Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA96-32-1609G | BGA96-32-1609G | | IC | 4 | U18; U19; U20; U21 |
BGA817-26-3737 | BGA817-26-3737 | | IC | 1 | U44 |
CAP2-300-240 | CAP2-300-240 | | IC | 2 | C1; C2 |
DB9-2RM | DB9-2RM | DBR30_09K1206 | IO | 1 | J33 |
DB15-2RF | DB15-2RF | | IC | 4 | J19; J20; J21; J22 |
DB15-3RF-A | DB15-3RF-A | 17HE_R13150_73HC2 | IC | 1 | J28 |
DIM0425-80-A | DIM0425-80-A | | IC | 2 | J36; J37 |
GND12 | GND12 | TESTPOINT_HOLE_A | IC | 3 | TS1; TS2; TS3 |
HOLE125-8STAR | HOLE125-8STAR | HOLE105-8STAR | IC | 8 | M1; M2; M3; M4; M5; M6; M7; M8 |
HSOD323A | HSOD323A | | IC | 2 | D42; D43 |
HSOT416A | HSOT416A | | IC | 4 | Q4; Q5; Q6; Q7 |
IDC20-DTM1-A | IDC20-DTM1-A | | IC | 1 | J29 |
MJ8-SRLFY | MJ8-SRLFY | | IC | 2 | J16; J17 |
MLF14A-050-0404L | MLF14A-050-0404L | | IC | 1 | U27 |
MLF14B-050-0403L | MLF14B-050-0403L | | IC | 1 | U43 |
MLF32-050-0505LE | MLF32-050-0505LE | | IC | 1 | U28 |
MRT-RVG4M08 | MRT-RVG4M08 | | IC | 1 | RP1 |
PCI36-12V | PCI36-12V | | IC | 1 | J18 |
PSW3-RA | PSW3-RA | BR_11C_11P6 | IC | 1 | S2 |
PWC0103-M-C | PWC0103-M-C | | IC | 1 | J24 |
QFN64-050-0909LH | QFN64-050-0909LH | | IC | 2 | U29; U30 |
QFN-72 | QFN-72 | | IC | 1 | U31 |
QFP128C-40-1414L | QFP128C-40-1414L | | IC | 4 | U39; U40; U41; U42 |
SATA7-M | SATA7-M | | IC | 2 | J26; J27 |
SATA_POWER4-200 | SATA_POWER4-200 | | IC | 2 | J30; J31 |
SBAT2-3209 | SBAT2-3209 | | IC | 1 | U12 |
SC0402 | SC0402 | 33pF | DISCRETE | 191 | C21; C35; C36; C71; C72; C73; C74; C75; C76; C77; C79; C80; C81; C82; C84; C85; C86; C87; C88; C90; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C201; C202; C203; C204; C206; C207; C208; C209; C210; C212; C213; C214; C215; C219; C220; C221; C222; C223; C224; C225; C226; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C349; C350; C351; C352; C353; C354; C494; C495; C549; C550; C551; C552; C644; C646; C647; C648; C649; C650; C651; C652; C653; C654; C679; C680; C700; C701; C702; C703 |
SC0603 | SC0603 | 20pF | DISCRETE | 342 | C3; C4; C5; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C31; C32; C33; C34; C37; C38; C78; C83; C89; C91; C92; C93; C94; C199; C200; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C355; C356; C358; C359; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C400; C401; C402; C403; C404; C405; C406; C407; C408; C409; C410; C411; C412; C413; C414; C415; C416; C417; C418; C419; C420; C421; C422; C423; C424; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C445; C446; C447; C448; C449; C450; C451; C452; C453; C454; C455; C456; C457; C458; C459; C460; C461; C462; C463; C464; C465; C466; C467; C468; C469; C470; C471; C472; C473; C474; C475; C476; C477; C478; C479; C480; C481; C482; C483; C484; C485; C486; C487; C488; C489; C490; C491; C492; C493; C498; C499; C500; C501; C505; C543; C544; C545; C546; C547; C548; C594; C595; C596; C597; C598; C599; C600; C601; C602; C603; C604; C605; C606; C607; C608; C609; C610; C611; C612; C613; C614; C615; C637; C638; C639; C640; C641; C642; C645; C660; C661; C667; C668; C669; C670; C671; C672; C673; C674; C675; C676; C677; C678; C681; C684; C685; C686; C687; C688; C689; C690; C691; C692; C693; C694; C695; C696; C697; C698; C704; C705; C706 |
SC0805 | SC0805 | 1uF | DISCRETE | 74 | C22; C23; C24; C25; C26; C27; C28; C29; C30; C357; C497; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C529; C530; C531; C532; C533; C534; C535; C536; C537; C538; C539; C540; C541; C542; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C563; C564; C565; C566; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C587; C589; C590; C591; C592; C593 |
