Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
64HTQFP | TI_TFP_410_64HTQFP_1.2MM_312-75 | TFP410PAP | IC | 1 | U47 |
0402_CC | RES_0402_CC_0.40 MM_470-31288_1 | 10M | IC | 1 | R1001 |
0402_CC | RES_0402_CC_0.45 MM_470-75394_0 | 0 | IC | 3 | R1005; R1011; R1012 |
0603LED | LED_0603LED_0.8MM_370-76477_BLU | Blue | IC | 3 | D11; D14; D24 |
0603LED | LED_0603LED_1.1MM_370-76426_LED | LED Yellow | IC | 3 | D13; D18; D21 |
0603LED | LED_0603LED_0.65MM_370-75904_GR | GREEN LED | IC | 3 | D19; D22; D37 |
0603LED | LED_0603LED_0.65MM_370-75905_RE | RED LED | IC | 3 | D20; D25; D38 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_1.1MM_370 | LED_ORANGE | IC | 4 | D12; D17; D23; D36 |
AMP-787745-X | USB_A_DUAL_AMP-787745-X_15.51 M | USB_TYPE_A_DUAL | IC | 1 | J7 |
BATT_MS | LICELL_BATT_MS_2.8MM_670-00010_ | LICELL | IC | 1 | BAT1 |
BGA139_0P5_7X7MM | MC13892_27_BGA139_0P5_7X7MM_1.2 | MC13892 | IC | 1 | U7 |
CASE403D_02 | ZDIODE_CASE403D_02_2.41MM_480-7 | 1SMA5935B | IC | 1 | D1002 |
CASE_M | CAP_POL_CASE_M_0.9MM_150-78547_ | 47UF | IC | 1 | C108 |
CASE_P | CAP_POL_CASE_P_1.2MM_150-78548_ | 47uF | IC | 6 | C236; C239; C261; C265; C405; C406 |
CC0201 | CAP_NP_CC0201_0.33 MM_150-76034 | 15pF | IC | 4 | C86; C87; C250; C253 |
CC0201 | CAP_NP_CC0201_0.33 MM_150-77852 | 0.22UF | IC | 32 | C90; C91; C92; C98; C99; C100; C101; C102; C103; C109; C110; C124; C138; C148; C154; C170; C172; C177; C179; C187; C189; C193; C195; C198; C200; C205; C207; C213; C215; C218; C219; C221 |
CC0201 | CAP_NP_CC0201_0.33 MM_150-75465 | 0.01UF | IC | 24 | C93; C94; C95; C105; C106; C107; C112; C113; C147; C152; C153; C157; C171; C173; C175; C178; C180; C182; C199; C201; C203; C206; C208; C210 |
CC0201 | CAP_NP_CC0201_0.33MM_150-75429_ | 0.1UF | IC | 53 | C111; C115; C116; C118; C119; C120; C121; C123; C125; C126; C127; C129; C130; C131; C133; C134; C135; C136; C137; C139; C140; C141; C142; C143; C144; C145; C146; C149; C150; C151; C155; C156; C166; C167; C168; C169; C174; C181; C184; C185; C186; C188; C190; C192; C194; C196; C202; C209; C212; C214; C216; C220; C222 |
