Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2X6MMG | CRYSTAL_4_2X6MMG_26MHZ | 26MHz | IC | 1 | Y1 |
54BALL_FBGA_0_8MM | SDRAM1X16_0_54BALL_FBGA_0_8MM_H | H55S2562JFR-60M | IC | 1 | U6 |
0402C | 0402C_0402C_105 | 105 | IC | 5 | C1; C6; C7; C9; C10 |
0402C | 0402C_0402C_104 | 104 | IC | 33 | C2; C3; C8; C11; C17; C25; C26; C29; C32; C33; C35; C36; C37; C38; C39; C42; C45; C57; C60; C94; C95; C96; C97; C99; C100; C101; C102; C103; C105; C106; C107; C108; C109 |
0402C | 0402C_0402C_22P | 22P | IC | 2 | C4; C5 |
0402C | 0402C_0402C_101 | 101 | IC | 4 | C12; C13; C24; C43 |
0402C | 0402C_0402C_223 | 223 | IC | 1 | C15 |
0402C | 0402C_0402C_474 | 474 | IC | 3 | C27; C28; C31 |
0402C | CAP NP_0402C_103 | 103 | IC | 3 | C41; C63; C72 |
0402C | CAP NP_0402C_104 | 104 | IC | 5 | C47; C50; C52; C55; C61 |
0402C | 0402C_0402C_103 | 103 | IC | 1 | C49 |
0402C | CAP NP_0402C_100P | 100P | IC | 1 | C53 |
0402C | CAP NP_0402C_105 | 105 | IC | 1 | C66 |
0402C | CAP NP_0402C_33PF | 33pF | IC | 1 | C73 |
0402C | CAP NP_0402C_NC | NC | IC | 2 | C74; C75 |
0402C | CAP NP_1_0402C_27NH | 27nH | IC | 1 | C79 |
0402C | CAP NP_1_0402C_2.7P | 2.7P | IC | 1 | C80 |
0402C | CAP NP_2_0402C_104 | 104 | IC | 3 | C81; C85; C88 |
0402C | CAP NP_1_0402C_12NH | 12nH | IC | 1 | C82 |
0402C | CAP NP_3_0402C_104 | 104 | IC | 1 | C83 |
0402C | CAP NP_2_0402C_22P | 22p | IC | 1 | C86 |
0402C | CAP NP_1_0402C_103 | 103 | IC | 3 | C91; C112; C113 |
0402C | 0402C_0402C_18P | 18P | IC | 2 | C92; C93 |
0402C | CAP NP_5_0402C_104 | 104 | IC | 1 | C98 |
0402C | CAP NP_4_0402C_104 | 104 | IC | 1 | C104 |
0402C | CAP NP_0402C_101 | 101 | IC | 1 | C111 |
0402ESD_N | DIODE BI-DIR TRIG_0402ESD_N_ESD | ESD | IC | 3 | ED1; ED2; ED3 |
0402R | D1S297_0_0402R_ESD | ESD | IC | 4 | D7; D8; D9; D10 |
0402R | 0402R_0402R_10K | 10K | IC | 9 | R1; R2; R7; R8; R16; R18; R38; R39; R94 |
0402R | 0402R_0402R_4.7K | 4.7K | IC | 9 | R3; R21; R22; R23; R24; R25; R26; R27; R28 |
0402R | 0402R_0402R_10R | 10R | IC | 3 | R4; R14; R15 |
0402R | 0402R_0402R_1K | 1K | IC | 2 | R5; R6 |
0402R | 0402R_0402R_3.3K | 3.3K | IC | 1 | R9 |
0402R | 0402R_0402R_2.2K | 2.2K | IC | 2 | R10; R11 |
0402R | 0402R_0402R_470R | 470R | IC | 2 | R12; R13 |
0402R | 0402R_0402R_47K | 47K | IC | 1 | R17 |
0402R | 0402R_0402R_20K | 20K | IC | 2 | R19; R20 |
0402R | 0402R_0402R_100R | 100R | IC | 5 | R29; R30; R31; R32; R33 |
0402R | 0402R_0402R_4R7 | 4R7 | IC | 1 | R34 |
0402R | RESISTOR_0402R_200K%1 | 200K%1 | IC | 2 | R35; R36 |
0402R | 0402R_0402R_120K/1% | 120K/1% | IC | 1 | R37 |
0402R | 0402R_0402R_27K/1% | 27K/1% | IC | 1 | R40 |
0402R | RESISTOR_0402R_220K/1% | 220K/1% | IC | 1 | R41 |
0402R | RESISTOR_0402R_200K/1% | 200K/1% | IC | 1 | R43 |
0402R | SMALL R1_0402R_200K | 200K | IC | 1 | R44 |
0402R | RESISTOR_0402R_10K | 10K | IC | 9 | R45; R78; R79; R80; R85; R95; R96; R97; R98 |
0402R | RESISTOR_0402R_1M | 1M | IC | 1 | R46 |
0402R | RESISTOR_0402R_27K | 27K | IC | 1 | R47 |
0402R | RESISTOR_5_0402R_33R | 33R | IC | 1 | R48 |
0402R | RESISTOR_0402R_4.7K | 4.7K | IC | 1 | R49 |
0402R | RESISTOR_0402R_330K | 330K | IC | 2 | R50; R51 |
0402R | RESISTOR_0402R_82K | 82K | IC | 1 | R52 |
0402R | RESISTOR_0402R_15R | 15R | IC | 1 | R53 |
0402R | RESISTOR_0402R_0R | 0R | IC | 9 | R54; R81; R82; R90; R100; R101; R102; R103; R104 |
0402R | RESISTOR_0402R_100R | 100R | IC | 9 | R55; R57; R59; R60; R61; R62; R63; R65; R66 |
0402R | RESISTOR_5_0402R_10K | 10K | IC | 4 | R56; R67; R68; R91 |
0402R | RESISTOR_5_0402R_220K | 220K | IC | 2 | R58; R92 |
0402R | RESISTOR_5_0402R_1M | 1M | IC | 2 | R64; R93 |
0402R | RESISTOR_5_0402R_0R | 0R | IC | 1 | R69 |
0402R | RESISTOR_5_0402R_NC | NC | IC | 1 | R70 |
0402R | RESISTOR_8_0402R_200K/1% | 200K/1% | IC | 1 | R71 |
0402R | RESISTOR_8_0402R_100K/1% | 100K/1% | IC | 1 | R72 |
0402R | RESISTOR_6_0402R_4.7K | 4.7K | IC | 2 | R73; R74 |
0402R | RESISTOR_5_0402R_4K7 | 4K7 | IC | 1 | R75 |
0402R | R_2_0402R_47K | 47K | IC | 1 | R76 |
0402R | RESISTOR_5_0402R_220R | 220R | IC | 1 | R77 |
0402R | RESISTOR_0402R_44.2R | 44.2R | IC | 1 | R83 |
0402R | RESISTOR_0402R_NC | NC | IC | 6 | R84; R89; R105; R106; R107; R108 |
0402R | 0402R_0402R_1M | 1M | IC | 1 | R86 |
0402R | RESISTOR_5_0402R_4.7K | 4.7K | IC | 2 | R87; R88 |
0402R | RESISTOR_0402R_10R | 10R | IC | 1 | R99 |
0603R | INDUCTOR_0603R_600R/100MHZ | 600R/100MHZ | IC | 8 | L1; L2; L5; L6; L7; L8; L9; L10 |
0603R | INDUCTOR_0603R_10UH | 10uH | IC | 2 | L3; L11 |
0603R | INDUCTOR_0603R_100NH | 100nH | IC | 1 | L4 |
0603R | INDUCTOR_0603R_0R | 0R | IC | 8 | L13; L14; L16; L18; L20; L24; L25; L26 |
0603R | INDUCTOR_0603R_NC | NC | IC | 1 | L17 |
0603R | INDUCTOR FERRITE_0603R_BLM15BB2 | BLM15BB221SN1 | IC | 2 | L21; L22 |
0603R | 0603R_0603R_0R | 0R | IC | 1 | R42 |
0805C | 0805C_0805C_106 | 106 | IC | 8 | C14; C16; C18; C23; C30; C34; C58; C59 |
0805C | 0805C_0805C_475 | 475 | IC | 4 | C19; C20; C21; C22 |
0805C | CAP NP_0805C_106 | 106 | IC | 8 | C40; C48; C51; C56; C76; C77; C78; C110 |
0805C | 0805C_0805C_226 | 226 | IC | 2 | C44; C46 |
0805C | CAP NP_0805C_226 | 226 | IC | 1 | C54 |
0805C | CAP NP_0805C_226/16V | 226/16V | IC | 1 | C62 |
0805C | SMALL CAP_0805C_106 | 106 | IC | 7 | C64; C65; C67; C68; C69; C70; C71 |
0805C | CAPACITOR POL_1_0805C_106 | 106 | IC | 2 | C84; C87 |
0805C | CAPACITOR POL_0_0805C_106 | 106 | IC | 2 | C89; C90 |
0805C | CAPACITOR POL_0805C_22UF | 22uF | IC | 2 | EC3; EC4 |
0805C | CAP NP_0805C_105/40V | 105/40V | IC | 1 | EC6 |
0805R | INDUCTOR_0805R_100M/600R | 100M/600R | IC | 1 | L19 |
3528E | CAPACITOR POL_2_3528E_220UF | 220uF | IC | 2 | EC1; EC2 |
ANT_RFJACK | BNC_1_ANT_RFJACK_CON5 | CON5 | IC | 2 | J3; J4 |
BAT_4 | BATTERY_0_BAT_4_LI_3.7V | LI_3.7V | IC | 1 | BT1 |
BGA265_RK2728 | 2728_0_BGA265_RK2728_RK2728 | RK2728 | IC | 1 | U18 |
BTB10P_0R5 | LCM0200CE1A0_1_BTB10P_0R5_3PIN- | 3PIN-S2.54 | IC | 3 | J2; J5; J6 |
BTB_80X05_SOC_12 | 80PIN-05_0_BTB_80X05_SOC_12_80P | 80PIN | IC | 1 | J7 |
BTB_AXT44012 | LPJ028P001A_0_BTB_AXT44012_LPJ0 | LPJ028P001A | IC | 1 | U19 |
CMMB_MODULE | CMMB_MODULE_0_CMMB_MODULE_CMMB_ | CMMB_MODULE | IC | 1 | U14 |
CRY3225 | CRYSTAL-2PIN_0_CRY3225_24M | 24M | IC | 1 | Y2 |
D1206 | DIODE_0_D1206_SSA23 | SSA23 | IC | 2 | D1; D2 |
D1206 | DIODE_0_D1206_1N4148 | 1N4148 | IC | 2 | D3; D6 |
D1206 | DIODE_D1206_1N5819 | 1N5819 | IC | 1 | D5 |
E0805 | CAPACITOR POL_E0805_106 | 106 | IC | 1 | EC5 |
FPC24PIN_0R5MMA | ZT3001B1_FPC24PIN_0R5MMA_ZT3001 | ZT3001B1 | IC | 1 | U12 |
IN1900DT | USB CONNECTOR_1_IN1900DT_IN1900 | IN1900DT | IC | 1 | U15 |
IND_PB27 | INDUCTOR_IND_PB27_4.7UH | 4.7uH | IC | 2 | L12; L15 |
IND_PB27 | INDUCTOR_IND_PB27_22UH | 22uH | IC | 1 | L23 |
IND_PB27 | INDUCTOR_3_IND_PB27_4.7UH | 4.7uH | IC | 1 | L27 |
MIC_D4 | MIC_MIC_D4_MIC | MIC | IC | 1 | MIC1 |
MINI_USB_5 | USB MIN_2_MINI_USB_5_USBMIN | USBmin | IC | 1 | J1 |
PHONE_4C | PHONEJACK STEREO SW_0_PHONE_4C_ | PHONEJACK | IC | 1 | P306 |
PT5382MSOP8 | PT5382MSOP8_0_PT5382MSOP8_PT538 | PT5382 | IC | 1 | U3 |
QFN_16 | DS8008_5_QFN_16_AK4182A/TSC2046 | AK4182A/TSC2046 | IC | 1 | U20 |
QN8006 | QN8006_1_QN8006_QN8006 | QN8006 | IC | 1 | U1 |
SOT23A | DIODE_1_SOT23A_BAT54C | BAT54C | IC | 1 | D4 |
SOT23A | P DGS_1_SOT23A_SI2305 | SI2305 | IC | 1 | Q1 |
SOT23A | 40852_1_SOT23A_2N3904 | 2N3904 | IC | 1 | Q2 |
SOT23A | NDS351N/SOT_1_SOT23A_CD2306 | CD2306 | IC | 1 | Q3 |
SOT23A | NDS351N/SOT_2_SOT23A_CD2306 | CD2306 | IC | 1 | Q4 |
SOT23A | PNP BCE_0_SOT23A_8550 | 8550 | IC | 1 | Q5 |
SOT23A | 40852_2_SOT23A_2N3904 | 2N3904 | IC | 1 | Q6 |
SOT23A | DS8008_6_SOT23A_RT9193-18CV | RT9193-18CV | IC | 1 | U9 |
SOT25 | DS8008_SOT25_RT8008 | RT8008 | IC | 2 | U7; U8 |
SOT25 | DS8008_SOT25_CD8008ADJ | CD8008ADJ | IC | 1 | U16 |
SOT25 | LTC3406-1_0.8_SOT25_CD6219-332S | CD6219-332SK | IC | 1 | U17 |
SOT26 | DS8008_3_SOT26_PT5127(2V8/1V8) | PT5127(2V8/1V8) | IC | 1 | U11 |
SOT26 | G5121_SOT26_RT9293B | RT9293B | IC | 1 | U13 |
SP1 | SPEAKER_SP1_SPEAKER | SPEAKER | IC | 1 | LS1 |
SW_4P-D5 | SW PUSHBUTTON_5_SW_4P-D5_UPDATE | UPDATE | IC | 1 | SW1 |
SW_4P-D5 | SW PUSHBUTTON_5_SW_4P-D5_RESET | RESET | IC | 1 | SW2 |
TEST | CAP NP_0_TEST_PAD | PAD | IC | 36 | P2; P3; P4; P5; P6; P7; P8; P17; P18; P19; P21; P23; P24; P26; P27; P28; P29; P30; P31; P32; P33; P34; P35; P36; P37; P38; P39; P40; P41; P48; P49; P50; P51; P52; P53; P54 |
TEST | CAP NP_0_TEST_SDR_A13 | SDR_A13 | IC | 1 | P9 |
TEST | CAP NP_0_TEST_SDR_A14 | SDR_A14 | IC | 1 | P10 |
TEST | CAP NP_0_TEST_SDR_A15 | SDR_A15 | IC | 1 | P11 |
TEST | CAP NP_0_TEST_SDR_A16 | SDR_A16 | IC | 1 | P12 |
TEST | CAP NP_0_TEST_SDR_A17 | SDR_A17 | IC | 1 | P13 |
TEST | CAP NP_0_TEST_SDR_A18 | SDR_A18 | IC | 1 | P14 |
TEST | CAP NP_0_TEST_SDR_A19 | SDR_A19 | IC | 1 | P15 |
TEST | CAP NP_0_TEST_SDR_A20 | SDR_A20 | IC | 1 | P16 |
TEST | CAP NP_0_TEST_ADC_AIN1 | ADC_AIN1 | IC | 1 | P20 |
TEST | CAP NP_0_TEST_ADC_AIN2 | ADC_AIN2 | IC | 1 | P22 |
TEST | CAP NP_0_TEST_EXTCLK | EXTCLK | IC | 1 | P25 |
TEST | CAP NP_0_TEST_JTMS | JTMS | IC | 1 | P42 |
TEST | CAP NP_0_TEST_JTDO | JTDO | IC | 1 | P43 |
TEST | CAP NP_0_TEST_JTCK | JTCK | IC | 1 | P44 |
TEST | CAP NP_0_TEST_JTDI | JTDI | IC | 1 | P45 |
TEST | CAP NP_0_TEST_JRTCK | JRTCK | IC | 1 | P46 |
TEST | CAP NP_0_TEST_JTRST | JTRST | IC | 1 | P47 |
TF_CARDKLJ07002 | SD_SOCKET_3_TF_CARDKLJ07002_TFC | TFCARD | IC | 1 | U5 |
TOUCH_PAD | LCM0200CE1A0_2_TOUCH_PAD_TOUCH_ | TOUCH_PAD | IC | 1 | J8 |
TSOP1_48 | HY27UF082G2M_1_TSOP1_48_FLASH_1 | FLASH_1ST | IC | 1 | U4 |
UMLP10 | LM4990_3_UMLP10_FSUSB30(MICROPA | FSUSB30(MicroPak) | IC | 1 | U10 |
WM8988 | WM8988_WM8988_WM8988 | WM8988 | IC | 1 | U2 |
附件:
