查看: 2833|回复: 1
用cadence capture cis,在annotate时,出现错误!
发表于 2008-4-21 10:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cadence capture cis,在annotate时,出现错误:. @+ N3 ^1 W3 N) z0 g
Cannot peRForm annotation of heterogeneous part 'U?A(Value SN74AUC2G08DBV)', part has not been uniquely grouped (using a common User Property with differing Values) or the device designation has not been chosen
  D/ \1 {0 w- D  s3 PDone updating part references
5 a7 v- B* ~( u其中SN74AUC2G08DBV是含有两个与门的器件。请教一下!!
发表于 2008-4-23 13:07 | 只看该作者
这个含有两个与门的器件肯定用到不止一次,所以在ANNOTATE时ORCAD无法判断PART是哪一个的。具体看一下帮助吧!
GMT+8, 2025-9-10 03:00 , Processed in 0.109375 second(s), 24 queries , Gzip On.