CC0402_25 | CAP_NP_CC0402_25_0.635MM_150-75 | 0.1UF | IC | 117 | C1; C73; C82; C88; C89; C158; C160; C163; C164; C224; C227; C230; C232; C233; C234; C235; C238; C242; C244; C246; C247; C249; C252; C254; C256; C257; C259; C260; C262; C263; C264; C266; C267; C268; C269; C271; C272; C274; C277; C278; C279; C280; C281; C282; C283; C288; C289; C290; C292; C293; C305; C306; C307; C310; C313; C314; C316; C317; C321; C322; C323; C324; C325; C326; C328; C332; C333; C336; C337; C338; C342; C345; C346; C347; C354; C355; C361; C362; C363; C368; C369; C370; C371; C374; C375; C376; C377; C379; C380; C383; C387; C388; C389; C390; C391; C393; C397; C400; C404; C407; C408; C409; C410; C411; C413; C414; C415; C416; C417; C418; C422; C423; C424; C5002; C5008; C5009; C5010 |
CC0402_25 | CAP_NP_CC0402_25_0.56MM_150-300 | 0.01UF | IC | 9 | C240; C275; C276; C311; C312; C365; C372; C402; C403 |
CC0402_25 | CAP_NP_CC0402_25_0.74 MM_150-30 | 0.01UF | IC | 2 | C286; C287 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-3_1 | 10PF | IC | 4 | C301; C302; C420; C421 |
CC0402_25 | CAP_NP_CC0402_25_0.635MM_150-30 | 33PF | IC | 3 | C349; C352; C357 |
CC0402_25 | CAP_NP_CC0402_25_.55MM_150-3000 | 15PF | IC | 2 | C384; C385 |
CC0402_25 | CAP_NP_CC0402_25_0.60MM_150-754 | 470PF | IC | 2 | C394; C395 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-757 | 1.0UF | IC | 1 | C419 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-302 | 220PF | IC | 2 | C3002; C3003 |
CC0402_25 | CAP_NP_CC0402_25_0.635 MM_150-7 | 20PF | IC | 1 | C5011 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-300 | 470PF | IC | 1 | C5013 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-756 | 560PF | IC | 1 | C5020 |
CC0402_25 | VARISTOR-C_CC0402_25_0.5MM_150- | 3PF | IC | 1 | D9 |
CC0603 | CAP_NP_CC0603_0.86 MM_150-75417 | 2.2uF | IC | 1 | C1001 |
CC0603_OV | CAP_NP_CC0603_OV_0.84MM_150-301 | 1uF | IC | 11 | C3; C85; C241; C255; C258; C270; C319; C330; C331; C344; C382 |
CC0603_OV | CAP_NP_CC0603_OV_1.0MM_150-7783 | 10UF | IC | 32 | C56; C57; C58; C64; C65; C66; C96; C104; C114; C117; C122; C128; C161; C165; C176; C183; C191; C197; C204; C211; C217; C223; C273; C315; C318; C364; C366; C367; C386; C3001; C5006; C5007 |
CC0603_OV | CAP_NP_CC0603_OV_0.9MM_150-7797 | 4.7uF | IC | 16 | C59; C60; C61; C62; C67; C225; C226; C229; C231; C284; C285; C291; C398; C399; C412; C5001 |
CC0603_OV | CAP_NP_CC0603_OV_0.9 MM_150-302 | 2.2UF | IC | 18 | C69; C70; C71; C72; C74; C75; C76; C77; C78; C79; C80; C81; C83; C84; C132; C228; C329; C396 |
CC0603_OV | CAP_NP_CC0603_OV_0.9MM_150-3024 | 10PF | IC | 4 | C294; C295; C296; C297 |
CC0603_OV | CAP_NP_CC0603_OV_0.84MM_150-753 | 0.022UF | IC | 1 | C298 |
CC0603_OV | CAP_NP_CC0603_OV_0.95MM_150-300 | 100 PF | IC | 3 | C308; C340; C343 |
CC0603_OV | CAP_NP_CC0603_OV_0.87MM_150-764 | 24PF | IC | 1 | C309 |
CC0603_OV | CAP_NP_CC0603_OV_0.87MM_150-754 | 0.47UF | IC | 3 | C320; C334; C335 |
CC0603_OV | CAP_NP_CC0603_OV_1.016MM_150-75 | 22 PF | IC | 8 | C348; C350; C351; C353; C356; C358; C359; C360 |
CC0805 | CAP_NP_CC0805_1.35MM_150-77793_ | 22UF | IC | 2 | C63; C97 |
CC0805_OV | CAP_NP_CC0805_OV_1.4MM_150-7797 | 10uF | IC | 6 | C68; C237; C304; C327; C378; C381 |
CC1206 | CAP_NP_CC1206_1.8MM_150-77350_1 | 10UF | IC | 4 | C1002; C1003; C1004; C1005 |
CC1206_OV | CAP_NP_CC1206_OV_1.63MM_150-300 | 1000PF | IC | 5 | C299; C300; C303; C373; C392 |
CC1210 | CAP_NP_CC1210_2.42 MM_150-30186 | 47uF | IC | 1 | C2001 |
CC3216_10 | CAP_POL_CC3216_10_1.2MM_150-785 | 220UF | IC | 2 | C339; C341 |
CC6032 | CAP_POL_CC6032_2.8 MM_150-76490 | 100UF | IC | 10 | C243; C245; C248; C251; C5014; C5015; C5016; C5017; C5018; C5019 |
CC7343 | CAP_POL_CC7343_3.1MM_150-30200_ | 22uF | IC | 1 | C2 |
CON2_FPC_1P25_SM | 87213-02_CON2_FPC_1P25_SM_3.65M | CON FPC 2 | IC | 1 | X1 |
CON5_AUD_JACK_RA_TH_SJ-43515TS | SJ-43515TS_CON5_AUD_JACK_RA_TH_ | AUD_5 | IC | 2 | J13; JK1 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IC | 1 | J6 |
CON8_FH19_SM_SH | CON_1X8_CON8_FH19_SM_SH_1.6MM_2 | CON FPC/FFC 8 | IC | 1 | J10 |
CON8_RJ45_1P02 | RJ45-8_CON8_RJ45_1P02_14.22MM_2 | RJ45-8 | IC | 1 | P3 |
CON19_SDCARD_28X16_SM | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | IC | 2 | P1; P2 |
CON20_0P5_FPC | CON20_1_CON20_0P5_FPC_2.39MM_21 | CON FPC 20 | IC | 1 | CON1 |
CONN_RT_RA_30 | CON_DVI-I_CONN_RT_RA_30_9.9MM_2 | DVI-I_Dual_29 | IC | 1 | P4 |
CON_2X26_0P8_SMT | MINI_PCI_LATCH_52P_CON_2X26_0P8 | CON 2X26 MINI PCI EXPRESS | IC | 1 | J8 |
CON_4M_1MM_SM_RA | SM04B_CON_4M_1MM_SM_RA_2.95MM_2 | SM04B-SRSS-TB | IC | 2 | CN1; J9 |
CON_22_1P27_SMT_SATA | CON22_SATA_CON_22_1P27_SMT_SATA | SATA 22 | IC | 1 | J5 |
CON_26_FH12_1MM_SM_RA | CON_1X26_CON_26_FH12_1MM_SM_RA_ | CON 1X26 FPC | IC | 1 | J12 |
CON_52F_8S_25_SM | CONN_2X26_S8_B_CON_52F_8S_25_SM | CON SKT 52 | IC | 1 | J16 |
CON_120S_QSH_SM_05PITCH | QSH060_CON_120S_QSH_SM_05PITCH_ | QSH-060-01-L-D-A | IC | 2 | J14; J18 |
CON_DB9P_190-009-263R001 | CONN_DB9F_MTGTABS_CON_DB9P_190- | DB 9 | IC | 1 | P5A1 |
CON_DF_20F_1MM_SM_RA | CON20_1_CON_DF_20F_1MM_SM_RA_1. | CON 20 | IC | 1 | CON3 |
CON_JACK_3F_RA_TH_PJ-047A | PJ-047A_CON_JACK_3F_RA_TH_PJ-04 | CON PWR 3 | IC | 1 | J1 |
CON_SIM_CD_2P54MM | SF7W006S1A_CON_SIM_CD_2P54MM_2. | CON 6 SIM CARD | IC | 1 | CON2 |
DFN_6_0P65_2P1X2 | ISL29003_DFN_6_0P65_2P1X2_0.75M | ISL29003IROZ | IC | 1 | U234 |
DIP10_1P27MM_SM | SW_DIP-10_DIP10_1P27MM_SM_1.45M | SW_DIP-10/SM | IC | 1 | S1 |
FBGA_84_0P8_8X12P5 | MT47H64M16_84P_FBGA_84_0P8_8X12 | EDE1116AEBG | IC | 4 | U15; U16; U17; U18 |
FUSE_1P6X0P8 | FUSE_RST_FUSE_1P6X0P8_0.55MM_51 | SF-0603F | IC | 1 | F1 |
H1102_XFMR16_SM | H1102_H1102_XFMR16_SM_5.97 MM_5 | H1102NL | IC | 1 | T1 |
HDR104 | CONN_HDR_4X1_HDR104_10.29MM_210 | HDR 1X4 | IC | 1 | J3 |
HDR105 | CONN_HDR_5X1_HDR105_5.41MM_210- | HDR 1X5 | IC | 1 | J11 |
HDR204_TMM_SM | CONN_HDR_4X2_HDR204_TMM_SM_5.97 | TMM-104-01-T-D-SM | IC | 1 | J4 |
HDR210_TST_RA | TSW-110-05-G-D_HDR210_TST_RA_9. | TST-110-05-T-D-RA | IC | 1 | J15 |
HTSSOP20_VIA | TPA6017A2_HTSSOP20_VIA_1.2MM_31 | tpa6017a2 | IC | 1 | U41 |
IND_2P2X2 | IND_IND_2P2X2_1.4MM_180-76836_3 | 3.3UH | IC | 1 | L1001 |
IND_0402 | INDUCTOR_IND_0402_0.55MM_180-77 | 0.27uH | IC | 1 | L25 |
IND_0402 | INDUCTOR_IND_0402_0.6MM_180-776 | 0.082UH | IC | 6 | L32; L33; L34; L35; L36; L37 |
IND_0402 | INDUCTOR_FERRITE_IND_0402_0.55M | 180 OHM@100MHZ | IC | 2 | L38; L39 |
IND_0603 | BLM18R_IND_0603_0.95MM_180-7762 | 75 OHM@100MHZ | IC | 7 | FB1; FB2; FB3; FB4; FB5; FB8001; FB8002 |
IND_0603 | BLM18R_IND_0603_0.65MM_180-7762 | 120 OHM@100MHZ | IC | 17 | L11; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L23; L24; L41; L42; L43; L44 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-76 | 2.5K | IC | 3 | L28; L29; L30 |
IND_0603 | INDUCTOR_IND_0603_0.95MM_180-77 | 300 OHM@100MHZ | IC | 3 | L40; L45; L46 |
IND_0804_8P | IND_8P_IND_0804_8P_0.6MM_180-77 | 90 OHM@100MHZ | IC | 1 | L22 |
IND_0805 | INDUCTOR_FERRITE_IND_0805_1.05M | 470 OHM@100MHZ | IC | 2 | L26; L27 |
IND_2012 | INDUCTOR_IND_2012_1.05MM_180-77 | 0.082uH | IC | 1 | L31 |
IND_DO1608 | COIL_IND_DO1608_2.92 MM_180-750 | 1.0UH | IC | 1 | L5002 |
IND_ELLVGG | INDUCTOR_IND_ELLVGG_1.5MM_180-7 | 3.3uH | IC | 1 | L10 |
IND_VLF4012 | IND_IND_VLF4012_1.2MM_180-77614 | 2.2UH | IC | 3 | L7; L8; L9 |
IND_VLS252012 | IND_IND_VLS252012_1.2MM_180-768 | 1.5UH | IC | 1 | L6 |
LED_0603_C1 | LED_LED_0603_C1_0.9MM_370-75079 | RED | IC | 1 | D5001 |
LQFP48 | GL830-MNG_LQFP48_1.6MM_315-7884 | GL830-MNGXX | IC | 1 | U19 |
LQFP48 | ADV7123_LQFP48_1.6MM_315-78825_ | ADV7123 | IC | 1 | U44 |
PBGA529_0P8MM | IMX51_TO2_BGA_0P8_PBGA529_0P8MM | iMX51 | IC | 1 | U10 |
QFN20_3X3MM_A | SI4702_QFN20_3X3MM_A_0.6MM_312- | SI4702 | IC | 1 | U37 |
QFN24_4X4MM_SLUG | USB3317_QFN24_4X4MM_SLUG_1.0MM_ | USB3317 | IC | 1 | U20 |
QFN24_4X4MM_SLUG | MC34713_A_QFN24_4X4MM_SLUG_1MM_ | MC34713EP | IC | 1 | U5004 |
QFN32 | SGTL5000_QFN32_0.9MM_315-77907_ | SGTL5000 32QFN | IC | 1 | U40 |
QFN36 | LAN8700_QFN36_1MM_312-77775_LAN | LAN8700 | IC | 1 | U35 |
QFN56EP_0P5_8X8MM | SK5101_QFN56EP_0P5_8X8MM_1MM_31 | SK5101 | IC | 1 | U36 |
QFN64_0P5_9X9B | USB2517_QFN64_0P5_9X9B_1MM_312- | USB2517 | IC | 1 | U26 |
RC0402_25 | RES_RC0402_25_470-75557_10K | 10K | IC | 65 | R4; R6; R7; R10; R68; R69; R116; R117; R118; R119; R121; R122; R130; R135; R136; R137; R138; R139; R141; R142; R169; R176; R177; R178; R180; R181; R182; R183; R184; R187; R233; R235; R237; R242; R255; R256; R276; R317; R322; R325; R330; R331; R334; R335; R336; R337; R338; R339; R340; R344; R345; R346; R347; R348; R404; R406; R416; R422; R462; R4001; R5018; R6001; R8002; R8003; RA002 |
RC0402_25 | RES_RC0402_25_470-75597_100K | 100K | IC | 7 | R5; R11; R179; R305; R309; R415; R8001 |
RC0402_25 | RES_RC0402_25_470-75636_2.2K | 2.2K | IC | 7 | R8; R263; R307; R311; R329; R332; R417 |
RC0402_25 | RES_RC0402_25_470-75559_47K | 47K | IC | 8 | R9; R240; R286; R3004; R3005; R7001; R7002; RA001 |
RC0402_25 | RES_RC0402_25_470-75394_0 | 0 | IC | 112 | R71; R72; R75; R76; R88; R97; R103; R104; R105; R132; R144; R145; R164; R165; R166; R167; R168; R212; R214; R216; R238; R239; R241; R248; R249; R251; R252; R253; R254; R257; R258; R260; R261; R294; R295; R300; R302; R327; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R393; R394; R395; R396; R397; R398; R399; R400; R401; R407; R408; R409; R410; R418; R419; R420; R421; R423; R424; R425; R428; R429; R430; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R464; R465; R466; R467; R468; R469; R470; R493; R494; R495; R496; R497; R498; R499; R509; R510; R1004; R5010; R5012 |
RC0402_25 | RES_RC0402_25_470-75626_4.7K | 4.7K | IC | 43 | R80; R89; R98; R99; R100; R101; R188; R189; R200; R210; R211; R270; R278; R280; R288; R289; R291; R292; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R403; R405; R471; R474; R475; R476; R477; R491; R492 |
RC0402_25 | RES_RC0402_25_470-30923_6.04K | 6.04K | IC | 1 | R106 |
RC0402_25 | RES_RC0402_25_470-30317_75 | 75 | IC | 3 | R107; R108; R109 |
RC0402_25 | RES_RC0402_25_470-75609_22K | 22K | IC | 6 | R120; R140; R174; R175; R231; R232 |
RC0402_25 | RES_RC0402_25_470-30330_68K | 68K | IC | 9 | R127; R143; R250; R259; R314; R315; R375; R402; R414 |
RC0402_25 | RES_RC0402_25_470-30822_768 | 768 | IC | 2 | R146; R147 |
RC0402_25 | RES_RC0402_25_470-76695_8.06K | 8.06K | IC | 1 | R163 |
RC0402_25 | RES_RC0402_25_470-75634_33 | 33 | IC | 2 | R170; R324 |
RC0402_25 | RES_RC0402_25_470-75613_330 | 330 | IC | 8 | R171; R173; R275; R282; R290; R373; R5009; R5011 |
RC0402_25 | RES_RC0402_25_470-30955_12K | 12K | IC | 1 | R185 |
RC0402_25 | RES_RC0402_25_470-75642_1.0M | 1.0M | IC | 4 | R186; R213; R333; R487 |
RC0402_25 | RES_RC0402_25_470-30957_12.4K | 12.4K | IC | 1 | R201 |
RC0402_25 | RES_RC0402_25_470-76474_5.1K | 5.1K | IC | 18 | R219; R449; R450; R451; R452; R453; R454; R456; R457; R458; R459; R460; R461; R500; R501; R502; R503; R504 |
RC0402_25 | RES_RC0402_25_470-30313_15K | 15K | IC | 4 | R271; R479; R480; R5013 |
RC0402_25 | RES_RC0402_25_470-30933_7.5K | 7.5K | IC | 1 | R272 |
RC0402_25 | RES_RC0402_25_470-75555_1K | 1K | IC | 15 | R283; R321; R365; R366; R367; R368; R369; R370; R371; R372; R455; R481; R482; R483; R484 |
RC0402_25 | RES_RC0402_25_470-75591_100 | 100 | IC | 10 | R293; R296; R297; R298; R299; R341; R505; R506; R507; R508 |
RC0402_25 | RES_RC0402_25_470-76479_510 | 510 | IC | 1 | R473 |
RC0402_25 | RES_RC0402_25_470-76221_750 | 750 | IC | 1 | R485 |
RC0402_25 | RES_RC0402_25_470-76166_510K | 510K | IC | 1 | R486 |
RC0402_25 | RES_RC0402_25_470-76556_470 | 470 | IC | 1 | R5004 |
RC0402_25 | RES_RC0402_25_470-30914_5.1K | 5.1K | IC | 1 | R5005 |
RC0402_25 | RES_RC0402_25_470-30944_9.31K | 9.31K | IC | 1 | R5007 |
RC0402_25 | RES_RC0402_25_470-75416_10.0K | 10.0K | IC | 1 | R5008 |
RC0402_25 | RES_RC0402_25_470-30903_4.12K | 4.12K | IC | 1 | R5014 |
RC0402_25 | RES_RC0402_25_470-30913_4.99K | 4.99K | IC | 1 | R5015 |
RC0402_25 | RES_RC0402_25_470-76207_18.2K | 18.2K | IC | 1 | R5016 |
RC0402_25 | RES_RC0402_25_470-76183_4.99K | 4.99K | IC | 1 | R5017 |
RC0603 | RES_RC0603_0.55MM_470-75846_1.0 | 1.0M | IC | 2 | R1007; R1008 |
RC0603_OV | RES_RC0603_OV_470-75784_220K | 220K | IC | 1 | R2 |
RC0603_OV | RES_RC0603_OV_470-75407_0 | 0 | IC | 51 | R81; R83; R90; R91; R92; R93; R94; R95; R112; R133; R134; R149; R161; R162; R190; R191; R193; R199; R229; R230; R234; R236; R246; R269; R273; R274; R277; R279; R281; R284; R285; R287; R316; R318; R319; R320; R328; R342; R343; R376; R377; R426; R427; R463; R472; R3002; R3003; R5001; R5002; R5006; R8004 |
RC0603_OV | RES_RC0603_OV_470-77983_1.18K | 1.18K | IC | 1 | R102 |
RC0603_OV | RES_RC0603_OV_470-30029_200 | 200 | IC | 2 | R150; R151 |
RC0603_OV | RES_RC0603_OV_470-75432_49.9 | 49.9 | IC | 10 | R194; R195; R196; R197; R202; R203; R204; R205; R208; R209 |
RC0603_OV | RES_RC0603_OV_470-75423_10 | 10 | IC | 1 | R198 |
RC0603_OV | RES_RC0603_OV_470-75826_75.0 | 75 | IC | 5 | R206; R207; R265; R266; R267 |
RC0603_OV | RES_RC0603_OV_470-75451_330 | 330 | IC | 10 | R215; R217; R218; R220; R221; R222; R223; R224; R225; R431 |
RC0603_OV | RES_RC0603_OV_470-77861_24.0 | 24 | IC | 2 | R226; R227 |
RC0603_OV | RES_RC0603_OV_470-75412_1K | 1K | IC | 1 | R228 |
RC0603_OV | RES_RC0603_OV_470-77751_2.0 | 2 | IC | 4 | R243; R244; R245; R247 |
RC0603_OV | RES_RC0603_OV_470-75411_100 | 100 | IC | 2 | R262; R264 |
RC0603_OV | RES_RC0603_OV_470-75840_680 | 680 | IC | 1 | R268 |
RC0603_OV | RES_RC0603_OV_470-75410_10K | 10K | IC | 7 | R301; R303; R306; R310; R478; R488; R490 |
RC0603_OV | RES_RC0603_OV_470-75414_4.7K | 4.7K | IC | 1 | R323 |
RC0603_OV | RES_RC0603_OV_470-75422_10.0K | 10.0K | IC | 1 | R326 |
RC0603_OV | RES_RC0603_OV_470-75444_100K | 100K | IC | 1 | R489 |
RC0805_OV | RES_RC0805_OV_470-75442_0 | 0 | IC | 6 | PAD5; R312; R313; R5003; R5019; RE001 |
RC0805_OV | RES_RC0805_OV_470-30324_0.02 | 0.02 | IC | 19 | R67; R70; R74; R77; R78; R79; R82; R84; R85; R86; R87; R96; R148; R152; R153; R192; R304; R308; R3001 |
RCA_8_10 | NETW_B8_10P_RCA_8_10_470-75833_ | 10K | IC | 2 | RN2; RN3 |
RCA_8_10 | BUS_TSIP10P8RN1_RCA_8_10_470-79 | 1.0K | IC | 1 | RN4 |
SC70-5_A | 1G125_SC70-5_A_1.1MM_312-30153_ | NC7SP125P5X | IC | 7 | U9; U22; U38; U39; U43; U52; U53 |
SC-70 | 100201_SO-1_SC-70_1.1 MM_312-30 | NL17SZ126DF | IC | 1 | U23 |
SLP1616P6 | RCCLAMP_SLP1616P6_0.65MM_312-76 | RCLAMP0504P.TCT | IC | 1 | U25 |
SO6_A | 1T45_SO6_A_1.1MM_312-75172_SN74 | SN74LVC1T45 | IC | 2 | U45; U46 |
SO8-25X75-200 | AT45DB161D-S_SO8-25X75-200_2.16 | AT45DB321D-S | IC | 1 | U14 |
SO8_0P65_3X1P7 | SI5855DC_SO8_0P65_3X1P7_1.1MM_4 | Si5855DC | IC | 2 | Q5001; Q5002 |
SO8 | MIC2075_2_8P_SO8_1.73 MM_315-75 | MIC2075-2YM | IC | 2 | U21; U24 |
SO8 | MIC2526_8P_SO8_1.73MM_312-75936 | MIC2026-1YM | IC | 3 | U27; U28; U29 |
SO8-25X75 | AT93C46DN_SO8-25X75_1.75MM_334- | AT93C46DN | IC | 1 | U34 |
SOD123 | DIODE_SCHTKY_SOD123_1.0MM_480-7 | MBR120LSFT1G | IC | 1 | D15 |
SOD123 | DIODE_SCHTKY_SOD123_1.0 MM_480- | MBR140SFT | IC | 1 | D1001 |
SOD-123 | DIODE_SOD-123_1.35MM_480-77939_ | 1N4148W | IC | 1 | D27 |
SOD-323-A | DIODE_SOD-323-A_1MM_480-77953_B | BAS16H | IC | 7 | D1; D2; D3; D4; D5; D7001; D7002 |
SOD-923 | DIODE_TVS_BIDIR_SOD-923_0.4MM_4 | ESD9B3.3ST5G | IC | 3 | D26; D28; D29 |
SOT23 | 2N7002_SOT23_1.11 MM_480-75159_ | 2N7002 | IC | 2 | Q21; Q2005 |
SOT23 | NPN_SOT23_1.12 MM_480-75173_MMB | MMBT3904LT1G | IC | 1 | Q22 |
SOT23-8 | MAX3373E_SOT23-8_1.45MM_312-752 | MAX3373E | IC | 1 | U30 |
SOT353 | NL17SZ07_SOT353_1.1MM_312-75421 | NL17SZ07DFT2G | IC | 1 | U42 |
SOT-23 | DUALDIODE_SERIES_SOT23_SOT-23_1 | BAT54S | IC | 5 | D30; D31; D32; D33; D34 |
SOT-23 | MOSFET_P_SOT-23_1.12MM_480-7771 | IRLML6401 | IC | 1 | Q2001 |
SOT-553-5P | NL17SZ06_SOT-553-5P_1.7MM_315-7 | NL17SZ06 | IC | 1 | U3 |
SOT-563 | PNP_1_SOT-563_0.60MM_480-76618_ | NSS12100XV6T1G | IC | 5 | Q14; Q15; Q16; Q17; Q18 |
SPACER_150T | SPACER_SPACER_150T_16.13MM_280- | .635" LONG | IC | 4 | H1; H2; H3; H4 |
SSOP8_0P65_2P9X3P1 | TXB0102_SSOP8_0P65_2P9X3P1_1.3M | TXS0102 | IC | 1 | U33 |
SSOP16 | SP3232E_SSOP16_1.99MM_312-77064 | SP3232 | IC | 1 | U51 |
SSOT6_1P7X3 | FDC6331L_SSOT6_1P7X3_1.1MM_315- | FDC6331L | IC | 4 | U2; U49; U50; U54 |
SUPERSOT6 | FDC697P_SUPERSOT6_0.85MM_480-75 | FDC697P | IC | 3 | Q2002; Q2003; Q2004 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_5M | SPST PB | IC | 2 | SW1; SW2 |
TESTPOINT_39MIL | TEST PAD_TESTPOINT_39MIL_DISCRE | 1 mm | DISCRETE | 7 | TP7; TP8; TP9; TP10; TP14; TP17; TP18 |
TEST_LOOP | TESTLOOP_TEST_LOOP_4.8 MM_210-7 | TEST POINT WHITE | IC | 6 | TP1; TP2; TP3; TP4; TP15; TP19 |
TSSOP14_A | SN74LVC06_TSSOP14_A_1.2MM_312-7 | SN74LVC06A | IC | 1 | U55 |
TSSOP56_0P5_14X6P1MM | DS90C385AMT_TSSOP56_0P5_14X6P1M | DS90C385AMT | IC | 1 | U48 |
ULLGA6_1P45X1_0P5MM | NLU2GU04_ULLGA6_1P45X1_0P5MM_0. | NLX2G14 | IC | 3 | U1; U5002; U5003 |
ULLGA6_1P45X1_0P5MM | NLSV1T34_ULLGA6_1P45X1_0P5MM_0. | NLSV1T34 | IC | 3 | U8; U31; U32 |
WDFN3_2X2MM | PNP_WDFN3_2X2MM_0.8MM_480-77906 | NSS12100UW3 | IC | 1 | Q19 |
XTAL4_5P2X3P4MM_SM | XTAL_13Y_XTAL4_5P2X3P4MM_SM_0.8 | 24MHz | IC | 1 | Y3 |
XTL2_4P2X1P6 | XTAL_XTL2_4P2X1P6_0.9MM_230-774 | 32.768KHz | IC | 1 | Y1 |
XTL4_2P5X2MM_SM | O4-0_XTL4_2P5X2MM_SM_0.9MM_230- | 22.5792MHZ | IC | 1 | Y5 |
XTLOSC4_3P2X2P5MM_SM | OSC3_XTLOSC4_3P2X2P5MM_SM_1.1MM | 26MHz | IC | 1 | Y2 |
XTLOSC4_3P2X2P5MM_SM | CRYSTAL_JXS63_XTLOSC4_3P2X2P5MM | 24MHZ | IC | 1 | Y6 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 25MHZ | IC | 2 | Y4; Y7 |
附件:
