本帖最后由 Zedd 于 2020-3-18 10:10 编辑 ) L1 c8 }9 Y6 M- ^- t( ^7 ^7 \* o
' m* P/ D8 [7 W2 ^* Y% z3 W画风玫瑰图,网上查找到的风向与风速强度都有点问题,修改代码后,与大家分享,有什么问题可以讨论。
" l7 J% I5 @* B3 h/ |function varargout = wind_rose(D,F,varargin)
! x F7 W* V% u%WIND ROSE Wind rose of direction and intensity
7 m. g% o% P( p) R% 7 Q+ N) A- w9 F9 S) J1 f4 d2 N
% Syntax:
% Z. p e9 p6 j% HANDLES = WIND_ROSE(D,I,VARARGIN)
" k; f+ @7 `2 D6 o6 d' ~%6 U5 O' v, S: p2 R% _7 u
% Inputs:1 A, d$ T2 a) K8 H* c f2 P2 ?- M
% D Directions# t7 q/ b# R* W1 ^) u0 w
% I Intensities
: @- q: j( |/ \: {4 H% VARARGIN:
4 ~* K# ^8 W! v8 ?4 U% -dtype, type of input directions D, standard or meteo,
2 ?2 R4 {: |/ q' H% if meteo, the conversion dnew=mod(-90-D,360) is done;1 J n$ y) h ]( G) v# O4 a+ T P# O
% if not meteo, standard is used (default)
' s, l# y" h: w1 d% -n, number of D subdivisons
$ ?( u7 a" x' m0 p! J a4 ?% -di, intensities subdivisons, default is automatic
3 G/ B9 v9 J: f4 }% -ci, percentage circles to draw, default is automatic5 G' U1 Q V% R# \7 P9 y, v
% -labtitle, main title1 m2 p( d e& C( C! h# [# c2 V, l: E# v
% -lablegend, legend title
( f- `& i9 Z1 {' W, \% -cmap, colormap [jet]5 ^% [* g6 u: D! t, D' Z% ^
% -colors, to use instead of colormap, for each di+ N4 F, c3 E8 L+ s+ E, i+ F
% -quad, Quadrant to show percentages [1]( h! g0 p7 x- n$ j H2 w3 e7 O
% -ri, empty internal radius, relative to size of higher9 O( q& W& b% @& E$ e, Q
% percentage [1/30]8 m- \0 C b( e/ I& f
% -legtype, legend type: 1, continuous, 2, separated boxes [2]
; b1 n$ F* Y/ [3 l+ W1 _% -bcolor, full rectangle border color ['none']
0 \; u" g2 T* ?( [3 u+ }% -lcolor, line colors for axes and circles ['k']; S9 q/ y. N, g6 ^6 L
% -percbg, percentage labels bg ['w']
; K( u4 J$ s6 ?7 |9 {6 v( P% -ax, to place wind rose on pervious axes, the input for ax1 ~: s6 y' q/ O; M0 i' r4 a2 i
% must be [theax x y width], where theax is the previous
3 O% ~ ]1 N z; A* U% axes, x and y are the location and width is the wind
" p* I% _" y; M% rose width relative to theax width (default=1/5)
( u- T9 F+ @# U/ C% -iflip, flip the intensities as they go outward radially, ie,8 r/ h$ @6 S* ]: R. f
% highest values are placed nearest the origin [{0} 1]2 U4 w& J |) E- l3 @& T: q! w2 _
%% |. d4 o# O$ h: R- J! j
% Output:+ D" X8 @3 ^& K7 c) s0 ^% c! G
% HANDLES Handles of all lines, fills, texts
8 o N0 c. `- y( U" p%
* [. K% Q1 M9 s; x) d6 d% Examle:5 I: r) ? J+ u+ r& Y* l1 a
% d=0:10:350;
5 S$ U% `+ C* i7 e8 H% D=[];) Y" r Q9 s. c" r% x! c
% V=[];' Z$ X" c9 O1 i; l
% for i=1:length(d)
& a& D* T$ }' g# Y/ w% n=d(i)/10;8 Y/ J% e/ P& R* v% K
% D=[D ones(1,n)*d(i)];
& M4 v8 m; U5 r4 Z5 @% V=[V 1:n];. ]' R! D6 j# ^- \
% end
0 G* u+ d& O, X% i) Z%. y, a+ P8 {) A8 w% o# V
% figure
% a1 ?# L; P# J$ E+ j- k* K; v' v% wind_rose(D,V)% t2 Y+ ^# A+ V: b9 R: D1 B1 V
%0 S- F, z* g6 A8 o4 Z3 B1 Z# z
% figure
1 @4 @9 V p; M. a% wind_rose(D,V,'iflip',1)
3 A" r% l6 o: K/ Y; y( n4 m5 z%: x% `6 W9 R! p6 f) ~
% figure4 n8 r/ K s3 C
% wind_rose(D,V,'ci',[1 2 7],'dtype','meteo')% A) n; Q0 S7 H; p1 N% K/ H
2 R b* J. S. D, |4 }5 A% % place it on a previous axes:
5 E) |/ c, Z' V% ax=axes;8 q Q# K# N4 i. h( y3 C* L) N1 z# y
% plot(lon,lat)! d; W. x1 l6 \: ?
% wind_rose(D,V,'ax',[ax x y 1/3])- p1 M* ?, H& v: v7 D) t
: ?: U* h6 m( d% MMA 26-11-2007, mma@odyle.net
, y2 S. D) F1 m! h1 K8 O# W
/ `' X/ G5 U- Y# `* k: g3 M4 p% IEO, Instituto Espa?l de Oceanograf?# b* l1 }! Z! [
% La Coru?, Espa?+ I4 }: a6 U9 B! n4 o- c
' G& B! f1 f/ N/ ~& U/ H- m% 10-12-2007 - Added varargin ci and n (nAngles removed as input)
2 z6 ]; ?. ^% S+ K, A$ [& n" P% 17-12-2007 - Added varargin ax, colors9 y7 \" ?2 N+ q3 f& l
% 22-02-2008 - Added varargin dtype- |3 \6 I. a) l5 q7 h- h9 X; g
% 08-05-2008 - Bug fix (bar at dir=0 could be incorrect in some cases)* _6 Q1 G( k1 {0 U3 y9 L; p
% 14-05-2008 - Added varargin iflip: Z w: {" K3 p, G/ `
. N2 `# @# Q1 a6 ^/ B" V%figure;7 {- p4 k0 j* }1 W
handles=[];
% ~7 R; z( t1 q( G
) G A( {; N6 T7 j) f% A; G; D% varargin options:
& o. _; @7 D, U7 j' Cdtype='standard';3 Y# V; |: j& }" ~: B
nAngles=16;1 Z# h" Q/ s8 P/ h: j
ri=0.01;
* d4 ^* N4 U! \: R9 n: e4 r0 xquad=1;5 l% z4 ^/ W& l
legType=2;
" Z) t( K7 u$ i2 |' N% X8 X: e' D( hpercBg='w';
8 u( \. R# |, s" \- o% percBg=[204/256 204/256 204/256];%ͼ}ѳްɫ' t+ Y- W0 d' [# U K
titStr='';; O6 Y$ y6 d0 m) ?$ H# d( S5 M
legStr='';# p7 f4 J7 f H) }$ q5 `
cmap=jet;& \9 F( K" R7 \6 D$ q4 H3 \
colors=[]; \, }# Y+ r' D! O' l0 y. y- Q
Ag=[]; % intensity subdivs.4 z! P' u! M. M" c g
ci=[]; % percentage circles
% U! m2 N8 o! e* Z6 X: F) ^* E) K" {lineColors='k';2 ^+ Z5 `4 M/ O) H" M9 U# g* E) [
borderColor='none';
# c' j2 Q5 R4 I; N- k9 s( `" [onAxes=false;
8 N9 u/ b$ w. S/ J3 \5 \# Uiflip=0;- w% g; H$ Q p0 ^
t& W9 H/ ~% ], qvin=varargin;
8 }, ~* b1 E& ^+ {for i=1:length(vin)
0 y+ \8 b M$ _3 i0 r! O if isequal(vin{i},'dtype')
* f- R: ?" L* ]; s9 h dtype=vin{i+1};& S$ ?: w. g5 T5 n. i. |
elseif isequal(vin{i},'n')
, E& ^1 W- u" G3 y: m nAngles=vin{i+1};5 ?$ P. q W1 Y4 p, u" T
elseif isequal(vin{i},'ri')
V3 V6 J3 z! s; r8 k ri=vin{i+1};
# E. d! X/ W2 j3 U/ b6 P$ \ elseif isequal(vin{i},'quad')! N3 ~3 G! d' Q4 L$ j j
quad=vin{i+1};: y) g. G0 k' p& d$ I; `+ H
elseif isequal(vin{i},'legtype')- l; l4 Y8 T$ b. @% v" ?) ~4 b
legType=vin{i+1};
( l% c# G1 b7 H/ E. f+ a$ h; G elseif isequal(vin{i},'percbg')0 E8 }" d# w5 U; d0 V Y5 A1 f- j; i; _
percBg=vin{i+1};
1 `: j4 l0 X" }2 o2 ?" ]3 A7 c& j3 v elseif isequal(vin{i},'labtitle'); \. x& T1 F2 h/ ~0 O
titStr=vin{i+1};
- G: G. p; K5 Z& L( W, q/ g( F" x7 I elseif isequal(vin{i},'lablegend')
) E4 A5 f8 w( B legStr=vin{i+1};
: `; ]$ j, d M, ~: |. C elseif isequal(vin{i},'cmap'): s1 h3 J5 P# r( D) d8 O" `6 d
cmap=vin{i+1};2 D' }) Y. c* z L
elseif isequal(vin{i},'colors')
# h# W: B8 G' W% M1 b colors=vin{i+1};
7 q- P; N8 @# h! H3 Q% f elseif isequal(vin{i},'di')
) {* L- w( L4 h' h Ag=vin{i+1};* `: ~: g5 i/ z
elseif isequal(vin{i},'ci')/ e& { z) [$ a7 F/ o" _4 t
ci=vin{i+1};! N8 n* E: o- P ?3 i
elseif isequal(vin{i},'lcolor')
, b; ^% _1 {* ^* w5 Z G! h lineColors=vin{i+1};: G2 H, l9 z' F e
elseif isequal(vin{i},'bcolor')) w2 v" E0 F$ S9 c( |
borderColor=vin{i+1};& {' L) u' y" [6 u! y* [ d9 ?
elseif isequal(vin{i},'ax')
1 u0 j7 F7 D+ b, p9 X ax=vin{i+1};6 Y+ W' C3 \! t3 Z
try) e& Y& n0 D" |- |, F9 f; y
onAxes=ax(1);
( P1 s$ R$ R8 [: L; ]& F7 a+ R* Z onAxesX=ax(2); Q; j, p9 h# ~" Q! a8 ^
onAxesY=ax(3);
) ]. u9 a9 z t+ q8 ]1 I onAxesR=ax(4);
: n$ O# v( f8 P catch
$ n- F% X: Y) ~& I z" {. @" p disp(':: cannot place wind rose on axes, bad argument for ax')- {' P- Z1 l9 P9 m5 Z8 ]3 h6 h- M
return
& F0 ^: S/ R0 B end
, Q$ f& Q- U( u# h& \. X) ?7 l) h elseif isequal(vin{i},'iflip')" j) M" p# Y5 h
iflip=vin{i+1};
% M V" H) u6 {+ X# o( I end' x) }( ~2 Z: `4 a) t8 v9 h0 ~
end. S! t: n7 R/ a2 f
' e' U- [8 X# l8 q- t6 |0 l
% other options:
- Q% z5 V+ c. e' {, w5 ?! V% size of the full rectangle:
/ A* A2 I- t( s0 O9 @+ w7 Y2 Rrs=1.2;
8 _/ c$ ?4 `) `8 Qrl=1.7;
+ h' T1 J6 f, B, |: m1 z; G \! B8 L9 [3 f" b
% directions conversion:( @( x" h' p/ p5 @( {% G# A" _* }! e4 {
if isequal(dtype,'meteo')# f" D. v, S0 l( S7 ]
D=mod(-90-D,360);! ]7 L5 @$ C; |, Z6 O( A
% D = mod(90-D,360);
8 @# }2 e+ ]5 Q; d1 T7 h! p- y5 Eend
* |: J4 _6 ^8 w( h: V! T' n5 i) X" ]- R
& O3 V5 _2 k# Y& L
% angles subdivisons:: N6 P' W) s, f; f- ^8 j
D=mod(-270 - D,360);
' J. o1 J* s2 ]. g; C+ C& _Ay=linspace(0,360,nAngles+1)-0.5*360/nAngles;
9 M0 W4 j0 p W! }
5 s0 p& M. p( t9 c7 x+ Z! U: G' t% X0 M" P% M
% calc instensity subdivisions:
+ D; Z7 f( O6 R5 p, r& M& vif isempty(Ag)& q# H6 _" `! g. {! D
% gen Ag:7 A2 h) E' E7 w V
f=figure('visible','off');6 Y& ]! W' `) @5 G$ v
plot(F); axis tight;
5 B3 R' m4 L' E# l5 R& H/ {! y: _1 { i0 J3 x8 |
yl=get(gca,'ytick');
: V9 {$ q9 \2 G- h( v) v' G close(f)
# h& m" \ i& b& O+ P3 ^! l; g dyl=diff(yl); dyl=dyl(1);/ X' }; t# P. t4 x8 \4 z4 t
if min(F)>yl(1), yl=[yl(1)-dyl yl]; end' L3 H3 U; R' E
if max(F)>yl(end), yl=[yl yl(end)+dyl]; end ~: S, ?7 K( P
Ag=yl;
, ]8 M3 O3 \- V3 g4 p1 x Q) M0 dend
2 |' `4 M' r8 _. O* D- M& e; H8 k9 c, d; S. {4 f- d
IncHiLow=1; % include values higher and lower that the limits of Ag.2 `0 A n; h/ G0 T
for i=1:length(Ay)-1
; R6 O5 ?; ]/ O if i==1
! ^0 V4 p# J6 V I=find( (D>=Ay(i) & D<Ay(i+1)) | D>=Ay(end));; j( h. y# y9 t$ T/ [" j' \
else
. ^. d2 k4 K' m) ~# N7 b5 U I=find(D>=Ay(i) & D<Ay(i+1));
! Q2 i4 J: m9 f. @ end
8 I! L# W w8 G* y7 X, t b=F(I);) O$ N4 F) q- o# K9 m( l: Z
) I/ E0 S# O: y
for j=1:length(Ag)-1% T y+ w9 |$ X+ }$ D' M" ?
J=find(b>=Ag(j) & b<Ag(j+1));
( m! w0 ?, B; K# b8 \) R E(i,j)=length(J);+ T& i% j+ c* O; T5 X
end
" X) n% D# H2 H. H: H) `
; J& c3 C+ r, }$ C" f# G if IncHiLow, V- f4 o, H5 Q8 A5 Q
E(i,1)=length(find(b<Ag(2)));% t( ~8 l3 _- d+ O) _$ s: X
E(i,end)=length(find(b>=Ag(end-1)));
, U8 j4 m4 U* u+ Z- P6 v end
) u, g. r+ T. @! f* Aend
0 N- O" ^/ Y- i" G: R! `0 \3 P: sb=sum(E,2)/length(D)*100;
- ~* p Q% q& O$ w0 R+ ^& ^' X2 L* U L% `0 z* U0 U7 j' ^0 ~
% check if has values higher or lower than the Ag limits
" a f* ?$ \1 l9 ]5 u* _hasH=length(find(F>=Ag(end)));
- }$ j1 S+ ?, C* T+ s H8 ohasL=length(find(F<Ag(1)));
3 P s( N% e! m2 W! _' j- \! h9 ^ m# e7 J8 P+ K/ _
% calc number of percentage circles to draw:# E# P# w \8 y; F
if isempty(ci)/ I! T% D' z, h$ L
dcircles=[1 2 5 10 15 20 25 30 50];
9 Z9 k. a8 x6 @ z$ Q# [+ X ncircles=3;- `: R3 G- _0 d+ r* }. q
d=abs(1./(dcircles/max(b))-ncircles);
2 V. m$ X( ?* h5 g( y9 | i=find(d==min(d));0 V2 m9 U$ T8 c6 i5 v! K+ e
d=dcircles(i(1));: }# }5 ]. ]+ l6 P1 a
if d*ncircles<max(b)
8 T5 z7 i3 @7 [7 o+ z ncircles=ncircles+1;; c' j1 K# D0 H- K
end
; ]) o: d# F! N2 ~1 B; l$ [ ci=[1:ncircles]*d;
; O, L8 p, v9 V8 P g=ncircles*d;
# r; M# [4 z helse
2 P+ y7 a3 D1 S. L ncircles=length(ci);
8 K% G7 o' B) f+ M, E0 Y V: f g=max(max(ci),max(b));, S# G$ z& }) @3 X1 Y
end. [% f, B; _9 ?& [6 d. Y
( ?4 @# `* ]1 n( x) u
' p0 k) }0 x# W/ k r- w, c% plot axes, percentage circles and percent. data:
" t: e6 m3 c% b; c, |& V! f1 p3 [& n: pwrAx=axes('units','normalized');
6 D1 y8 ]7 l7 eri=g*ri;) `, ?5 b* ]6 v6 i; }* `
handles(end+1)=fill([-rs*g rl*g rl*g -rs*g],[-rs*g -rs*g rs*g rs*g],'w',...
( ?( O/ R. r5 F7 J% A 'EdgeColor',borderColor);
& H. n6 g, Q7 \$ @9 @0 b# ^4 oif onAxes
) O( M6 _/ P5 f set(handles(end),'facecolor','none')
+ Y+ U" v9 Q+ o5 U4 T" S9 B9 S: Jend' r! q K1 q v( x
hold on
/ t0 u7 C, t: I( f& lhandles(end+1)=plot([-g-ri -ri nan ri g+ri nan 0 0 nan 0 0],...
3 w. g W% {4 A0 d% y; J* Q [0 0 nan 0 0 nan -g-ri -ri nan ri g+ri],':','color',lineColors);
& x! Z* N" i8 ~5 }8 `t0=[0:360]*pi/180;4 Z& r; k8 C3 t
labs=[];; C/ N3 G$ _+ E; J5 o! p! d
Ang=[1/4 3/4 5/4 7/4]*pi;* u0 R$ b b8 G/ }: r
Valign={'top' 'top' 'bottom' 'bottom'};; ]5 S2 F/ A& b$ _, |3 R- t
Halign={'right' 'left' 'left' 'right'};
7 S% J$ I( d$ rfor i=1:ncircles
, F, z3 m! A7 Z9 u x=(ci(i)+ri)*cos(t0);! E- C6 T& i* l3 T
y=(ci(i)+ri)*sin(t0);
|; ]% Y/ S6 u; o/ n5 p! o- }
7 p0 G" [& ]% x; B- R handles(end+1)=plot(x,y,':','color',lineColors);' ]0 V" `. P6 u! w6 A
! L5 S/ U! _2 a' J3 K labs(i)=text((ci(i)+ri)*cos(Ang(quad)),(ci(i)+ri)*sin(Ang(quad)),[num2str(ci(i)),'%'],...
f6 {/ O, H3 D' ~7 w8 C( s0 k 'VerticalAlignment',Valign{quad},'HorizontalAlignment',Halign{quad},...3 D& {6 m* h, S1 W1 ^& h
'BackgroundColor',percBg,'FontSize',18);+ K5 ?" O* b7 d. ?
end& ~$ u5 b$ o; l7 y+ `2 G
handles=[handles labs];
6 s) q2 a- z, X# c% ]6 @) g2 H# D" h+ u* h: w# l, V6 k
% calc colors:. t. z3 O% _! M2 v
if isempty(colors)
1 R8 ~% r" @4 W' p* q cor={};
% S3 n1 a; p0 i, q+ B for j=1:length(Ag)-1
# {% r# p' _- R cor{j}=caxcolor(Ag(j),[Ag(1) Ag(end-1)],cmap);+ Q6 _3 E( C m( R/ I- a1 J
end
, [) ~; Q, g @* M; i selse& v- `% }5 v6 N' v( k2 q
cor=colors;
: E, i! a! U: hend
3 x8 u2 H! a- m c0 M$ K, Y' P
1 y& J8 e3 _& j7 [! t r% M H% fill data:
8 Q; d' L" @. {+ yn=sum(E,2);% }8 Q* v) N. \+ m. |* f
if iflip, E=fliplr(E); end
* V8 Z+ Z: R) T$ \3 x1 Sfor i=1:length(Ay)-1. r% z# z# m% P8 f" e2 N
if n(i)+ C u3 ?: ~- ?& U% t
t=linspace(Ay(i),Ay(i+1),20)*pi/180;
2 K& }6 L {" X: O- M r1=ri;! n7 X" u/ m# j) r1 I% q
* Q0 \; L9 g! c2 L6 M$ F5 J3 m r2=E(i,j)/n(i) *b(i) +r1;* S+ v/ T+ i, d; r
0 @7 q7 Y/ @# A& [1 S* c/ m
x=[r1*cos(t(1)) r2*cos(t) r1*cos(fliplr(t))];5 ]' [8 U! k6 e( ]) i# m
y=[r1*sin(t(1)) r2*sin(t) r1*sin(fliplr(t))];& m$ k K$ V( b$ N+ B: z; W
" V% g, s) t/ z1 w$ c, i b
if iflip, jcor=length(Ag)-1-j+1;+ d; T7 E; ?+ I* s
else, jcor=j;
x) m3 M. M3 v" L end
! ?2 p4 U/ f8 M0 ~8 X" ?1 u2 W p w2 C9 y7 O
if E(i,j)>0, handles(end+1)=fill(x,y,cor{jcor}); end$ w5 A |- ^( ?9 z' A: z
r1=r2;
, j* x& }$ z) t$ J2 k# g end5 H9 C. R1 O! D0 m3 m$ f
end/ T3 s6 K+ i( w$ M# n& n3 B
end \4 M( A4 ?3 k G# W
axis equal
5 `" l0 a2 O9 P2 I; a3 }7 M6 `axis off
$ B. ?; R, [$ l# s( iuistack(labs,'top')
, R A# {1 f/ u* ]5 k9 h$ {: |
* D% k- `. T6 B; f0 V% N S E W labels:
$ ?1 S V" Z# @/ k* qbg='none';
+ a B, I, _( k! P; } @args={'BackgroundColor',bg,'FontSize',18};- C8 b- U |0 I
h(1)=text(-g-ri, 0,'WEST', 'VerticalAlignment','top', 'HorizontalAlignment','left', args{:});' {1 S4 L$ H2 l8 f9 p5 U
h(2)=text( g+ri, 0,'EAST', 'VerticalAlignment','top', 'HorizontalAlignment','right',args{:});
7 W3 P8 [$ f, `- Fh(3)=text( 0,-g-ri,'SOUTH','VerticalAlignment','bottom','HorizontalAlignment','left', args{:});
! Q+ A+ @1 u8 I$ @h(4)=text( 0, g+ri,'NORTH','VerticalAlignment','top', 'HorizontalAlignment','left', args{:});
: |: c3 \2 q5 N2 i' Q8 F0 z) Y# T# L, K* h$ a: O7 K$ A
handles=[handles h];2 m: @# @4 p* i9 u$ ?5 ]* f. ?
" f3 I( V4 [8 j% I% A, s
% scale legend:' ^4 E- }: s, P" r
L=(g*rl-g-ri)/7;
' Z( J3 i7 _" [7 v; jh=(g+ri)/10;
5 K% J0 \- A% L# s8 v; bdy=h/3;' C4 E I X$ I* z
# D, g" ^1 Y% T% T( s1 g* g7 |x0=g+ri+(g*rl-g-ri)/7;
1 M; P5 V& E( V5 Ox1=x0+L;
i1 y# a! s6 R. \y0=-g-ri;! S- \1 b( ]# S4 V; J
) x" ]5 A* h) n5 J) [& L+ r x
if legType==1 % contimuous.0 z" f# |& I- f* R9 q7 i' L2 F
for j=1:length(Ag)-1$ H5 z* ^3 M, A4 }* p
lab=num2str(Ag(j));
5 \: G9 D& |, Y: f if j==1 & hasL & ~IncHiLow
& O! } ]" f/ t4 x0 E+ m1 V lab='';
, r4 m1 k: W' P6 s, w3 z v end
5 e0 I& v2 }2 C1 b4 ^ y1=y0+h;2 ^" M7 p; p1 Z
handles(end+1)=fill([x0 x1 x1 x0],[y0 y0 y1 y1],cor{j});
1 u/ K& p! p- W, Q handles(end+1)=text(x1+L/4,y0,lab,'VerticalAlignment','middle','FontSize',18);
0 D, c3 S9 s- I" m* Q y0=y1;
6 ]! g2 L- o! i! N end
* E8 ?* b. o2 \1 \ if ~ (hasH & ~IncHiLow)" d) L7 _/ Y- H9 X" q7 g
handles(end+1)=text(x1+L/4,y0,num2str(Ag(end)),'VerticalAlignment','middle','FontSize',18);
' M& A# O0 h, P- b end
5 V, n3 U* K' o ?6 \3 nelseif legType==2 % separated boxes.
4 V8 [& A' [1 p x% k+ y& b for j=1:length(Ag)-1 w* } L3 _ N6 T1 u- ?( [# j
lab=[num2str(Ag(j)) ' - ' num2str(Ag(j+1))];
/ j# ~" n2 ?" F9 n$ s: X if j==1 & hasL & ~IncHiLow
+ G6 G/ N, |% n+ t* P lab=['<',num2str(Ag(2))];
9 C" ^8 L$ P9 U+ m, P. W+ L4 ]7 l( h end
: j' ]! L1 W K! q' D, a if j==length(Ag)-1 & hasH & ~IncHiLow( k! Q7 L$ Q; A, E% u
lab=['>=',num2str(Ag(j))];
) E" _1 z5 E8 L2 A6 w: c end
& ^0 d8 Y, i9 @: F: a- a4 @ y1=y0+h;* w8 R$ N* S( }3 u& c4 J
handles(end+1)=fill([x0 x1 x1 x0],[y0+dy y0+dy y1 y1],cor{j});
5 [0 P) U# ?/ z( @, S* F E handles(end+1)=text(x1+L/4,(y0+dy+y1)/2,lab,'VerticalAlignment','middle','FontSize',18);* ]. f! Y i) x! k. H
y0=y1;
/ s% U7 z- E/ ] V end
/ z9 h7 I) x& n; B
% b& G4 C" }' ]end2 y) {3 S8 K, e0 u/ b+ ^( Y6 w
, a& ~3 Q3 C0 D$ i% title and legend label:+ d2 e1 m! s/ T1 P( u* K
x=mean([-g*rs,g*rl]);- a5 e) N2 ` L: U
y=mean([g+ri,g*rs]);
0 d- v( u, N, q! }; Shandles(end+1)=text(x,y,titStr,'HorizontalAlignment','center');
* ]" s) E+ D+ }( K
/ s3 W6 N% p/ Ix=x0;
- M# S2 f1 r; a& t/ O7 c" [3 ~y=y1+dy;- ], r( ~1 f; [" z* \, ^/ v
handles(end+1)=text(x,y,legStr,'HorizontalAlignment','left','VerticalAlignment','bottom');" s) j8 k5 k- w x- I
6 N+ U3 v. u7 h' zif onAxes; ]) }+ l3 R! G2 k8 n
place_wr(onAxes,wrAx,onAxesX,onAxesY,onAxesR);
, l2 Q, n l8 w- C9 v( h! Dend* k* u: y3 ^8 [' ^7 D9 w. l/ \
. l) p& U$ H! t" u3 Xif nargout==14 c$ n, q* x7 y/ y" r. r7 J+ }
varargout{1}=handles;
h# |' q2 M6 o2 G2 a( I. Hend
# n! D: p* Q0 K0 I& E8 d
7 m$ p/ a8 \- l: }. Afunction place_wr(ax,ax2,x,y,width)' O. a5 L4 Y( N) m9 g* g# Y
if nargin < 52 W, L; m8 }1 X \9 }
width=1/5;9 M: I) n+ _0 r% s7 ]4 @2 b
end
3 {9 g1 M( O. v+ d8 Juax=get(ax,'units');8 l2 z* W8 M- J+ |* q: ]
pax=get(ax,'position');$ T- A9 T8 V1 B% v
set(ax,'units',uax)) W7 r0 X# H5 e, W5 e" ?8 G
axXlim=get(ax,'xlim');! P7 |8 x* T- Y3 D2 d% b
axYlim=get(ax,'ylim');' x/ k# A! C0 N4 @ @- ~& ^
" y5 E0 C8 ~! C8 ?/ Rx_ax2=pax(1)+pax(3)*(x-axXlim(1))/diff(axXlim);
! c: U0 T4 V# Uy_ax2=pax(2)+pax(4)*(y-axYlim(1))/diff(axYlim);/ X5 `3 W8 E# M& q7 F- e8 ^( c
$ F' I8 e. p# N( }0 e* _
pax2=get(ax2,'position');
, b) c+ e5 o) w7 Y3 {2 E5 w& iwidth=pax(3)*width;
2 g+ i- y8 K4 M" e0 S$ jheight=pax2(4)*width/pax2(3);3 ]! A {- Z6 N' P
pax2=[x_ax2 y_ax2 width height];
h# F6 r4 W! v6 B3 l G
0 X( M% P' _! Q$ P a" U! r: E$ e' Eif 1
: L. p7 T( Q [) @ % place at centre of the wr, not the bottom left corner:
. A- V# T3 s6 m. y( x, ~ ax2Xlim=get(ax2,'xlim');
! U; Y S: B/ l ax2Ylim=get(ax2,'ylim');
# S: e! C% ]8 V5 i1 Z K$ c- @ dx=(0-ax2Xlim(1))/diff(ax2Xlim)*pax2(3);& j6 k: J/ {* E& i& K
dy=(0-ax2Ylim(1))/diff(ax2Ylim)*pax2(4);
3 R, f7 n/ t% U7 V2 | x_ax2=x_ax2-dx;
) ~% J1 M- z: x* V4 }7 T, j0 A y_ax2=y_ax2-dy;
2 t8 ^" s8 Y) }, V( y# G. | pax2=[x_ax2 y_ax2 width height];
, B7 p0 S" H- l4 O/ `% vend
0 G2 f- @- T I" K0 W6 G2 t' {* h$ nset(ax2,'position',pax2)* W! [) Z, }) o
; w1 m- |2 B1 B( H% @
* s2 w t+ s( ~+ |9 \8 X
$ x! N6 Q7 @4 j( A1 E5 o5 @function cor = caxcolor(val,cax,cmap)
% w& b+ M6 w& X9 W%CAXCOLOR Caxis color for value3 z1 J/ f- F4 m- A1 ~+ t: R3 H6 q
% Find the color for a given value in a colormap.
, M. E* }; O I4 g J z%+ B; z& H3 V# y' W8 z$ K' M
% Syntax:
$ S2 ^& ^- g3 w* \% COLOR = CAXCOLOR(VALUE,CAXIS,COLORMAP), C+ X7 _ k1 A) t& f
3 w: U8 N/ y% }9 i+ G7 W% Inputs:
1 i2 b: Y) Z' f+ e) s% VALUE# D$ E0 V: U1 P
% CAXIS Default is current caxis7 o! T- ~8 A) C+ s1 i x
% COLORMAP Default is current colormap- I0 X$ S5 ^; ]# I
9 h Y% I/ m9 {* `" m: k5 K4 l% Output:
+ U p- h" e" I' X! M1 h3 e% COLOR RGB color vector
+ v; M, d1 @, f. ?) L%& j3 O' |$ v% M' ]4 C
% Example:7 J: d; ?( A& r* C" [9 p
% figure0 F: P, h) `. e7 G6 D
% pcolor(peaks)
5 O/ K1 l2 _) z& i; [# k) `% color=caxcolor(0);! Z4 Z l) V& @4 @! I
% set(gcf,'color',color)2 }( s/ d4 s3 r: ~, p" z* Y
' f5 c; K; b" w' Q% MMA 28-5-2007, martinho@fis.ua.pt& r' B- R: k! v6 \$ n" I
) P2 V0 q) D! o6 _& i
% Department of Physics
6 y4 u5 M/ E$ x8 q" F1 ^/ F% University of Aveiro, Portugal
+ o, U5 r! a2 x9 @% a1 |( q( ^% [4 `: A# p( X b: `; l
if nargin < 37 U1 A& h- z5 |3 ^4 A
cmap=jet;
9 }& [4 r3 `! v. l' L3 z7 Aend$ T2 N4 i; p& Q( A) D
if nargin < 2
+ W4 g; Q% P" _# U cax = caxis;6 n# J0 ?) x& l
cmap=jet;! ~6 t8 K2 u1 r) V- a
end
! {5 r+ [; x0 N9 a
& u4 w0 b `% z1 B$ J6 S) d3 f6 Cn=size(cmap,1);8 I) ]6 ^% r: |+ z0 |; z
i= (val-cax(1))/diff(cax) * (n-1) +1;
" Y) j5 N0 z/ g" t; la=i-floor(i);6 `: m6 }+ P4 Y+ x" d
i=floor(i);
^; F/ t0 O3 m" Q& s7 C" s7 U. J" K. D' A
i=min(i,n);
' A1 v J! j2 `& Zi=max(i,1);
6 Q2 d% e5 W1 E" M. s( t _% Y
7 u# E/ X$ E M E) }4 Mif i==n
* C! R6 S: i8 A4 _- z cor=cmap(n,: );4 k$ w/ @( }, u2 p
elseif i==12 i0 |% Z6 Z- s3 ?% j! ~2 x
cor=cmap(1,: );" y; T7 V" j- }$ ^% v) o
else
/ x& L$ G2 w9 O& G! ] cor=cmap(i,: )*(1-a) + cmap(i+1,: )*a;& l1 t* o6 B p9 [0 T# G* T
end, h. \9 O, K9 }; v/ Q" ? U& T- f
% [+ Q- ^/ k- W+ Q6 [