SC1206 | SC1206 | 22uF | DISCRETE | 73 | C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C205; C211; C496; C508; C509; C510; C511; C512; C513; C514; C515; C516; C517; C518; C567; C588; C616; C617; C618; C619; C620; C621; C622; C623; C624; C625; C626; C627; C628; C629; C630; C631; C632; C633; C634; C635; C636; C643; C662; C663; C664; C665; C666; C682; C683; C699; C2000 |
SCAPC2-280-327 | SCAPC2-280-327 | 100uF | DISCRETE | 11 | C44; C502; C503; C504; C506; C507; C655; C656; C657; C658; C659 |
SCAPC2-0808C | SCAPC2-0808C | | IC | 4 | C40; C41; C42; C43 |
SD0805-LED | SD0805-LED | LED | IC | 3 | D8; D34; D41 |
SD2723 | SD2723 | DIODE | DISCRETE | 1 | D1 |
SDSW8-L | SDSW8-L | GSW3 | DISCRETE | 7 | SW1; SW2; SW3; SW4; SW5; SW6; SW7 |
SEN3-100C | SEN3-100C | 3638A | IC | 1 | D33 |
SF6127 | SF6127 | SSQ4 | DISCRETE | 2 | F1; F3 |
SIP-1P | SIP-1P | 013-0018-192 | IC | 10 | J2; J3; J4; J5; J6; J7; J8; J9; J10; J11 |
SIP-2P | SIP-2P | | IC | 1 | J45 |
SIP-3P | SIP-3P | | IC | 4 | J1; J42; J43; J44 |
SL0402 | SL0402 | | IC | 6 | LB13; LB22; LB25; LB26; LB67; LB68 |
SL0603 | SL0603 | | IC | 8 | LB14; LB23; LB24; LB62; LB63; LB64; LB65; LB66 |
SL0805 | SL0805 | 1uH | DISCRETE | 31 | LB1; LB2; LB3; LB4; LB5; LB6; LB7; LB8; LB9; LB10; LB11; LB12; LB15; LB16; LB17; LB18; LB19; LB20; LB53; LB54; LB55; LB56; LB57; LB58; LB59; LB60; LB61; LB75; LB76; LB79; LB80 |
SL1206 | SL1206 | LB | IC | 31 | LB27; LB28; LB29; LB30; LB31; LB32; LB33; LB34; LB35; LB36; LB37; LB38; LB39; LB40; LB41; LB42; LB43; LB44; LB45; LB46; LB47; LB48; LB49; LB50; LB51; LB52; LB69; LB70; LB71; LB72; LB73 |
SL1806 | SL1806 | FCFBMJ4516HS720NT | DISCRETE | 4 | LB21; LB74; LB77; LB78 |
SL4040 | SL4040 | | IC | 1 | L3 |
SOP8-26-118 | SOP8-26-118 | | IC | 1 | U13 |
SOP8-50-150 | SOP8-50-150 | 24LC16B_SN | IC | 4 | U15; U16; U23; U24 |
SOP8-50-150A | SOP8-50-150A | | IC | 1 | U14 |
SOP8-50-157H | SOP8-50-157H | | IC | 2 | U33; U34 |
SOP8-50-173 | SOP8-50-173 | LM833D | IC | 2 | U22; Z1 |
SOP8H-50-155A | SOP8H-50-155A | | IC | 3 | U36; U37; U47 |
SOP16-26-173 | SOP16-26-173 | | IC | 2 | U45; U46 |
SOP16-26-208-255 | SOP16-26-208-255 | ICL3232EIA_T | IC | 1 | U32 |
SOP16-50-300A | SOP16-50-300A | | IC | 1 | U35 |
SOP38-20-173A | SOP38-20-173A | | IC | 2 | U1; U2 |
SOP48-20-720 | SOP48-20-720 | | IC | 1 | U17 |
SOP56-20-250-550 | SOP56-20-250-550 | | IC | 9 | U3; U4; U5; U6; U7; U8; U9; U10; U11 |
SOT23 | SOT23 | PMOS-GSD | IC | 41 | D2; D3; D4; D5; D6; D7; D9; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D21; D22; D23; D24; D25; D26; D27; D28; D29; D30; D31; D32; D39; D40; D44; D45; D46; Q1; Q2; Q3; Q8; Q9; Q10 |
SOT23-5B | SOT23-5B | SN74LVC1G125DBVR | IC | 2 | U25; U26 |
SOT543-4 | SOT543-4 | | IC | 2 | D37; D38 |
SPL0705A | SPL0705A | | IC | 2 | L1; L2 |
SPL1209 | SPL1209 | 10uH | DISCRETE | 1 | L6 |
SPL1212C | SPL1212C | | IC | 2 | L4; L5 |
SPW-PW22ASAB-HW6 | SPW-PW22ASAB-HW6 | | IC | 1 | U38 |
SR0402 | SR0402 | | DISCRETE | 169 | R13; R14; R139; R140; R141; R143; R144; R145; R146; R147; R152; R153; R154; R155; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R196; R201; R202; R203; R204; R205; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R241; R242; R243; R244; R245; R265; R275; R290; R407; R417; R418; R423; R424; R425; R427; R428; R429; R430; R431; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R456; R457; R458; R459; R462; R463; R464; R465; R470; R471; R472; R473; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R525; R541; R558; R559; R560; R561; R562; R563; R564; R565; R566; R567; R568; R569; R570; R571; R572; R573; R692; R702; R703; R707; R710; R711; R712; R713; R714; R715; R716; R717; R718; R719; R720; R721; R722; R723; R724; R725; R734; R742; R743; R744; R745; R754; R755; R756; R757; R758 |
SR0603 | SR0603 | 49.9 | DISCRETE | 596 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R142; R148; R149; R150; R151; R156; R157; R158; R159; R160; R161; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R197; R198; R199; R200; R206; R207; R233; R234; R235; R236; R237; R238; R239; R240; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R266; R267; R268; R269; R270; R271; R272; R273; R274; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R291; R292; R293; R294; R295; R296; R297; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R393; R394; R395; R396; R397; R398; R399; R400; R401; R402; R403; R404; R405; R406; R408; R409; R410; R411; R412; R413; R414; R415; R416; R419; R420; R421; R422; R426; R432; R433; R434; R453; R454; R455; R460; R466; R467; R468; R469; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R494; R495; R496; R497; R498; R499; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R526; R527; R528; R529; R530; R531; R532; R533; R534; R535; R536; R537; R538; R539; R540; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553; R554; R555; R556; R557; R574; R575; R576; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R593; R594; R595; R596; R597; R598; R599; R600; R601; R602; R603; R604; R605; R606; R607; R608; R609; R610; R611; R612; R613; R614; R615; R616; R617; R618; R619; R620; R621; R622; R623; R624; R625; R626; R627; R628; R629; R630; R631; R632; R633; R634; R635; R636; R637; R638; R639; R640; R641; R642; R643; R644; R645; R646; R647; R648; R649; R650; R651; R652; R653; R654; R655; R656; R657; R658; R659; R660; R661; R662; R663; R664; R665; R666; R667; R668; R669; R670; R671; R672; R673; R674; R675; R676; R677; R678; R679; R680; R681; R682; R683; R684; R685; R686; R687; R688; R689; R690; R691; R693; R694; R695; R696; R697; R698; R699; R700; R701; R705; R706; R708; R709; R726; R727; R728; R729; R730; R731; R732; R733; R735; R736; R737; R738; R739; R740; R741; R746; R747; R748; R749; R750; R751; R752; R753; R759; R760; R761; R762; R763; R764; R765; R766; R767; R2000 |
SR0805 | SR0805 | 0 | DISCRETE | 1 | R704 |
SR1206 | SR1206 | | IC | 1 | R162 |
SSW-PUSH | SSW-PUSH | TC-108 | IC | 1 | S1 |
STC3216 | STC3216 | 10uF | DISCRETE | 1 | C360 |
STC7343 | STC7343 | 100UF | IC | 5 | C6; C7; C8; C9; C39 |
STFM24-39-630 | STFM24-39-630 | | IC | 2 | T1; T2 |
STP40 | STP40 | | IC | 16 | TS4; TS5; TS6; TS7; TS8; TS9; TS10; TS11; TS12; TS13; TS14; TS15; TS16; TS17; TS18; TS19 |
SX2-1205 | SX2-1205 | 25MHz | IC | 3 | X2; X3; X4 |
SX4-0503C | SX4-0503C | | IC | 2 | X5; X6 |
SX4-0705 | SX4-0705 | 27MHz | DISCRETE | 3 | OSC1; OSC2; OSC3 |
TW-MKT2-26 | TW-MKT2-26 | | IC | 1 | J32 |
TW-MKT2-100-F | TW-MKT2-100-F | | IC | 2 | J14; J15 |
USB4-1415 | USB4-1415 | 292303_1 | IC | 2 | J34; J35 |
VAF2 | VAF2 | | IC | 2 | J12; J13 |
VAF3-A | VAF3-A | AV2_84_9B_PB | IC | 2 | J38; J39 |
VAF5-A | VAF5-A | | IC | 1 | J23 |
VAF6-1914 | VAF6-1914 | AV3_84_15 | IC | 1 | J25 |
WBC0109-20RA | WBC0109-20RA | | IC | 2 | J40; J41 |
XTAL2-100 | XTAL2-100 | | IC | 1 | X1 |
附件:
