Fixed CCRs: SPB 17.4 HF006
: J: h% T V# z0 V, A0 w2 {4 ]04-30-2020: z" H5 g1 e! P& L9 H
========================================================================================================================================================: E& ]' C0 `0 w! {: j
CCRID Product ProductLevel2 Title
" E( @; c0 h/ T3 S& w9 c! P========================================================================================================================================================
5 W: c f4 B/ x2 z0 M2194747 ALLEGRO_EDITOR DFM Minimum gap DFM error within same polygon not caught, w1 _% D9 G2 p
2233051 ALLEGRO_EDITOR DFM Copper Spacing: Thru via hole to Non signal shape DRC not working with BB via. H% `/ \- x n0 }9 l
2238666 ALLEGRO_EDITOR DFM DFF Silkscreen constraints showing DRC even though there is no violation.# S8 n) _. i# F* ^2 w
1938592 ALLEGRO_EDITOR EDIT_ETCH Not able to use AiDT option to length match the traces.
' W" v$ C! M' U% G2 [. u! M9 z1960535 ALLEGRO_EDITOR EDIT_ETCH AiDT does not work for buses with width larger than minimum width
% ~$ e! E K9 y* G/ @( ~! W2036229 ALLEGRO_EDITOR EDIT_ETCH AiDT does not work on Non-default min Width/ `2 w' e4 e6 u; l w
2157973 ALLEGRO_EDITOR EDIT_ETCH AiDT is not working due to line width constraints
3 Z% `$ k9 j. D0 ]9 L$ T2175464 ALLEGRO_EDITOR EDIT_ETCH auto tuning in AiDT fails to tune differential pairs
}+ M. O! e* y% q( Q* P' V2223214 ALLEGRO_EDITOR EDIT_SHAPE Menus for Shape Operations are missing from OrCAD menu set
; t# }7 B$ {+ F! V, J2213659 ALLEGRO_EDITOR INTERACTIV Last placed component is unplaced in Allegro PCB Editor because cross placement is picking that component
; g: C2 f# s! j: ^$ t5 d- B+ ?0 @* x2216410 ALLEGRO_EDITOR INTERACTIV Issue with cross place from OrCAD Capture to PCB Editor: placed part selected
+ c$ m, t2 K+ F/ U. A9 \2253831 ALLEGRO_EDITOR INTERFACES Release 17.2-2016, HotFix065: Some arc segments not mirrored properly on exporting PDF with Film mirrored checked# {8 f$ f* N+ |) N! J
2254260 ALLEGRO_EDITOR INTERFACES Arc lines not flipping correctly in PDF in HotFix004 and HotFix005 when the film is mirrored6 L$ [- d& d8 R$ }6 a5 E. o1 e7 H
2226610 ALLEGRO_EDITOR NC Backdrill_pressfit_connector - the bottom side drill passes are not getting excluded
" R4 I$ t+ V7 J6 e- C8 c9 c( v! h3 G2228366 ALLEGRO_EDITOR NC Setting 'BACKDRILL_OVERRIDE' to 'TOP:TOP:BOTTOM:BOTTOM' does not work4 @8 }3 m: G) I e1 ?
2230619 ALLEGRO_EDITOR NC PCB Editor stops responding when creating Layer Pairs in the Backdrill Layer Pair Initialization window.$ F9 g7 f! m) l8 w$ S
2241339 ALLEGRO_EDITOR NC Setting 'Backdrill_Override' to 'top:top:bottom:bottom' leads to incorrect backdrill analysis result; ]7 P# n, P! H, [% T1 B- {, Q% @
2236280 ALLEGRO_EDITOR PAD_EDITOR Drill tool size reverts to original value
8 `+ @. E! K& [- @$ f. y0 H1 _& ^2232567 ALLEGRO_EDITOR PLACEMENT Place manually by library takes long time in HotFix 0643 {7 h0 I4 i1 c$ A
2243727 ALLEGRO_EDITOR PLACEMENT Allegro PCB Editor crashes on Place Manual
3 A6 T' y: g# E2246145 ALLEGRO_EDITOR PLACEMENT Place manually by 'library' as the source takes much longer than it used to in release 16.6., Y2 K( Y# b4 s9 u
2215844 ALLEGRO_EDITOR SHAPE Route Keepout prevents correct shape update
" H1 q7 D$ G* ]2234915 ALLEGRO_EDITOR SHAPE PCB Editor crashes on selecting 'Trim corner' popup option in Shape Edit mode
* x2 Y9 U' l- c/ m* P3 z* ^3 J# W2078335 ALLEGRO_EDITOR SKILL Discrepancy with axlAddSelectBox() and axlSingleSelectBox() definition5 g2 c+ L8 }- ]/ ^1 p$ Q3 v* a
2223446 ALLEGRO_EDITOR SKILL Casing of axlDBTextBlockFindName()+ {" F$ [) [, X; T8 w* m$ P
2231369 ALLEGRO_EDITOR SKILL Invalid option type warning when using "axlFilmCreate("test" ?polyCutLayer nil)"7 C/ `3 o( g9 c2 }: R* ?
2235666 ALLEGRO_EDITOR UI_FORMS Export parameters window is small and cannot be scaled up in HotFixes 003 and 004
) H1 H( u2 ]3 E) Y; A2239984 ALLEGRO_EDITOR UI_FORMS Callback function for form not invoked if multiple fields are selected by dragging mouse: O" O# X4 x2 w1 @) p
2167454 ALLEGRO_EDITOR UI_GENERAL Custom commands and HTML XProbe: Triggering actions from HTML files
' o& ?8 O! L. g, t2227489 ALLEGRO_EDITOR UI_GENERAL HTML cross probing in release 17.4 works partially: o2 w' _1 b( Q+ L
2222689 ALLEGRO_LIB_CRT CORE Edit External Padstack from LC
}. g: a6 e/ u; h* f2233072 CAPTURE CONNECTIVITY OrCAD Capture stops responding on transferring occurrence property to instance5 a, U# S3 d& _" G$ b4 a' H3 U
2237520 CAPTURE GENERAL Issue with CIS toolbar translation in Japanese: Capture crashes: E- `" i& p( L# V7 l
2220792 PSPICE PROBE Release 17.4-2019, PSpice: Unable to read simulation messages in summary window! x3 _! Y' s: I ^
2239253 PSPICE PROBE Message summary dialog in PSpice in release 17.4-2019 does not show message; _: f% d1 q0 N* r5 |# H
2234913 PULSE CORE Data node crash because of going out of memory
# @4 X" }/ `8 P# O" F+ ~7 `2236450 PULSE CORE Database syntax error: server out of memory0 W* K+ o3 i0 T# X p; s) Z# |
2222469 PULSE UNIFIED_SEARC OrCAD Capture Search Providers crash with specific part placement: X# G5 }) D/ W- T
2233638 PULSE UNIFIED_SEARC Capture crashes when trying to use Place > Search Providers, v! M: C, l0 R- \
1913829 SPECCTRA LICENSING Cannot run SPECCTRA with an OrCAD PCB Expert license
5 V) ]. B! K% E f" k2 S( L4 Q2212091 SPECCTRA LICENSING Include OrCAD PCB Router license for autorouting in OrCAD PCB Expert suite (PO9205)% K5 r# P7 N8 a4 E! a" d% d" _
