查看: 28167|回复: 222
更新Allegro17.4_006号补丁SPB v17.40.006 Hotfix
    2021-2-2 15:32
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2020-5-2 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    4 a$ E8 f* z7 X0 v. H& }' F# l' M8 Q1 `
    下载链接:
    游客,如果您要查看本帖隐藏内容请回复
    推荐
    发表于 2020-5-4 21:56 | 只看该作者
    Fixed CCRs: SPB 17.4 HF006
    * [6 |/ R* y7 Q- B$ e8 p04-30-2020* |6 B2 ^1 Y) V2 o
    ========================================================================================================================================================& B5 }  F4 R; w$ z; v6 q
    CCRID   Product            ProductLevel2 Title
    + N, _2 {4 T" O6 j0 Q  x========================================================================================================================================================
    / e( a  C$ @  n0 t+ N# _+ Y/ m2194747 ALLEGRO_EDITOR     DFM           Minimum gap DFM error within same polygon not caught
    1 @9 n/ w5 B" a- C: I4 z2233051 ALLEGRO_EDITOR     DFM           Copper Spacing: Thru via hole to Non signal shape DRC not working with BB via
    ! O; S& R+ w4 c+ d+ d; c* O' @8 m! g. a2238666 ALLEGRO_EDITOR     DFM           DFF Silkscreen constraints showing DRC even though there is no violation.
    7 _& ~( t0 b2 U' `1 m" \1938592 ALLEGRO_EDITOR     EDIT_ETCH     Not able to use AiDT option to length match the traces.4 L: O9 Q6 V1 _6 i: i6 G
    1960535 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work for buses with width larger than minimum width
    " C9 a4 J( V( d. g8 U& j; \/ _1 t3 t2036229 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work on Non-default min Width
    9 t& G1 R1 b; z+ X, j2157973 ALLEGRO_EDITOR     EDIT_ETCH     AiDT is not working due to line width constraints8 y- [, Q2 \/ n, a! [
    2175464 ALLEGRO_EDITOR     EDIT_ETCH     auto tuning in AiDT fails to tune differential pairs
    % Y: _8 G; d# q8 c$ Z2223214 ALLEGRO_EDITOR     EDIT_SHAPE    Menus for Shape Operations are missing from OrCAD menu set: U. M* n( u: Q# ?  Q& {
    2213659 ALLEGRO_EDITOR     INTERACTIV    Last placed component is unplaced in Allegro PCB Editor because cross placement is picking that component( e& Q+ A8 `, e$ E  L
    2216410 ALLEGRO_EDITOR     INTERACTIV    Issue with cross place from OrCAD Capture to PCB Editor: placed part selected
    " V9 w( _3 i* z% w* l2253831 ALLEGRO_EDITOR     INTERFACES    Release 17.2-2016, HotFix065: Some arc segments not mirrored properly on exporting PDF with Film mirrored checked' G% V  w9 r' e6 X% g3 d, _
    2254260 ALLEGRO_EDITOR     INTERFACES    Arc lines not flipping correctly in PDF in HotFix004 and HotFix005 when the film is mirrored
    & X' R7 X6 _" p1 r2226610 ALLEGRO_EDITOR     NC            Backdrill_pressfit_connector - the bottom side drill passes are not getting excluded$ t) S( O; I! P: p& }
    2228366 ALLEGRO_EDITOR     NC            Setting 'BACKDRILL_OVERRIDE' to 'TOP:TOP:BOTTOM:BOTTOM' does not work
    7 Y8 g: _- U$ }2230619 ALLEGRO_EDITOR     NC            PCB Editor stops responding when creating Layer Pairs in the Backdrill Layer Pair Initialization window.2 m, U9 t& z5 U( _' z
    2241339 ALLEGRO_EDITOR     NC            Setting 'Backdrill_Override' to 'top:top:bottom:bottom' leads to incorrect  backdrill analysis result5 `  C4 ^9 G( ^* E
    2236280 ALLEGRO_EDITOR     PAD_EDITOR    Drill tool size reverts to original value
    9 B) k/ v% ]9 D% R# f: _. z2232567 ALLEGRO_EDITOR     PLACEMENT     Place manually by library takes long time in HotFix 064( n& Z$ i" d' x5 v4 ~# M9 `' J
    2243727 ALLEGRO_EDITOR     PLACEMENT     Allegro PCB Editor crashes on Place Manual- q7 I0 F( g+ E* W# k/ c* c+ R2 o
    2246145 ALLEGRO_EDITOR     PLACEMENT     Place manually by 'library' as the source takes much longer than it used to in release 16.6./ f# u) [: h: N* U; O: V
    2215844 ALLEGRO_EDITOR     SHAPE         Route Keepout prevents correct shape update' e2 A7 v* Z1 _5 T6 _
    2234915 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes on selecting 'Trim corner' popup option in Shape Edit mode
    ) t- p+ R. E" K4 O4 B" G- H2078335 ALLEGRO_EDITOR     SKILL         Discrepancy with axlAddSelectBox() and axlSingleSelectBox() definition$ U3 [: {0 X) y3 A1 W
    2223446 ALLEGRO_EDITOR     SKILL         Casing of axlDBTextBlockFindName()
    % t$ e2 d1 [" Q& f& X: j: X  Y2231369 ALLEGRO_EDITOR     SKILL         Invalid option type warning when using "axlFilmCreate("test" ?polyCutLayer nil)"
    " T6 Q" d: E5 h! L2235666 ALLEGRO_EDITOR     UI_FORMS      Export parameters window is small and cannot be scaled up in HotFixes 003 and 004
    1 p) ^; d3 U& T  k9 J! r, R2239984 ALLEGRO_EDITOR     UI_FORMS      Callback function for form not invoked if multiple fields are selected by dragging mouse6 e; {  ?2 x- N* i9 x
    2167454 ALLEGRO_EDITOR     UI_GENERAL    Custom commands and HTML XProbe: Triggering actions from HTML files
    , V% V; Y! W! L; D" U! P2227489 ALLEGRO_EDITOR     UI_GENERAL    HTML cross probing in release 17.4 works partially
    # T5 d4 a8 T4 J/ _* [8 F& D$ D2222689 ALLEGRO_LIB_CRT    CORE          Edit External Padstack from LC
    ! z5 g- d" k& W! ^2233072 CAPTURE            CONNECTIVITY  OrCAD Capture stops responding on transferring occurrence property to instance
    , I% ]$ L  C( c2237520 CAPTURE            GENERAL       Issue with CIS toolbar translation in Japanese: Capture crashes: p* y, G; F. q
    2220792 PSPICE             PROBE         Release 17.4-2019, PSpice: Unable to read simulation messages in summary window# Q/ o: N, l5 N) Y: F) k
    2239253 PSPICE             PROBE         Message summary dialog in PSpice in release 17.4-2019 does not show message% a$ Q! s! P! ~0 D- u1 @* N4 z: P3 _' L
    2234913 PULSE              CORE          Data node crash because of going out of memory5 @) b% l- m, M" A% T  D
    2236450 PULSE              CORE          Database syntax error: server out of memory
      Z2 i: T# I3 @" F2 n2222469 PULSE              UNIFIED_SEARC OrCAD Capture Search Providers crash with specific part placement
    0 Q5 v$ t! J$ q- z( r3 b( F& t2233638 PULSE              UNIFIED_SEARC Capture crashes when trying to use Place > Search Providers. b4 s. ?2 d6 @3 V
    1913829 SPECCTRA           LICENSING     Cannot run SPECCTRA with an OrCAD PCB Expert license% x3 s& ?) [' Z  Z6 {8 V& H0 o3 e
    2212091 SPECCTRA           LICENSING     Include OrCAD PCB Router license for autorouting in OrCAD PCB Expert suite (PO9205)
    4 z9 r& @! G6 m: f# y' e( o8 Z
    推荐
    发表于 2020-11-9 22:52 | 只看该作者
    sen1233 发表于 2020-5-2 16:32
    + @& a! Y' `4 A2 @先留个记号。使用过17.4的软件总体感觉还不错,上来折腾折腾新补丁看
      m. e0 X9 l0 X0 U% E
    你好,请问一下17.4版本在哪里下的,是否有下载地址分享一下的?# p4 X" ]) x( j! b2 p- z
    * |" t  D3 \6 U! W8 m. _
    2023-8-4 15:22
    推荐
    发表于 2021-4-11 18:11 | 只看该作者
                    顶    起- [. D0 p* U$ s/ s
    发表于 2020-5-2 11:46 | 只看该作者
    更新这么快,谢谢分享!
    2025-9-25 15:26
  • 签到天数: 788 天
    [LV.10]以坛为家III
    发表于 2020-5-2 11:55 | 只看该作者
    谢谢分享!下载学习一下!. F1 z4 y( a) ]+ o" }/ i. B/ G9 Y
    2025-9-28 15:00
  • 签到天数: 701 天
    [LV.9]以坛为家II
    发表于 2020-5-2 13:05 | 只看该作者
    这个也太快了吧
    2020-2-27 15:47
  • 签到天数: 25 天
    [LV.4]偶尔看看III
    发表于 2020-5-2 13:27 | 只看该作者
    谢谢分享kkkkkkkkkkk% F) T  M4 k# o& }
    2024-2-9 15:00
  • 签到天数: 191 天
    [LV.7]常住居民III
    发表于 2020-5-2 13:29 | 只看该作者
    更新这么快,谢谢分享!
    % t! O, y! D2 {6 c, s
    发表于 2020-5-2 16:06 | 只看该作者
    谢谢分享啦
      o* k* z( d* m7 Y. L( q$ P
    13#
    发表于 2020-5-2 16:32 | 只看该作者
    先留个记号。使用过17.4的软件总体感觉还不错,上来折腾折腾新补丁看7 `+ ?' n3 t+ e" i' X, Q
    你好,请问一下17.4版本在哪里下的,是否有下载地址分享一下的?  详情 回复 发表于 2020-11-9 22:52
    16#
    发表于 2020-5-2 19:38 | 只看该作者
    好快呀,谢谢楼主分享) a- @/ S9 g! ~
    17#
    发表于 2020-5-2 20:47 | 只看该作者
    #在这里更新这么快快速回复#
    GMT+8, 2025-9-29 23:18 , Processed in 0.140625 second(s), 26 queries , Gzip On.
