查看: 482|回复: 1
FPC专业术语简介
发表于 2020-4-2 14:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
; l) u1 U7 v" E  N9 u+ D
专业术语简介8 W/ m7 |6 Q% Y  L( M  I* k' b
) N4 Z0 _$ s* s
决定出去见识见识,出去后与同事交流时: w) [9 V, D( w" W# H; ^  I" M% o
dummying为何物?所以呢这些术语不知道到底有多大的用处,但
0 C* a6 ^7 r$ n6 U
( j$ G  d' V$ f: E  J
$ O2 N  |: y& B  n8 E( t:Printed circuit board,印刷电路板; ! s5 x# e& K6 G5 H
: Flexible Printed circuit,柔性电路板,也称挠性电路板,俗称软板;
& K* F4 o. f% W6 l0 n:Copper Clad Laminates,铜箔基材; ( R$ K2 u8 s$ n; N
:Flexible Copper Clad Laminates,柔性铜箔基材;
3 a9 A, F: u- j* R* |" x:Roll Anneal Copper Foil,压延铜;
# ^6 n& x0 E2 L- f) w! T:Electrolysis Desposition Copper Foil,电解铜;
' n$ A% w# h8 D9 M7 U:Adhesive,粘接剂,俗称胶;
2 Z$ w& Y7 d% m! J* I, \:Polyimide,聚亚酰胺;
! `9 s9 n# s# s; S  F5 K+ \:Cover lay,覆盖膜,日资厂称为保胶、有的厂称为包封等
+ B& S5 z; N# t; z$ X! L- r:Solder Resist,阻焊;
4 ?& J2 J, \8 _& U' n:电磁屏蔽膜;
4 L/ E. Y  ~1 O- i8 Y8 F% @3 F:Prepreg,半固化片,也称黏结片
4 R+ S) e! A. F/ |; f:Liquid Crystal Polyme,液晶聚合物 : u7 [+ j4 o! F1 K
:Plated Trough Holes,镀通孔
' R4 M$ E6 \) `- Y, g, z) M:No Plated Trough Holes,
5 P+ c, S2 ?3 Y0 M8 u1 T, U( e:Blind Via Holes盲孔
6 V7 g) {2 Z, F* @:Electroless Nickel Immersion Gold无电解(化学)镍金 / X: D! h' u% F0 u4 ~$ t6 |
:Electroless Nickel Electroless Palladium Immersion Gold无电解(化学)0 M$ z) D% e3 s
6 Q/ N1 U+ S# I# P$ P- i3 H
:Organic Solderability Preservatives,有机可焊性预处理; ; I6 B' I! t  U) x4 Q$ D* ~
:Integrated Circuit,集成电路; " e" j+ F; [# A& U
:Automatic Optic Inspection;自动光学检查; 8 P4 d2 G: {+ E8 m
:Vertical Continuous Plate,垂直连续电镀;
" G% ]) @3 c1 Z0 _3 RVI:
" r' ?0 s  V+ D  A4 h5 ^! ~:SuRFace Mount Technology,表面贴装技术;
0 o' n% |$ i) b4 @. X' x, ?& T* e9 x:Design For Manufacture,可制造性设计; $ a% g# ?: S$ p; u5 p
2 W8 ~: \0 Y! t:Developing Etching Stripping显影、蚀刻、去膜
; _8 @/ D! H& r8 v; g, v7 R% Y/ g3 y$ L
    2019-11-19 15:55
    发表于 2020-4-2 17:29 | 只看该作者
    决定出去见识见识,出去后与同事交流时为何物?所以呢这些术语不知道到底有多大的用处
    GMT+8, 2025-7-27 20:31 , Processed in 0.140625 second(s), 23 queries , Gzip On.
