Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
3G_MODE | 3G_MODEN_1_3G_MODE_NC/3G_MODEN | NC/3G_moden | IC | 1 | U43 |
A_MM9329-2700-A | ANT_UFL_1_A_MM9329-2700-A_W-G7 | W-G7169 | IC | 1 | ANT1 |
B_0402 | BAV99_0_B_0402_ESDA-11 | ESDA-11 | IC | 15 | D1; D8; D9; D10; D12; D19; D20; D21; D25; D34; D36; D37; D39; D40; D41 |
B_0402 | BAV99_0_B_0402_NC/ESDA-11 | NC/ESDA-11 | IC | 1 | D33 |
B_0402 | BAV99_0_B_0402_ESDA-LP | ESDA-LP | IC | 1 | D35 |
B_0402 | INDUCTOR_0_B_0402_60 OHMS @ 100 | 60 Ohms @ 100MHz | IC | 3 | FB30; FB31; FB32 |
CON_2D54_4P | CON4P_0_CON_2D54_4P_NC/CON4P | NC/CON4P | IC | 1 | J1 |
CON_DC_0501 | DC00038-A_0_CON_DC_0501_DC_0501 | DC_0501 | IC | 1 | J9 |
CON_HDMI_19P_04M | HDMI_0_CON_HDMI_19P_04M_SHD-19F | SHD-19F021 | IC | 1 | CON2 |
CON_MINIUSB_5P | USB_MINI_AB_RECEPTACLE_0_CON_MI | SMU-05F010 | IC | 1 | CON3 |
CON_PJ-3581 | PHONEJACK STEREO_0_CON_PJ-3581_ | PHONEJACK STEREO_7 | IC | 1 | J5 |
CON_TF_CARD | TF_0_CON_TF_CARD_STF-09P-H1.85 | STF-09P-H1.85 | IC | 1 | U29 |
C_0402 | CAPNP_C_0402_0.1UF | 0.1uF | IC | 18 | C1; C10; C22; C33; C35; C36; C48; C50; C65; C252; C259; C262; C267; C270; C273; C276; C279; C282 |
C_0402 | CAP NP_C_0402_0.1UF | 0.1uF | IC | 60 | C2; C3; C4; C5; C6; C7; C8; C9; C11; C12; C13; C14; C15; C26; C30; C31; C40; C66; C67; C68; C70; C71; C72; C73; C74; C76; C77; C78; C79; C80; C81; C82; C83; C84; C86; C87; C88; C89; C90; C91; C92; C93; C94; C98; C99; C100; C101; C182; C187; C188; C189; C190; C191; C212; C215; C240; C245; C246; C264; C268 |
C_0402 | CAPNP_C_0402_10NF | 10nF | IC | 5 | C17; C20; C23; C49; C283 |
C_0402 | CAP NP_C_0402_NC/0.1UF | NC/0.1uF | IC | 3 | C18; C32; C110 |
C_0402 | CAPNP_C_0402_22NF | 22NF | IC | 3 | C25; C249; C254 |
C_0402 | CAP NP_C_0402_10NF | 10nF | IC | 1 | C29 |
C_0402 | CAP NP_C_0402_NC/1UF | NC/1uF | IC | 1 | C37 |
C_0402 | CAP NP_C_0402_18PF | 18pF | IC | 4 | C38; C39; C45; C46 |
C_0402 | CAP NP_C_0402_1UF | 1uF | IC | 3 | C44; C171; C172 |
C_0402 | CAPNP_C_0402_1NF | 1nF | IC | 1 | C51 |
C_0402 | CAP NP_0_C_0402_10NF | 10nF | IC | 9 | C52; C53; C55; C56; C58; C59; C60; C62; C64 |
C_0402 | CAP NP_0_C_0402_1UF | 1uF | IC | 4 | C54; C57; C61; C63 |
C_0402 | CAP NP_0_C_0402_NC/1UF | NC/1uF | IC | 3 | C95; C96; C97 |
C_0402 | CAP_NP_0_C_0402_0.1UF | 0.1uF | IC | 3 | C133; C134; C139 |
C_0402 | CAP NP_1_C_0402_1UF | 1uF | IC | 5 | C146; C147; C149; C152; C155 |
C_0402 | CAP NP_C_0402_0.1U | 0.1u | IC | 1 | C150 |
C_0402 | CAP NP_1_C_0402_0.1UF | 0.1uF | IC | 1 | C156 |
C_0402 | CAP NP_1_C_0402_10PF | 10pF | IC | 1 | C157 |
C_0402 | CAP_NP_2_C_0402_0.1UF | 0.1uF | IC | 14 | C192; C194; C196; C197; C200; C218; C220; C226; C228; C230; C231; C232; C280; C314 |
C_0402 | CAP_NP_2_C_0402_NC/0.1UF | NC/0.1uF | IC | 4 | C193; C199; C302; C303 |
C_0402 | CAP_NP_7_C_0402_1UF | 1uF | IC | 1 | C209 |
C_0402 | CAP_NP_7_C_0402_0.1UF | 0.1uF | IC | 2 | C210; C211 |
C_0402 | CAP NP_C_0402_22PF | 22pF | IC | 2 | C222; C227 |
C_0402 | CAP NP_C_0402_15PF | 15pF | IC | 1 | C223 |
C_0402 | CAP NP_C_0402_8.2PF | 8.2pF | IC | 1 | C224 |
C_0402 | CAP NP_1_C_0402_100P | 100P | IC | 2 | C233; C234 |
C_0402 | CAP NP_C_0402_NC/10PF | NC/10pF | IC | 1 | C235 |
C_0402 | CAP NP_C_0402_1NF | 1NF | IC | 2 | C236; C237 |
C_0402 | C0603_C_0402_0.1UF | 0.1uF | IC | 1 | C239 |
C_0402 | CAP_NP_3_C_0402_0.1UF | 0.1uF | IC | 1 | C242 |
C_0402 | CAP NP_1_C_0402_1NF | 1nF | IC | 1 | C243 |
C_0402 | CAPNP_C_0402_1UF | 1uF | IC | 4 | C247; C248; C250; C253 |
C_0402 | CAPNP_C_0402_NC/0.1UF | NC/0.1uF | IC | 3 | C255; C256; C257 |
C_0402 | CAPNP_C_0402_NC/22PF | NC/22pF | IC | 4 | C260; C261; C274; C275 |
C_0402 | C_0_C_0402_NC/1NF | NC/1nF | IC | 6 | C284; C285; C286; C287; C288; C289 |
C_0402 | CAP_NP_2_C_0402_NC/0.01UF | NC/0.01uF | IC | 2 | C290; C293 |
C_0402 | CAP_NP_2_C_0402_NC/1NF | NC/1nF | IC | 2 | C291; C292 |
C_0402 | CAP_NP_2_C_0402_NC/22PF | NC/22pF | IC | 1 | C299 |
C_0402 | CAP NP_C_0402_100P | 100p | IC | 5 | C307; C308; C309; C316; C317 |
C_0603 | CAPNP_C_0603_2.2UF | 2.2uF | IC | 5 | C16; C19; C21; C34; C251 |
C_0603 | CAP NP_C_0603_4.7UF | 4.7uF | IC | 3 | C168; C186; C214 |
C_0805 | CAPNP_C_0805_10U/16V | 10u/16V | IC | 8 | C27; C28; C47; C238; C258; C266; C272; C278 |
C_0805 | CAP_NP_0_C_0805_10U/16V | 10u/16V | IC | 1 | C132 |
C_0805 | CAP_C_0805_10U/16V | 10u/16V | IC | 3 | C145; C148; CT2 |
C_0805 | CAP NP_C_0805_10U/16V | 10u/16V | IC | 3 | C151; C153; C154 |
C_0805 | CAP_NP_2_C_0805_10U/16V | 10u/16V | IC | 5 | C195; C198; C217; C219; C229 |
C_0805 | CAP_1_C_0805_10U/16V | 10u/16V | IC | 1 | C241 |
C_0805 | CAP POL_C_0805_10U/16V | 10u/16V | IC | 3 | C244; C265; C271 |
C_0805 | CAP_C_0805_NC/10U/16V | NC/10u/16V | IC | 2 | C300; C301 |
C_0805 | CAP_NP_2_C_0805_4.7U/16V | 4.7u/16V | IC | 3 | C304; C312; C313 |
C_0805 | CAP_C_0805_10UF/16V | 10uF/16V | IC | 2 | CT1; CT3 |
C_3216 | CAP POL_C_3216_100UF/6.3V | 100uF/6.3V | IC | 2 | C114; C115 |
C_3216A | CAPNP_C_3216A_22UF/6.3V | 22uF/6.3V | IC | 4 | C24; C69; C75; C85 |
C_3216A | CD4.0/2.0_C_3216A_22UF/6.3V | 22uF/6.3V | IC | 4 | C263; C269; C277; C281 |
C_3216A | CAP_C_3216A_47UF/6.3V | 47uF/6.3V | IC | 2 | CT5; CT6 |
D_0603 | DIODE_3_D_0603_IN4148 | IN4148 | IC | 2 | D22; D24 |
D_1206 | DIODE SCHOTTKY_0_D_1206_DL-35 1 | DL-35 15V | IC | 1 | D3 |
D_1206 | DIODE SCHOTTKY_0_D_1206_DL-35_1 | DL-35 10V | IC | 1 | D5 |
D_1206 | DIODE SCHOTTKY_0_D_1206_IN5819 | IN5819 | IC | 1 | D7 |
D_IN5819_ER3AB | DIODE_0_D_IN5819_ER3AB_IN5819 | IN5819 | IC | 2 | D6; D27 |
D_IN5819_ER3AB | DIODE_0_D_IN5819_ER3AB_CMS06 | CMS06 | IC | 1 | D23 |
FCON_4P_0D5 | FPC_10P_3_FCON_4P_0D5_FPC_6P_0D | FPC_6P_0d5 | IC | 1 | J6 |
FCON_6P_0D5_B | FPC_10P_2_FCON_6P_0D5_B_FPC_6P_ | FPC_6P_0d5 | IC | 1 | J4 |
FCON_24PIN_BB | CM2880-B130SF-E_2_FCON_24PIN_BB | CAMERA1 0308 | IC | 1 | J7 |
FCON_60P_0D5 | TL080WX800-V0_2_FCON_60P_0D5_TL | TL080WX800-V0 | IC | 1 | J2 |
ISL29023 | MMC314XMS_0_ISL29023_ISL29023 | ISL29023 | IC | 1 | U28 |
I_ALC5621_TQFP32 | ALC5621_0_I_ALC5621_TQFP32_ALC5 | ALC5621 | IC | 1 | U1114 |
I_AML_8726_M | AML8726-M_5_I_AML_8726_M_(S1+S2 | AML8726-M | IC | 1 | U2 |
I_BAT54C_SOT23 | BAT54S/SOT_0_I_BAT54C_SOT23_BAT | BAT54S | IC | 2 | D2; D4 |
I_CL6201_SOT23_6 | ACT6360_1_I_CL6201_SOT23_6_MP32 | MP3202 | IC | 1 | U14 |
I_DDR2_60PIN | DDR2-60PIN_0_I_DDR2_60PIN_K4T1G | K4T1G084QE | IC | 4 | U5; U6; U7; U8 |
I_MMA8452Q_QFN_16P | MMA8452QT_0_I_MMA8452Q_QFN_16P_ | MMA8452QT | IC | 1 | U26 |
I_MMC3140MS | MMC314XMS_I_MMC3140MS_MMC3140MS | MMC3140MS | IC | 1 | U27 |
I_MXC6225XU | MXC6225XU_I_MXC6225XU_MXC6225XU | MXC6225XU | IC | 1 | U25 |
I_RCLAMP0524P | 0524P_I_RCLAMP0524P_NC/RCLAMP05 | NC/RCLAMP0524P | IC | 2 | U34; U42 |
I_RT8020 | RT8020_0_I_RT8020_RT8020 | RT8020 | IC | 2 | U38; U41 |
I_RT9513 | RT9513_I_RT9513_RT9513 | RT9513 | IC | 1 | U40 |
I_SN7325 | MMC314XMR_4_I_SN7325_NC/SN7325 | NC/SN7325 | IC | 1 | U3 |
I_SOT23_5P | BF1303_I_SOT23_5P_RT9193-33 | RT9193-33 | IC | 1 | U1 |
I_SOT23_5P | U_RT9701_1_I_SOT23_5P_RT9702GB | RT9702GB | IC | 1 | U30 |
I_SOT23_5P | BF1303_I_SOT23_5P_RT9193T-33PB | RT9193T-33PB | IC | 1 | U36 |
I_SOT23_5P | BF1303_I_SOT23_5P_RT9193T-25PB | RT9193T-25PB | IC | 1 | U37 |
I_SOT23_6 | SY8009_I_SOT23_6_NC/SY8009BEBC | NC/SY8009BEBC | IC | 1 | U45 |
I_TLV70028_TSOT23_5P | MIC5219BM5_I_TLV70028_TSOT23_5P | RT9013-18GB | IC | 1 | U21 |
I_TLV70028_TSOT23_5P | MIC5219BM5_I_TLV70028_TSOT23__1 | RT9013-28GB | IC | 1 | U22 |
I_TSOC6 | DS28E10P+T_I_TSOC6_SIL5635 | SIL5635 | IC | 1 | U61 |
I_TSOP48 | NAND-ALL_1_I_TSOP48_29F32G08CBA | 29F32G08CBABA | IC | 1 | U9 |
I_WM-BN-BM-01 | MD_WM-BN-BM-01_11_I_WM-BN-BM-01 | WM269 | IC | 1 | MD1 |
K_TC1100E-A | SW4P_0_K_TC1100E-A_TC-1100E-RES | TC-1100E-RESET | IC | 1 | SW7 |
LED_226SURSYGC | LED_3_LED_226SURSYGC_19-226SURS | 19-226SURSYGC-S530-A3-E2-TR8 | IC | 1 | D11 |
LED_226SURSYGC | LED_3_LED_226SURSYGC_NC/19-226S | NC/19-226SURSYGC-S530-A3-E2-TR8 | IC | 1 | D32 |
L_0402 | PANASONIC/EXC-3BB221H_0_L_0402_ | 60 OHM@100MHZ | IC | 4 | B4; B7; B9; B10 |
L_0402 | FB0805_L_0402_60 OHM@100MHZ | 60 OHM@100MHz | IC | 8 | FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB27 |
L_0402 | FB0805_0_L_0402_60 OHM@100MHZ | 60 OHM@100MHz | IC | 4 | FB8; FB9; FB10; FB11 |
L_0402 | INDUCTOR_0_L_0402_60 OHM@100MHZ | 60 OHM@100MHz | IC | 4 | FB12; FB18; FB20; FB21 |
L_0402 | FB_L_0402__60 OHM@100MHZ | 60 OHM@100MHz | IC | 2 | FB14; FB15 |
L_0402 | FB_L_0402__1.5NH | 1.5nH | IC | 1 | FB16 |
L_0402 | INDUCTOR_0_L_0402_NC/60 OHM@100 | NC/60 OHM@100MHz | IC | 4 | FB22; FB23; FB24; FB25 |
L_0603 | PANASONIC/EXC-3BB221H_0_L_0603_ | 60 OHM@100MHZ | IC | 1 | B11 |
L_0603 | FB_L_0603__NC/60 OHM@100MHZ | NC/60 OHM@100MHz | IC | 1 | FB26 |
L_3012 | INDUCTOR_1_L_3012_22UH(CDRH2D14 | 22uH(CDRH2D14)400mA | IC | 1 | L1 |
L_3012 | INDUCTOR_L_3012_10UH 1000MA(CDR | 10uH 1000mA(CDRH2D14) | IC | 1 | L2 |
L_3012 | INDUCTOR_3_L_3012_3.3UH/SWPA301 | 3.3uH/SWPA3012S3R3MT | IC | 1 | L5 |
L_3012 | INDUCTOR_POWER_L_3012_4.7UH_1.5 | 4.7uH_1.5A | IC | 4 | L9; L11; L12; L13 |
L_3012 | INDUCTOR_3_L_3012_4.7UH 1000MA( | 4.7uH 1000mA(CDRH2D14) | IC | 1 | L10 |
L_5020 | INDUCTOR_1_L_5020_NC/10UH(SWPA5 | NC/10uH(SWPA5020S100MT) | IC | 1 | L14 |
MIC_SMT | MICROPHONE_0_MIC_SMT_MICROPHONE | MICROPHONE | IC | 1 | MK1 |
M_ZEN056V | ZEN056V230A24LS_M_ZEN056V_ZEN05 | ZEN056V230A16LS | IC | 1 | U35 |
Q_AO3401_SOT23 | MOSFET P_0_Q_AO3401_SOT23_AO340 | AO3401 | IC | 3 | Q1; Q4; Q20 |
Q_AO3401_SOT23 | MOSFET P_0_Q_AO3401_SOT23_NC/AO | NC/AO3401 | IC | 2 | Q3; Q9 |
Q_AO3401_SOT23 | AO3402_9_Q_AO3401_SOT23_AO3402 | AO3402 | IC | 1 | Q7 |
Q_AO3401_SOT23 | IRF4905/TO_0_Q_AO3401_SOT23_AO3 | AO3415 | IC | 2 | Q13; Q16 |
Q_AO3401_SOT-23 | MOSFET P_1_Q_AO3401_SOT-23_NC/A | NC/AO3401 | IC | 1 | Q11 |
Q_MMBT3904_SOT23 | NPN_0_Q_MMBT3904_SOT23_MMBT3904 | MMBT3904 | IC | 6 | Q2; Q5; Q6; Q10; Q21; Q23 |
Q_MMBT3904_SOT23 | PNP BEC_Q_MMBT3904_SOT23_MMBT39 | MMBT3906 | IC | 1 | Q17 |
Q_MMBT3904_SOT23 | NPN_Q_MMBT3904_SOT23_3904 | 3904 | IC | 1 | Q18 |
Q_MMBT3904_SOT23 | RESET_0_Q_MMBT3904_SOT23_BM809A | BM809A263 | IC | 1 | U4 |
Q_MMBT3904_SOT-23 | FAIRCHILD/BAT54C_Q_MMBT3904_SOT | BAT54C | IC | 1 | D26 |
Q_MMBT3904_SOT-23 | NPN_0_Q_MMBT3904_SOT-23_MMBT390 | MMBT3904 | IC | 2 | Q12; Q19 |
Q_MMBT3904_SOT-23 | NPN_0_Q_MMBT3904_SOT-23_NC/MMBT | NC/MMBT3904 | IC | 6 | Q25; Q26; Q27; Q28; Q29; Q30 |
R0402 | RES_R0402_NC/22R | NC/22R | IC | 2 | NR1; NR2 |
R0402 | RES_R0402_33R | 33R | IC | 1 | NR3 |
R_0402 | RESISTOR_R_0402_NC | NC | IC | 7 | R1; R3; R5; R13; R14; R364; R365 |
R_0402 | R_R_0402_1K/5% | 1K/5% | IC | 1 | R2 |
R_0402 | RESISTOR_R_0402_NC/4.7K | NC/4.7K | IC | 1 | R4 |
R_0402 | RESISTOR_R_0402_200R/1% | 200R/1% | IC | 1 | R6 |
R_0402 | RESISTOR_R_0402_22R/NC | 22R/NC | IC | 2 | R7; R54 |
R_0402 | RESISTOR_R_0402_4.7K/NC | 4.7K/NC | IC | 1 | R8 |
R_0402 | RESISTOR_R_0402_4.7K | 4.7K | IC | 5 | R9; R51; R53; R137; R380 |
R_0402 | R_2_R_0402_43.2R/1% | 43.2R/1% | IC | 2 | R10; R11 |
R_0402 | R_2_R_0402_1K | 1K | IC | 1 | R12 |
R_0402 | R0603_R_0402_1K | 1K | IC | 2 | R15; R41 |
R_0402 | RESISTOR_R_0402_600R/1% | 600R/1% | IC | 1 | R16 |
R_0402 | RESISTOR_0_R_0402_4.7K | 4.7K | IC | 11 | R17; R18; R19; R20; R22; R23; R25; R26; R32; R33; R36 |
R_0402 | R_R_0402_100R/5% | 100R/5% | IC | 1 | R24 |
R_0402 | RESISTOR_0_R_0402_0R/NC | 0R/NC | IC | 2 | R27; R31 |
R_0402 | RESISTOR_0_R_0402_4.7K/NC | 4.7K/NC | IC | 2 | R28; R29 |
R_0402 | RESISTOR_R_0402_191R/1%/NC | 191R/1%/NC | IC | 1 | R30 |
R_0402 | RESISTOR_0_R_0402_33R | 33R | IC | 2 | R34; R35 |
R_0402 | RESISTOR_R_0402_220K/1% | 220K/1% | IC | 2 | R37; R38 |
R_0402 | RESISTOR_R_0402_100R | 100R | IC | 2 | R39; R111 |
R_0402 | RESISTOR_R_0402_4.99K/1% | 4.99K/1% | IC | 1 | R40 |
R_0402 | RES_R_0402_10K/NC | 10K/NC | IC | 6 | R42; R346; R347; R348; R349; R350 |
R_0402 | RESISTOR_R_0402_33R | 33R | IC | 17 | R43; R44; R46; R47; R48; R57; R59; R261; R262; R356; R357; R358; R359; R360; R361; R362; R363 |
R_0402 | RESISTOR_3_R_0402_4.7K/NC | 4.7K/NC | IC | 1 | R45 |
R_0402 | RESISTOR_R_0402_150R | 150R | IC | 1 | R49 |
R_0402 | RESISTOR_R_0402_1K/1% | 1K/1% | IC | 6 | R61; R62; R63; R65; R66; R67 |
R_0402 | RES_R_0402_0R | 0R | IC | 2 | R64; R68 |
R_0402 | RES_R_0402_0R/NC | 0R/NC | IC | 1 | R69 |
R_0402 | RESISTOR_R_0402_47K | 47K | IC | 1 | R70 |
R_0402 | RES_0_R_0402_NC/0R | NC/0R | IC | 1 | R85 |
R_0402 | RESISTOR_0_R_0402_100K | 100K | IC | 7 | R86; R110; R113; R121; R141; R230; R296 |
R_0402 | RESISTOR_0_R_0402_10K | 10K | IC | 11 | R87; R89; R112; R115; R116; R119; R142; R143; R231; R297; R298 |
R_0402 | R_R_0402_33R | 33R | IC | 28 | R90; R91; R92; R93; R94; R95; R96; R124; R195; R196; R197; R198; R199; R200; R202; R203; R204; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R225 |
R_0402 | R_R_0402_10K | 10K | IC | 13 | R97; R98; R99; R100; R105; R130; R131; R132; R136; R178; R309; R386; R389 |
R_0402 | R_R_0402_10K/NC | 10K/NC | IC | 5 | R101; R102; R103; R308; R387 |
R_0402 | R_R_0402_2.2R | 2.2R | IC | 2 | R104; R107 |
R_0402 | R_R_0402_20K | 20K | IC | 1 | R106 |
R_0402 | RESISTOR_R_0402_1K | 1K | IC | 2 | R108; R263 |
R_0402 | RESISTOR_R_0402_480R | 480R | IC | 1 | R109 |
R_0402 | R_R_0402_500R | 500R | IC | 1 | R114 |
R_0402 | R_R_0402_1R | 1R | IC | 2 | R117; R118 |
R_0402 | RESISTOR_R_0402_82K/1% | 82K/1% | IC | 1 | R120 |
R_0402 | RESISTOR_R_0402_0.22R/1% | 0.22R/1% | IC | 1 | R122 |
R_0402 | RESISTOR_R_0402_10K/1% | 10K/1% | IC | 1 | R123 |
R_0402 | R_R_0402_0R | 0R | IC | 4 | R127; R311; R313; R391 |
R_0402 | RESISTOR_R_0402_680R | 680R | IC | 1 | R128 |
R_0402 | R_R_0402_NC/10K | NC/10k | IC | 14 | R129; R179; R180; R305; R317; R319; R320; R321; R323; R324; R330; R331; R388; R390 |
R_0402 | R_2_R_0402_5.6K | 5.6k | IC | 1 | R133 |
R_0402 | R_2_R_0402_680R | 680R | IC | 1 | R134 |
R_0402 | R_2_R_0402_0R | 0R | IC | 1 | R135 |
R_0402 | RESISTOR_R_0402_100K | 100K | IC | 1 | R138 |
R_0402 | RES_1_R_0402_33R_5% | 33R | IC | 3 | R146; R147; R162 |
R_0402 | RES_1_R_0402_100K/NC_5% | 100K/NC | IC | 1 | R150 |
R_0402 | RES_1_R_0402_0R_5% | 0R | IC | 1 | R152 |
R_0402 | RES_1_R_0402_100K_5% | 100K | IC | 1 | R157 |
R_0402 | RES_1_R_0402_4.7K_5% | 4.7k | IC | 1 | R161 |
R_0402 | RES_1_R_0402_10K_5% | 10K | IC | 1 | R163 |
R_0402 | RES_5_R_0402_0R_5% | 0R | IC | 7 | R171; R173; R174; R175; R176; R181; R182 |
R_0402 | RES_5_R_0402_10K | 10K | IC | 1 | R172 |
R_0402 | RES_5_R_0402_10K/NC | 10K/NC | IC | 1 | R177 |
R_0402 | RES_1_R_0402_OR_5% | OR | IC | 1 | R183 |
R_0402 | RES_1_R_0402_15K | 15K | IC | 8 | R185; R186; R187; R188; R189; R190; R191; R192 |
R_0402 | RES_1_R_0402_0R | 0R | IC | 2 | R201; R208 |
R_0402 | R_R_0402_15K | 15k | IC | 1 | R205 |
R_0402 | RES_1_R_0402_10K | 10K | IC | 4 | R209; R210; R212; R232 |
R_0402 | R_R_0402_220R | 220R | IC | 2 | R224; R243 |
R_0402 | RESISTOR_0_R_0402_0R | 0R | IC | 2 | R228; R229 |
R_0402 | R_0_R_0402_10K | 10K | IC | 7 | R233; R234; R235; R247; R285; R286; R287 |
R_0402 | R_0_R_0402_33R | 33R | IC | 6 | R236; R237; R238; R239; R241; R242 |
R_0402 | R_R_0402_1K | 1K | IC | 2 | R240; R266 |
R_0402 | R_0_R_0402_47K | 47K | IC | 2 | R244; R246 |
R_0402 | R0603_R_0402_10K/NC | 10K/NC | IC | 1 | R245 |
R_0402 | R0603_R_0402_2.2K | 2.2K | IC | 1 | R248 |
R_0402 | R_0_R_0402_4.7K | 4.7K | IC | 2 | R249; R271 |
R_0402 | R_1_R_0402_10K | 10K | IC | 2 | R250; R251 |
R_0402 | RES_R_0402_DISCRETE_0R | 0R | DISCRETE | 2 | R253; R256 |
R_0402 | R_1_R_0402_0R | 0R | IC | 3 | R254; R255; R257 |
R_0402 | RESISTOR_R_0402_2.2K | 2.2K | IC | 2 | R259; R260 |
R_0402 | RESISTOR_R_0402_10K | 10K | IC | 6 | R264; R352; R353; R354; R355; R381 |
R_0402 | R_R_0402_4.7K/1% | 4.7K/1% | IC | 1 | R265 |
R_0402 | R_R_0402_2K/1% | 2K/1% | IC | 2 | R267; R268 |
R_0402 | R_R_0402_1.6K/1% | 1.6K/1% | IC | 1 | R269 |
R_0402 | R_R_0402_2.7K/1% | 2.7K/1% | IC | 1 | R270 |
R_0402 | R_0_R_0402_200R | 200R | IC | 1 | R272 |
R_0402 | RES_R_0402_4.7K/NC | 4.7K/NC | IC | 2 | R273; R280 |
R_0402 | RES_R_0402_47R | 47R | IC | 1 | R274 |
R_0402 | RES_R_0402_47K | 47K | IC | 5 | R275; R277; R279; R282; R284 |
R_0402 | RES_R_0402_100K | 100K | IC | 2 | R276; R281 |
R_0402 | RES_R_0402_4.7K | 4.7K | IC | 7 | R278; R283; R288; R289; R290; R291; R315 |
R_0402 | R_R_0402_75K/1% | 75K/1% | IC | 1 | R292 |
R_0402 | R_R_0402_91K/1% | 91K/1% | IC | 2 | R293; R303 |
R_0402 | R_R_0402_36K/1% | 36K/1% | IC | 1 | R294 |
R_0402 | R_R_0402_20K/1% | 20K/1% | IC | 2 | R295; R306 |
R_0402 | R_0_R_0402_300K/1% | 300K/1% | IC | 1 | R299 |
R_0402 | R_0_R_0402_100K/1% | 100K/1% | IC | 1 | R300 |
R_0402 | RES_R_0402_750R/1% | 750R/1% | IC | 1 | R301 |
R_0402 | RES_R_0402_10K/5% | 10K/5% | IC | 1 | R302 |
R_0402 | R_R_0402_200K/1% | 200K/1% | IC | 1 | R304 |
R_0402 | R_R_0402_180K/1% | 180K/1% | IC | 1 | R307 |
R_0402 | R_R_0402_1.2K/1% | 1.2K/1% | IC | 1 | R310 |
R_0402 | R_R_0402_100K | 100K | IC | 1 | R312 |
R_0402 | R_R_0402_499K% | 499K% | IC | 1 | R314 |
R_0402 | R_R_0402_NC | NC | IC | 2 | R316; R322 |
R_0402 | R_R_0402_NC/680R | NC/680R | IC | 1 | R318 |
R_0402 | R_R_0402_NC/1K | NC/1K | IC | 3 | R328; R329; R384 |
R_0402 | RESISTOR_R_0402_NC/100K/1% | NC/100K/1% | IC | 2 | R332; R335 |
R_0402 | RESISTOR_0_R_0402_NC/0R | NC/0R | IC | 1 | R333 |
R_0402 | RESISTOR_R_0402_NC/22K/1% | NC/22K/1% | IC | 1 | R334 |
R_0402 | RES_R_0402_10K | 10K | IC | 6 | R337; R341; R342; R343; R344; R345 |
R_0402 | RES_R_0402_DISCRETE_4.7K/5% | 4.7K/5% | DISCRETE | 1 | R338 |
R_0402 | RESISTOR_3_R_0402_0R | 0R | IC | 1 | R339 |
R_0402 | RESISTOR_3_R_0402_0R/NC | 0R/NC | IC | 1 | R340 |
R_0402 | RES_R_0402_ | | IC | 1 | R351 |
R_0402 | RESISTOR_R_0402_0R | 0R | IC | 1 | R378 |
R_0402 | R_R_0402_NC/0R | NC/0R | IC | 1 | R392 |
R_0402_8 | R-PACK_0_R_0402_8_33X8P4R | 33x8P4R | DISCRETE | 6 | RA1; RA2; RA3; RA4; RA5; RA6 |
SOT23_6 | CL8802_SOT23_6_RT9266 | RT9266 | IC | 1 | U15 |
SOT23_6 | CL8802_0_SOT23_6_RT9266 | RT9266 | IC | 1 | U39 |
TESTPOINT_39MIL | T POINT R_TESTPOINT_39MIL_T\POI | T\POINT\R | IC | 17 | IR; TP11; TP12; TP19; TP20; TP47; TP50; TP51; TP52; TP54; TP55; TP56; TP62; TP63; TP64; TP65; TP66 |
TESTPOINT_39MIL | T POINT R_TESTPOINT_39MIL_TEST | TEST | IC | 20 | TP8; TP9; TP10; TP13; TP14; TP15; TP16; TP17; TP18; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP32; TP33; TP36; TP67 |
TESTPOINT_39MIL | TP_TESTPOINT_39MIL_TP | TP | IC | 2 | TP28; TP29 |
TESTPOINT_39MIL | TEST PAD_1_TESTPOINT_39MIL_DISC | 1 mm | DISCRETE | 2 | TP34; TP35 |
TESTPOINT_39MIL | TEST PAD_0_TESTPOINT_39MIL_DISC | 1 mm | DISCRETE | 13 | TP37; TP38; TP39; TP40; TP41; TP42; TP44; TP46; TP57; TP58; TP59; TP60; TP61 |
TESTPOINT_39MIL | TP_2_TESTPOINT_39MIL_TP | TP | IC | 5 | TP43; TP45; TP48; TP49; TP53 |
TP_2X1D5_M | CON1_0_TP_2X1D5_M_CON1 | CON1 | IC | 4 | BAT+1; BAT+2; TP30; TP31 |
XTAL4_SX_3225 | SMD_CRYSTAL_XTAL4_SX_3225_24MHZ | 24MHz_20pF | IC | 1 | Y1 |
XTAL4_SX_3225 | SMD_CRYSTAL_0_XTAL4_SX_3225_37. | 37.4MHz_20ppm | IC | 1 | Y3 |
Y_MC_146 | XTAL_0_Y_MC_146_32.768KHZ | 32.768KHz | IC | 1 | Y2 |
