Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
8P4R | 141-0326 | RR-4x100k-1206 | IC | 1 | RR1 |
8P4R | RR-4X100K-1206_8P4R_RR-4X100K-1 | RR-4x100k-1206 | IC | 2 | RR2; RR3 |
1206L | FILTRE FERRITES CMS-742792093_1 | Filtre ferrites CMS-742792093 | IC | 1 | L3 |
BGA217 | 051-2000 | AT91SAM9G20B-CU | IC | 1 | U1 |
C0603 | CAP NP_C0603_100NF | 100nF | IC | 48 | C1; C2; C4; C8; C10; C11; C13; C14; C15; C17; C18; C19; C20; C21; C22; C23; C24; C25; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C49; C50; C51; C52; C53; C54; C55; C67; C68; C69 |
C0603 | CAP NP_C0603_10PF | 10pF | IC | 4 | C3; C6; C7; C9 |
C0603 | 036-0532 | COG-10PF-50V | IC | 1 | C66 |
C0805 | CAP NP_C0805_10UF | 10uF | IC | 3 | C5; C27; C64 |
C0805 | CAP NP_C0805_1UF | 1uF | IC | 2 | C62; C63 |
CAP_CASEB | CAPACITOR POL_0_CAP_CASEB_22UF | 22uF | IC | 9 | C12; C16; C26; C48; C56; C57; C58; C61; C65 |
CAP_CASED | CAP_CAP_CASED_220UF | 220uF | IC | 1 | C59 |
DIP_40_100A | HEADER 20X2_DIP_40_100A_HEADER | HEADER 20X2 | IC | 2 | J2; J3 |
D_SMB | BZX84C6V8/SOT_2_D_SMB_SS34 | SS34 | IC | 1 | D1 |
LED0805 | LED_LED0805_LED | LED | IC | 2 | D2; D3 |
MICROSD | MMC-SD CARD SOCKET_2_MICROSD_MM | MMC-SD card socket | IC | 1 | J1 |
MSOP10 | 176-2002 | TPS60500DGS | IC | 1 | U9 |
OSCMS26 | SG-8002JC-50.0000M_OSCMS26_SG-8 | SG-8002JC-50.0000M | IC | 1 | Y3 |
QFP48A | DM9161AE_QFP48A_DM9161AE | DM9161AE | IC | 1 | U6 |
R0603 | R_R0603_0R | 0R | IC | 2 | R1; R24 |
R0603 | R_R0603_1R | 1R | IC | 3 | R2; R7; R40 |
R0603 | R_R0603_1K | 1K | IC | 5 | R3; R5; R12; R13; R26 |
R0603 | R_R0603_10K | 10K | IC | 17 | R4; R6; R10; R11; R14; R15; R16; R20; R22; R25; R28; R31; R32; R37; R38; R39; R41 |
R0603 | R_R0603_100K | 100K | IC | 2 | R8; R9 |
R0603 | R_R0603_49R9 | 49R9 | IC | 4 | R17; R18; R19; R21 |
R0603 | R_R0603_6.80K | 6.80K | IC | 1 | R23 |
R0603 | R_R0603_51K | 51K | IC | 2 | R27; R35 |
R0603 | R_R0603_510R | 510R | IC | 2 | R29; R30 |
R0603 | R_R0603_12K | 12K | IC | 1 | R33 |
R0603 | 100K-0603_R0603_100K-0603_5% | 100k-0603 | IC | 1 | R34 |
R0603 | R_R0603_6.8K | 6.8K | IC | 1 | R36 |
R0603 | GDC_NO-0603_R0603_GDC_NO-0603_N | GDC_NO-0603 | IC | 1 | S1 |
R0805 | 106-2019 | 10uH | IC | 2 | L1; L2 |
SO8 | 146-2036 | LM293 | IC | 1 | U8 |
SOD123 | 156-2067 | MMSD4148 | IC | 1 | D4 |
SOIC16A | FM3130_1_SOIC16A_M25P64 | M25P64 | IC | 1 | U11 |
SOIC16B | FM3130_0_SOIC16B_DS3231 | DS3231 | IC | 1 | U10 |
SOP8A | AT45DB642D_CNU_SOP8A_AT45DB642D | AT45DB642D_CNU | IC | 1 | U5 |
SOT23 | 156-2066 | AO3415 | IC | 1 | Q1 |
SOT23 | 2N3904_0_SOT23_S8050 | S8050 | IC | 1 | Q2 |
TO252A | LM1117-33_TO252A_LM1086-33 | LM1086-33 | IC | 1 | U7 |
TP34 | PAD0S7 | USER GRID 1.27 | IC | 9 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9 |
TSOP48 | K9F2G08U0M-PCB0_0_TSOP48_K9F2G0 | K9F2G08U0M-PCB0 | IC | 1 | U4 |
TSOP54A | MT48LC16M16A2TG_TSOP54A_MT48LC8 | MT48LC8M16A2TG-75 | IC | 2 | U2; U3 |
XTAL_5032S | FOXSD/184-20TR_6_XTAL_5032S_FOX | FOXSD/184-20TR | IC | 1 | Y1 |
XTAL_RTC | CM200S 32_2.768KHZ_XTAL_RTC_CM2 | CM200S 32.768kHz | IC | 1 | Y2 |
附件:
