Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2SB1188 | 2SB1188_2SB1188_2SB1188 | 2SB1188 | IC | 2 | Q1; Q2 |
BGA60C80P6X10_800X1200X100 | H5MS1G62MFP-K3M_BGA60C80P6X10_8 | H5MS1G62MFP-K3M | IC | 2 | U32; U34 |
BGA256C100P16X16_1700X1700X155 | EP3C5B_BGA256C100P16X16_1700X17 | EP3C5B | IC | 1 | U1 |
BGA256C100P16X16_1700X1700X155 | EP2C8_BGA256C100P16X16_1700X170 | EP2C8 | IC | 1 | U10 |
BGA424C50P25X25_1300X1300X120 | S3C6410X_BGA424C50P25X25_1300X1 | S3C6410X-66 | IC | 1 | U31 |
BS1220 | BATTE_7_BS1220_3V | 3V | IC | 1 | BT1 |
CAPR2_200 | CAP_CAPR2_200_1000PF | 1000pF | IC | 1 | C1210 |
CAPR2_200 | CAP_CAPR2_200_0.01UF | 0.01uF | IC | 1 | C2115 |
CON6P-USB-ATOM | USB-A_CON6P-USB-ATOM_USB-A | USB-A | IC | 1 | J1903 |
CON9P-MINI-USB-ATOM | USB-MINIAB_CON9P-MINI-USB-ATOM_ | USB-MINIAB | IC | 1 | J1902 |
CON11P-SD-ATOM | SD/MMC_CON11P-SD-ATOM_SD/MMC | SD/MMC | IC | 1 | J1904 |
CONN-2X5-254 | CONN-2X5-254-M_CONN-2X5-254_CON | CONN-2x5-254-M | IC | 5 | J401; J601; J802; J901; J902 |
CONN-2X17-200-SMD | CONN-2X17-200-M_CONN-2X17-200-S | CONN-2x17-200-M | IC | 1 | J1601 |
CONN-2X25-254 | CONN-2X25-254-M_CONN-2X25-254_C | CONN-2x25-2254-M | IC | 2 | J1101; J1102 |
DIP8 | 25F2048_DIP8_25F2048 | 25F2048 | IC | 1 | U6 |
IT3205EE | CRYSTAL_SX-8_IT3205EE_24.576MHZ | 24.576MHz | IC | 1 | X2001 |
IT3205EE | CRYSTAL_1_IT3205EE_12MHZ | 12MHz | IC | 1 | Y1502 |
IT3205EE | CRYSTAL_1_IT3205EE_27MHZ | 27MHz | IC | 1 | Y1503 |
IT3205EE | CRYSTAL_1_IT3205EE_48MHZ | 48MHz | IC | 1 | Y1505 |
MJ8_SRLFY1 | RJ-45_MJ8_SRLFY1_RJ45/1X1 | RJ45/1x1 | IC | 3 | JP2; JP4; JP1901 |
QFN50P700X700X90-49VKKD8 | WM9713LGEFL/RV_QFN50P700X700X90 | WM9713LGEFL/RV | IC | 1 | U39 |
QFN50P1000X1000X80-73W3 | RTL8211BN_QFN50P1000X1000X80-73 | RTL8211BN | IC | 1 | U69 |
RN_3216 | RES_PACK4_RN_3216_22/5% | 22/5% | IC | 51 | RN301; RN302; RN303; RN304; RN305; RN306; RN307; RN308; RN501; RN502; RN503; RN504; RN505; RN506; RN507; RN508; RN509; RN510; RN511; RN512; RN513; RN514; RN515; RN516; RN517; RN518; RN519; RN520; RN809; RN810; RN811; RN812; RN813; RN814; RN815; RN816; RN818; RN820; RN821; RN1001; RN1002; RN1003; RN1004; RN1005; RN1006; RN1007; RN1008; RN1009; RN1010; RN1011; RN1012 |
RN_3216 | RES_PACK4_RN_3216_4.7K/5% | 4.7K/5% | IC | 1 | RN822 |
SC0402 | CAP_SC0402_0.1UF | 0.1uF | IC | 97 | C402; C403; C404; C405; C406; C407; C414; C415; C416; C417; C418; C419; C420; C421; C422; C429; C430; C431; C432; C433; C434; C435; C436; C437; C902; C903; C904; C905; C906; C907; C908; C909; C910; C911; C912; C913; C914; C915; C916; C917; C918; C919; C920; C921; C922; C923; C925; C926; C1702; C1703; C1704; C1705; C1706; C1707; C1708; C1709; C1710; C1711; C1716; C1717; C1718; C1719; C1720; C1721; C1722; C1723; C1724; C1725; C1726; C1727; C1728; C1729; C1730; C1731; C1732; C1735; C1736; C1737; C1738; C1739; C1745; C1746; C1805; C1806; C1807; C1808; C1809; C1810; C1811; C1812; C1813; C1814; C1815; C1816; C1817; C1818; C1819 |
SC0402 | CAP_SC0402_0.01UF | 0.01uF | IC | 2 | C1743; C1744 |
SC0603 | CAP_SC0603_1UF | 1uF | IC | 26 | C36; C1218; C1219; C1220; C1224; C1225; C1226; C1227; C1229; C1230; C1231; C1232; C1234; C1240; C1241; C1242; C1243; C2008; C2010; C2019; C2020; C2021; C2022; C2202; C2209; C12211 |
SC0603 | CAP_SC0603_0.1UF | 0.1uF | IC | 77 | C83; C85; C116; C163; C164; C166; C167; C193; C257; C301; C306; C356; C501; C502; C503; C504; C505; C506; C508; C509; C603; C604; C605; C606; C608; C609; C610; C611; C705; C707; C709; C711; C1001; C1002; C1003; C1005; C1101; C1102; C1103; C1104; C1105; C1106; C1107; C1108; C1109; C1110; C1222; C1233; C1239; C1305; C1308; C1309; C1311; C1313; C1315; C1317; C1601; C1602; C1605; C1906; C2101; C2102; C2103; C2107; C2108; C2109; C2110; C2112; C2113; C2114; C2214; C2216; C2221; C2222; C2223; C2224; C2227 |
SC0603 | CAP_SC0603_0.01UF | 0.01uF | IC | 35 | C302; C303; C365; C366; C507; C511; C512; C513; C514; C515; C516; C517; C518; C519; C520; C1004; C1006; C1007; C1008; C1009; C1010; C1201; C1203; C1204; C1206; C1207; C1208; C1209; C1211; C1212; C1213; C1214; C1215; C1216; C5081 |
SC0603 | CAP_SC0603_22PF | 22pF | IC | 11 | C745; C1359; C1501; C1502; C1503; C1504; C1507; C1508; C2105; C2106; C2204 |
SC0603 | CAP_SC0603_27PF | 27pF | IC | 2 | C1202; C1205 |
SC0603 | CAP_SC0603_1000PF | 1000pF | IC | 1 | C1217 |
SC0603 | CAP_SC0603_12PF | 12pF | IC | 2 | C1505; C1506 |
SC0603 | CAP_SC0603_1800PF | 1800pf | IC | 1 | C1603 |
SC0603 | CAP_SC0603_680PF | 680pF | IC | 4 | C1908; C1909; C1911; C2228 |
SC0603 | CAP_SC0603_220PF | 220pF | IC | 2 | C2017; C2018 |
SC0603 | CAP_SC0603_2.2UF | 2.2uF | IC | 2 | C2205; C2213 |
SD0604 | DIODE_2PIN_SD0604_1N4148 | 1N4148 | IC | 1 | D1503 |
SIP2 | HEADER_1X2_SIP2_PINHEADER1X2 | PINHEADER1x2 | IC | 1 | JP1 |
SIP2_9MM | HEADER_1X2_SIP2_9MM_HEADER_1X2 | HEADER_1x2 | IC | 1 | JP5 |
SL0805 | BEAD_SL0805_BEAD/3A | BEAD/3A | IC | 4 | L1104; L1201; L1202; L1203 |
SL0805 | BEAD_SL0805_BLM15EG121SN1 | BLM15EG121SN1 | IC | 6 | L1208; L1209; L1210; L1213; L1216; L1217 |
SL0805 | BEAD_SL0805_MPZ1608S300A | MPZ1608S300A | IC | 5 | L1214; L2204; L2205; L2206; L2207 |
SL1210 | IND_SL1210_10UH | 10uH | IC | 3 | L1218; L1219; L2215 |
SLED0603 | LED_1_SLED0603_LED/1X1/RED | LED/1x1/Red | IC | 15 | D301; D302; D303; D304; D701; D801; D1201; D1202; D1203; D1204; D1205; D1301; D1302; D1501; D1502 |
SMD32K | CRYSTAL_1_SMD32K_32.768KHZ | 32.768kHz | IC | 1 | Y1504 |
SOIC127P600X175-8 | 25F2048_SOIC127P600X175-8_25F20 | 25F2048 | IC | 2 | U5; U12 |
SOIC127P600X175-8 | DS1621_SOIC127P600X175-8_DS1621 | DS1621S | IC | 1 | U11 |
SOIC127P600X175-8 | EPCS4_SOIC127P600X175-8_EPCS4 | EPCS4 | IC | 1 | U13 |
