Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
4_8X4_8 | L_SMT_4_8X4_8_22UH | 22uH | IC | 1 | L16 |
A06-H-E_138 | SWITCH2_A06-H-E_138_SWITCH | Switch | IC | 4 | BP1;BP2;BP4;BP5 |
BAR2PTS02 | SIP2_BAR2PTS02_SIP2 | SIP2 | IC | 11 | JP4;JP8;JP9;JP10;JP12;JP13;JP14;JP15;JP16;JP17;JP18 |
BAR3PTS02 | SIP3-DROIT_BAR3PTS02_SIP3 | SIP3 | IC | 7 | JP1;JP2;JP3;JP5;JP6;JP7;JP11 |
BGA56_8X7_0295_039 | M58WR032KT_VFBGA56_BGA56_8X7_02 | M58WR032KT_VFBGA56 | IC | 1 | MN10 |
BP_KNITTER_TSSJ30 | JOYSTICK2_BP_KNITTER_TSSJ30_JOY | JoyStick | IC | 1 | BP3 |
C0603 | C0603_C0603_100N | 100n | IC | 129 | C1;C8;C18;C28;C30;C38;C39;C40;C41;C42;C43;C44;C45;C47;C48;C49;C51;C52;C54;C55;C56;C58;C59;C60;C61;C62;C63;C64;C65;C67;C68;C69;C70;C71;C72;C73;C74;C75;C76;C77;C78;C79;C80;C81;C82;C83;C84;C85;C86;C87;C88;C89;C91;C92;C93;C94;C95;C96;C97;C98;C99;C100;C101;C102;C103;C104;C105;C106;C107;C108;C109;C110;C111;C112;C113;C114;C115;C116;C117;C118;C119;C120;C121;C122;C123;C124;C125;C130;C131;C135;C136;C138;C139;C141;C143;C145;C153;C157;C158;C159;C160;C161;C162;C163;C164;C165;C166;C167;C169;C172;C173;C176;C177;C178;C179;C182;C183;C184;C185;C186;C188;C196;C197;C200;C202;C203;C207;C210;C212 |
C0603 | C0603_C0603_10N | 10n | IC | 14 | C3;C5;C16;C19;C31;C32;C33;C34;C35;C36;C37;C192;C193;C194 |
C0603 | C0603_C0603_1U | 1u | IC | 12 | C7;C10;C11;C13;C22;C24;C25;C26;C146;C147;C150;C151 |
C0603 | C0603_C0603_15P | 15p | IC | 3 | C17;C53;C57 |
C0603 | C0603_C0603_22P | 22p | IC | 6 | C46;C50;C133;C137;C174;C175 |
C0603 | C0603_C0603_10P | 10p | IC | 4 | C66;C171;C208;C209 |
C0603 | C0603_C0603_470P | 470p | IC | 6 | C128;C129;C148;C149;C155;C156 |
C0603 | C0603_C0603_33P | 33p | IC | 1 | C204 |
C0603 | C0603_C0603_100P | 100p | IC | 2 | C205;C206 |
C0603 | R0603_C0603_220K | 220K | IC | 1 | R205 |
C0805 | C0805_C0805_4.7U | 4.7u | IC | 5 | C2;C14;C20;C29;C90 |
C1206 | C1206_C1206_2.2U_10% X5R | 2.2u | IC | 2 | C15;C191 |
C1206 | C1206_C1206_10U | 10u | IC | 2 | C189;C190 |
CE1206 | CE1206_CE1206_10U | 10u | IC | 20 | C6;C9;C12;C21;C23;C27;C132;C134;C140;C142;C144;C152;C154;C180;C181;C187;C198;C199;C201;C211 |
CI_ATMEL_TFBGA324_0MM8_SOCKET6088 | AT91SAM9M10_CI_ATMEL_TFBGA324_0 | AT91SAM9G45 | IC | 1 | MN5 |
CI_MICRON_FBGA60_8X10 | DDRII64M8-FBGA60_CI_MICRON_FBGA | MT47H64M8CF-3 -F | IC | 4 | MN6;MN7;MN8;MN9 |
CI_MICRON_VFBGA63_0MM8 | NAND2G08_VFBGA63_CI_MICRON_VFBG | MT29F2G08ABDHC | IC | 1 | MN11 |
CON_3_WDC001_575 | DC POWER JACK_CON_3_WDC001_575_ | DC POWER JACK | IC | 1 | J2 |
CON_AMP_787616 | USB_A_CON_AMP_787616_G3505-4NBT | G3505-4NBT1S1W | IC | 1 | J12 |
CON_FPS_SDCARD_009_3202 | SD_MMC_12PIN_CON_FPS_SDCARD_009 | FPS009-3202-BL | IC | 1 | J6 |
CON_JACK_KLBR-4J | STEREO CMS_CON_JACK_KLBR-4J_STE | STEREO_3.5mm | IC | 3 | J7;J8;J9 |
CON_KINGCONN_7SDMM_2211 | SD_MMCPLUS_CON_KINGCONN_7SDMM_2 | 7SDMM-B0-2211 | IC | 1 | J5 |
CON_LCD_TFT1N4633_40 | FPC_40PINS_CON_LCD_TFT1N4633_40 | FPC_top_40pins | IC | 1 | J24 |
CON_RJ45_J00_00XX_SHIELD | J0061NL_CON_RJ45_J00_00XX_SHIEL | J00-0061NL | IC | 1 | J15 |
CON_SAMTEC_SSM_110_X_DV | HDR_2X10_SMT_CON_SAMTEC_SSM_110 | HDR_2x10_SMT | IC | 1 | J18 |
CON_SAMTEC_SSM_120_X_DV | HDR_2X20_SMT_CON_SAMTEC_SSM_120 | HDR_2x20_SMT | IC | 1 | J23 |
CON_SAMTEC_TSM_104_01_DV_A | TSM 2X4 PTS-DROIT_0_CON_SAMTEC_ | TSM-104-01-LM-DV-TR | IC | 1 | J1 |
CON_SAMTEC_TSM_115_01_DV_A | HDR_2X15_SMT_CON_SAMTEC_TSM_115 | HDR_2x15_SMT | IC | 1 | J17 |
CRS_DO214AB_01 | TVS_CRS_DO214AB_01_5V | 5V | IC | 1 | CR1 |
C_6032 | CE_SMT_C_6032_33U | 33u | IC | 3 | C4;C168;C170 |
C_PANASONIC_FK_D | CE_SMT_C_PANASONIC_FK_D_100U/6. | 100u/6.3V | IC | 2 | C126;C127 |
HE10M2X10TH | HDR_2X10_TH_HE10M2X10TH_HTST-11 | HTST-110-01-SM-D | IC | 1 | J13 |
JACK2P_815X512_728 | RCA JACK_JACK2P_815X512_728_RCA | RCA JACk | IC | 1 | J20 |
JEDEC_MS026_BBC_LQFP7X7_48 | DM9161AE_0_JEDEC_MS026_BBC_LQFP | DM9161AEP | IC | 1 | MN18 |
JEDEC_MS026_BBC_LQFP7X7_48 | CH7024B_JEDEC_MS026_BBC_LQFP7X7 | CH7024B | IC | 1 | MN20 |
L1210 | L1206_L1210_10UH | 10uH | IC | 6 | L1;L2;L3;L4;L5;L11 |
LED0805 | LED_LED0805_GREEN | Green | IC | 4 | D1;D2;D5;D6 |
LED0805 | LED_LED0805_RED | Red | IC | 1 | D3 |
LED0805 | LED_LED0805_YELLOW | Yellow | IC | 1 | D4 |
OSC4SM_126X98_039 | OSCILLATOR_OSC4SM_126X98_039_50 | 50MHz | IC | 1 | Y4 |
OSC4SM_126X98_039 | OSCILLATOR_OSC4SM_126X98_039_13 | 13MHz | IC | 1 | Y6 |
