查看: 624|回复: 4
[allegro15.2][8层] ]经典的上网本(FPGA+网口+PCIE)pcb文件
发表于 2020-4-27 15:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  e0 c& ?! G1 P1 R* g& Y[allegro15.2][8层] ]经典的上网本(FPGA+网口+PCIE)pcb文件
8 `& z8 r# z# V" V) C
1 E& S7 K5 B& ^8 q# S文件描述:
# @: Z( L, c$ w, A
" y. R# X* K) X" k1. 作品用途:]经典的上网本+ L, @7 f) n+ H0 @3 |' X
2. 软件版本:allegro15.24 h5 j, A4 t7 W$ q& {
3. 层数:8层$ K/ h9 A8 t/ Q, H* G3 q7 h
4. 用到的主要芯片:FPGA+网口+PCIE
# }- l# S' q  @+ |( W" t, C5 p5. pcb尺寸: 5835*6021 MIL
4 L6 q7 q4 ~, u! q2 `* c  h' f; x$ t! L3 I/ s7 y9 u
作品截图如下:
1 M( }7 Z0 _; r" U4 [  \5 t9 w( k2 a( G( C* o
顶层截图:
* N! R/ g. K5 X* }9 r + y! r* [+ R, ^- j$ l* Z% m0 b' p
底层截图:
; h3 h4 r7 S2 n. V6 q5 N! L( X% U5 p' {9 S1 E( ^
7 S! O1 n6 g. r' g1 x3 |- A
全层截图:
3 n+ L3 E# U; G: s4 G* l
# {# C; W/ q* i0 ]* d
; ~3 M2 Y8 H( N' y* {' U4 zBOM:2 T+ Q* j/ B( i) _6 Z% v! D2 [; u
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
9MM9MM0.01U/3KVIC1C365
BAT_B7566BP5LBAT_B7566BP5LBATTERYIC1BAT1
BEAD0603BEAD0603LQP18MNR10G02D_100nHDISCRETE6L10; L11; L12; LB2; LB3; LB4
BEAD0805BEAD0805QT2012RL060HC3ADISCRETE1FB10
BEAD1206BEAD1206EBM321611A520DISCRETE7FB18; FB19; FB20; FB21; FB22; FB33; FB34
BEAD2012BEAD2012CB201209-600DISCRETE21FB1; FB2; FB4; FB5; FB6; FB7; FB8; FB9; FB14; FB15; FB16; FB17; FB24; FB25; FB26; FB27; FB28; FB29; FB32; L2; L4
BGA981BGA981VT3324IC1U15
C0805C08052.2uFIC2D17; D18
C1206C120610UF/16VDISCRETE1C57
CAP0603CAP060339pFDISCRETE275C5; C6; C9; C10; C11; C12; C13; C15; C16; C17; C18; C20; C21; C22; C23; C24; C28; C29; C30; C31; C32; C33; C38; C39; C41; C42; C43; C47; C48; C53; C54; C58; C59; C60; C61; C62; C64; C65; C66; C67; C69; C71; C73; C76; C77; C82; C83; C84; C85; C86; C89; C91; C92; C93; C96; C97; C98; C99; C100; C105; C106; C107; C109; C110; C111; C112; C113; C114; C120; C121; C122; C130; C131; C132; C134; C137; C138; C139; C140; C141; C142; C143; C144; C147; C148; C149; C150; C155; C157; C158; C161; C162; C163; C172; C173; C174; C175; C182; C192; C193; C194; C195; C196; C197; C198; C200; C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C218; C220; C221; C222; C223; C224; C229; C233; C241; C244; C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C257; C258; C259; C261; C262; C263; C267; C268; C269; C270; C271; C272; C274; C276; C277; C286; C288; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C359; C360; C361; C362; C363; C364; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C493; CB2; CB3; CB4; CB5; CB6; CB7; CB8; CB12; CB13; CB14; CB15; CB17; CB18; CB21; CB22; CB23; CB25; CB26; CB28; CB29; CB30; CB31; CB35; CB36; CB37; CB38; CB73; CB74; CB75; CC13; CC14; CC15
CAP0805CAP08052.2uFDISCRETE15C117; C128; C129; C133; C167; C190; CM1; CM2; CM3; CM4; CM5; CM6; CM8; CM9; CM10
CAP1206CAP12064.7uFDISCRETE40C26; C27; C34; C35; C46; C63; C108; C115; C116; C118; C135; C146; C168; C171; C177; C180; C181; C191; C199; C201; C225; CT1; CT4; CT5; CT6; CT7; CT8; CT9; CT10; CT11; CT12; CT13; CT14; CT15; CT16; CT17; CT18; CT25; CT27; CT33
CAP1210CAP121010uFDISCRETE5C52; C217; C219; C226; C227
CAP7343CAP7343330uFDISCRETE16CE11; CE12; CE13; CE14; CE17; CE19; CE20; CE21; CE22; CE25; CE26; CE27; CE29; CEB3; CEB4; CEB5
COIL_RING_M2COIL_RING_M24.7UH 6053 8T 1.0RIC2L13; L14
CON_3PINS_WOLCON_3PINS_WOLHEADER_3X1(2MM)IC1WOL1
CON_DVIACON_DVIADVIIC1P1
DDR200DDDR200DSO-DIMMIC1DIMM1
DIO_MLL_34ADIO_MLL_34A1N4148IC1D16
ECAPR25D5_SECAPR25D5_S100 UFIC3C176; C178; C179
ECAPR50D10_SECAPR50D10_S3300UF/6.3V/10x25IC1CE15
ECD-6-2_5ECD-6-2_5100UFDISCRETE4CE23; EC2; EC3; EC4
ECD-8-3_5ECD-8-3_51000UFDISCRETE6CE9; CE10; CE16; CE24; CEB2; EC1
FIDFIDFIDUCIAL MARKDISCRETE3FID1; FID2; FID3
FPE_SEAN8FPE_SEAN8FPE F0032IC1U31
FUSE1206FUSE1206FUSE_SMD1206P050TS/15DISCRETE1F1
H2X5JZH2X5JZjackIC1U44
IBM_AUDIO-9PIBM_AUDIO-9PjackIC1U34
IC100AIC100ARTL8100BIC1U29
JHS70EJHS70EPCI_CON_3IC1PCI1
L0805_SL0805_STB321611U520IC3FB36; FB37; FB38
L-8_5-1_6L-8_5-1_61.2uHIC1L8
LL34LL341N4148DISCRETE2D3; D4
LL400LL4001.2UH 3X1.0R 5T 6053IC1L3
LQFP48-19P7LQFP48-19P7ALC260IC1U23
MH30X45_1MH30X45_1IC10MH1; MH2; MH3; MH4; MH5; MH6; MH7; MH8; MH9; MH10
PCIESLOT-164PCIESLOT-1643GIO_X16DISCRETE1PCIE_1
PQFP128-19P7PQFP128-19P7W83697HFIC1U25
PWR9P2PWR9P2IC1J1
QFN40-19P7-THQFN40-19P7-THMAX1907AETLIC1U6
RES0402RES0402140_1%DISCRETE7RB11; RB12; RB13; RB14; RB15; RB16; RB17
RES0603RES0603680DISCRETE392R7; R8; R9; R10; R12; R13; R14; R15; R16; R17; R18; R21; R22; R23; R25; R26; R27; R28; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R58; R59; R60; R61; R62; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R91; R92; R93; R94; R96; R99; R100; R101; R102; R103; R104; R105; R106; R108; R109; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R124; R125; R126; R129; R130; R131; R132; R135; R136; R138; R139; R142; R150; R153; R158; R160; R162; R163; R165; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R179; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R203; R205; R206; R207; R208; R211; R212; R213; R214; R215; R216; R217; R218; R222; R223; R224; R225; R226; R227; R228; R229; R230; R235; R238; R239; R240; R241; R245; R246; R257; R258; R259; R260; R265; R266; R267; R270; R271; R272; R275; R283; R285; R286; R287; R288; R289; R290; R291; R292; R293; R294; R296; R297; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R348; R349; R350; R351; R354; R355; R356; R357; R358; R359; R362; R363; R364; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R389; R390; R391; R394; R395; R396; R397; R398; R399; R402; R403; R405; R406; R408; R409; R411; R413; R416; R417; R418; R419; R420; R421; R422; R423; R424; R425; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R462; R463; R464; R465; R466; R467; R468; R469; R470; R471; R472; R473; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R484; R485; R486; R487; R490; R491; R646; R647; R648; R649; R650; R651; R652; R653; R654; RB4; RB7; RB8; RB9; RB10
RES0805RES08051DISCRETE2R57; R90
RJ45P8_LEDRJ45P8_LEDIC1USB2
RN8P4RRN8P4R8.2KDISCRETE2RN36; RN37
RN-8P4R-19P7X50RN-8P4R-19P7X50470DISCRETE18RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN23; RN24; RN28; RN29; RN30; RN32; RN33; RN34; RN35; RN38
RN-8P4R-31P5X062RN-8P4R-31P5X0620/XDISCRETE2RN1; RN2
SIP2X8PINSIP2X8PINIDE/REDIC1IDE2
SMD_NANOC5J_400SMD_NANOC5J_400nano_C5JIC1U7
SMD_TP_1SMD_TP_1TestPointDISCRETE37GGH1; RSVD1; RSVD2; RSVD3; RSVD4; RSVD5; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP13; TP14; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; VCORE_SENSE1; VSS_SENSE1
SOD-323SOD-323RB551V-30DISCRETE1D1
SOIC8-50X204SOIC8-50X204APM9426KCIC3U10; U16; U19
SOIC8_7SOIC8_77057IC1U33
SOIC8_225_SSOIC8_225_S9173IC2U30; U32
SOIC14-50X204SOIC14-50X20474LV04DIC2U14; U24
SOT23-132SOT23-132BAW56DISCRETE5D7; D8; D9; D10; D11
SOT23-BCESOT23-BCEMMBT2222ALT1DISCRETE4Q4; Q12; Q15; Q22
SOT23-GDSSOT23-GDS2N7002DISCRETE3Q5; Q6; Q19
SOT23_BCESOT23_BCE2N3904IC8Q24; Q25; Q26; Q31; Q32; Q33; Q34; Q35
SOT23_RACSOT23_RACTL431IC1U21
SOT_223SOT_223LM1117_3V3IC2Q13; Q14
SSOP28-25P6X278SSOP28-25P6X278ICS9P935AFIC1U8
SSOP48-25X378SSOP48-25X378ICS952906FTIC1U22
S_VIDEO_9PS_VIDEO_9PKB/MOUSEIC1J7
TANCAP_ATANCAP_A14.318MHzIC4X1; X2; X4; Y1
TO252_S_GDSTO252_S_GDS85T03IC6Q7; Q8; Q9; Q10; Q27; Q28
TSOP32CFTSOP32CFN82802ABIC1U45
USB_1394-U2415BAHLUSB_1394-U2415BAHLCONN_1394+USBIO1USB1
VIA_TPBVIA_TPBTestPoint_viaDISCRETE1TP15
X4S90X40X4S90X4032.768KHzDISCRETE1X3
附件:( B+ [6 _. W8 P' \  s
PCB文件如下:
; E5 e- h# ?) P* ^1 E+ ]0 F
游客,如果您要查看本帖隐藏内容请回复
6 ?7 X9 C( x1 c, p" {1 s; A
1 ^& R$ j  g+ g1 p( [) W
发表于 2020-4-28 15:46 | 只看该作者
正在学FPGA
    奋斗
    2025-7-17 15:03
  • 签到天数: 69 天
    [LV.6]常住居民II
    发表于 2020-5-8 16:37 | 只看该作者
    正好学习一下
    发表于 2020-8-5 16:12 | 只看该作者
    学习一下
    GMT+8, 2025-7-19 22:10 , Processed in 0.156250 second(s), 27 queries , Gzip On.
