TA的每日心情 | 开心 2019-11-19 15:19 |
签到天数: 1 天 [LV.1]初来乍到
DEK印刷机手册SqueegeeModule
. ~( _" \( X) }MODULE OVERVIEW4 U& j$ O7 l+ x
Purpose
; i/ u5 f! H QThe squeegee module allows the setting and monitoring of squeegee height and pressure during the print stroke.- n$ y5 |' P9 j8 ~% h
The positioning of the squeegee module across the print stroke (from front to back).
" Y/ V, x8 n2 T3 m( f9 H9 m+ [Elements - E8 S0 `! p$ m( d4 [+ c" V; B
The major components of the squeegee module are as follows:
+ [8 _" I! Z% C' l/ Q6 c? Squeegee Housing
: D% A4 E. g" i8 J? Squeegees. v8 ?+ Y( @* J1 V' o& \
? Squeegee Pressure Amplifier
. R6 M9 n) t2 y) d? Squeegee Drive Stepper Motors
" s. d/ }8 H5 M6 b c$ a? Pre-load Set Screw: C$ ~( {" c# N: x, R/ u
? Load Cell& f9 E4 e+ ]1 L" o" [
? Main Compression Spring
7 x/ q+ P6 x( T- |. |3 U/ t? Squeegee Drive Mechanism6 i$ [& p8 _/ t2 \* r0 O
? Front And Rear Squeegee Mounts8 x7 b7 y; M3 x2 }+ ?$ d/ M7 Q7 P
? Home Sensor Hall Effect Switches (2 positions) q7 F0 X4 g! Y
Operation The squeegee drive motors move the front and rear squeegee mounts to the required positions.3 a( z: p/ }: \: M; a
The printhead pressure system is the mechanism which drives the two squeegees independently down onto the screen and applies the pressure necessary to print.0 S" D! L2 V* f# _# a
The pressure being applied during print is monitored by the pressure amplifier,and if necessary, corrections to pressure is made as part of a closed loop process. The load cell and pressure amplifier give a change in output voltage proportional to the pressure applied by the squeegees.8 I, G" g( m4 P: o& D1 `% A) ~) V0 U, v- Y
The pre-load set screw and main compression spring are used to calibrate the load cell/squeegee pressure.
H% G) I* d$ t" ^6 P+ VThe home sensors, sited in the printhead mechanism, detect when the front and rear squeegee mounts are at the top of their travel.
4 S1 K, l* a/ l. A6 V5 k/ e; N/ U% A% n/ ?+ { |6 J4 j8 I G
9 c% D4 n" V& Y7 ~6 @) q: y
: m4 @+ O: M. m. k7 x$ m1 y
