查看: 343|回复: 0
[allegro16.6][4层]嵌入式3D 扫描仪机器视觉检查解决方案CM_A1 LM_A2 PM_A2(STAND...
发表于 2020-3-5 14:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层]嵌入式3D 扫描仪机器视觉检查解决方案CM_A1 LM_A2 PM_A2(STANDOFF+CONN_MINI_PCIe_52+B3F-1102)原理图和pcb文件
文件描述:
1. 作品用途:嵌入式3D 扫描仪机器视觉检查解决方案CM_A1 LM_A2 PM_A2
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:STANDOFF+CONN_MINI_PCIe_52+B3F-1102
5. PCB尺寸:8450*5350 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
201CAP_0.1UF_X5R_6.3V_20% 0201 _200.1uF/201IC1C100
201CAP_1.0UF_X5R_4V_20%_0201_201_11uF,4V,0201IC1C101
402CAP,0.1UF_402_0.1UF0.1uFIC34C1; C2; C3; C4; C5; C6; C7; C8; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C90; C91; C92
402CAP NP_402_2.2NF2.2nFIC1C12
402CAP NP_402_1NF, 25V1nF, 25VIC1C14
4020402_4.7UF_X7R_10V_402_4.7UF4.7uFIC1C21
402CAP NP_402_47NF47nFIC1C23
402CAP .1 UF 10% 0603_402_0.1UF0.1uFIC2C46; C47
402CAP_8.2NF_X5R_10V_10%_0201 _4028.2nF,10V,0201IC1C52
402CAP NP_402_0.001UF,50V0.001uf,50VIC1C81
402CAP_2.2UF_X5R_6.3V_20%_0402_4022.2uF,6.3VIC2C82; C85
402CAP 100NF CERMC 16V 10% 603_3_45.6pFIC2C83; C86
402CAP_0.001_X7R_50V_5%_0402_402_00.001uf,50VIC2C88; C89
402CAP_0.1UF_X7R_16V_10% 0402 _4_10.1uf,16VIC2C98; C99
402CAP_0.1UF_X7R_16V_10% 0402 _4020.01uf,16VIC8C102; C103; C104; C105; C106; C107; C108; C109
402RES_10_1/10W_5%_0402_402_10,5%10,5%DISCRETE29R1; R2; R3; R5; R8; R11; R14; R17; R18; R20; R22; R24; R26; R28; R30; R32; R34; R36; R38; R40; R42; R44; R46; R48; R50; R52; R54; R56; R119
402RES_33_1/16W_5%_0402_402_33,5%33,5%DISCRETE24R4; R6; R7; R9; R10; R12; R13; R15; R16; R19; R21; R23; R25; R27; R29; R31; R33; R35; R37; R39; R41; R43; R45; R47
402RES_33_0402_402_33,5%33,5%DISCRETE4R49; R51; R53; R55
402RES_10K_1/16W_1%_0402_402_10K,110K,1%IC27R57; R62; R64; R68; R70; R71; R76; R81; R103; R106; R110; R113; R142; R143; R144; R145; R146; R153; R154; R170; R171; R172; R173; R174; R175; R176; R400
402RES_10K_402_DISCRETE_442K_1%442KDISCRETE1R58
402RES_10K_402_DISCRETE_499K_1%499KDISCRETE2R59; R72
402RES_10K_402_DISCRETE_15K_1%15KDISCRETE1R60
402RES_10K_402_DISCRETE_60.4K_1%60.4KDISCRETE1R61
402RES_10K_1/16W_1%_0402_402_10K_110K,1%,DNIIC6R63; R65; R66; R69; R77; R82
402RES_10K_402_DISCRETE_357K_1%357KDISCRETE1R67
402RES_10K_402_DISCRETE_680K_1%680KDISCRETE1R73
402RES_10K_402_DISCRETE_100K_1%100KDISCRETE1R74
402RES_10K_402_DISCRETE_49.9K_1%49.9KDISCRETE1R75
402RES_330_0402_402_330330IC1R78
402RES_10K_402_DISCRETE_0_1%0DISCRETE1R80
402R_402_0,DNI0,DNIIC3R99; R101; R111
402R_402_1K1KIC1R100
402RES_10.1K_1/16W_1%_0402_402_10.10.2K,1%IC1R102
402RESISTOR_402_3.24K3.24KDISCRETE1R105
402RESISTOR_402_30K,1%30K,1%IC1R107
402RES_12.1K_1/16W_1%_0402_402_51.51.1KDISCRETE1R108
402RES_20.5K_1/16W_1%_0402_402_20.20.5K,1%IC1R109
402RES_1M_1/16W_1%_0402_402_1M,1%1M,1%IC1R112
402RES_10K_402_DISCRETE_12.1K,1%_112.1K,1%DISCRETE1R121
402RES_10K_402_DISCRETE_10.2K,1%_110.2K,1%DISCRETE1R139
402R_402_NO-POPNO-POPIC2R141; R155
402R_402_20K20KIC5R147; R148; R149; R150; R151
402R_402_NPNPIC1R152
402R_402_00IC1R156
402RESISTOR_0_402_4.7K4.7kIC3R157; R164; R165
402RESISTOR_0_402_2K2KIC6R158; R159; R166; R167; R168; R169
402RES_4.7K_1/16W_5%_0402_402_4.7K4.7KIC2R398; R399
603CAP NP_603_0.22UF0.22uFIC10C13; C15; C16; C17; C19; C93; C94; C95; C96; C97
603CAP NP_603_1UF, 25V1uF, 25VIC3C18; C20; C25
603CAP_10UF_X5R_6.3V_20%_0603_603_10uF,6.3VIC2C84; C87
603RES_33_603_DISCRETE_1.0_1%1DISCRETE1R79
603RES_14.5K_1/16W_0.1%_0402_603_115K,0.1%IC1R104
603R_3_603_15K15KIC1R160
603R_3_603_17.4K17.4KIC1R161
603R_3_603_12.1K,1%12.1K,1%IC1R162
603R_3_603_4.99K4.99KIC1R163
805CAP NP_805_22UF, 25V22uF, 25VIC3C9; C11; C56
805CAP NP_805_6.8PF, 50V6.8pF, 50vIC1C10
805CAP NP_805_4.7UF, 25V4.7uF, 25VIC2C22; C24
805CAP_805_220PF,50V220pF,50VIC1C26
805CAP_0.1UF_X7R_25V_10% 0805_805_0.1uf,25V,0805IC1C48
805CAP_15PF_NPO_50V_5%_0805_805_1515pF,50VIC1C53
8050402_4.7UF_X7R_10V_805_4.7UF4.7uFIC1C54
805CAP_820PF_X5R_50V_10%_0805_805_820pF,50VIC1C55
BGA96-ZKEIC_SN74AVC32T245_1_BGA96-ZKE_ICIC_SN74AVC32T245IC2U1; U9
CON8_XF3M-0815-1BCONN_CAPTOUCH_1X8_CON8_XF3M-081XF3M-0815-1BIC2P11; P15
CON50_OMRON_653-XF3M-5015-1BCONN_50P_LCD_CON50_OMRON_653-XFXF3M-5015-1BIC1P5
DCK5SN74LVC1G06DCK_0_DCK5_SN74LVC1GSN74LVC1G06DCKIC2U11; U12
DCK-17X60-6TMP_1_DCK-17X60-6_SN74LVC1T45SN74LVC1T45IC1U14
DCU8-10X50PCA9306_DCU8-10X50_PCA9306PCA9306IC2U18; U21
DDA-8IC_TPS54331,3A_0_DDA-8_TPS54531TPS54531DIC1U7
DO214ACDIO_ZEN_DDZ9678-7_1.8V_DO214AC_B130-13-FIC1D8
DO214ACDIO_B130_13_F_SMD_1_DO214AC_B13B130-13-FIC1D9
DO_76SQ_SMDDIODE SCHOTTKY_1_DO_76SQ_SMD_MBMBRM120LIC1D1
DRC10-11X33TPS61080DRC_0_DRC10-11X33_TPS61TPS61080DRCIC1U3
DRC10-11X33U-TPS78601_AJUST - 1_3.5A LDO_DTPS74801IC2U19; U20
HDR2X30SMD_FX18-60P-0P8SVCONN_30X2_1.27MM_HDR2X30SMD_F_1FX18-60P-0.8SVIC1P9
HDR2X30SMD_FX18-60S-0P8SV15CONN_30X2_1.27MM_HDR2X30SMD_FX1fx18-60s-0p8sv15IC4P1; P2; P3; P4
IND86SMD_118SQIND_3.3UH_1.2A_20%_SMD_IND86SMD2.2uH,72mOhmIC1L6
IND130_208X216INDUCTOR_IND130_208X216_3.3UH,73.3uH,7AIC1L5
IND-LQH32MINDUCTOR/SM_IND-LQH32M_4.7UH4.7uHIC2L1; L2
LED_603LED_LTST-C150GKT_LED_603_DISCRELTST-C191KFKTDISCRETE1D3
LED_603LED_LTST-C150GKT_0_LED_603_DISCLTST-C191KFKTDISCRETE1D7
MEC6-150-02-S-D-RA1HEADER 50X2_MEC6-150-02-S-D-RA1MEC6-150-02-S-D-RA1IC1P12
MOLEX_67910-5700CONN_MINI_PCIE_0_MOLEX_67910-57CONN_MINI_PCIe_52IC1P7
MOLEX_67910-5700CONN_MINI_MSATA_6_MOLEX_67910-5CONN_MINI_PCIe_52IC1P8
MOLEX_LBRKT_MINIPCIE_LATCH_MOLEX_L_MOLMOLEX-48099-400IC2M1; M2
MTGH200C102D_PLTESTPOINT_MTGH200C102D_PL_STANDSTANDOFFIC6MH15; MH16; MH17; MH18; MH19; MH20
MTGH250C125D_PLTESTPOINT_MTGH250C125D_PL_STANDSTANDOFFIC12MH1; MH2; MH3; MH4; MH5; MH6; MH11; MH12; MH13; MH14; MH21; MH22
OSC4_65-87SMD_98X126OSC4/SM_0_OSC4_65-87SMD_98X126_TC32M5I32K7680IC1Y1
PW20-14X70TXB0108PWR_0_PW20-14X70_TXS0108TXS0108EPWIC1U15
PWP24-14X70TPS65105PWP_0_PWP24-14X70_TPS65TPS65105PWPIC1U2
QFN16_RGYSN74AVC4T245RGYR_0_QFN16_RGY_SNSN74AVC4T245RGYRIC1U17
QFN20_0P5_4P0X4P0_T1IC_SN75LVCP412A_1_QFN20_0P5_4P0SN75LVCP412AIC1U22
QFN24_RHLSN74AVC8T245_2_QFN24_RHL_SN74AVSN74AVC8T245RHLIC2U13; U16
RD279SMDF_315DCAP_100UF_AE_35V_RD279SMDF_315D100uF,35VIC3C49; C50; C51
SIP2HDR_1X1_M_.1_SIP2_HEADER2HEADER2IC1J1
SIP3HEADER 3_SIP3_HEADER 3HEADER 3IC2J5; J6
SOIC_8MEM_24WC256_0_SOIC_8_24WC25624WC256IC1U10
SOT23-5PWR_LM510510X_SOT23-5_LMR10510LMR10510IC1U8
SOT23_EBCFMMT458/SOT_0_SOT23_EBC_FMMT458FMMT458/SOTIC1Q1
SOT323BAT54S/SOT_0_SOT323_BAT54S/SOTBAT54S/SOTIC1D2
SOT323_GSDMOSFET_NCHAN_BSS138_SOT323_GSD_BSS138IC1Q3
SW4-B3F-315XSW_KT11P2JM_0_SW4-B3F-315X_DISCB3F-3100DISCRETE2S6; S7
SWRST4_177X256LSSW_KT11P2JM_1_SWRST4_177X256LS_B3F-1102DISCRETE5S1; S2; S3; S4; S5
TP25C12DTESTPOINT_TP25C12D_TESTPOINTTESTPOINTIC8TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8
TP100MILTESTPT1_TP100MIL_TESTPT1TESTPT1IC1TP9
WSON-8TPS22965DSG_1_WSON-8_TPS22965DSTPS22965DSGIC1U4
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
! t+ s) ~" h  \' q
GMT+8, 2025-7-28 02:19 , Processed in 0.140625 second(s), 28 queries , Gzip On.
