EDA365»¶ÓÄúµÇ¼£¡
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
DEK Ïà¹Ø265Îļþ 7 g) \1 y7 b- J) L2 d
1¡¢Èí¼þ°²×°Ê±ÌṩµÄÎļþ DOS4SW.EXE ©rVIS022.SAV ©rVIS0213.SAV©rSDRCONF.CFG ©rCFGSDR.EXE©rSDR140.EXE ©r 2¡¢µ÷УºÍLOADʱÉú³ÉµÄÎļþ TRACE.DAT ©rBAUDRATE.TXT©rCALIB.CAL ©rLOCATION.DAT © RFIDUCIAL.DAT ©rTHETA.DAT©rVIDEOXY.DAT©rOFFSET.DAT©rPRESSURE.DAT 3¡¢Ë¿Ó¡»úÆäËüÌõ¼þÉú³ÉµÄÎļþ MANINF.DAT ©rMANINT.DAT ©rSPC.CFG ©rCONF170.CFG ©rEVENT.DAT ©rLOCAL.LPF©rTEMP.LPF Ïà¹ØÎļþ¹¦ÄÜ DOS4GW.EXE DOSÀ©Õ¹Èí¼þÒòΪ265ÔËÐÐÔÚ±£»¤Ä£Ê½,ËüʹӦÓÃÈí¼þÖ±½Ó½øÈë¸ü¶àÄÚ´æ(MEMORY). VIS0213.SAV ÕâÒ»¶þλÂëÎļþÓÃÀ´ºÍVISION¿¨×÷ÓÃ,ËüÓÃÔÚ2.09ÒÔÉÏÈí¼þ°æ±¾. SDRCONF.CFG ÊÇASCIIÎļþ,±»ÓÃÀ´ÅäÖÃHOSTSÁ¬½Ó. CFGSDR.EXE ËüÀûÓÃÉÏÎļþÅäÖÃHOSTÁ¬½Ó SDR140.EXE ËüÔÚ¿ª»úÊDZ»AUTOEXEC.BATµ÷ÓÃ,½«Çý¶¯³ÌÐò×°ÈëTSRÄÚ´æÓÃ×÷´®ÐÐÁ¬½Ó. BAUDRATE.TXT ÊÇDOWNLOAD MINTʱ²úÉúµÄÒ»¸öÎı¾Îļþ,Ëü¾ö¶¨265ÓëMINTÁ¬½ÓËÙ¶È. CALIB.CAL ±¾Îļþ²úÉúÓÚ265CALIBRATE ¹ý³ÌÖУ¬Ëü¸ø³öʶ±ðµã¼ä¾à£¬µÚһʶ±ðµãԵ㣬PCBºÍ¸ÖÍøÉÏʶ±ðµãÊýÁ¿£¬ËùÓÐÕâЩÐÅÏ¢±»Ð´ÔÚDEKÈí¼þ£¬Ã¿´Îµ÷УʱʹÓᣠCONFIG.CFGºÍCONFIG.TXT ÕâÁ½¸öÎļþÔÚ»úÆ÷µ÷У»ò¿ª»úʱ²úÉú£¨µ±Ã»ÓÐÕâÒ»Îļþ£©ËüÓÃÀ´¾ö¶¨µ÷УÉèÖã¬Èç¹û¶ªÊ§ÁËÕâÒ»ÎļþÐèÒªÖØÐµ÷УÉ豸£¬ËùÒÔÐèÒª¶¨ÆÚ½øÐб¸·Ý¡£ LOCATION.DAT ÕâÒ»ÎļþûÓã¬Ëü¼Ç¼SETUPʱʶ±ðµãµÄλÖúͷÖÊý¡£ TRACE.DAT ÊÇÔËÐÐʱ²úÉúµÄÒ»¸öÎı¾Îļþ£¬¿ÉÒÔÓÃÀ´¼ì²éÄÚ´æÊ¹ÓÃÇé¿ö FIDUCIAL.DAT ÕâÒ»Îļþ²úÉúÓÚµ÷Уʱ£¬ËüÊÇÓÃÀ´½øÐе÷УµÄ£¬Ëü°üÀ¨Ê¶±ðµãÏà¹ØµÄһЩ²ÎÊý¡£ THETA.DAT µ÷Уʱ²úÉúµÄÎı¾Îļþ£¬µ÷УʹÓà VIDEOXY.DAT µ÷У²úÉú£¬°üÀ¨Ê¶±ðµã×ø±ê .OFFSET.DAT µ÷У²úÉú£¬°üÀ¨XY×ø±êºÍÆ«²î¡£ PRESSURE.DAT ѹÁ¦µ÷У²úÉúÎı¾Îļþ¡£ MANINF.DAT »úÆ÷ʹÓÃÿÎå·ÖÖÓ²úÉúÒ»¸ö£¬±£´æ×îºóÉú²úµÄ²úÆ·ÃûºÍ¶¯×÷ÐÅÏ¢£¬ÈçûÓÐÕâÒ»Îļþ£¬»úÆ÷½«×Ô¶¯Éú³ÉÒ»¸ö¡£ MAINT.DAT ÃÜÂëÓйØÎļþ£¬¿ÉÒÔ½«ÕâÒ»Îļþ¸ÄÃû¶øÊ¹ÃÜÂëʧЧ¡£ SPC.CFG µ±´æ´¢SPCÊý¾Ýʱ²úÉú£¬¿ÉÒÔÓÃQC-CALÈí¼þ¶ÁÈ¡¡£CONF170.CFG ÓëHOSTÁ¬½ÓÓйصÄÈí¼þ¡£EVENT.DAT ʼþ¼Ç¼Îļþ .LOCAL.LPF GEMÔËÐÐʹÓà TEMP.LPF GEMÔËÐÐʱʹÓᣠÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
4 i4 n$ K) Z5 `% j- b9 n x. V4 ]" Z7 x: ~1 L# r