OSC-7M | CRYSTAL_4PIN_OSC-7M_12MHZ | 12MHz | IC | 1 | Y1 |
OSC-7M | CRYSTAL_4PIN_OSC-7M_25MHZ | 25MHz | IC | 1 | Y5 |
OSC-7M | CRYSTAL_4PIN_OSC-7M_13MHZ | 13MHz | IC | 1 | Y7 |
OSC-9H | CRYSTAL_OSC-9H_32.768KHZ | 32.768KHz | IC | 1 | Y2 |
PILE_KEYSTONE_3000_DIA12MM0 | BATTERYHOLDER_PILE_KEYSTONE_300 | BatteryHolder | IC | 1 | J3 |
QFN48_276_0197_039 | WM9711L_0_QFN48_276_0197_039_WM | WM9711L | IC | 1 | MN14 |
R0603 | R0603_R0603_1R | 1R | IC | 5 | R1;R5;R12;R20;R50 |
R0603 | R0603_R0603_100K | 100k | IC | 16 | R2;R3;R9;R10;R11;R13;R23;R26;R53;R55;R74;R86;R87;R88;R89;R199 |
R0603 | R0603_R0603_47K | 47k | IC | 7 | R4;R8;R19;R71;R72;R95;R97 |
R0603 | R0603_R0603_12K | 12k | IC | 3 | R6;R14;R18 |
R0603 | R0603_R0603_15K | 15k | IC | 2 | R7;R15 |
R0603 | R0603_R0603_10K | 10k | IC | 10 | R16;R17;R38;R64;R65;R66;R73;R98;R162;R184 |
R0603 | R0603_R0603_470R | 470R | IC | 6 | R21;R22;R25;R118;R119;R121 |
R0603 | R0603_R0603_1K | 1k | IC | 2 | R24;R61 |
R0603 | R0603_R0603_100R | 100R | IC | 3 | R27;R28;R29 |
R0603 | R0603_R0603_39R | 39R | IC | 4 | R30;R31;R32;R33 |
R0603 | R0603_R0603_0R | 0R | IC | 86 | R34;R35;R36;R54;R57;R58;R60;R63;R68;R69;R70;R75;R76;R77;R85;R90;R91;R92;R93;R94;R99;R100;R101;R103;R104;R105;R106;R108;R109;R110;R112;R114;R116;R120;R122;R123;R127;R128;R129;R130;R131;R132;R133;R134;R136;R137;R138;R139;R140;R141;R142;R143;R144;R145;R146;R147;R148;R149;R150;R151;R152;R153;R154;R155;R156;R157;R158;R159;R160;R161;R163;R165;R166;R167;R168;R169;R170;R171;R172;R173;R174;R175;R176;R185;R186;R200 |
R0603 | R0603_R0603_6.8K | 6.8k | IC | 2 | R37;R117 |
R0603 | R0603_R0603_4.7K | 4.7k | IC | 4 | R39;R126;R179;R180 |
R0603 | R0603_R0603_27R | 27R | IC | 11 | R40;R41;R42;R43;R44;R45;R46;R47;R48;R49;R125 |
R0603 | R0603_R0603_1.5K | 1.5k | IC | 3 | R51;R52;R115 |
R0603 | R0603_R0603_470K | 470k | IC | 4 | R56;R59;R62;R67 |
R0603 | R0603_R0603_49.9R | 49.9R | IC | 5 | R78;R102;R107;R111;R113 |
R0603 | R0603_R0603_8.2K | 8.2K | IC | 4 | R79;R80;R81;R82 |
R0603 | R0603_R0603_680R | 680R | IC | 2 | R83;R84 |
R0603 | R0603_R0603_68K | 68k | IC | 13 | R96;R187;R188;R189;R190;R191;R192;R193;R194;R195;R196;R197;R198 |
R0603 | R0603_R0603_10R | 10R | IC | 5 | R164;R201;R202;R203;R204 |
R0603 | R0603_R0603_1.2K_1% | 1.2k | IC | 1 | R178 |
R0603 | R0603_R0603_75R | 75R | IC | 3 | R181;R182;R183 |
R0805 | BEAD_ FERRITE_R0805_220OHM AT 1 | 220ohm at 100MHz | IC | 8 | L6;L7;L8;L9;L10;L12;L13;L14 |
R0805 | BEAD_ FERRITE_R0805_2200R | 2200R | IC | 6 | L15;L17;L18;L19;L20;L21 |
R0805 | L0805_R0805_1.8UH | 1.8uH | IC | 1 | L22 |
RN0402 | RN0402X4_RN0402_33R | 33R | IC | 5 | RR1;RR4;RR8;RR14;RR54 |
RN0402 | RN0402X4_RN0402_27R | 27R | IC | 29 | RR2;RR3;RR5;RR6;RR7;RR9;RR10;RR11;RR12;RR13;RR15;RR16;RR17;RR18;RR19;RR20;RR21;RR22;RR23;RR24;RR25;RR26;RR27;RR28;RR29;RR30;RR31;RR32;RR33 |
RN0402 | RR0402_RN0402_10K | 10k | IC | 5 | RR36;RR44;RR45;RR46;RR47 |
RN0402 | RR0402_RN0402_27R | 27R | IC | 5 | RR38;RR39;RR40;RR41;RR42 |
RN0402 | RN0402_RN0402_27R | 27R | IC | 6 | RR48;RR49;RR50;RR51;RR52;RR53 |
RN0603 | RR0402_RN0603_100K | 100k | IC | 1 | RR43 |
SM_5_SOT23_70H | CP2122_SM_5_SOT23_70H_CP2122ST | CP2122ST | IC | 1 | MN19 |
SO8 | AT24_IICFLASH_SO8_AT24C512BN | AT24C512BN | IC | 1 | MN12 |
SO16 | ADM3202-SOIC16N_SO16_ADM3202ARN | ADM3202ARNZ | IC | 2 | MN15;MN16 |
SOD-123 | SCH_SOD-123_RB160M-60 | RB160M-60 | IC | 1 | D7 |
SOIC8_325_0500_085 | AT45D_SPIFLASH_SOIC8_325_0500_0 | AT45DB321D-SU | IC | 1 | MN13 |
SOP8_244_0500_069 | SP2526A-SO8_SOP8_244_0500_069_A | AIC1526-0GS | IC | 1 | MN17 |
SOP_8__50_154X193_69 | RT9018A_SOP_8__50_154X193_69_RT | RT9018A | IC | 2 | MN2;MN4 |
SOT23 | SCH_2SERIES_SOT23_SOT23_BAT54SL | BAT54SLT1G | IC | 1 | D8 |
SOT23T02 | NMOS_SOT23T02_IRLML2402 | IRLML2402 | IC | 1 | Q2 |
SOT-363 | SI1563EDH_SOT-363_SI1563EDH | Si1563EDH | IC | 1 | Q1 |
SUBD9M | DSUB9_M_SUBD9M_DB9M_R | DB9M_R | IC | 2 | J10;J11 |
TP_0MM4_0MM9 | TEST_POINT_TP_0MM4_0MM9_TP PAD | TP pad | IC | 1 | TP5 |
TP_KEYSTONE_5012 | TEST_POINT_TP_KEYSTONE_5012_TP | TP | IC | 5 | TP1;TP2;TP3;TP4;TP6 |
USBCONN_5SM_315X217_118 | USB_MICROAB_USBCONN_5SM_315X217 | G3515-09010101-00 | IC | 1 | J14 |
VDFN_8_026_120X120_39 | RT9186A_VDFN_8_026_120X120_39_R | RT9186A | IC | 2 | MN1;MN3 |
XTAL4SM_197X126_035 | CRYSTAL_4PIN_XTAL4SM_197X126_03 | 24.576MHz | IC | 1 | Y3 |
附件:
