Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BATTERY | BATTERY_0_BATTERY_BATTERY HL | BATTERY Hl | IC | 1 | BH1 |
BGA361 | OMAP-L138_0_BGA361_OMAP-L138 | OMAP-L138 | IC | 1 | U6 |
BGA-63 | K9F1208R0C_8_BGA-63_MT29F1G08AB | MT29F1G08ABCHC:C | IC | 1 | U17 |
BGA-DDR2 | MT47H64M16HR _1_BGA-DDR2_MT47H6 | MT47H64M16HR-3 IT | IC | 1 | U16 |
C0402 | CAPACITOR NON-POL_C0402_0.1UF/5 | 0.1uF/50V X7R | IC | 116 | C3; C19; C20; C21; C22; C23; C24; C25; C28; C29; C30; C32; C33; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C47; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C65; C66; C67; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C85; C88; C95; C96; C97; C98; C100; C101; C102; C103; C104; C105; C107; C108; C117; C118; C119; C121; C125; C127; C129; C132; C134; C136; C137; C139; C140; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C165; C166; C167; C168; C169; C170; C173; C175; C181; C182; C184; C185; C186; C187; C188; C189; C192 |
C0402 | CAP NP_C0402_0.1UF/50V X7R | 0.1uF/50V X7R | DISCRETE | 5 | C4; C91; C92; C93; C94 |
C0402 | CAPACITOR NON-POL_C0402_0.22UF/ | 0.22uF/50V X7R | IC | 2 | C26; C27 |
C0402 | CAPACITOR_C0402_0.1UF/50V X7R | 0.1uF/50V X7R | IC | 5 | C69; C70; C138; C202; C203 |
C0402 | CAPACITOR NON-POL_C0402_33PF/50 | 33pF/50V NPO | IC | 3 | C106; C111; C114 |
C0402 | CAPACITOR NON-POL_C0402_100PF/5 | 100pF/50V NPO | IC | 3 | C109; C112; C115 |
C0402 | CAPACITOR NON-POL_C0402_270PF/5 | 270pF/50V NPO | IC | 3 | C110; C113; C116 |
C0402 | CAPACITOR NON-POL_C0402_0.01UF/ | 0.01uF/50V X7R | IC | 8 | C120; C122; C126; C128; C130; C133; C135; C141 |
C0402 | CAP NP_1_C0402_0.1UF/50V X7R | 0.1uF/50V X7R | IC | 1 | C179 |
C0603 | CAP POL_C0603_1UF/16V/X7R | 1uF/16V/X7R | IC | 2 | C7; C180 |
C0603 | CAPACITOR NON-POL_C0603_10PF/_1 | 10pF/50V X7R | IC | 1 | C48 |
C0603 | CAPACITOR NON-POL_C0603_18PF/50 | 18pF/50V NPO | IC | 2 | C83; C84 |
C0603 | CAPACITOR NON-POL_C0603_33PF/50 | 33pF/50V/COG | IC | 4 | C86; C87; C199; C200 |
C0603 | CAPACITOR NON-POL_C0603_27PF/50 | 27pF/50V X7R | IC | 4 | C89; C90; C171; C172 |
C0603 | CAPACITOR NON-POL_C0603_1UF/16V | 1uF/16V/X7R | IC | 3 | C99; C142; C191 |
C0603 | CAPACITOR NON-POL_C0603_330PF/1 | 330pF/100V X7R | IC | 1 | C164 |
C0603 | CAP NP_C0603_220PF/50V X7R | 220pF/50V X7R | IC | 2 | C174; C176 |
C0603 | CAPACITOR NON-POL_C0603_10PF/50 | 10pF/50V COG | IC | 4 | C193; C194; C195; C196 |
C0603 | CAPACITOR_C0603_0.022UF/50V X7R | 0.022uF/50V X7R | IC | 1 | C197 |
C0603 | CAPACITOR_C0603_0.1UF/50V X7R | 0.1uF/50V X7R | IC | 1 | C205 |
C0805 | CAP POL_C0805_10UF/16V X5R | 10uF/16V X5R | IC | 14 | C1; C2; C5; C6; C8; C9; C10; C11; C12; C13; C14; C183; C190; C201 |
C0805 | CAP POL_C0805_2.2UF/16V X7R | 2.2uF/16V X7R | IC | 3 | C15; C16; C17 |
C0805 | CAP POL_C0805_1UF/16V/X7R | 1uF/16V/X7R | IC | 1 | C18 |
C0805 | CAPACITOR NON-POL_C0805_10UF/16 | 10uF/16V X5R | IC | 11 | C31; C34; C46; C49; C50; C64; C68; C81; C123; C124; C131 |
C1206 | CAPACITOR NON-POL_C1206_4.7UF/2 | 4.7uF/25V X5R | IC | 1 | C82 |
C1206 | C_C1206_1000PF/2KV X7R | 1000pF/2KV X7R | IC | 2 | C198; C204 |
CAPT6032N | FUSE_CAPT6032N_1500MA | 1500mA | IC | 1 | F1 |
CC1206P | R_CC1206P_1.0OHM 2W | 1.0ohm 2W | IC | 1 | R2 |
CON2X100P-14 | CON14AP_0_CON2X100P-14_72454-01 | 72454-014LF | IC | 1 | J6 |
CSM-7 | CRYSTAL_4_CSM-7_CS10-24.000MABJ | CS10-24.000MABJ-UT | IC | 1 | Y3 |
CSM-7 | CRYSTAL_5_CSM-7_CS10-14.31818MA | CS10-14.31818MABJ-UT | IC | 1 | Y4 |
CSM-7 | CRYSTALL_0_CSM-7_CS10 25.000MAB | CS10 25.000MABJ-UT | IC | 1 | Y6 |
DB9-HF | DSUB9-MALE_DB9-HF_190-009-163R0 | 190-009-163R001 | IC | 1 | J3 |
DBV | NC7WZ16P6X_1_DBV_SN74LVC2G34DBV | SN74LVC2G34DBVR | IC | 1 | U9 |
DBV | SN74LVC1G11_DBV_SN74LVC1G11DBVR | SN74LVC1G11DBVR | IC | 1 | U10 |
DCU | SN74LVC2T45DCUT_DCU_SN74AVCH2T4 | SN74AVCH2T45DCUR | IC | 1 | U11 |
DCU | SN74LVC2T45DCUT_DCU_SN74LVC2T45 | SN74LVC2T45DCUR | IC | 1 | U13 |
DCU | TXS0102DCUR_DCU_TXS0102DCUR | TXS0102DCUR | IC | 1 | U15 |
DIP8 | SW DIP-4_0_DIP8_MGDH04 | MGDH04 | IC | 1 | SW1 |
F0805 | INDUCTOR_F0805_MMZ2012S121A | MMZ2012S121A | IC | 27 | FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB23; FB24; FB25; FB26; FB27 |
FSX | CRYSTAL_6_FSX_FSX327LF | FSX327LF | IC | 1 | Y2 |
HDR50X2 | CONN PCB 50X2-S_HDR50X2_GRPB502 | GRPB502VWQP-RC | IC | 1 | J13 |
L0805 | INDUCTOR_L0805_1UH/80MA | 1uH/80mA | IC | 3 | L4; L5; L6 |
LED0805 | LED_LED0805_LED-G | LED-G | IC | 6 | LED1; LED2; LED3; LED4; LED5; LED6 |
LQFP48 | THS8135PHP_8_LQFP48_THS8135PFP | THS8135PFP | IC | 1 | U12 |
MINIUSB-5PF | MINI-USB-AB-SOCKET_2_MINIUSB-5P | SD-56579-015 | IC | 1 | J2 |
MSOP8 | TPS2087_0_MSOP8_TPS2068DGNR | TPS2068DGNR | IC | 1 | U3 |
OSC_7X5 | OSC4/SM_0_OSC_7X5_CB3LV-3I-24M5 | CB3LV-3I-24M5760 | IC | 1 | Y5 |
OSC_SATA | ECS-250-20-33-A-E-L-TR_2_OSC_SA | ECS-250-20-33-A-E-L-TR | IC | 1 | Y1 |
PE_RES_0402_3P_OPTION | JUMPER_0_PE_RES_0402_3P_OPTION_ | 1K/1% 1/10W | IC | 1 | R22 |
POWERJACK | KLDX-0202-AC_1_POWERJACK_PJ-002 | PJ-002A | IC | 1 | J1 |
PQFP80 | TVP5146M2_1_PQFP80_TVP5147M1PFP | TVP5147M1PFP | IC | 1 | U20 |
PULSE_H2019 | S558-5999-46_2_PULSE_H2019_HX11 | HX1188NL | IC | 1 | TFR1 |
QFN32 | TPS650250_3_QFN32_TPS650250RHBR | TPS650250RHBR | IC | 1 | U5 |
QFN32 | CDCM61001RHBT_0_QFN32_CDCM61001 | CDCM61001RHBT | IC | 1 | U8 |
QFN32 | LAN8700_SMALL_0_QFN32_LAN8710A- | LAN8710A-EZK | IC | 1 | U22 |
QFN48 | TLV320AIC3106_5_QFN48_TVL320AIC | TVL320AIC3106RGZ | IC | 1 | U21 |
R0402 | R_R0402_220E/5% 1/10W | 220E/5% 1/10W | IC | 1 | R1 |
R0402 | R_R0402_3.4K/1% 1/10W | 3.4K/1% 1/10W | IC | 2 | R3; R120 |
R0402 | R_R0402_1K/1% 1/10W | 1K/1% 1/10W | IC | 9 | R4; R28; R33; R34; R43; R44; R128; R129; R153 |
R0402 | RESISTOR_R0402_0E/5% 1/10W | 0E/5% 1/10W | IC | 19 | R5; R6; R58; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R118; R119; R125; R126 |
R0402 | R_R0402_10K/1% 1/10W | 10K/1% 1/10W | IC | 30 | R7; R8; R54; R59; R60; R63; R64; R65; R66; R67; R69; R70; R71; R73; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R92; R99; R100 |
R0402 | R_R0402_4.7K/5% 1/10W | 4.7K/5% 1/10W | IC | 43 | R9; R10; R13; R16; R17; R19; R20; R23; R29; R30; R31; R32; R35; R36; R37; R39; R45; R46; R47; R48; R49; R50; R51; R57; R101; R102; R103; R116; R117; R130; R136; R143; R145; R146; R147; R149; R151; R154; R155; R167; R175; R191; R192 |
R0402 | R_R0402_1E/5%/1/10W | 1E/5%/1/10W | IC | 1 | R11 |
R0402 | R_R0402_100K/1% 1/10W | 100K/1% 1/10W | IC | 3 | R12; R14; R148 |
R0402 | R_R0402_330E/1% 1/10W | 330E/1% 1/10W | IC | 1 | R15 |
R0402 | R_R0402_5.6K/1% 1/10W | 5.6K/1% 1/10W | IC | 1 | R18 |
R0402 | R_R0402_1.4K/1% 1/10W | 1.4K/1% 1/10W | IC | 1 | R21 |
R0402 | R_R0402_200K/1% 1/10W | 200K/1% 1/10W | IC | 1 | R24 |
R0402 | R_R0402_160K/1% 1/10W | 160K/1% 1/10W | IC | 1 | R25 |
R0402 | R_R0402_300K/1% 1/10W | 300K/1% 1/10W | IC | 1 | R26 |
R0402 | R_R0402_60K/1% 1/10W | 60K/1% 1/10W | IC | 1 | R27 |
R0402 | R_R0402_1.18K/1% 1/10W | 1.18K/1% 1/10W | IC | 1 | R38 |
R0402 | R_R0402_680E/5% 1/10W | 680E/5% 1/10W | IC | 2 | R40; R41 |
R0402 | RESISTOR_R0402_100E/1% 1/10W | 100E/1% 1/10W | IC | 1 | R52 |
R0402 | R_R0402_100E/1% 1/10W | 100E/1% 1/10W | IC | 18 | R53; R68; R72; R76; R93; R94; R95; R96; R177; R178; R179; R180; R181; R182; R183; R184; R187; R188 |
R0402 | RESISTOR_R0402_10K/1% 1/10W | 10K/1% 1/10W | IC | 1 | R55 |
R0402 | R_R0402_0E/5% 1/10W | 0E/5% 1/10W | IC | 6 | R56; R61; R62; R150; R173; R190 |
R0402 | R_R0402_330E/5% 1/10W | 330E/5% 1/10W | IC | 2 | R90; R91 |
R0402 | RESISTOR_R0402_33E/5% 1/10W | 33E/5% 1/10W | IC | 3 | R97; R98; R168 |
R0402 | R_R0402_75E/5% 1/10W | 75E/5% 1/10W | IC | 3 | R121; R122; R127 |
R0402 | RESISTOR_R0402_2.2K/1% 1/10W | 2.2K/1% 1/10W | IC | 2 | R123; R124 |
R0402 | RESISTOR_R0402_22E/1% 1/10W | 22E/1% 1/10W | DISCRETE | 9 | R131; R132; R133; R134; R135; R139; R140; R141; R142 |
R0402 | RESISTOR_R0402_10E/1% 1/10W | 10E/1% 1/10W | DISCRETE | 2 | R137; R138 |
R0402 | RESISTOR_R0402_4.7K/5% 1/10W | 4.7K/5% 1/10W | IC | 1 | R144 |
R0402 | R_R0402_20K/1% 1/10W | 20K/1% 1/10W | IC | 4 | R152; R160; R161; R165 |
R0402 | R_R0402_5.6K/5% 1/10W | 5.6K/5% 1/10W | IC | 4 | R156; R157; R158; R159 |
R0402 | R_R0402_2K/1% 1/10W | 2K/1% 1/10W | IC | 4 | R162; R163; R164; R166 |
R0402 | R_R0402_49.9E/1% 1/10W | 49.9E/1% 1/10W | IC | 4 | R169; R170; R171; R172 |
R0402 | R_R0402_1.5K/1% 1/10W | 1.5K/1% 1/10W | IC | 2 | R174; R176 |
R0402 | RESISTOR_R0402_75E/5% 1/10W | 75E/5% 1/10W | IC | 2 | R185; R186 |
R0402 | RESISTOR_R0402_12.1K/1% 1/10W | 12.1K/1% 1/10W | IC | 1 | R189 |
R0402 | R_R0402_10E/1% 1/10W | 10E/1% 1/10W | IC | 1 | R193 |
R0402 | R_R0402_1M/5% 1/10W | 1M/5% 1/10W | IC | 1 | R194 |
R0402 | RESISTOR_R0402_220E/5% 1/10W | 220E/5% 1/10W | IC | 2 | R195; R202 |
R0402 | RESISTOR_R0402_49.9E/1% 1/10W | 49.9E/1% 1/10W | IC | 6 | R196; R197; R198; R199; R200; R201 |
R0603 | R_R0603_50E/0.5% 1/8W | 50E/0.5% 1/8W | IC | 1 | R42 |
R0603 | R_R0603_2.2K/5% 1/8W | 2.2K/5% 1/8W | IC | 2 | R74; R75 |
RCA | CONNECTOR COAX-J_1_RCA_RCJ-014 | RCJ-014 | IC | 1 | J9 |
RJ45-59_LED | RJHSE-5384_0_RJ45-59_LED_2-4065 | 2-406549-4 | IC | 1 | J12 |
RN0804 | RESISTOR DIP 4_RN0804_4.7K/5% 1 | 4.7K/5% 1/10W | IC | 11 | RP1; RP2; RP3; RP4; RP5; RP6; RP7; RP8; RP9; RP10; RP11 |
SATA | 8 HEADER_0_SATA_SD-67491-002 | SD-67491-002 | IC | 1 | J7 |
SD | MMC4_1.0_CONN_SD_MHC-W21-601 | MHC-W21-601 | IC | 1 | J4 |
SIP100P2N | B2S_0_SIP100P2N_JUMPER 2P | JUMPER 2P | IC | 1 | JP1 |
SMD_SW | SPST W/ESD_2_SMD_SW_GSE10.00F13 | GSE10.00F130QP | IC | 1 | S1 |
SOIC8 | TPS3705_0_SOIC8_TPS3705-33DR | TPS3705-33DR | IC | 1 | U1 |
SOIC-D16 | TPS2087B_SOIC-D16_TPS2087D | TPS2087D | IC | 1 | U2 |
SOP-DGG48 | OCT_DS_BUSTRASCEIVER_0_SOP-DGG4 | SN74AVC16T245DGGR | IC | 2 | U14; U19 |
SOT23-5 | NC7SZ14P5X_2_SOT23-5_SN74AHC1G0 | SN74AHC1G04DBVR | IC | 1 | U4 |
SOT23-5 | SN74LVC1G125_SOT23-5_SN74LVC1G1 | SN74LVC1G125DBVR | IC | 1 | U18 |
SOT23_3 | DIODE ZENER_1_SOT23_3_BZX84B5V1 | BZX84B5V1LT1G | IC | 1 | D1 |
SOT23_3 | DIODE_DUAL_RS_AJK_1_SOT23_3_BAV | BAV99LT1 | IC | 1 | DN1 |
SOT23_3 | DIODE_DUAL_RS_AJK_2_SOT23_3_BAV | BAV99LT1 | IC | 1 | DN2 |
SOT23_3 | 2N1613_1_SOT23_3_MMBT3904LT1G | MMBT3904LT1G | IC | 6 | Q1; Q2; Q3; Q4; Q5; Q6 |
SP53 | INDUCTOR IRON_SP53_3.3UH/2.6A | 3.3uH/2.6A | IC | 1 | L2 |
SPC1608 | INDUCTOR IRON_SPC1608_2.2UH/1.7 | 2.2uH/1.7A | IC | 2 | L1; L3 |
SSOP16 | TRS3221ECDBR_1_SSOP16_TRS3221EC | TRS3221ECPWR | IC | 1 | U7 |
STX3500 | KYCON ST-3500_3_STX3500_STX-350 | STX-3500-4NTR | IC | 1 | J10 |
STX3500 | KYCON ST-3500_4_STX3500_STX-350 | STX-3500-4NTR | IC | 1 | J11 |
TC7343 | CAPACITOR POL_0_TC7343_10UF/6.3 | 10uF/6.3V POL | IC | 2 | C177; C178 |
TP | TEST POINT_TP_TEST POINT | TEST POINT | IC | 19 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19 |
USB-A | 1-1734084-1_2_USB-A_156-1000000 | 156-1000000901 | IC | 1 | J5 |
VGA-DB15 | CONN ASY CENT S/S 14_1_VGA-DB15 | 070213FR | IC | 1 | J8 |
附件:
