查看: 219|回复: 0
[allegro16.6][8层]面向汽车应用的Vybrid VF5xxR系列评估板(HDR_2X8+CON_2X5+MMC_...
发表于 2020-3-5 11:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]面向汽车应用的Vybrid VF5xxR系列评估板(HDR_2X8+CON_2X5+MMC_SD_CARD)原理图和pcb文件
文件描述:
1. 作品用途:面向汽车应用的Vybrid VF5xxR系列评估板
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:HDR_2X8+CON_2X5+MMC_SD_CARD
5. PCB尺寸:7550*6000 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
4_4_PIN_THPHONOJACK_STEREO-15_4_4_PIN_TH_AUD 4IO3P6; P7; P8
0402_CCCAP_NP_0402_CC_DISCRETE_0.55MM_1500pFDISCRETE5C1; C3; C96; C500; C533
0402_CCCAP_NP_0402_CC_DISCRETE_0.635MM0.1UFDISCRETE56C8; C9; C17; C20; C21; C23; C24; C30; C31; C32; C34; C35; C36; C37; C40; C42; C51; C70; C72; C92; C97; C98; C102; C104; C501; C502; C507; C509; C513; C514; C518; C519; C523; C524; C527; C528; C532; C538; C539; C543; C544; C547; C596; C607; C624; C629; C631; C632; C633; C634; C635; C639; C640; C641; C642; C643
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_30.22uFDISCRETE41C60; C556; C559; C561; C562; C563; C564; C565; C566; C567; C569; C570; C571; C572; C574; C575; C576; C577; C578; C581; C582; C583; C584; C585; C587; C588; C589; C590; C591; C592; C593; C594; C595; C597; C598; C599; C600; C601; C602; C604; C605
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_12.2UFDISCRETE9C85; C505; C506; C510; C512; C515; C516; C521; C522
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_5120PFDISCRETE1C93
0402_CCCAP_NP_0402_CC_DISCRETE_0.6MM_1180pFDISCRETE1C504
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_22700PFDISCRETE4C525; C526; C529; C530
0402_CCCAP_NP_0402_CC_DISCRETE_0.74MM_33PFDISCRETE2C548; C549
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_40.22uFDISCRETE15C609; C610; C611; C612; C613; C614; C616; C617; C618; C619; C620; C621; C622; C625; C626
0402_CCRES_0402_CC_DISCRETE_470-80245_120 OHMDISCRETE1R91
0402_CCRES_0402_CC_DISCRETE_0.45MM_470100DISCRETE1R566
0603_CCCAP_NP_0603_CC_DISCRETE_0.95MM_1UFDISCRETE13C14; C15; C84; C503; C508; C511; C517; C531; C534; C535; C536; C537; C628
0603_CCCAP_NP_0603_CC_DISCRETE_1.0MM_112PFDISCRETE2C45; C46
0603_CCCAP_NP_0603_CC_DISCRETE_0.9MM_14.7uFDISCRETE7C71; C573; C580; C586; C603; C608; C623
0603_CCRES_0603_CC_DISCRETE_0.55 MM_471.5KDISCRETE6R2; R35; R546; R569; R573; R577
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_110KDISCRETE41R3; R4; R5; R6; R7; R9; R12; R17; R21; R57; R58; R61; R62; R63; R65; R66; R71; R86; R92; R93; R94; R509; R510; R520; R528; R529; R530; R531; R532; R540; R550; R557; R562; R563; R565; R567; R570; R575; R617; R618; R627
0603_CCRES_0603_CC_DISCRETE_0.55MM_4703.3KDISCRETE2R10; R18
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_25.1KDISCRETE1R15
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_2560DISCRETE9R19; R83; R87; R511; R516; R517; R518; R519; R548
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_31.5KDISCRETE5R22; R41; R629; R630; R639
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_510KDISCRETE1R27
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_10DISCRETE31R29; R30; R43; R68; R72; R77; R80; R82; R85; R88; R90; R95; R97; R98; R99; R534; R543; R547; R549; R551; R552; R554; R578; R581; R583; R633; R634; R635; R636; R637; R638
0603_CCRES_0603_CC_DISCRETE_470-75420_100DISCRETE7R32; R39; R42; R500; R521; R523; R545
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_31.5KDISCRETE2R44; R631
0603_CCRES_0603_CC_DISCRETE_470-75847_10DISCRETE1R51
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_48.45KDISCRETE1R53
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_510KDISCRETE1R54
0603_CCRES_0603_CC_DISCRETE_0.6MM_470-100KDISCRETE3R55; R525; R574
0603_CCRES_0603_CC_DISCRETE_470-75995_1.5KDISCRETE1R56
0603_CCRES_0603_CC_DISCRETE_470-75513_12.0KDISCRETE1R59
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_63.9KDISCRETE1R60
0603_CCRES_0603_CC_DISCRETE_470-75400_22KDISCRETE1R64
0603_CCRES_0603_CC_DISCRETE_470-30163_5.1KDISCRETE40R73; R74; R75; R501; R502; R505; R506; R538; R571; R572; R585; R586; R587; R588; R589; R590; R591; R592; R593; R594; R595; R599; R600; R601; R602; R603; R604; R605; R606; R607; R608; R609; R610; R611; R612; R613; R614; R615; R616; R619
0603_CCRES_0603_CC_DISCRETE_0.6MM_47_71KDISCRETE1R79
0603_CCRES_0603_CC_DISCRETE_0.55 MM__120DISCRETE4R503; R504; R507; R508
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_675DISCRETE4R512; R513; R514; R515
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_7240DISCRETE5R522; R559; R560; R561; R564
0603_CCRES_0603_CC_DISCRETE_0.55MM_4_41.0MDISCRETE1R535
0805_CCCAP_NP_0805_CC_DISCRETE_1.45MM_10UFDISCRETE22C7; C25; C26; C27; C28; C33; C38; C39; C53; C87; C91; C540; C541; C542; C545; C546; C552; C553; C555; C557; C568; C630
0805_CCRES_0805_CC_DISCRETE_470-76820_0.02DISCRETE8R20; R33; R34; R38; R46; R49; R50; R52
1210_CCCAP_NP_1210_CC_DISCRETE_2.8MM_110uFDISCRETE1C82
BGA12_0P5_1P9X1P4WM9010_BGA12_BGA12_0P5_1P9X1P4_WM9010IC2U500; U501
BGA96_0P8_8P15X14P151G_DDR3_SDRAM_64MX16_96P_BGA96_MT41J64M16JT-15E AATIC1U6
BGA364_0P8_17X17_C13SPF701M512ZVLH17_364P_A_BGA364_0SVF522R3K1CMK4IC1U5
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTIC6DCLK1; DOUT1; EEPROM_SCK1; EEPROM_SDA1; XIN1; XOUT1
C335_RADCAP_POL_C335_RAD_DISCRETE_13MM_220UFDISCRETE1C74
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UFDISCRETE2C44; C560
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PFDISCRETE2C63; C66
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_318PFDISCRETE1C65
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M180pFDISCRETE1C520
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_218pFDISCRETE1C636
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uFDISCRETE2C6; C579
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE3C558; C615; C627
CC1210CAP_NP_CC1210_DISCRETE_2.8MM_15100UFDISCRETE1C29
CC1210MOT_CAP_CC1210_DISCRETE_2.7 MM_47UFDISCRETE8C75; C78; C79; C80; C88; C89; C94; C95
CON4_RA_4P2MMCONN_HDR_4X1_CON4_RA_4P2MM_IO_1CON PLUG 4IO1P25
CON4_RCA_RA_THCONN_RCA_4P_CON4_RCA_RA_TH_IO_1RCJ-014IO4P2; P3; P4; P5
CON9_MICROAB_USB_SHELL_THMICRO_USB_CONN_9PIN_CON9_MICROAUSB AB 5IO1P9
CON19_SDCARD_28X25_SMCON_SDCARD_19P_CON19_SDCARD_28XMMC_SD_CARDIO1P500
CON_60S_QSH_SM_AQSH030_CON_60S_QSH_SM_A_IO_3.25QSH-030-01-L-D-A-K-TRIO1J10
CON_120S_QSH_SM_05PITCHQSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-AIO1P20
CON_DB9S_RA_318CONN_DB9F_MTGTABS_CON_DB9S_RA_3DB9IO1P26
CON_HTST_20M_2P54_SMCONN_SHRHDR_10X2_CON_HTST_20M_2HDR2X10IO1P15
CON_SKT_10F_100_THCONN_HDR_5X2_CON_SKT_10F_100_THCON_2X5IO1P17
CON_SKT_44_0P5_SMTCONN_SKT_44P_CON_SKT_44_0P5_SMTQSH-020-01-L-D-DP-AIO1P22
CON_TFM_60M_50_SMHDR_2X30_M_CON_TFM_60M_50_SM_IOCON 2X30 PLUGIO1P13
HDR2X4CONN_HDR_4X2_HDR2X4_IO_8.6MM_21HDR_2X4IO1P11
HDR102_TMMCONN_HDR_1X2_HDR102_TMM_IO_7.51X2IO2J7; J9
HDR103_78MILJUMPER_3_2MM_HDR103_78MIL_IO_5.HDR_1X3IO9J1; J2; J3; J14; J15; J16; J17; J18; J19
HDR103_78MILCONN_HDR_3X1_HDR103_78MIL_IO_7.1X3IO1J8
HDR205_10M_50_SMCONN_HDR_5X2_HDR205_10M_50_SM_IFTSH-105-01-L-DVIO1P16
HDR206CONN_HDR_6X2_HDR206_IO_8.382 MMHDR_2X6IO1P18
HDR208CONN_HDR_8X2_HDR208_IO_8.58MM_2HDR_2X8IO1P14
HDR215_ACONN_HDR_15X2_HDR215_A_IO_10.69HDR_2X15_MIO1J5
IND2_7P5X7P5IND_FERRITE_IND2_7P5X7P5_DISCRE2.2uHDISCRETE1L2
IND_13X13P8IND_IRON_B_IND_13X13P8_DISCRETE2.2UHDISCRETE1L500
IND_0402BEAD_IND_0402_DISCRETE_0.55MM_1120 OHMDISCRETE8FB1; FB3; FB8; FB500; FB501; FB502; FB503; FB504
IND_IHLPINDUCTOR_IND_IHLP_DISCRETE_3.01uHDISCRETE1L3
JUMP1X4-6040HDR-1X4_JUMP1X4-6040_IO_8.4MM_2HDR_1X4IO1P27
JUMP2X2-6040HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR 2X2IO1P19
LED_0603LED_LED_0603_IC_0.8MM_370-75077LED_GREENIC5DS1; DS3; DS4; DS5; DS6
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1DS2
LQFP48CS48560_48P_LQFP48_IC_1.6MM_312CS48560IC1U510
MIC_LGA_CAV_4P82X3P86ADMP441_LGA9_MIC_LGA_CAV_4P82X3ADMP441ACEZ-RL7IC2U503; U504
OSC4_2P5X2P0_SMO4-0_OSC4_2P5X2P0_SM_IC_0.8MM_224 MHzIC1Y2
PJ-202BDC POWER JACK_PJ-202B_IO_11.2MMCONN PWR 1IO1P12
POT3_3310YPOT_POT3_3310Y_DISCRETE_18.9MM_2KDISCRETE1RV1
QFN32_0P5_EP3P3MAX16993_1_QFN32_0P5_EP3P3_IC_0MAX16993AGJA/VY+IC1U7
R603-X2RES_0603_X2_R603-X2_DISCRETE_470DISCRETE3R28; R621; R625
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE1R23
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE1R24
RC0402_25RES_RC0402_25_DISCRETE_470-30841.18KDISCRETE1R542
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_12.2MDISCRETE1R640
RC2512RES_RC2512_DISCRETE_470-76704_00.022DISCRETE1R48
RCA_8_10NETW_B8_10P_RCA_8_10_DISCRETE_010KDISCRETE4RN500; RN501; RN502; RN503
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT500
SMA2_4_4P6X2P9DIODE_SCHTKY_SMA2_4_4P6X2P9_IC_B340AIC1D500
SO8MOSFET_N_8P_SO8_IC_1.75MM_480-7FDS6680IC2Q4; Q5
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U3
SO8-25X75-200SST25VF032B-SOIC8_SO8-25X75-200SST25VF032B-80-4I-S2AFIC1U2
SO8_1P27_4X5MC33399_SO8_1P27_4X5_IC_1.75MM_MC33661PEFIC1U9
SO8_1P27_4X5TJA1051T_SO_8P_SO8_1P27_4X5_IC_TJA1051T/3IC1U512
SOD-923DIODE_TVS_SOD-923_IC_0.43MM_480ESD5V0D9-TPIC2TZ1; TZ2
SOD-923DIODE_TVS_SOD-923_IC_0.43MM_4_1ESD3V3D9-TPIC5TZ500; TZ501; TZ502; TZ503; TZ504
SOIC16_1P27_7P5X10P3S25FL256S_SOIC_16P_SOIC16_1P27_S25FL256SDPMFV011IC3U507; U508; U509
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC2Q1; Q500
SOT23NPN_SOT23_IC_1.1MM_480-78569_PBPBSS4021NTIC1Q2
SOT23-40X40DUALDIODE_CC_SOT23_SHTKY_SOT23-BAT54C-7-FIC1DD2
SOT143-25X60STM6315RDW13F_SOT143-25X60_IC_1STM6315RDW13FIC1U4
SOT223LM1117_ADJ_SOT223_IC_1.8MM_315-LM1117MPX-ADJIC1U1
SOT-23DUALDIODE_SERIES_SOT23_SOT-23_IBAV99IC6DD3; DD8; DD500; DD501; DD502; DD503
SSOP16MAX3221A_SSOP16_IC_2.0MM_312-30TR3221IC1U10
SW5_2P5_12P5X13P2_THPEC11-4220F-S0012_SW5_2P5_12P5XPEC11-4220F-S0012IC2SW1; SW2
SW_8P2X8P2SW_SPNO_2P_SW_8P2X8P2_IC_13.2MMB3WN-6002IC5SW3; SW4; SW5; SW6; SW7
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8IC4SW8; SW9; SW10; SW11
TESTPOINT_138_059MILTEST_POINT_TESTPOINT_138_059MILTEST POINTIC10TP9; TP10; TP20; TP26; TP42; TP43; TP44; TP51; TP52; TP500
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO1TP22
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO9TP23; TP24; TP25; TP28; TP31; TP32; TP35; TP36; TP37
TSSOP10_0P5_3X3MMCS5343_TSSOP_10P_TSSOP10_0P5_3XCS5343IC1U502
TSSOP10_0P5_3X3MMCS4344_TSSOP_10P_TSSOP10_0P5_3XCS4344IC2U505; U506
TSSOP16MAX7310_TSSOP_16_TSSOP16_IC_1.1MAX7310IC1U8
USB_A_TH_SAMTECUSB_A_USB_A_TH_SAMTEC_IO_6.95 MUSB_TYPE_A_FEMALEIO1P1
XTAL2_5X2_SMXTAL_XTAL2_5X2_SM_IC_1.0MM_230-32.768KHZIC1Y4
XTAL_CS10_SMXTAL_CS10_XTAL_CS10_SM_IC_1MM_224.5760MHzIC1Y500
XTLOSC4_3P2X2P5MM_SMXTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I24MHZIC1Y3
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
9 j7 o& g% p4 c. A7 I) `) M
GMT+8, 2025-7-27 23:11 , Processed in 0.171875 second(s), 28 queries , Gzip On.
