9 S% X, u7 S# y" i: j( t[allegro15.0][6层]at91rm9200-dk_PCB的开发板(at91rm9200+网口+USB)pcb文件
+ K5 C+ ?2 m6 o
# t" ~" t5 D+ w& R* H2 U8 [文件描述:
9 l2 J, h' I/ v6 D% D. n5 @. ]5 C. K6 i
1. 作品用途: at91rm9200-dk_PCB的开发板
, L& Q: W4 D& C5 j0 i8 V: N* Y2 G2. 软件版本:allegro15.5) R; M& z! o4 F0 Y) g
3. 层数:6层" H0 J7 m2 m `" V
4. 用到的主要芯片:at91rm9200+网口+USB% X i) G; H! c6 R3 r
5. pcb尺寸: 179.07*192.41 MM
* ^5 ]% G4 n, T8 F" D X, f! p# }' X0 `% U- }9 m- @5 `' d
作品截图如下:+ E- W$ s6 [9 B4 @. U
, \. D/ `5 K' Q/ i
顶层截图:; v6 j% I } a8 y' w2 ~9 _
4 L0 k, |( @( d3 p/ G, P底层截图:
f, d: T* k3 Y: m& \' M; J y' K
0 n3 J6 j9 {7 i- p7 i2 \+ L6 I( n7 i: O2 m( S
全层截图:
3 ]' V) e+ q5 q2 Q1 V& _
/ M+ @0 q' K6 I! X' W6 x+ z; K) c5 H8 N- _& k0 ?' H" g1 z* L
BOM:2 a6 a8 X& a: d5 V: _# k
Bill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | BAR2PTS02 | BAR2PTS02 | | IO | 6 | J2; J10; J11; J12; J13; J18 | BAR3PTS02 | BAR3PTS02 | | IO | 1 | J9 | BGA96_01 | BGA96_01 | | IC | 4 | MN7; MN8; MN18; MN20 | BGA256_PAS08 | BGA256_PAS08 | | IC | 1 | MN4 | BUZZER10 | BUZZER10 | | DISCRETE | 1 | LS1 | C0603 | C0603 | | DISCRETE | 213 | C5; C9; C10; C14; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C118; C119; C121; C122; C123; C125; C126; C127; C128; C129; C130; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C154; C155; C156; C157; C161; C162; C163; C164; C165; C166; C167; C168; C171; C173; C174; C175; C179; C180; C181; C183; C184; C186; C189; C194; C195; C197; C198; C199; C206; C207; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C229; C231; C232; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C247; C248; C249; C255; C256; C258; C259; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C272; C274; C277; C278; C279; C280 | C0805 | C0805 | | DISCRETE | 14 | C2; C6; C11; C15; C115; C116; C117; C201; C202; C203; C204; C208; C226; C227 | C1206 | C1206 | | DISCRETE | 36 | C62; C63; C120; C124; C131; C153; C158; C159; C160; C169; C170; C172; C185; C188; C191; C193; C196; C200; C205; C224; C225; C228; C230; C233; C245; C246; C250; C251; C252; C253; C254; C257; C260; C273; C275; C276 | C1812 | C1812 | | DISCRETE | 4 | C178; C187; C190; C192 | CAFE02_NF | CAFE02_NF | | IO | 36 | S1; S3; S4; S6; S7; S9; S10; S11; S12; S13; S14; S15; S16; S17; S18; S19; S20; S21; S22; S23; S24; S25; S26; S27; S28; S29; S30; S31; S32; S33; S34; S35; S36; S37; S39; S40 | CAFE02_NO | CAFE02_NO | | IO | 3 | S5; S8; S38 | CON-CN015R-3013-2 | CON-CN015R-3013-2 | | IO | 1 | J17 | CON-FPS009-3203 | CON-FPS009-3203 | | IO | 1 | J24 | CON-SIM-S-3M_N7E50 | CON-SIM-S-3M_N7E50 | | IO | 1 | J16 | CONNECT3PTS03 | CONNECT3PTS03 | | IO | 1 | J1 | CONNECT_CCM02_2504 | CONNECT_CCM02_2504 | | IO | 1 | J26 | CON_DF11_30DP2DSA | CON_DF11_30DP2DSA | | IO | 1 | J33 | CON_DF11_32DP2DSA | CON_DF11_32DP2DSA | | IO | 1 | J29 | CON_ILZ6PTS125T | CON_ILZ6PTS125T | | IO | 1 | J31 | CON_JACK_KLBR-4J | CON_JACK_KLBR-4J | | IO | 2 | J21; J22 | CON_MICTOR38PTS | CON_MICTOR38PTS | | IO | 1 | J7 | CON_S_FLE_2X25PTS | CON_S_FLE_2X25PTS | | IO | 4 | J3; J4; J5; J6 | CON_USB787780 | CON_USB787780 | | IO | 1 | J28 | CON_USBDUAL72309 | CON_USBDUAL72309 | | IO | 1 | J27 | CP-S-FC_H16-01 | CP-S-FC_H16-01 | | DISCRETE | 1 | C1 | CP-S-FE_G-01 | CP-S-FE_G-01 | | DISCRETE | 8 | C3; C4; C7; C8; C12; C13; C16; C17 | CP-S-VS_HB_A-01 | CP-S-VS_HB_A-01 | | DISCRETE | 1 | C177 | CP_TAJA | CP_TAJA | | DISCRETE | 2 | C176; C182 | CVARCMS_TZB4 | CVARCMS_TZB4 | | DISCRETE | 1 | C30 | DIL20_3 | DIL20_3 | | IC | 1 | MN31 | DIN6PTS_SDA87123 | DIN6PTS_SDA87123 | | IO | 2 | J14; J15 | DO214AA | DO214AA | | DISCRETE | 8 | CR1; CR2; CR3; CR4; CR5; CR6; CR7; CR8 | DO_SMP30 | DO_SMP30 | | DISCRETE | 1 | CR16 | ETOILE4 | ETOILE4 | | IO | 1 | S2 | FILTRE_BDS3_3_8_9 | FILTRE_BDS3_3_8_9 | | DISCRETE | 3 | L14; L15; L16 | FUSEMS06 | FUSEMS06 | | DISCRETE | 3 | F1; F3; F4 | FUSE_TS250 | FUSE_TS250 | | DISCRETE | 1 | F2 | HE10M2X10PTS02 | HE10M2X10PTS02 | | IO | 1 | J8 | LEDMS01 | LEDMS01 | | DISCRETE | 5 | DS1; DS2; DS3; DS4; DS5 | LEDMS04 | LEDMS04 | | DISCRETE | 1 | MN30 | OSCHC49SUB_01 | OSCHC49SUB_01 | | DISCRETE | 2 | Y1; Y5 | OSCMS03 | OSCMS03 | | DISCRETE | 1 | Y4 | OSCMS14 | OSCMS14 | | DISCRETE | 1 | Y2 | OSCMS_CSTCR | OSCMS_CSTCR | | DISCRETE | 1 | Y3 | POTARMS12 | POTARMS12 | | DISCRETE | 1 | R149 | PULSE_P1172 | PULSE_P1172 | | DISCRETE | 2 | L1; L2 | QFP48_01 | QFP48_01 | | IC | 2 | MN22; MN25 | QFP144_07 | QFP144_07 | | IC | 1 | MN32 | R0805 | R0805 | | DISCRETE | 159 | L3; L4; L5; L6; L7; L8; L9; L10; L11; L12; L13; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R75; R76; R77; R78; R79; R80; R81; R82; R86; R87; R88; R89; R90; R91; R92; R93; R94; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160 | R1206 | R1206 | | DISCRETE | 10 | R1; R2; R3; R4; R72; R73; R74; R83; R84; R85 | R2512 | R2512 | | DISCRETE | 1 | R95 | RJ6P01 | RJ6P01 | | IO | 1 | J20 | RJ45_PULSE | RJ45_PULSE | | IO | 1 | J19 | SC70-3L | SC70-3L | | DISCRETE | 1 | MN10 | SC70-4L | SC70-4L | | DISCRETE | 1 | MN6 | SC70-5L | SC70-5L | | DISCRETE | 1 | MN5 | SMD200 | SMD200 | | DISCRETE | 1 | F5 | SO08 | SO08 | | IC | 5 | MN1; MN2; MN3; Q1; Q2 | SO14 | SO14 | | IC | 3 | MN9; MN16; MN19 | SO16 | SO16 | | IC | 2 | MN15; MN26 | SO16L01 | SO16L01 | | IC | 1 | MN34 | SO16_02 | SO16_02 | | IC | 2 | MN23; MN24 | SO20SO8 | SO20SO8 | | IC | 1 | MN14 | SO24 | SO24 | | IC | 1 | MN33 | SOD80C | SOD80C | | DISCRETE | 3 | CR11; CR12; CR14 | SOL28 | SOL28 | | IC | 1 | MN28 | SOT23T02 | SOT23T02 | | DISCRETE | 18 | CR9; CR10; CR13; CR17; CR18; CR19; CR20; CR21; CR22; CR23; CR24; Q4; Q5; Q6; Q7; Q8; Q9; Q10 | SOT223 | SOT223 | | DISCRETE | 1 | Q3 | SSOP16_03 | SSOP16_03 | | IC | 1 | MN29 | SUBD9M_H_C | SUBD9M_H_C | | IO | 2 | J23; J25 | SUBD15F01 | SUBD15F01 | | IO | 1 | J30 | SWITCHMS12 | SWITCHMS12 | | DISCRETE | 1 | BP1 | TM6CIR3_2 | TM6CIR3_2 | | IO | 4 | Z3; Z4; Z6; Z7 | TO269AA | TO269AA | | DISCRETE | 1 | CR15 | TPCMS5016 | TPCMS5016 | | IO | 4 | TP1; TP2; TP3; TP4 | TQFP32_01 | TQFP32_01 | | IC | 1 | MN17 | TSOP48_01 | TSOP48_01 | | IC | 1 | MN21 | TSOP48_02 | TSOP48_02 | | IC | 1 | MN13 | TSOP54_01 | TSOP54_01 | | IC | 2 | MN11; MN12 | TSSOP16_01 | TSSOP16_01 | | IC | 1 | MN27 | 附件:7 m- Q6 a4 z* [% Y# r% a3 t
PCB文件如下:
$ X5 V$ ~- @7 L* `- N7 ?, y' f0 C
, z! z$ o- T2 R
; ]0 a k8 H8 |" ~ |
