作品名字:[pads VX.2.4][2层]通用车载按键板12个按键原理图+PCB文件分享下载
7 S% S. Y2 R) H9 S$ }3 w. i, |, p - s' }5 p( S V% [
文件描述
( H T9 u: a5 q" t, {
- l) ^1 F" m" _, g4 {. s+ f5 k+ e+ K1.功能描述:通用车载按键板+ c& s0 t8 U8 X, R: h2 \
# S- i! c5 t9 a. J6 L) {
2.软件版本:PADS VX.2.4
2 j) s0 ~, C3 Z$ S, d# F ' r( |& Q+ @) H# h; w3 f; n3 p
3.层数:2层板
0 k( l; m& L& q
: ^) k1 \1 |' L6 a# d9 D4.用到的主要芯片:/ " _+ p* Q3 F8 b( ?5 F. Y
5.PCB板尺寸:异形
; T- Q) n& Y9 v) F
2 O# i' N6 s: j1 m0 I0 V作品截图如下: - o0 `& d" W' ~: d2 W) K
$ l' [5 Y: Y; f; O8 F- H
顶层截图:" x3 Q0 r/ F. O. N ~
& F8 w+ g1 b7 M+ W7 O: e底层截图:
7 E1 k, d8 x0 v a9 o+ Y& I, R
/ d4 b$ K+ K9 t# x/ G" [全层截图:: u, O( W0 l' L# a7 z2 T% a
; g# @, B" t0 D叠层截图:& t I. O. a6 s6 O6 d
BOM:
8 ~% t7 E- k& _2 X( n4 J L1 U* G# a0 B" [4 p: F
REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | C1 | 603 | 102 | C3 | 603 | 102 | C4 | 603 | 102 | C5 | 603 | 102 | C28 | 603 | 104 | C38 | 603 | 104 | C49 | 603 | 102 | CK1 | ENCODE-A | | CK2 | ENCODE-A | | CN1 | CON14-SMT-0.5-R | 14PIN-0.5MM | CN3 | CON14-SMT-0.5-R | 14PIN-0.5mm | CON1 | CON10-1.25MM | 10p-1.25mm卧贴 | CON2 | CON5-SMT-1.25 | 5PIN-1.27mm | CON3 | CON5-SMT-1.25 | 5PIN-1.27mm | CON4 | CON10-1.25MM | 10p-1.25mm卧贴 | D1 | LED-0603 | LED(red) | D2 | LED-0603 | LED(red) | D3 | LED-0603 | LED(red) | D4 | LED-0603 | LED(red) | D5 | LED-0603 | LED(red) | D6 | LED-0603 | LED(red) | D7 | LED-0603 | LED(red) | D8 | LED-0603 | LED(red) | D9 | LED-0603 | LED(red) | D14 | LED-0603 | LED(red) | D15 | LED-0603 | LED(red) | D21 | LED-0603 | LED(red) | IR1 | IRM838AAA | SMD | J1 | MINIUSB_5_BT | USB | J2 | 2PIN | | J3 | CON4 | | J4 | CON4 | | J5 | CON10-1.4 | | J6 | CON10-1.4 | | J7 | CON10-1.4 | | J8 | CON10-1.4 | | J9 | CON4 | | J10 | JACK_EJ3524C | 贴片4芯耳插3.5MM | J11 | CON4 | | R1 | 603 | 9.1k | R4 | 603 | 0R | R7 | 603 | 0R | R8 | 603 | 1.5K | R9 | 603 | 1K | R10 | 603 | 1K | R11 | 603 | 1K | R12 | 603 | 1K | R13 | 603 | 1K | R14 | 603 | 1K | R15 | 603 | 1K | R16 | 603 | 1K | R17 | 603 | 1K | R18 | 603 | 3.3K | R19 | 603 | 5.6K | R20 | 603 | 15K | R21 | 603 | 15K | R22 | 603 | 1.5K | R23 | 603 | 3.3K | R30 | 603 | 75R | R31 | 603 | 75R | R32 | 603 | 75R | R33 | 603 | 75R | R34 | 603 | 75R | R35 | 603 | 75R | R55 | 603 | 100R | R72 | 603 | 2K2 | R85 | 603 | 5.6K | R89 | 603 | 9.1K | R92 | 603 | 1K | R93 | 603 | 1K | R94 | 603 | 1K | S1 | SW2.5MMA | | S2 | SW2.5MMA | | S3 | SW2.5MMA | | S4 | SW2.5MMA | | S5 | SW2.5MMA | | S6 | SW2.5MMA | | S7 | SW2.5MMA | | S8 | SW2.5MMA | | S9 | SW2.5MMAA | | S10 | SW2.5MMA | | S11 | SW2.5MMA | | SD3 | SD_TF_PUSH | SD_TF | SD4 | SD_TF_PUSH | SD_TF |
3 \8 r, X. i+ `) S: M3 d& w
( u& V3 n* p+ m附件: " H1 p0 h; Z1 o$ P6 _7 P
