查看: 192|回复: 1
calibrations Rising Table Print Height
    2019-11-19 15:19
    发表于 2020-4-21 10:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    . Y7 _0 E+ h( e/ ]( b' q: n/ `
    / {' H) r) M8 t
    . ?& d/ [/ i, L% \Yesterdy, on he ste wi not see a otor bohers creton Pint Hegnt, now soting out he nomaton o, we want 10 help Please read the adtonal prestge and paisel ! Corecion metio in detail as flos3 k9 f6 A3 r: ?: i
    1. Ensure that a screen is ftted in the machine.8 O* E& K6 x$ D  E  z/ ]
    2. Select Maintenance.$ G: G1 u3 N) b
    3. Select Diagnostics.
    0 s. U- z+ [' P7 A: k8 l4. Use Next or Previous to highlight Rising Table.
    $ l" f) h/ A% D3 [  V" Q3 r5. Select Select Module.
    + c$ T1 Y2 ?( ]6. Ensure that Home Rising Table is highighted." v( Z  Y; ]- O* r! t3 S) s1 D
    7. Select Run Diagnost.
    2 V: Q9 J7 v$ R  x8. Use Next or Previous to hglight Set Reference Print Height.  A8 d4 W$ d$ o% }
    9. Select Run Diagnost.The ising table moves to the default stting and the flowin window is displayed:# W8 y9 @% u' U/ s; U" z
    10 Selet Confrm to open the Table Print Heignt Cibration window.2 U& {" H( y' J$ k' q# \- D
    11. Check the gap between the top of the board clamps and the sren. The coret print height is when the top of the tansport rais is just touching the screen.
    9 Z, u5 y$ a% P* J; m- x12. Use the Incr. or Decr. button to adjust the displayed dimension.
    0 I  a! }, j3 A4 l- z( v13. Select Move.
    0 h* t" c1 {' {  x14 Repeat Steps 11 to 13 until the top of the board camps are in contact with the screen, without force.
    6 ^# D  E& ]6 V( }15. When the crrect heigt has been achieved, selet Set Height. The fllwing window is displayed:
    $ e. T1 q/ I9 e  a1 y0 n16. Select Confrm to save the new print height.# r6 q8 Q# [4 w: R( ]
    17 Select Cancel to close the Set Reference Vision Height window.* p: a: z& G4 }4 @0 X$ W
    18. Select Exit.! Z) Z7 e7 \+ y$ W! o5 b
    19. Select Exit.
    ) g# G% c7 K: `20. Select Back.9 v$ |4 n, \0 c5 u" P7 V0 K
    21.Cary out the Squeegee Reference Height clbratin Squeegee chapler refers.+ S+ h  ]8 K4 V9 r# D
    ; P9 \  N- O' A% `* k
    " A3 P- S3 T2 y; r/ @( S0 S
    发表于 2020-4-21 14:13 | 只看该作者
    英文的,但是很实用。
    GMT+8, 2025-9-28 19:43 , Processed in 0.109375 second(s), 23 queries , Gzip On.
