. Checking the X position, Y position, and height for pickup using the pickup test function
, N- q1 ~% C. w, n: n) O" O3. PeRForming pickup and vision processing, and determining the optimum height for acquiring images during vision processing
+ o- D O0 n' P/ v( x6 M0 \( A2 n4. Checking shape data using the results of vision processing* c- u5 F9 `2 Q7 h; u# P& ^8 j3 M' g
5. To test parts placement during actual production
# Z+ g; D( ?5 w5 q" @( P4 n( P: }% m! J" x/ q
4 F7 Y* ? Z9 V1 ]$ M" F% A
+ k) W W% b6 v$ j |
