Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2512R | RESISTOR_2512R_0.033 | 0.033 | IC | 4 | R177; R178; R180; R181 |
BATTERY2 | BATTERY_0_BATTERY2_CR1220 | CR1220 | IC | 1 | BT1 |
BGA84C80P9X15 | MT47H64M16HR_1_BGA84C80P9X15_MT | MT47H64M16HR | IC | 2 | U1; U2 |
BGA361C80P19X19_1600X1600X120 | DM6446_BGA361C80P19X19_1600X160 | DM6446 | IC | 1 | U3 |
BGA676C100P26X26_2700X2700X260 | XC3S1400AN_BGA676C100P26X26_270 | XC3S1400AN | IC | 1 | U22 |
BGA-63 | K9K1208/Q/D/U/0C_1_BGA-63_SAMSU | SAMSUNG K9K1208/Q/D/U/0C | IC | 1 | U4 |
C0402 | CAP NP_C0402_0.1UF | 0.1uF | IC | 121 | C2; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C24; C25; C26; C27; C28; C31; C32; C33; C34; C39; C40; C41; C50; C51; C53; C56; C57; C59; C60; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C79; C80; C83; C84; C85; C86; C87; C88; C89; C90; C91; C94; C95; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C112; C113; C114; C127; C133; C134; C136; C139; C140; C141; C142; C147; C148; C151; C152; C153; C154; C155; C156; C160; C161; C167; C168; C171; C258; C259; C344; C349; C350; C355; C358; C359; C360; C361; C364; C365; C366; C367; C368; C369; C370; C372 |
C0402 | C_C0402_NO-POP | NO-POP | IC | 1 | C23 |
C0402 | CAP NP_C0402_20PF | 20pF | IC | 6 | C29; C30; C37; C38; C42; C46 |
C0402 | CAP NP_C0402_1NF | 1nF | IC | 74 | C35; C173; C174; C175; C176; C177; C178; C179; C180; C181; C194; C195; C196; C197; C198; C199; C200; C201; C202; C215; C216; C217; C218; C219; C220; C221; C222; C223; C236; C237; C238; C239; C240; C241; C242; C243; C244; C260; C261; C262; C264; C265; C266; C267; C268; C269; C270; C271; C272; C273; C274; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313 |
C0402 | CAP NP_C0402_0.01UF | 0.01uF | IC | 7 | C49; C120; C157; C162; C166; C169; C341 |
C0402 | C_C0402_1000PF/2KV | 1000pF/2KV | IC | 1 | C58 |
C0402 | C_C0402_NON-POP | NON-POP | IC | 1 | C61 |
C0402 | CAP NP_C0402_10PF | 10pF | IC | 2 | C116; C345 |
C0402 | CAP NP_C0402_1500PF | 1500pF | IC | 4 | C118; C119; C340; C342 |
C0402 | CAP NP_C0402_33PF | 33pF | IC | 2 | C123; C354 |
C0402 | CAP NP_C0402_100PF | 100pF | IC | 2 | C128; C357 |
C0402 | CAP NP_C0402_12.5PF | 12.5pF | IC | 2 | C144; C146 |
C0402 | CAP NP_C0402_47NF | 47nF | IC | 85 | C185; C186; C187; C188; C189; C190; C191; C192; C193; C206; C207; C208; C209; C210; C211; C212; C213; C214; C227; C228; C229; C230; C231; C232; C233; C234; C235; C248; C249; C250; C251; C252; C253; C254; C255; C256; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387 |
C0603 | CAP NP_C0603_0.22UF | 0.22uF | IC | 1 | C1 |
C0603 | CAP NP_C0603_NO-POP | NO-POP | IC | 3 | C115; C121; C129 |
C0603 | CAP NP_C0603_0.47UF | 0.47uF | IC | 12 | C182; C183; C203; C204; C224; C225; C245; C246; C263; C275; C314; C315 |
