FPC物料中英文对照表
6 p& S4 U4 [* P) u% J+ i% c" }% X2 {9 X2 t2 t- d3 w) R
1、基材:base material 2、层压板:laminate
1 D2 }) }" n5 p0 G" F2 G6 p7 R9 N3、覆金属箔基材:metal-clad bade material 4 laminate (CCL) 3 F' u" l; v) `$ X% ?
5、单面覆铜箔层压板:single-sided copper-clad laminate 6 copper-clad laminate
! y" U+ Y" o; b" z( p7、复合层压板:composite laminate 8、薄层压板:thin laminate
* f [- O+ z. b9、金属芯覆铜箔层压板:metal core copper-clad laminate 10、金属基覆铜层压板:metal base copper-clad laminate
* ?0 ]5 f% V2 G. k" x- @9 p11、挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 12、基体材料:basis material * e5 A+ ^' x/ a1 B8 A1 z- o! d7 S
13、预浸材料:prepreg 14、粘结片:bonding sheet 5 x! q+ I9 M6 y
15、预浸粘结片:preimpregnated bonding sheer 16 glass substrate ! s: N4 n! W2 G5 m: Y$ h/ T6 C
17、加成法用层压板:laminate for additive process 18 lamination panel 7 v9 f8 G7 r" ]. }1 V8 f
19、内层芯板:core material 20、催化板材:catalyzed board coated catalyzed laminate
3 A1 Z& B0 m0 F" y21、涂胶催化层压板:adhesive-coated catalyzed laminate 22、涂胶无催层压板:adhesive-coated uncatalyzed laminate ' d' J1 e* s6 I" W
23、粘结层:bonding layer 24、粘结膜:film adhesive
1 q c T1 A6 v5 e) C; W. S25、涂胶粘剂绝缘薄膜:adhesive coated dielectric film 26、无支撑胶粘剂膜:unsupported adhesive film ! J, K# L$ h. q3 C) c
27、覆盖层:cover layer (cover lay) 28 material 6 f8 n! s$ Z0 ?
29、铜箔面:copper-clad suRFace 30、去铜箔面:foil removal surface
[) d$ c, F9 k p31、层压板面:unclad laminate surface 32、基膜面:base film surface 2 B3 ?0 ^ n. w+ k! b: X" X
33、胶粘剂面:adhesive face 34 finish ( X- L4 h) m- u& n: z1 q
35、粗面:matt finish 36 wise direction
, [: G. j) v. U3 I37、模向:cross wise direction 38、剪切板:cut to size panel
' C% y5 _& u% {39、酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL) 1 l% @$ C9 x. L
40、环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL) % C( p; @4 {& P+ e/ Q# W
41、环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates
0 b. r! m5 r( y6 Z$ T42、环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core glass cloth surfaces copper-clad laminates
1 g# b% G9 Z! h. l0 o43、环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates $ d; P$ {9 V+ R
44、聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates * a$ L; _4 a& L1 O( A; N
45、聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
: U6 X7 ^! @7 t, s: o& m46、双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates ( c" d! g/ E1 l
47、环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates
* ?( ~- d) \( _: B48、聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
/ P3 y7 M; j6 y0 _/ E; }49、超薄型层压板:ultra thin laminate
4 z, k% d K1 f3 c+ x& O3 @6 w4 w0 {50、陶瓷基覆铜箔板:ceramics base copper-clad laminates : S/ K3 B: ?" q
51、紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates" O" }* f4 w0 S% c$ N6 }
' H! A( I9 ]6 e: _- u. K' |
3 a9 T4 i2 ?2 l0 ~& Q
+ H3 ]" w4 [1 S9 [5 k
2 j, m$ z- d7 A) W' x基材材料. E) D2 P" s/ q" B8 g4 b! A- Y9 c
' \) s9 q. Y+ ^4 T5 k1、A阶树脂:A-stage resin 2、B阶树脂:B-stage resin
8 c. w- {6 U" Z4 ^/ J7 I3、C阶树脂:C-stage resin 4、环氧树脂:epoxy resin
! i, D, W, ^& y5、酚醛树脂:phenolic resin 6 resin # T7 g9 Q& D$ g: a7 a$ `
7、聚酰亚胺树脂:polyimide resin 8、双马来酰亚胺三嗪树脂:bismaleimide-triazine resin
3 N# ^+ K6 X D9 G- [) K& e9、丙烯酸树脂:acrylic resin 10、 三聚氰胺甲醛树脂:melamine formaldehyde resin & Q/ @% e8 b* u
11、多官能环氧树脂:polyfunctional epoxy resin 12、溴化环氧树脂:brominated epoxy resin 3 z L8 P' Q2 W
13、环氧酚醛:epoxy novolac 14、氟树脂:fluroresin
9 a9 R2 o3 \- a* U" T15、硅树脂:silicone resin 16、硅烷:silane
1 V0 [9 ~0 h$ w1 h17、聚合物:polymer 18、无定形聚合物:amorphous polymer
! ?- [$ s, I. W2 K5 L6 R19、结晶现象:crystalline polamer 20、双晶现象:dimorphism
D! V( d4 u) [) X, ]: @21、共聚物:copolymer 22、合成树脂:synthetic 5 P! f. Q/ n) s4 j: o
23、热固性树脂:thermosetting resin 24 resin
9 K' ?7 o1 y( E25、感光性树脂:photosensitive resin 26、环氧当量:weight per epoxy equivalent (WPE)
4 Y* p; l ~; F) u9 [& n27、环氧值:epoxy value 28 - u" x& I7 x7 E% @* [
29、粘结剂:binder 30 ' _+ f) w; r. u2 C% l6 S' @
31、固化剂:curing agent 32 retardant ( D0 _: l8 ], u0 n) i- r+ l/ y
33、遮光剂:opaquer 34 $ ]9 w. ^" y4 a
35、不饱和聚酯:unsatuiated polyester 36、聚酯薄膜:polyester
9 o8 ] _7 R8 M37、聚酰亚胺薄膜:polyimide film (PI) 38 (PTFE)
; |6 O7 a5 c9 G: F39、聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP)
# t$ F+ D2 |' ~. ]" j2 ?40、增强材料:reinforcing material 41、玻璃纤维:glass fiber
$ K* B8 ?; G- H4 \7 D, i42、E玻璃纤维:E-glass fibre 43、D玻璃纤维:D-glass fibre
: }! t5 L x& ?% j! R u44、S玻璃纤维:S-glass fibre 45、玻璃布:glass fabric
: F8 d5 i$ d- b8 ?! ^5 {% p* x46、非织布:non-woven fabric 47、玻璃纤维垫:glass mats g9 K+ j$ j4 x* Z. j, c
48、纱线:yarn 49 8 ~! w* p) ?- v8 c
50、绞股:strand 51、纬纱:weft yarn * ]& x) K) } |
52、经纱:warp yarn 53、但尼尔:denier " H1 e6 d; l& _ ~' P2 A0 q
54、经向:warp-wise 55、纬向:weft-wise filling-wise
4 ]& I$ z8 I: Z3 h56、织物经纬密度:thread count 57、织物组织:weave structure * J3 E. E% n9 s
58、平纹组织:plain structure 59、坏布:grey fabric 0 `2 F# j9 J& \4 _- [5 f8 H+ }
60、稀松织物:woven scrim 61、弓纬:bow of weave
8 l- ~/ p) X$ e) d0 r8 l62、断经:end missing 63、缺纬:mis-picks " q! c0 G( K" H( Q J
64、纬斜:bias 65、折痕:crease
, e, l9 I2 _! E5 u2 L66、云织:waviness 67 eye 9 K+ Y: Q8 u9 w7 S/ A3 F
68、毛圈长:feather length 69
7 e& n4 t! n$ E& M$ g4 X70、裂缝:split 71、捻度:twist of yarn
5 V, s- C6 R" L' p. V72、浸润剂含量:size content 73、浸润剂残留量:size residue
- Y' K% u) Z' T& [* @; U2 E74、处理剂含量:finish level 75、浸润剂:size ! \% { ^- T S8 s) k
76、偶联剂:couplint agent 77、处理织物:finished fabric & Z) m: s7 X+ n) g
78、聚酰胺纤维:polyARMide fiber 79、聚酯纤维非织布:non-woven polyester fabric
, G) Q; \2 E9 |% {3 R1 m4 J80、浸渍绝缘纵纸:impregnating insulation paper 81、聚芳酰胺纤维纸:aromatic polyamide paper
9 f& d( L' c2 o; O% e {4 k, W4 J+ S. }; ~* e! m6 D5 i
82、断裂长:breaking length 83、吸水高度:height of capillary rise
k+ F* d9 }) d- n8 o I+ Q* ~. H84、湿强度保留率:wet strength retention 85、白度:whitenness # j" O9 l7 F& @# `( g$ Z! |
86、陶瓷:ceramics 87 foil
, M, w$ x: `, M' K# T3 x: J8 w88、铜箔:copper foil 89 copper foil (ED copper foil)
! R) ?& E$ |( _* f' |; _( T90、压延铜箔:rolled copper foil 91 copper foil
( x- Q- j" u/ @1 c92、压延退火铜箔:rolled annealed copper foil (RA copper foil) 93、薄铜箔:thin copper foil 1 c7 G$ J6 u6 |5 F$ h# D
94、涂胶铜箔:adhesive coated foil 95 coated copper foil (RCC) $ J, e% A, ^+ F
96、复合金属箔:composite metallic material 97 foil
Y+ R3 E, M2 E1 ^- I% @2 A98、殷瓦:invar 99 profile % T# J! b4 b0 b" a+ t2 J7 A7 }3 I
100、光面:shiny side 101 side
% m' q/ E5 l9 M& ^102、处理面:treated side 103 proofing 104、双面处理铜箔:double treated foil( ?, K% P; R' {1 E3 D, X
