5 a- Q5 L( L0 ?, K# u1 l* H3 ~
[allegro15.5][2层] EP9315参考板(EP9315+flash+网口)原理图和pcb文件. w5 L/ |" m9 u) g' w4 s" P2 A
: g: n6 o' T* T- p& [. |* X# F
文件描述:
o: F3 S- O1 ?; Y/ ], l
: w9 {/ D1 m7 f, R, R2 z1. 作品用途: EP9315参考板
/ u" v, k# U [3 x2. 软件版本:allegro15.50 a( Y- P/ j+ V: h9 c- N
3. 层数:2层/ c2 g9 n3 O+ ^" V
4. 用到的主要芯片:EP9315+flash+网口7 g$ U4 r9 _2 n2 ]
5. pcb尺寸:3314*3724 MIL5 o8 b: P( Y8 x2 H3 N: p# w0 @3 O
* h' X% ?) t' H: `* Y$ W
作品截图如下:
9 V+ l8 S, A1 R. Z' m, k
+ V7 r! Y/ L& T7 [+ S顶层截图:; e6 \, ]0 K$ p4 w/ Q
9 d7 v; ~6 R# e底层截图:# p9 l2 g' e* m% w3 \2 ] a2 `
5 |) q1 r- e+ h8 q: o: \7 p/ F' |# @) f7 @7 l
全层截图:
4 _0 e8 t/ w9 x _/ G$ q
. I3 Q9 [' V0 d" i, ~& F2 [
$ G- G9 u* z" D O
BOM:8 N0 S% v* x O6 A7 Y6 z
Bill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | 5566-02A | 5566-02A | | IO | 4 | J3; J4; J13; J14 | 5566_03A | 5566_03A | | IO | 5 | J5; J7; J8; J9; J10 | B0505T | B0505T | | IC | 1 | U7 | C0603 | C0603 | 15pF | IC | 46 | C1; C3; C5; C6; C8; C9; C10; C12; C14; C15; C16; C19; C21; C22; C24; C25; C26; C29; C30; C32; C34; C35; C36; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61 | C0805 | C0805 | 1uF | IC | 1 | C31 | C3216 | C3216 | | DISCRETE | 11 | C2; C4; C13; C18; C20; C28; C33; C37; C38; C62; C63 | C6032 | C6032 | | DISCRETE | 5 | C7; C11; C17; C23; C27 | CON381 | CON381 | | IO | 1 | J12 | DSUB9_M_DIP-H | DSUB9_M_DIP-H | | IO | 1 | J6 | JYNJ254_20 | JYNJ254_20 | | IO | 1 | J11 | LED1206 | LED1206 | | DISCRETE | 4 | DS1; DS2; DS3; DS4 | R0603 | R0603 | 10K | IC | 56 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57 | R0805 | R0805 | | DISCRETE | 6 | FB1; FB2; FB3; FB4; FB5; FB6 | R1206 | R1206 | | DISCRETE | 1 | R36 | SD-54373A | SD-54373A | | IO | 1 | J1 | SO8 | SO8 | ADM706R | IC | 3 | U3; U5; U6 | SOT23-5P | SOT23-5P | SN74AHC1G125DBV | IC | 1 | U4 | SOT223 | SOT223 | | DISCRETE | 1 | U1 | SW_SMD2 | SW_SMD2 | | DISCRETE | 1 | SW1 | TLP521-1 | TLP521-1 | | IC | 2 | U8; U9 | TSSOP16 | TSSOP16 | SP3232EEY | IC | 3 | U10; U11; U12 | TSSOP24 | TSSOP24 | | IC | 1 | U13 | TSSOP28 | TSSOP28 | | IC | 1 | U2 | 附件:
0 i, g/ G9 `. X x原理图和PCB文件如下:0 }- |% X2 `' e, N7 N* C2 Z
9 d: R! Y$ R Q0 q, K9 `, K7 }
6 f2 _3 x% s* n& ~, c N; P5 w |