C0805 | CAP POL_C0805_1UF | 1uF | IC | 7 | C3; C36; C122; C125; C164; C172; C353 |
CAPMP3216X180N | CAP POL_CAPMP3216X180N_10UF | 10uF | IC | 18 | C48; C132; C135; C137; C158; C163; C165; C170; C184; C205; C226; C247; C257; C276; C316; C347; C348; C351 |
CAPMP3528X210N | CAP POL_CAPMP3528X210N_22UF | 22uF | IC | 10 | C21; C22; C78; C81; C82; C92; C93; C96; C97; C131 |
CAPMP6032X250N | CAP POL_CAPMP6032X250N_47UF/6.3 | 47uF/6.3V | IC | 5 | C52; C54; C55; C126; C356 |
CAPMP7243X430N | CAP POL_CAPMP7243X430N_100UF/10 | 100uF/10V | IC | 10 | C111; C117; C124; C130; C138; C343; C346; C352; C362; C363 |
CAPMP7243X430N | CAPACITOR POL/SM_CAPMP7243X430N | 100uF/10V | IC | 1 | C159 |
CAPT6032N | FUSE_CAPT6032N_FUSE | FUSE | IC | 1 | F1 |
CAPT6032N | FUSEHOLDER_CAPT6032N_SMD1812P15 | SMD1812P150TF | IC | 1 | F2 |
CAP_TVS | CAP NP_CAP_TVS_1000PF/2KV | 1000pF/2KV | IC | 4 | C43; C44; C45; C47 |
CON2X100P-14 | HEADER 7X2_CON2X100P-14_HEADER | HEADER 7X2 | IC | 1 | JTAG1 |
CQFP50P900X900X160-48N | KS8721_48P_CQFP50P900X900X160-4 | KS8721BLI | IC | 1 | U6 |
CRYSTAL4115X140N | CRYSTAL_5_CRYSTAL4115X140N_32.7 | 32.768KHz | IC | 1 | Y4 |
CRYSTAL6035X140N | CRYSTAL_5_CRYSTAL6035X140N_24MH | 24MHz | IC | 1 | Y1 |
CRYSTAL6035X140N | CRYSTAL_5_CRYSTAL6035X140N_27MH | 27MHz | IC | 1 | Y2 |
CRYSTAL6035X140N | CRYSTAL_5_CRYSTAL6035X140N_25MH | 25MHz/20pF | IC | 1 | Y3 |
DBV | TPS3808G09DBVR_DBV_TPS3808G09_2 | TPS3808G09DBVR-12 | IC | 1 | U9 |
DBV | TPS3808G09DBVR_DBV_TPS3808G09DB | TPS3808G09DBVR-33 | IC | 1 | U10 |
DBV | TPS3808G09DBVR_DBV_TPS3808G09_1 | TPS3808G09DBVR-18 | IC | 1 | U12 |
DIOM5436X244N | DIODE_0_DIOM5436X244N_SS32 | SS32 | IC | 4 | D7; D8; D14; D15 |
DIOMELF3515N | DIODE_0_DIOMELF3515N_IN4148 | IN4148 | IC | 1 | D9 |
DIOMELF3515N | DIODE_0_DIOMELF3515N_ESD | ESD | IC | 3 | D10; D11; D12 |
DIOMELF5040N | DIODE_0_DIOMELF5040N_TVS | TVS | IC | 4 | D1; D2; D3; D4 |
HDR-2X5 | HEADER 5X2_HDR-2X5_HEADER 5X2 | HEADER 5X2 | IC | 1 | J19 |
HEADER9X2 | HEADER 9X2_HEADER9X2_HEADER 9X2 | HEADER 9X2 | IC | 1 | J16 |
HEADER30X2 | HEADER 30X2_HEADER30X2_HEADER 3 | HEADER 30X2 | IC | 1 | J15 |
INDC7070X200N | INDUCTOR IRON/SM_INDC7070X200N_ | 15uH | IC | 2 | L6; L15 |
INDC7070X200N | INDUCTOR IRON/SM_INDC7070X200_1 | 5uH | IC | 2 | L7; L16 |
INDC7070X200N | INDUCTOR IRON/SM_INDC7070X200_2 | 10uH | IC | 2 | L8; L17 |
JUMP2 | HEADER 2_JUMP2_HEADER 2 | HEADER 2 | IC | 1 | J6 |
JUMP4 | JUMPER2_JUMP4_JUMPER2 | JUMPER2 | IC | 1 | JP1 |
JUMPER_2X3 | JUMPER3_JUMPER_2X3_JUMPER3 | JUMPER3 | IC | 1 | J17 |
L0805 | INDUCTOR_L0805_MMZ2012S121A | MMZ2012S121A | IC | 2 | FB1; FB2 |
L0805 | INDUCTOR_L0805_BLM21PG221SN1D | BLM21PG221SN1D | IC | 4 | L1; L2; L13; L14 |
L0805 | INDUCTOR_L0805_10UH | 10uH | IC | 1 | L3 |
L0805 | INDUCTOR_L0805_BEAD(221@100MHZ) | BEAD(221@100MHz) | IC | 3 | L4; L5; L12 |
L0805 | INDUCTOR_L0805_BLM41P750SPT | BLM41P750SPT | IC | 1 | L9 |
L0805 | INDUCTOR IRON_L0805_BLM21PG221S | BLM21PG221SN1D | IC | 2 | L10; L11 |
LED0805 | LED_0_LED0805_LED_CHIP | LED_CHIP | IC | 2 | D5; D6 |
LED0805 | DIODE_0_LED0805_LED | led | IC | 1 | D13 |
MSOP8 | PCA9306DCTT_MSOP8_PCA9306DCT | PCA9306DCT | IC | 2 | U13; U19 |
MSOP8 | SN74AVC2T45DCTR_1_MSOP8_SN74LVC | SN74LVC2T45DCTR | IC | 3 | U17; U18; U29 |
N7E50-7516PG-20 | CF_CARD_1_N7E50-7516PG-20_CF_CA | CF_CARD | IC | 1 | J9 |
POWERJACK | PHONEJACK_0_POWERJACK_POWER INP | POWER INPUT | IC | 1 | J5 |
R0603 | R_R0603_47 | 47 | IC | 11 | R1; R2; R3; R6; R7; R8; R9; R10; R11; R12; R13 |
R0603 | R_R0603_000 | 0 | IC | 7 | R4; R5; R16; R129; R130; R131; R132 |
R0603 | R_R0603_200R | 200R | IC | 5 | R14; R15; R108; R110; R111 |
R0603 | R_R0603_1K | 1K | IC | 4 | R17; R18; R24; R27 |
R0603 | R_R0603_22 | 22 | IC | 10 | R19; R20; R21; R22; R23; R25; R26; R28; R29; R169 |
R0603 | R_R0603_10K | 10K | IC | 6 | R30; R31; R32; R170; R171; R172 |
R0603 | R_R0603_NO_POP | NO_POP | IC | 2 | R33; R34 |
R0603 | RESISTOR_R0603_000 | 0 | IC | 20 | R35; R75; R89; R92; R100; R121; R141; R142; R160; R161; R162; R163; R164; R165; R166; R167; R168; R175; R176; R179 |
R0603 | RESISTOR_R0603_NC | NC | IC | 4 | R36; R40; R41; R118 |
R0603 | RESISTOR_R0603_33 | 33 | IC | 7 | R37; R50; R53; R56; R57; R58; R98 |
R0603 | RESISTOR_R0603_39 | 39 | IC | 2 | R38; R39 |
R0603 | RESISTOR_R0603_49.9/1% | 49.9/1% | IC | 10 | R42; R43; R45; R46; R64; R65; R66; R67; R68; R69 |
R0603 | RESISTOR_R0603_75 | 75 | IC | 4 | R44; R47; R48; R49 |
R0603 | RESISTOR_R0603_4.7K | 4.7k | IC | 1 | R51 |
R0603 | RESISTOR_R0603_1K | 1K | IC | 17 | R52; R59; R60; R61; R62; R79; R80; R81; R82; R83; R84; R85; R86; R87; R119; R126; R134 |
R0603 | RESISTOR_R0603_6.49K/1% | 6.49K/1% | IC | 1 | R54 |
R0603 | RESISTOR_R0603_10K | 10K | IC | 18 | R55; R71; R72; R73; R74; R88; R90; R94; R95; R96; R97; R102; R103; R112; R113; R124; R133; R136 |
R0603 | RESISTOR_R0603_221 | 221 | IC | 4 | R63; R70; R77; R78 |
R0603 | RESISTOR_R0603_0.025 | 0.025 | IC | 1 | R76 |
R0603 | RESISTOR_R0603_61.9K 1% | 61.9K 1% | IC | 2 | R91; R149 |
R0603 | RESISTOR_R0603_36.5K 1% | 36.5K 1% | IC | 2 | R93; R150 |
R0603 | RESISTOR_R0603_470K 1% | 470K 1% | IC | 2 | R99; R157 |
R0603 | RESISTOR_R0603_180K 1% | 180K 1% | IC | 2 | R101; R158 |
R0603 | RESISTOR_R0603_2.2K | 2.2K | IC | 8 | R104; R105; R106; R107; R114; R115; R116; R117 |
R0603 | RESISTOR_R0603_0.22 | 0.22 | IC | 2 | R120; R123 |
R0603 | RESISTOR_R0603_100K | 100K | IC | 3 | R122; R138; R139 |
R0603 | RESISTOR_R0603_7.5K | 7.5K | IC | 1 | R125 |
R0603 | RESISTOR_R0603_4.02K | 4.02K | IC | 1 | R127 |
R0603 | RESISTOR_R0603_4.99K | 4.99K | IC | 1 | R128 |
R0603 | RESISTOR_R0603_20K | 20K | IC | 2 | R135; R137 |
R0603 | RESISTOR_R0603_NO-POP | NO-POP | IC | 1 | R140 |
R0603 | R_R0603_100 | 100 | IC | 4 | R143; R144; R145; R148 |
R0603 | R_R0603_331 | 331 | IC | 1 | R146 |
R0603 | R_R0603_NC | NC | IC | 1 | R147 |
R0603 | RESISTOR_R0603_55K 1% | 55K 1% | IC | 1 | R151 |
R0603 | RESISTOR_R0603_10K 1% | 10K 1% | IC | 1 | R152 |
R0603 | R_R0603_4.7K | 4.7K | IC | 2 | R173; R174 |
RESCAXE80P160X320X70-8N | R PART4_0_RESCAXE80P160X320X70- | 47 | IC | 13 | RN1; RN2; RN3; RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13 |
RESCAXE80P160X320X70-8N | R PART4_0_RESCAXE80P160X320X7_1 | 10 | IC | 10 | RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN23 |
RESCAXE80P160X320X70-8N | R PART4_0_RESCAXE80P160X320X7_2 | 33 | IC | 1 | RN24 |
RESCAXE80P160X320X70-8N | RESISTOR DIP 4_0_RESCAXE80P160X | 4.7K/5% 1/10W | IC | 1 | RP1 |
RESCAXE80P160X320X70-8N | RESISTOR DIP 4_RESCAXE80P160X32 | 4.7K/5% 1/10W | IC | 1 | RP2 |
RJ45-59_LED | RJHSE-5384_0_RJ45-59_LED_2-4065 | 2-406549-4 | IC | 1 | J1 |
SD-MOLEX | MMC4_1.0_CONN_SD-MOLEX_MHC-W21- | MHC-W21-601 | IC | 1 | J7 |
SIP5 | HEADER 5_SIP5_HEADER 5 | HEADER 5 | IC | 1 | J8 |
SIP6 | HEADER 6_SIP6_JTAG HEADER | JTAG HEADER | IC | 1 | J10 |
SMD_SW | SW PUSHBUTTON-DPST_SMD_SW_SW PU | SW PUSHBUTTON-DPST | IC | 1 | SW1 |
SOCKET210 | 210CONNECTOR_1_SOCKET210_210CON | 210CONNECTOR | IC | 1 | U28 |
SOIC8 | AT24C16A_3_SOIC8_AT24C16A | AT24C16A | IC | 1 | U14 |
SOIC8 | DS1338Z-33_SOIC8_DS1338Z-33 | DS1338Z-33 | IC | 1 | U16 |
SOIC8 | AT88SC0104C-SU_0_SOIC8_AT88SC01 | AT88SC0104C-SU | IC | 1 | U20 |
SOIC127P760X203-16 | MAX3232/SO_1_SOIC127P760X203-16 | MAX3232ESE | IC | 1 | U31 |
SOIC127P1600X140-24N | H5004_SOIC127P1600X140-24N_H500 | H5004 | IC | 1 | U5 |
SOP50P0-11N | TPS62040DGQ_0_SOP50P0-11N_TPS62 | TPS62040DGQ | IC | 2 | U11; U27 |
SOP50P2000X120-56N | S29GL128N11TF102_1_SOP50P2000X1 | S29GL128P11TFIV1 | IC | 1 | U7 |
SOP-DGG48 | 74LVC16T4245_SOP-DGG48_74LVC16T | 74LVC16t4245 | IC | 3 | U23; U24; U25 |
SOT23_3 | MPF6660_SOT23_3_SI2323DS | Si2323DS | IC | 4 | Q1; Q2; Q3; Q4 |
TI-QFN20 | TPS75003_TI-QFN20_TPS75003 | TPS75003 | IC | 2 | U8; U26 |
TP | T POINT R_TP_T POINT R | T POINT R | IC | 15 | TP2; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17 |
TP | TEST POINT_TP_CSO_B | CSO_B | IC | 1 | TP22 |
TP | TEST POINT_TP_INIT_B | INIT_B | IC | 1 | TP23 |
TPCW64D254H584P | T POINT R_TPCW64D254H584P_T POI | T POINT R | IC | 2 | TP1; TP3 |
USB-A | USB-3190104-09A-R_2_USB-A_USB-3 | USB-3190104-09A-R | IC | 1 | U21 |
XTALSMD | CRYSTALOSC_XTALSMD_50MHZ | 50MHz | IC | 1 | U30 |
附件:
