查看: 3409|回复: 3
求救orcad pspice的问题,急
发表于 2008-4-18 16:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么还会出现这种对话框啊?3 T0 T* A, E# `7 t* G- f2 ^4 y
4 H  H" H" m0 s$ k7 t
*. y, A$ ]4 X/ z& M) @+ G8 R0 x
6 q& Z* Y: _1 \! J& H$ i
$ R8 l* L4 H0 f* g( ?
3 u/ Y# z5 s1 ?. L/ h4 H1 o
' f4 m* L( F: k7 @, V
1 {% A7 B( l+ _% `*** 04/18/08 16:21:39 ************** Pspice Lite (Mar 2000) *****************
4 ^7 d' C( h8 g) h4 Y. N ** Profile: "SCHEMATIC1-SCH1"  [ D:\1\1122-SCHEMATIC1-SCH1.sim ] - E* W( V* [3 J4 _3 v" i) q% m
. i! Y. @: @6 i0 O ****     CIRCUIT DESCRIPTION: Y* ]) ]  C) ^+ _4 w( x1 {4 B9 L
) W; \$ l, l* ?8 d2 Q******************************************************************************
2 u6 ?) v$ {3 E3 R4 R8 _3 s: j8 K. {
7 U5 u2 {. c( p, `! `** Creating circuit file "1122-SCHEMATIC1-SCH1.sim.cir"
2 E; B6 Q8 y" |  P# a** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
/ i, w9 w- X/ T6 B4 t  ~7 I( [0 C*Libraries:
- I1 C7 Z; ?7 ]' [; Y1 g1 ^* Local Libraries :
# Z: V1 V4 ?3 t6 I, x* From [PSPICE NETLIST] section of C:\Program Files\orcadLite\PSpice\PSpice.ini file:
9 }/ C4 c+ D, T/ f$ i  m; j.lib "nom.lib" 9 j7 x* w. @( u, F# ?
*Analysis directives: & [; o& C. }) q1 N- ^
.OP
: \1 [% G1 e/ b/ r1 n.PROBE V(*) I(*) W(*) D(*) NOISE(*)
5 t  e5 K/ D. {+ J.INC ".\1122-SCHEMATIC1.net"
- b- {* r+ z. u& z4 x* L/ A8 G  w/ h5 m* F+ \
**** INCLUDING 1122-SCHEMATIC1.net ****/ X& @( x$ _( f0 l+ K% T1 T
* source 1122
/ I9 E# ^) I# X+ ?+ }/ VQ_Q1         N00403 N00254 N00418 Q2N2222/ m! E$ M! Z4 n  F
V_V1         N00227 0 12V
0 a& t' a1 F, Y- {1 _) N0 k! Y**** RESUMING 1122-SCHEMATIC1-SCH1.sim.cir ****. w: q* e" ?, t& [$ A$ U/ v
.END
- ~4 w! V. b  fERROR -- Less than 2 connections at node N00403" y. W7 q' F. J5 y
ERROR -- Less than 2 connections at node N00254
0 R0 l. E6 B% y  MERROR -- Less than 2 connections at node N00418  J% H, O3 @3 c8 b1 t3 h$ g
ERROR -- Node N00403 is floating
! |: ~% C: \- |8 W" ]( m& QERROR -- Node N00254 is floating
8 u# o- s$ K8 t& Y) q4 ^( F9 o+ aERROR -- Node N00418 is floating
8 X) u3 K) B) F+ a2 M( _
/ i" d: M. D* A. _9 v9 v0 K" R
0 e) p3 R# |* E, V: |请问一下,这是什么错误啊?
发表于 2008-4-18 20:56 | 只看该作者
就是你原理图里有此net没有连接(元件的脚有未连接)。1 N0 _$ U# Y: z' [* @
你可以参考下图,用tool->design rules check,可以检查出哪此net没有连接。
发表于 2008-6-25 22:00 | 只看该作者
orCAD里面经常有这个情况发生,我的方法是将那个有问题的地方 rework, 不知道哪位高手有更好的方法!
发表于 2008-8-19 10:44 | 只看该作者
我觉得有两点啦。! |# ^' J  {5 i; E# q3 y' ~( i, |! d! W! f" @
1. 一个是net 连接问题 Less than 2 connections
3 D; L5 X; e' ]$ A* P, _$ w9 ]  |4 R
2.肯定有"地"是连接不可靠 Node N00418 is floating PSPICE里电容和电感直接接地是不允许的。2 `; M3 F6 _% U- X8 l& \  I
9 t' G0 r  U5 a4 a8 w  D! W
搂住可以把图全部发上来看看
GMT+8, 2025-9-30 09:23 , Processed in 0.140625 second(s), 27 queries , Gzip On.
