Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1P8X3P5 | CRYSTAL_1P8X3P5_0.9 MM_230-3002 | 32.768KHZ | IC | 2 | QZ1; QZ2 |
7X5MM | OSC4_SM_7X5MM_IC_1.9 MM_230-300 | 50MHz | IC | 1 | Y3 |
BGA206_0P8_13X13 | MC34708_PWRMGT_BGA_206P_BGA206_ | MC34708 | IC | 1 | U3 |
BGA400_8MM | MCIMX50CEC_MPBGA400_BGA400_8MM_ | MCIMX508 | IC | 1 | U6 |
CASE1206A-03 | NTHS2101P_8P_CASE1206A-03_IC_1. | NTHS2101P | IC | 1 | Q5 |
CASE_P | CAP_POL_CASE_P_DISCRETE_1.2MM_1 | 47uF | DISCRETE | 1 | C189 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33 M_1 | 0.01UF | DISCRETE | 28 | C11; C12; C44; C67; C72; C81; C88; C106; C107; C115; C116; C122; C127; C152; C154; C156; C180; C181; C182; C183; C201; C247; C248; C251; C252; C271; C276; C285 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | DISCRETE | 101 | C22; C23; C24; C25; C26; C27; C28; C36; C37; C40; C47; C48; C54; C55; C56; C58; C60; C63; C68; C74; C75; C76; C84; C91; C92; C93; C94; C96; C97; C110; C111; C112; C113; C114; C118; C119; C120; C121; C124; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C142; C145; C146; C147; C148; C149; C155; C159; C160; C166; C167; C168; C170; C172; C173; C174; C175; C177; C178; C188; C193; C203; C204; C210; C211; C215; C216; C221; C223; C227; C231; C232; C235; C236; C237; C238; C239; C240; C241; C242; C243; C249; C255; C257; C267; C270; C274; C279; C288 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33 M_2 | 15pF | DISCRETE | 4 | C61; C62; C143; C144 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33 MM_ | 0.22UF | DISCRETE | 28 | C64; C65; C66; C70; C71; C77; C78; C79; C80; C85; C86; C87; C98; C99; C100; C101; C102; C103; C104; C105; C151; C153; C260; C261; C263; C272; C282; C289 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 20PF | DISCRETE | 4 | C6; C190; C191; C192 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.59M | 18PF | DISCRETE | 2 | C140; C141 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 10PF | DISCRETE | 4 | C205; C206; C207; C208 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56 | 27 PF | DISCRETE | 2 | C213; C214 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 1000PF | DISCRETE | 1 | C290 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.95MM_1 | 10UF | DISCRETE | 26 | C5; C7; C9; C10; C14; C21; C29; C34; C35; C73; C82; C108; C109; C117; C123; C157; C176; C179; C194; C198; C202; C222; C244; C245; C246; C250 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.95MM_2 | 100 PF | DISCRETE | 2 | C233; C234 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 4.7uF | DISCRETE | 9 | C13; C15; C16; C17; C18; C19; C20; C197; C200 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2UF | DISCRETE | 10 | C32; C50; C51; C52; C53; C57; C59; C158; C212; C224 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.84M | 1uF | DISCRETE | 11 | C41; C42; C43; C49; C161; C169; C171; C195; C219; C226; C228 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.022UF | DISCRETE | 1 | C209 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 0.47UF | DISCRETE | 4 | C217; C218; C220; C225 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95M | 10UF | DISCRETE | 3 | C273; C281; C284 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 22UF | DISCRETE | 14 | C2; C3; C30; C31; C33; C38; C39; C45; C46; C69; C83; C89; C90; C125 |
CC0805_NFM21P | EMIFILTER_NFM21P_CC0805_NFM21P_ | NFM21PC104R1E3D | DISCRETE | 1 | FL1 |
CC1206 | CAP_NP_CC1206_DISCRETE_1.63MM_1 | 1000PF | DISCRETE | 1 | C150 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.42 MM_ | 47uF | DISCRETE | 1 | C4 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.7MM_15 | 10uF | DISCRETE | 1 | C8 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.2MM_15 | 68uF | DISCRETE | 1 | C95 |
CC3216_10 | CAP_POL_CC3216_10_DISCRETE_1.2M | 220UF | DISCRETE | 2 | C229; C230 |
CC6032 | CAP_POL_CC6032_DISCRETE_2.8 MM_ | 100UF | DISCRETE | 4 | C184; C185; C186; C187 |
CC7343A | MOT_TCAP_CC7343A_3.0MM_150-7530 | 120UF | IC | 2 | C196; C199 |
CON5_AUD_JACK_RA_TH_SJ-43515TS | SJ-43515TS_CON5_AUD_JACK_RA_TH_ | AUD_5 | IO | 1 | JK1 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J9 |
CON19_SDCARD_28X16_SM | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | IO | 2 | P1; P2 |
CON_2X26_0P8_SMT | MINI_PCI_LATCH_52P_CON_2X26_0P8 | CON 2X26 MINI PCI EXPRESS | IO | 1 | J8 |
CON_4M_1MM_SM_RA | SM04B_CON_4M_1MM_SM_RA_IO_2.95M | SM04B-SRSS-TB | IO | 1 | CN1 |
CON_120S_QSH_SM_05PITCH | QSH060_CON_120S_QSH_SM_05PITCH_ | QSH-060-01-L-D-A | IO | 2 | J12; J13 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9 | IO | 1 | J83 |
CON_HDMI_19F_20_SM_RA | CONN_HDMI_19P_TYPE_A_CON_HDMI_1 | 10029449-001RLF | IC | 1 | J14 |
CON_PH_2M_78_TH | HDR_1X2_M_CON_PH_2M_78_TH_IO_6. | B2B-PH-K-S | IO | 1 | J1 |
CON_SIM_CD_2P54MM | SF7W006S1A_CON_SIM_CD_2P54MM_IO | CON 6 SIM CARD | IO | 1 | CON1 |
DFN_8_0P5_3X3 | RT8011A_16_2_DFN_8_0P5_3X3_0.8M | RT8011A | IC | 1 | U30 |
DIP-SMT2 | SW_DIP-2_DIP-SMT2_IC_4.83 MM_51 | SW_DIP-2/SM | IC | 1 | S1 |
DO_TSLP2 | DIODE_SCHOTTKY_DO_TSLP2_0.4MM_4 | BAS3010S | IC | 2 | D14; D15 |
DO_VMN2 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | IC | 1 | D12 |
FBGA168_0P5_12X12MM | EDB4032B1PB_FBGA168_0P5_12X12MM | EDB4032B1PB-8D-F | IC | 1 | U26 |
FBGA169_0P5_14X18 | SANDISK_FBGA169_0P5_14X18_IC_1. | KLM4G1EEHM | IC | 1 | S2 |
HDR101 | CONN_HDR_1X1_HDR101_8.38 MM_210 | HDR_1X1 | IC | 7 | TP1; TP6; TP7; TP11; TP17; TP25; TP26 |
HDR102 | HDR_SHRD_2X1_HDR102_IO_9.45MM_2 | HDR 1X2 | IO | 2 | J84; J85 |
HDR102 | CONN_HDR_2X1_HDR102_8.58MM_210- | HDR 1X2 | IC | 5 | JP1; JP2; JP3; JP4; JP5 |
HDR103 | CONN_HDR_3X1_HDR103_8.586 MM_21 | HDR_1X3 | IC | 4 | J3; J4; J5; J15 |
HDR103_49MIL | CONN_HDR_3X1_HDR103_49MIL_4.2MM | CON_1X3 | IC | 1 | J2 |
HDR210_TST_RA | TSW-110-05-G-D_HDR210_TST_RA_IO | TST-110-05-T-D-RA | IO | 1 | J7 |
IND_0603 | BLM18R_IND_0603_DISCRETE_0.95MM | 75 OHM@100MHZ | DISCRETE | 3 | FB1; FB2; FB3 |
IND_0603 | BLM18R_IND_0603_DISCRETE_0.65MM | 120 OHM@100MHZ | DISCRETE | 5 | L12; L14; L15; L16; L21 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0.95 | 2.5K | DISCRETE | 4 | L17; L18; L19; L20 |
IND_0804_8P | IND_8P_IND_0804_8P_DISCRETE_0.6 | 90 OHM@100MHZ | DISCRETE | 1 | L11 |
IND_1210 | INDUCTOR_IND_1210_DISCRETE_1.7M | BRL3225 | DISCRETE | 6 | L3; L4; L5; L6; L7; L8 |
IND_2220 | INDUCTOR_A_IND_2220_DISCRETE_5. | LQH55DN2R2M03L | DISCRETE | 1 | L2 |
IND_DLW5BS_2020 | DLW43_IND_DLW5BS_2020_DISCRETE_ | DLW5BTN142SQ2L | DISCRETE | 1 | L1 |
IND_NR4018_4X4 | INDUCTOR_IND_NR4018_4X4_DISCRET | 2.2uH | DISCRETE | 1 | L13 |
IND_VLF4012 | IND_IND_VLF4012_DISCRETE_1.2MM_ | 2.2UH | DISCRETE | 2 | L9; L10 |
LED2_2P1X1P5 | LED_LED2_2P1X1P5_IC_1.4MM_370-7 | RED | IC | 1 | D1 |
LED1206 | LED_LED1206_IC_1.2MM_370-76404_ | RED | IC | 1 | D4 |
LED1206 | LED_LED1206_IC_1.2MM_370-76344_ | GREEN | IC | 3 | D5; LED1; LED2 |
LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | IC | 1 | D7 |
MIC_WM-63PR | MIC_MIC_WM-63PR_1.4MM_510-75938 | MIC | IC | 1 | P3 |
MLP6_2X2MM_SLUG | FDMA510PZ_MLP6_2X2MM_SLUG_0.8MM | FDMA510PZ | IC | 2 | Q6; Q7 |
PJ-202B | DC POWER JACK_PJ-202B_IO_11MM_2 | CON_1_PWR | IO | 1 | J6 |
QFN24_4X4MM_SLUG | LAN8720A-QFN24_QFN24_4X4MM_SLUG | LAN8720A | IC | 1 | U15 |
QFN24_4X4MM_SLUG | MAX9701_25P_QFN24_4X4MM_SLUG_IC | MAX9701 | IC | 1 | U17 |
QFN32 | SGTL5000_QFN32_IC_0.9MM_315-779 | SGTL5000 32QFN | IC | 1 | U16 |
QFN72_0P5_10X10_4P85SQ | SII9024ACNU_QFN72_0P5_10X10_4P8 | SiI9024ACNU | IC | 1 | U7 |
RC0402_25 | RES_RC0402_25_0.40 MM_470-30862 | 1.8K | IC | 1 | R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 100K | DISCRETE | 9 | R10; R12; R43; R44; R80; R112; R118; R160; R398 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 10K | DISCRETE | 119 | R13; R53; R66; R79; R81; R90; R102; R119; R121; R122; R123; R124; R125; R126; R128; R131; R132; R133; R134; R137; R138; R141; R143; R145; R147; R149; R150; R151; R153; R155; R157; R159; R161; R163; R165; R167; R169; R172; R174; R177; R179; R181; R184; R186; R189; R191; R193; R212; R213; R214; R215; R216; R217; R218; R219; R229; R230; R231; R233; R234; R235; R236; R237; R238; R239; R241; R242; R243; R244; R245; R246; R247; R248; R252; R253; R254; R255; R256; R257; R259; R260; R261; R263; R264; R268; R269; R270; R271; R273; R274; R275; R278; R279; R281; R282; R284; R286; R288; R312; R313; R314; R315; R316; R317; R318; R319; R322; R328; R330; R340; R376; R377; R382; R395; R399; R413; R454; R455; R498 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 2.2K | DISCRETE | 5 | R17; R329; R334; R417; R418 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 1.0K | DISCRETE | 4 | R25; R26; R198; R200 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_5 | 22K | DISCRETE | 1 | R42 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | DISCRETE | 34 | R54; R105; R106; R107; R108; R178; R180; R182; R185; R187; R190; R192; R194; R265; R294; R406; R407; R408; R409; R410; R482; R483; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R494; R495 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 68K | DISCRETE | 7 | R68; R69; R276; R277; R333; R342; R396 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 100 | DISCRETE | 4 | R127; R293; R338; R339 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 1K | DISCRETE | 3 | R129; R135; R136 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_1 | 1.0M | DISCRETE | 3 | R130; R320; R480 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_2 | 330 | DISCRETE | 4 | R142; R290; R299; R393 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 240 | DISCRETE | 3 | R195; R196; R470 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_3 | 22K | DISCRETE | 3 | R225; R258; R272 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_5 | 33 | DISCRETE | 31 | R228; R386; R387; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_2 | 470 | DISCRETE | 4 | R283; R285; R287; R291 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_3 | 1.5K | DISCRETE | 2 | R308; R309 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 12.1K | DISCRETE | 1 | R323 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | 47K | DISCRETE | 2 | R411; R458 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_4 | 4.3K | DISCRETE | 1 | R415 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3095 | 13K | DISCRETE | 1 | R474 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_6 | 150K | DISCRETE | 1 | R481 |
RC0603 | RES_RC0603_DISCRETE_470-75534_2 | 294K | DISCRETE | 1 | R2 |
RC0603 | RES_RC0603_DISCRETE_470-75424_1 | 100K | DISCRETE | 1 | R3 |
RC0603 | RES_RC0603_DISCRETE_0.55MM_47_2 | 42.2K | DISCRETE | 1 | R4 |
RC0603 | RES_RC0603_DISCRETE_0.55MM_47_3 | 17.4K | DISCRETE | 1 | R7 |
RC0603 | RES_RC0603_DISCRETE_0.55MM_470- | 0.1 | DISCRETE | 2 | R14; R15 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_1 | 470K | DISCRETE | 1 | R16 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_470 | 6.04K | DISCRETE | 2 | R111; R117 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_2 | 49.9 | DISCRETE | 4 | R303; R304; R305; R306 |
RC0603 | RES_RC0603_DISCRETE_0.55MM_47_1 | 270 | DISCRETE | 2 | R310; R311 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_3 | 1 | DISCRETE | 1 | R467 |
RC0603 | RES_RC0603_DISCRETE_470-75536_3 | 332K | DISCRETE | 1 | R475 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 0 | DISCRETE | 218 | R1; R8; R18; R19; R20; R21; R22; R23; R27; R28; R29; R30; R31; R32; R34; R35; R36; R37; R38; R39; R40; R41; R45; R46; R48; R49; R50; R51; R52; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R67; R70; R71; R72; R73; R74; R75; R76; R77; R78; R82; R83; R84; R85; R86; R87; R88; R89; R92; R93; R95; R98; R99; R100; R101; R103; R104; R109; R110; R113; R114; R115; R116; R120; R139; R140; R144; R146; R148; R152; R154; R156; R158; R171; R176; R183; R188; R197; R199; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R220; R221; R222; R223; R224; R226; R227; R232; R240; R249; R250; R251; R262; R266; R267; R280; R289; R292; R295; R296; R297; R298; R300; R301; R302; R307; R321; R324; R325; R326; R327; R331; R332; R335; R336; R337; R341; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R370; R371; R372; R373; R374; R375; R378; R379; R380; R381; R383; R384; R385; R388; R389; R390; R391; R392; R397; R400; R401; R402; R403; R404; R405; R412; R414; R416; R419; R420; R421; R422; R423; R424; R425; R456; R457; R459; R460; R461; R462; R463; R464; R465; R466; R468; R469; R471; R472; R473; R476; R477; R478; R479; R496; R497; R499 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7578 | 200K | DISCRETE | 1 | R47 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_4 | 2.7K | DISCRETE | 1 | R11 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_1 | 0.02 | DISCRETE | 4 | R24; R367; R369; R394 |
RC1206_OV | RES_RC1206_OV_DISCRETE_0.8MM_47 | 0.001 | DISCRETE | 6 | R33; R91; R94; R96; R97; R368 |
RJ45_8_MAGJACK_TH | RJ45_MAG_LED_SI-50170-F_RJ45_8_ | RJ45 8 | IO | 1 | J11 |
SC70-5_A | 1G125_SC70-5_A_IC_1.1MM_312-301 | NC7SP125P5X | IC | 2 | U5; U20 |
SC70_3 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | IC | 1 | Q3 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_0.1 | 0 | DISCRETE | 28 | SH1; SH8; SH10; SH12; SH14; SH19; SH20; SH21; SH22; SH23; SH24; SH28; SH29; SH30; SH31; SH32; SH35; SH36; SH37; SH40; SH42; SH43; SH44; SH45; SH46; SH47; SH48; SH53 |
SKT_BATT_4X8 | BATTERY_SKT_3V_SKT_BATT_4X8_1.7 | 2994TR | IC | 1 | BT1 |
SLP1616P6 | RCCLAMP_SLP1616P6_IC_0.65MM_312 | RCLAMP0504P.TCT | IC | 2 | U13; U14 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 1 | U12 |
SO8WST | M25P32_SO8WST_IC_2.5MM_334-7733 | M25P32-VMW6TG | IC | 1 | U21 |
SO8_PAK | FDMS6681Z_SO8_PAK_IC_1.10MM_480 | FDMS6681Z | IC | 1 | Q2 |
SOD123 | DIODE_ZENER21_SOD123_IC_1.35MM_ | MMSZ5231BT1G | IC | 1 | D2 |
SOD123 | DIODE_SCHTKY_SOD123_IC_1.0MM_48 | MBR120LSFT1G | IC | 1 | D6 |
SOD-923 | DIODE_TVS_SOD-923_IC_0.40MM_480 | ESD9L5.0ST5G | IC | 3 | D3; D8; D9 |
SOD-923 | DIODE_TVS_BIDIR_SOD-923_IC_0.4M | ESD9B3.3ST5G | IC | 2 | D10; D11 |
SOT23 | DUALDIODE_CA_SOT23_SOT23_IC_1.1 | BAT54A-7-F | IC | 1 | D13 |
SOT23 | NPN_SOT23_IC_1.12MM_480-75757_M | MMBT3904 | IC | 4 | Q14; Q17; Q22; Q24 |
SOT363 | PNP_DUAL_SOT363_IC_1.1MM_480-77 | MBT3906DW1T1 | IC | 2 | Q4; Q16 |
SOT-23 | MOSFET_P_SOT-23_IC_1.12MM_480-7 | IRLML6401 | IC | 2 | Q13; Q19 |
SOT-23 | MOSFET_N_SOT-23_IC_1.12MM_480-7 | SI2312BDS | IC | 1 | Q23 |
SOT-563 | PNP_1_SOT-563_IC_0.60MM_480-766 | NSS12100XV6T1G | IC | 3 | Q8; Q9; Q10 |
SPACER_150T | SPACER_SPACER_150T_IC_16.13MM_2 | .635" LONG | IC | 4 | H1; H2; H3; H4 |
SW3_SLIDE_TH | SW3_SPDT_SLIDE_SW3_SLIDE_TH_IC_ | SPDT_PWR_SWITCH | IC | 1 | SW14 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_IC | SPST PB | IC | 10 | SW1; SW2; SW6; SW7; SW8; SW9; SW10; SW11; SW12; SW13 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_IC_2. | SW DIP-8 | IC | 3 | SW3; SW4; SW5 |
TESTPOINT_39MIL | TEST PAD_TESTPOINT_39MIL_DISCRE | 1 mm | DISCRETE | 26 | TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP52; TP54 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IC_4.8 MM_21 | TEST POINT WHITE | IC | 4 | TP12; TP13; TP14; TP15 |
TO-263-5 | TPS786XX_5P_TO-263-5_IC_190MIL_ | TPS78601 | IC | 1 | U2 |
TPAD_020 | TESTLOOP_TPAD_020_IO_0.1MM_211- | TPAD_020 | IO | 9 | TP51; TP53; TP55; TP56; TP60; TP61; TP62; TP63; TP64 |
TQFN12_0P4_2P3X1P7MM | PI3USB10MZK_TQFN12_0P4_2P3X1P7M | PI3USB10MZKE | IC | 1 | U31 |
TSOP48_SKT | NANDFLASHSOCKET_TSOP48_SKT_5.33 | 980020-48-P2 | IC | 1 | U9 |
TSSOP8 | AT24CXX_TSSOP8_IC_1.2MM_334-760 | AT24C512B-TH-B | IC | 1 | U11 |
TSSOP16 | IDT74CBTLV3257Q_TSSOP16_IC_1.2M | IDT74CBTLV3257PGG | IC | 2 | U18; U19 |
TSSOP20 | MAX3222_TSSOP20_IC_1.2MM_312-79 | MAX3222 | IC | 1 | U8 |
TSSOP20 | 74-244_20P_TSSOP20_IC_1.1MM_312 | 74LVT244APW | IC | 2 | U28; U29 |
ULLGA6_1P45X1_0P5MM | NLSV1T34_ULLGA6_1P45X1_0P5MM_IC | NLSV1T34 | IC | 1 | U4 |
USB_A | USB_A_USB_A_IO_7.01MM_210-30008 | USB_TYPE_A | IO | 1 | J10 |
XTL4_2P5X2MM_SM | O4-0_XTL4_2P5X2MM_SM_IC_0.9MM_2 | 22.5792MHZ | IC | 1 | Y1 |
XTLOSC4_3P2X2P5MM_SM | CRYSTAL_JXS63_XTLOSC4_3P2X2P5MM | 24MHZ | IC | 1 | Y2 |
XTLOSC4_CB3_SM | OSC3_XTLOSC4_CB3_SM_1.8MM_230-7 | 12.288MHz | IC | 1 | Y5 |
XTLOSC4_JXS75_SM | XTAL_13Y_A_XTLOSC4_JXS75_SM_1.0 | 25MHZ | IC | 1 | Y4 |
附件:
