查看: 3463|回复: 26
[allegro16.6][8层] 飞思卡尔MPC8548方案POWERPC的高端电路板(MPC8548+RTL8211B+...
发表于 2020-4-7 17:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( m; m1 I  ?; \[allegro16.6][8层] 飞思卡尔MPC8548方案POWERPC的高端电路板(MPC8548+RTL8211B+5片DDR)原理图和pcb文件3 y; G: S- ^" w/ C. S" {2 k4 h0 u# T
1 y4 ]3 G6 U) E文件描述:
" x* `0 l" R, _3 I4 _3 a3 h" I2 B  v! x2 I: E) P
1. 作品用途:飞思卡尔MPC8548方案POWERPC的高端电路板
: G  @) f8 r4 j! W+ F2 i9 I2. 软件版本:allegro16.6
. @# K/ I0 h) k3. 层数:8层
- h5 U1 G" P3 ~% {( ^- G4. 用到的主要芯片:MPC8548+RTL8211B+5片DDR/ p. E) s+ @8 j
5. pcb尺寸: 5790*2790 MIL! ^: G: W" O* V  n: a
) ^' @' b# x4 ^5 [0 A! p作品截图如下:
* g/ {- @  C  Q
: n) {' d: B( I& O顶层截图:
3 X* B9 _( v. l" V
7 f) `; d) L+ L- Q. Q底层截图:
1 ]7 I: c; ^; M& r' N - j' h8 W' R5 t& X  e# p% P
- l1 L* p. E4 G9 N9 O全层截图:
% j4 x: X* w, n9 r% b3 I, o# @, q! P, R0 C4 V0 v9 u5 p( o: A
9 B" ~5 k) Q( v
叠层阻抗信息如下:0 D5 {+ o$ Y5 d8 q7 C' D9 c
4 X4 ^" a; k9 q" Q7 ~6 g6 G; G
BOM:$ z& _; `$ g5 m0 D$ J2 k
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA783MPC8548HIP8_HWREVC_0_BGA783_IC_MPC8548IC1U1
BTH_D_120BSH_120PIN_CONNECTOR_0_BTH_D_12BTH_120pin_connectorIO3P2; P4; P6
CASE_ECAP_CASEE_CASE_E_DISCRETE_470UF470uF 6V3DISCRETE2C256; C268
CC0402CAP_NP_1_CC0402_DISCRETE_10NF_C10nFDISCRETE48C1; C2; C3; C4; C5; C6; C7; C8; C20; C21; C23; C24; C30; C46; C114; C125; C128; C129; C130; C131; C132; C133; C137; C148; C149; C150; C151; C153; C154; C155; C156; C157; C158; C161; C162; C163; C164; C165; C166; C167; C168; C173; C174; C244; C245; C246; C247; C321
CC0402CAP_NP_1_CC0402_DISCRETE_10NF10nFDISCRETE2C169; C170
CC0402CAP_NP_1_CC0402_DISCRETE_3NF_CC3nFDISCRETE1C222
CC0402CAP_NP_1_CC0402_DISCRETE_100NF_100nFDISCRETE8C229; C230; C231; C232; C235; C236; C237; C238
CC0402CAP NP_2_CC0402_DISCRETE_10NF_C10nFDISCRETE5C273; C274; C275; C281; C306
CC0402CAP_NP_1_CC0402_DISCRETE_20PF20pFDISCRETE2C304; C305
CC0402R_4_CC0402_DISCRETE_0R_CC0402_C0RDISCRETE8R187; R190; R191; R193; R199; R200; R201; R202
CC0402_CRCAP_NP_1_CC0402_DISCRETE_10NF_C10nFDISCRETE135C9; C10; C11; C12; C13; C14; C15; C16; C17; C22; C25; C26; C27; C28; C31; C32; C33; C35; C36; C37; C38; C39; C41; C42; C43; C44; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C107; C108; C109; C110; C111; C112; C113; C115; C116; C117; C138; C139; C140; C141; C142; C143; C144; C147; C177; C178; C179; C180; C181; C182; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C198; C199; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C310; C319; C320
CC0402_CRCAP NP_0_CC0402_CR_DISCRETE_100100nFDISCRETE20C196; C200; C201; C202; C203; C249; C250; C261; C262; C277; C280; C284; C285; C286; C287; C288; C289; C290; C292; C293
CC0402_CRCAP_NP_1_CC0402_DISCRETE_100NF_100nFDISCRETE8C223; C224; C225; C226; C227; C228; C233; C234
CC0603CAP_NP_1_CC0603_DISCRETE_100NF100nFDISCRETE10C239; C240; C241; C242; C243; C251; C254; C267; C271; C283
CC0603CAP_NP_1_CC0603_DISCRETE_10NF-N10nF-NPDISCRETE1C294
CC0805CAP_NP_1_CC0805_DISCRETE_22UF_622uF_6V3DISCRETE47C18; C19; C29; C34; C40; C45; C65; C66; C89; C90; C118; C119; C120; C121; C122; C126; C127; C134; C135; C136; C145; C146; C152; C159; C160; C171; C172; C175; C176; C183; C184; C197; C218; C219; C252; C253; C255; C257; C258; C259; C260; C265; C266; C269; C270; C322; C323
CC0805CAP_NP_1_CC0805_DISCRETE_2.2UF_2.2uF_6V3DISCRETE2C220; C221
CC0805CAP_NP_1_CC0805_DISCRETE_10PF10pFDISCRETE1C248
CC0805CAP NP_0_CC0805_DISCRETE_22UF_622uF_6V3DISCRETE9C263; C264; C272; C278; C279; C282; C291; C324; C325
FBGA92DDR2-MO-207_0_FBGA92_IC_DDR2BGADDR2BGA92IC5U2; U3; U4; U5; U6
GBE_MAG24PG243002_0_GBE_MAG24_IC_PG24300PG243002IC1U59
HC49_SMDCRYSTAL_3_HC49_SMD_IC_25MHZ_CRY25Mhz_crystalIC1Y1
LED_0805LED0805_LED_0805_DISCRETE_G_LEDG_LED0805DISCRETE6D1; D2; D3; D4; D5; D6
LED_0805LED0805_LED_0805_DISCRETE_Y_LEDY_LED0805DISCRETE1D7
LED_0805LED0805_LED_0805_DISCRETE_R_LEDR_LED0805DISCRETE1D8
LED_0805LED0805_LED_0805_DISCRETE_GGDISCRETE3D9; D10; D11
LED_0805LED_5_LED_0805_DISCRETE_G_LED08G_LED0805DISCRETE6D12; D13; D14; D15; D16; D17
LL0805INDUCTOR_0_LL0805_DISCRETE_BEADBEAD-NPDISCRETE1L1
LL0805INDUCTOR_0_LL0805_DISCRETE_BE_1BEADDISCRETE6L2; L7; L8; L9; L18; L19
M3AT POINT F_3_M3A_M3M3IC2MH3; MH4
M3A_NON_PLATEDT POINT F_3_M3A_NON_PLATED_M3M3IC2MH1; MH2
OSC_SMTOSC_0_OSC_SMT_IC_66.667MHZ_OSCI66.667MHz_OscillatorIC1U10
PHR-3CON3_PHR-3_IO_PHR-3PHR-3IO1JP1
POWER_MODULEPOWER_MODULE_POWER_MODULE_IC_PTPTH03010WASIC1U54
QFN64PRTL8211B_QFN64P_IC_RTL8211BRTL8211BIC1U41
QTH_20DPQTH_20DP_QTH_20DP_IO_QTH_20DPQTH_20DPIO1P1
R0402R_4_R0402_DISCRETE_47R47RDISCRETE27R1; R2; R3; R4; R5; R6; R7; R9; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R30
R0402R_4_R0402_DISCRETE_10R10RDISCRETE38R33; R35; R64; R87; R88; R95; R96; R97; R98; R101; R102; R103; R104; R168; R185; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243
R0402R_4_R0402_DISCRETE_1K1KDISCRETE4R38; R39; R41; R42
R0402R_4_R0402_DISCRETE_4K7_R0402_CR4K7DISCRETE1R53
R0402R_4_R0402_DISCRETE_1K_R0402_CR1KDISCRETE1R54
R0402R_4_R0402_DISCRETE_4K74K7DISCRETE60R57; R58; R63; R72; R75; R79; R81; R84; R86; R93; R94; R105; R106; R107; R108; R115; R118; R119; R120; R121; R122; R123; R124; R125; R126; R136; R137; R140; R141; R142; R143; R144; R145; R154; R155; R156; R158; R170; R171; R214; R215; R216; R219; R220; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R267; R268; R269; R270
R0402R_4_R0402_DISCRETE_220R220RDISCRETE8R59; R60; R61; R62; R65; R69; R70; R71
R0402R_4_R0402_DISCRETE_33R33RDISCRETE3R66; R67; R68
R0402R_0_R0402_DISCRETE_4K74K7DISCRETE2R82; R83
R0402R_4_R0402_DISCRETE_470R470RDISCRETE2R99; R100
R0402R_4_R0402_DISCRETE_200R_R0402_C200RDISCRETE1R117
R0402R_4_R0402_DISCRETE_4K7-NP4K7-NPDISCRETE1R129
R0402R_0_R0402_DISCRETE_75R75RDISCRETE4R172; R178; R188; R189
R0402R_4_R0402_DISCRETE_0R_R0402_CR0RDISCRETE1R186
R0402R_0_R0402_DISCRETE_50R50RDISCRETE6R192; R194; R195; R196; R197; R198
R0402_CRR_4_R0402_DISCRETE_100R_R0402_C100RDISCRETE6R29; R85; R116; R212; R213; R244
R0402_CRR_4_R0402_DISCRETE_1K_R0402_CR1KDISCRETE2R55; R56
R0402_CRR_4_R0402_DISCRETE_4K7_R0402_CR4K7DISCRETE2R111; R112
R0402_CRR_4_R0402_DISCRETE_300R_R0402_C300RDISCRETE2R113; R114
R0402_CRR_4_R0402_DISCRETE_0R-NP_R0402_0R-NPDISCRETE8R138; R139; R257; R258; R259; R260; R261; R262
R0402_CRR_4_R0402_CR_DISCRETE_51R51RDISCRETE1R164
R0402_CRR_0_R0402_CR_DISCRETE_180R180RDISCRETE1R166
R0402_CRR_4_R0402_CR_DISCRETE_330R330RDISCRETE1R169
R0402_CRR_0_R0402_CR_DISCRETE_10R10RDISCRETE7R173; R174; R175; R176; R177; R179; R180
R0402_CRR_4_R0402_DISCRETE_4K7-NP_R04024K7-NPDISCRETE2R263; R264
R0402_CRR_4_R0402_DISCRETE_0R_R0402_CR0RDISCRETE1R266
R0603BR_4_R0603B_DISCRETE_4K74K7DISCRETE7R73; R78; R133; R147; R148; R217; R218
R0603BR_4_R0603B_DISCRETE_4K7-NP4K7-NPDISCRETE14R74; R77; R127; R128; R134; R135; R146; R149; R150; R151; R152; R153; R157; R271
R0603BR_4_R0603B_DISCRETE_0R0RDISCRETE2R89; R91
R0603BR_4_R0603B_DISCRETE_0R-NP0R-NPDISCRETE2R90; R92
R0603BR_0_R0603B_DISCRETE_4K74k7DISCRETE12R110; R130; R181; R182; R272; R273; R274; R275; R276; R277; R278; R279
R0603BR_4_R0603B_DISCRETE_0R-NP_R04020R-NPDISCRETE1R131
R0603BR_4_R0603B_DISCRETE_0R_R0402_CR0RDISCRETE1R132
R0603BR_4_R0603B_DISCRETE_10K10kDISCRETE1R184
R0603BR_4_R0603B_DISCRETE_4K7_4K7DISCRETE1R265
R0805R_4_R0805_DISCRETE_150R150RDISCRETE2R8; R10
R0805R_4_R0805_DISCRETE_18R2_1%18R2_1%DISCRETE2R31; R32
R0805R_4_R0805_DISCRETE_1R 1%_R08051R 1%DISCRETE1R109
R0805R_4_R0805_DISCRETE_5K65K6DISCRETE1R159
R0805R_4_R0805_DISCRETE_0R-NP0R-NPDISCRETE2R160; R161
R0805R_4_R0805_DISCRETE_24.2K 1%24.2K 1%DISCRETE1R162
R0805R_4_R0805_DISCRETE_10K10kDISCRETE1R163
R0805R_4_R0805_DISCRETE_22K22kDISCRETE1R165
R0805R_4_R0805_DISCRETE_330R330RDISCRETE1R167
R0805R_0_R0805_DISCRETE_2.49K 1%2.49K 1%DISCRETE1R183
RN0804BRN0804_0_RN0804B_DISCRETE_RN-4KRN-4K7DISCRETE2RN3; RN5
RN0804BRN0804_0_RN0804B_DISCRETE_RN-33RN-33RDISCRETE4RN7; RN8; RN9; RN10
RN0804BRN0804_0_RN0804B_DISCRETE_RN-_1RN-4K7DISCRETE6RN19; RN20; RN22; RN23; RN24; RN25
RN0804BRN0804_0_RN0804B_DISCRETE_RN-_2RN-4K7-NPDISCRETE3RN31; RN32; RN33
RN0804BRRN0804_0_RN0804B_DISCRETE_RN-4KRN-4K7DISCRETE3RN1; RN2; RN17
RN0804BRRN0804_0_RN0804B_DISCRETE_RN-33RN-33RDISCRETE6RN11; RN12; RN13; RN14; RN15; RN16
RN0804BRRN0804_0_RN0804B_DISCRETE_RN-_1RN-4K7DISCRETE6RN21; RN26; RN27; RN28; RN29; RN30
SMD_JP2X8CON16AP_1_SMD_JP2X8_IO_SMD_HEADSMD_HEADER_8x2IO1P10
SMD_SWSW PUSHBUTTON_0_SMD_SW_IO_TACT_TACT_SW_4pinIO1S1
SMD_SW_4PDIP_SWITCHX4_1_SMD_SW_4P_IO_SMDSMD_DIP_SWX4IO9S2; S3; S4; S5; S6; S7; S8; S9; S10
SMD_TPT_POINT_SMD_SMD_TP_IO_THERM0THERM0IO1TP1
SMD_TPT_POINT_SMD_SMD_TP_IO_ASLEEPASLEEPIO1TP2
SMD_TPT_POINT_SMD_SMD_TP_IO_THERM1THERM1IO1TP3
SMD_TPT_POINT_SMD_SMD_TP_IO_CLKOUTCLKOUTIO1TP4
SMD_TPT_POINT_SMD_SMD_TP_IO_TRIG-INTRIG-INIO1TP5
SMD_TPT_POINT_SMD_SMD_TP_IO_TRIG-OUTTRIG-OUTIO1TP6
SMD_TPT_POINT_SMD_SMD_TP_IO_MSRCID2MSRCID2IO1TP7
SMD_TPT_POINT_SMD_SMD_TP_IO_MSRCID4MSRCID4IO1TP8
SMD_TPT_POINT_SMD_SMD_TP_IO_MSRCID3MSRCID3IO1TP9
SMD_TPT_POINT_SMD_SMD_TP_IO_MDVALMDVALIO1TP10
SMD_TPT_POINT_SMD_SMD_TP_IO_LA30LA30IO1TP11
SMD_TPT_POINT_SMD_SMD_TP_IO_LA31LA31IO1TP12
SMD_TPT_POINT_SMD_SMD_TP_IO_LDP1LDP1IO1TP13
SMD_TPT_POINT_SMD_SMD_TP_IO_LDP0LDP0IO1TP14
SMD_TPT_POINT_SMD_SMD_TP_IO_LDP3LDP3IO1TP15
SMD_TPT_POINT_SMD_SMD_TP_IO_LDP2LDP2IO1TP16
SMD_TPT_POINT_SMD_SMD_TP_IO_SD-PLL-TPSD-PLL-TPAIO3TP17; TP21; TP23
SMD_TPT_POINT_SMD_SMD_TP_IO_SD-PLL-_1SD-PLL-TPDIO3TP18; TP20; TP22
SO8SEEPROM_1_SO8_IC_X24C02S8-3-NPX24C02S8-3-NPIC1U9
SO8LP2994_SO8_IC_LP2994MLP2994MIC1U57
SOT23TPS3808G12_SOT23_IC_TPS3808G09TPS3808G09IC1U61
SOT143AMAX811TEUS_SOT143A_IC_MAX811TEUMAX811TEUSIC1U13
SOT35374VHC1G08_SOT353_IC_74VHC1G08DF74VHC1G08DFIC2U11; U12
SOT35374VHC1G125_SOT353_74VHC1G125DF74VHC1G125DFIC4U18; U19; U21; U23
SOT35374VHC1G00_SOT353_IC_74VHC1G00DF74VHC1G00DFIC2U24; U50
SOT35374VHC1G32_SOT353_IC_74VHC1G32DF74VHC1G32DFIC1U26
SOT35374VHC1G02_1_SOT353_IC_74VHC1G0274VHC1G02DFIC1U27
SOT35374VHC1G08DF_SOT353_74VHC1G09DF74VHC1G09DFIC1U43
SOT35374VHC1G125_SOT353_IC_74VHC1G12574VHC1G125DFIC2U48; U49
SOT35374VHC1G14DF_SOT353_74VHC1G14DF74VHC1G14DFIC1U51
SOT353_DUAL_RESISTOR74VHC1G125_SOT353_IC_74VHC1G12574VHC1G125DFIC12U33; U34; U35; U36; U37; U38; U39; U40; U42; U44; U46; U47
SOT-892SB1188_SOT-89_2SB11882SB1188IC2Q1; Q2
SOT_223_4PIRU1206_SOT_223_4P_IC_IRU1206-2IRU1206-25CYIC1U56
SSOP16AMAX3232CUE_SSOP16A_IC_MAX3232CUMAX3232CUEIC1U32
S_PAKMIC29302BU_S_PAK_IC_MIC29302MIC29302IC1U55
TSOP48MX29LV640B_TSOP48_IC_MX29LV640BMX29LV640BTIC2U28; U30
TSSOP20A74LCX245_TSSOP20A_IC_MC74LCX245MC74LCX245DTIC6U14; U16; U25; U29; U31; U60
TSSOP4874ALVCH16245DT_TSSOP48_IC_MC74AMC74ALVCH16245DTIC2U15; U20
TSSOP4874ALVCH16373DT_TSSOP48_IC_MC74AMC74ALVCH16373DTIC2U17; U22
附件:
' {$ {  @/ U$ l0 i! e原理图和PCB文件如下:0 k5 _4 X: L5 A7 e, \7 |+ x3 C
游客,如果您要查看本帖隐藏内容请回复
0 {7 x  Y4 k/ v
) |4 V  K2 ?0 }2 c/ A) }
    擦汗
    2022-3-4 15:26
  • 签到天数: 56 天
    [LV.5]常住居民I
    推荐
    发表于 2021-1-15 14:46 | 只看该作者
    2025-7-18 15:30
  • 签到天数: 756 天
    [LV.10]以坛为家III
    推荐
    发表于 2021-7-2 10:59 | 只看该作者
    DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
    ' a  S8 `; x+ Y# X( p
    2023-5-29 15:28
  • 签到天数: 230 天
    [LV.7]常住居民III
    推荐
    发表于 2020-4-12 21:29 | 只看该作者
    下载来看看,多看看有好处。谢谢楼主。
    发表于 2020-4-9 20:53 | 只看该作者
    再转转了
    “来自电巢APP”
    发表于 2020-4-12 09:31 | 只看该作者
    是否收费
    “来自电巢APP”
    发表于 2020-4-14 00:11 | 只看该作者
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 17:49 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    2024-8-26 15:16
    发表于 2020-7-11 12:28 | 只看该作者
    多谢楼主无私分享! F' ^; ]# G- f5 O2 c/ X1 p2 s$ ~% l
    发表于 2020-11-10 10:33 | 只看该作者
    13#
    发表于 2020-11-13 13:32 | 只看该作者
    下载了看一i啊!
    5 p0 l* C+ [  Y$ P4 C' d: D
    14#
    发表于 2021-1-8 11:49 | 只看该作者
    谢谢楼主的分享
    2 N% {" L. h8 ?6 S; s
    15#
    发表于 2021-1-15 16:01 | 只看该作者
    看看高端电路图是怎么画的
    慵懒
    2023-12-14 15:50
  • 签到天数: 10 天
    [LV.3]偶尔看看II
    16#
    发表于 2021-1-15 17:11 | 只看该作者
    谢谢楼主分享
    GMT+8, 2025-7-18 23:54 , Processed in 0.140625 second(s), 29 queries , Gzip On.