SOIC127P600X175-16 | MAX3232_SOIC127P600X175-16_MAX3 | MAX3232 | IC | 1 | U35 |
SOIC127P1032X265-20 | 74HC574_SOIC127P1032X265-20_74H | 74HC574 | IC | 8 | U15; U16; U17; U18; U19; U20; U21; U22 |
SOIC127P1032X265-20 | 74HC245_SOIC127P1032X265-20_74H | 74HC245 | IC | 3 | U23; U24; U62 |
SOIC127P1600X551-24 | H5007_SOIC127P1600X551-24_H5007 | H5007 | IC | 1 | U25 |
SOP16 | SW DIP-8_SOP16_SW DIP-8 | SW DIP-8 | IC | 1 | SW1902 |
SOP127P953X590-16 | HS9016_SOP127P953X590-16_HS9016 | HS9016 | IC | 1 | U41 |
SOT95P280X100-5 | MP2104DJ_SOT95P280X100-5_MP2104 | MP2104DJ | IC | 3 | U42; U67; U68 |
SOT95P280X100-5 | XC6219B_SOT95P280X100-5_XC6219B | XC6219B122MR | IC | 1 | U43 |
SOT95P280X100-5 | XC6219B_SOT95P280X100-5_XC621_1 | XC6219B332MR | IC | 1 | U47 |
SOT95P280X100-6 | FDC6331L_SOT95P280X100-6_FDC633 | FDC6331L | IC | 1 | U36 |
SOT192P237X100-4 | MAX811S_SOT192P237X100-4_MAX811 | MAX811S | IC | 1 | U37 |
SOT223P650X160-4 | LM1117-ADJ_SOT223P650X160-4_LM1 | LM1117-ADJ | IC | 2 | U9; U100 |
SOT223P650X160-4 | LM1117_SOT223P650X160-4_LM1117- | LM1117-3.3V | IC | 1 | U45 |
SOT223P650X160-4 | LM1117_SOT223P650X160-4_LM111_1 | LM1117-1.8V | IC | 1 | U46 |
SR0603 | RES_SR0603_22 | 22 | IC | 13 | R3; R4; R5; R6; R7; R8; R221; R501; R1001; R1912; R1914; R2002; R2004 |
SR0603 | RES_SR0603_20K | 20K | IC | 2 | R106; R132 |
SR0603 | RES_SR0603_0 | 0 | IC | 54 | R117; R191; R192; R193; R194; R233; R234; R236; R303; R304; R305; R306; R307; R404; R405; R406; R407; R408; R605; R610; R611; R804; R805; R806; R901; R902; R903; R904; R905; R912; R914; R1502; R1510; R1514; R1519; R1520; R1610; R1801; R1806; R1807; R1916; R1917; R1918; R1919; R1920; R1921; R1922; R1923; R1924; R1925; R1926; R1927; R1928; R1929 |
SR0603 | RES_SR0603_510 | 510 | IC | 5 | R118; R119; R1202; R1207; R1210 |
SR0603 | RES_SR0603_680 | 680 | IC | 7 | R124; R125; R126; R130; R131; R2008; R2009 |
SR0603 | RES_SR0603_32 | 32 | IC | 2 | R127; R129 |
SR0603 | RES_SR0603_4.7K | 4.7K | IC | 36 | R155; R156; R157; R158; R159; R160; R161; R162; R174; R175; R709; R802; R803; R807; R1215; R1216; R1219; R1220; R1225; R1226; R1227; R1228; R1229; R1230; R1231; R1232; R1233; R1234; R1235; R1236; R1237; R1238; R1397; R2101; R2102; R2208 |
SR0603 | RES_SR0603_330 | 330 | IC | 9 | R241; R301; R302; R309; R603; R703; R1304; R1516; R2206 |
SR0603 | RES_SR0603_10K | 10K | IC | 43 | R242; R401; R402; R409; R410; R411; R412; R606; R607; R608; R609; R906; R907; R908; R909; R910; R911; R913; R1503; R1504; R1505; R1506; R1507; R1508; R1509; R1802; R1803; R1804; R1805; R1901; R1902; R1903; R1904; R1905; R1906; R1907; R1931; R1932; R1933; R1934; R1937; R1938; R2003 |
SR0603 | RES_SR0603_1K | 1K | IC | 7 | R403; R413; R915; R916; R917; R918; R2212 |
SR0603 | RES_SR0603_150/1% | 150/1% | IC | 2 | R706; R1306 |
SR0603 | RES_SR0603_100K/1% | 100K/1% | IC | 7 | R710; R1399; R1911; R1913; R2201; R2210; R2211 |
SR0603 | RES_SR0603_300K %1 | 300K %1 | IC | 7 | R711; R712; R713; R1300; R2203; R2204; R2205 |
SR0603 | RES_SR0603_100 | 100 | IC | 1 | R801 |
SR0603 | RES_SR0603_750 | 750 | IC | 4 | R1203; R1204; R1205; R1206 |
SR0603 | RES_SR0603_2.49K/1% | 2.49K/1% | IC | 1 | R1209 |
SR0603 | RES_SR0603_470 | 470 | IC | 3 | R1501; R2108; R2109 |
SR0603 | RES_SR0603_1M | 1M | IC | 3 | R1512; R1513; R1518 |
SR0603 | RES_SR0603_4.99M | 4.99M | IC | 1 | R1515 |
SR0603 | RES_SR0603_44.2 | 44.2 | IC | 1 | R1517 |
SR0603 | RES_SR0603_6.49K/1% | 6.49K/1% | IC | 1 | R1601 |
SR0603 | RES_SR0603_15K | 15K | IC | 4 | R1908; R1909; R1910; R1915 |
SR0603 | RES_SR0603_47K | 47K | IC | 3 | R2001; R2005; R2006 |
SR0603 | RES_SR0603_49.9/1% | 49.9/1% | IC | 4 | R2103; R2105; R2106; R2107 |
SR0603 | RES_SR0603_6.8K | 6.8K | IC | 1 | R2104 |
SR0603 | RES_SR0603_75 | 75 | IC | 3 | R2110; R2111; R2112 |
STC3528 | CAP_POL_STC3528_10UF/10%/10V | 10uF/10%/10V | IC | 29 | C27; C28; C30; C33; C35; C37; C82; C84; C117; C172; C256; C300; C304; C305; C748; C749; C1314; C1360; C1378; C1907; C1912; C2104; C2111; C2201; C2207; C2208; C2212; C13116; C22121 |
STC3528 | CAP_POL_STC3528_100UF | 100uF | IC | 19 | C68; C212; C253; C607; C704; C706; C708; C901; C924; C1304; C1306; C1307; C1310; C1312; C2013; C2016; C2211; C2225; C2226 |
STC3528 | CAP_POL_STC3528_4.7UF/10%/16V | 4.7uF/10%/16V | IC | 9 | C86; C87; C88; C112; C2001; C2002; C2023; C2024; C2025 |
STC3528 | CAP_POL_STC3528_22UF/20%/16V | 22uF/20%/16V | IC | 3 | C1221; C1228; C1244 |
STC3528 | CAP_POL_STC3528_10UF | 10uF | IC | 11 | C1701; C1712; C1713; C1714; C1715; C1733; C1734; C1740; C1741; C1803; C1804 |
SW_DIP2_180 | PUSHBUTTON_4_SW_DIP2_180_PUSHBU | PUSHBUTTON_4 | IC | 2 | S2; SW1901 |
SX4_0705MM | OSC_1_SX4_0705MM_25MHZ | 25MHz | IC | 3 | X6; X8; X10 |
SX4_0705MM | OSC_1_SX4_0705MM_125MHZ | 125MHz | IC | 1 | X9 |
TO254P1524X465-4 | LM1117_TO254P1524X465-4_AMS1085 | AMS1085CM-3.3 | IC | 3 | U8; U63; U66 |
TP-SMT-020-RND | TP-SMT-020-RND_TP-SMT-020-RND_T | TP-SMT-020-RND | IC | 21 | TP701; TP702; TP1201; TP1202; TP1203; TP1301; TP1302; TP1303; TP1501; TP1502; TP1503; TP1504; TP1505; TP1506; TP2201; TP2202; TP2203; TP2205; TP2206; TP2207; TP2208 |
TSOP65P490X109-8 | LM4871MM_TSOP65P490X109-8_LM487 | LM4871MM | IC | 1 | U50 |
TSQFP50P900X900X160-48 | DM9000ACE_TSQFP50P900X900X160-4 | DM9000ACE | IC | 1 | U40 |
TSQFP50P1600X1600X160-100 | EPM240_TSQFP50P1600X1600X160-10 | EPM240 | IC | 1 | U4 |
TSSOP50P1175X120-86 | HY57V643220CT_TSSOP50P1175X120- | HY57V643220CT | IC | 3 | U2; U3; U14 |
TSSOP50P2000X120-48 | K9K8G08_TSSOP50P2000X120-48_K9G | K9G8G08U0A | IC | 1 | U33 |
XTAL2_200 | CRYSTAL_XTAL2_200_25MHZ | 25MHz | IC | 2 | Y1201; Y2101 |
附件:
