1. 作品用途:来个TI最新的4核 CPU OMAP4460 平板电脑
2. 软件版本:allegro16.6
3. 层数:8层
5. PCB尺寸:4000*4500 mil
Bill of Material Report (Condensed) | | | | | |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
402 | 207-0000-075_0_0402_DISCRETE_0. | 0.015uF | DISCRETE | 1 | C181 |
BGA3X4-ZXU | 111-1003550_BGA3X4-ZXU_TXB0104Z | TXB0104ZXUR | IC | 1 | U12 |
BGA3X4-ZXU | 111-1003204_0_BGA3X4-ZXU_TXS010 | TXS0104EZXUR | IC | 1 | U20 |
BGA16_YZH | 111-1003570_BGA16_YZH_TPS62361 | TPS62361 | IC | 1 | U25 |
C402-25 | 0402_0R1UF_X7R_10V_10_C402-25_0 | 0.1uF | IC | 47 | C1; C2; C4; C7; C8; C10; C12; C13; C15; C16; C17; C23; C28; C29; C33; C51; C52; C53; C58; C60; C61; C62; C63; C71; C73; C95; C108; C116; C140; C144; C145; C154; C155; C156; C157; C161; C162; C167; C179; C186; C188; C189; C191; C194; C195; C196; C197 |
C402-25 | 111-1002271_0_C402-25_DISCRETE_ | 1UF | DISCRETE | 4 | C11; C74; C192; C198 |
C402-25 | 111-1002537_1_C402-25_2.2UF | 2.2uF | IC | 28 | C22; C31; C49; C50; C59; C87; C88; C89; C90; C91; C93; C94; C97; C100; C107; C113; C117; C128; C132; C143; C146; C147; C148; C149; C150; C175; C184; C231 |
C402-25 | 111-1002658_C402-25_470NF | 470nF | IC | 13 | C35; C37; C70; C104; C106; C112; C120; C124; C166; C172; C203; C222; C230 |
C402-25 | CAPACITOR NP_C402-25_220NF | 220nF | IC | 2 | C64; C126 |
C402-25 | 207-0225-000_C402-25_15PF | 15PF | IC | 4 | C76; C80; C96; C99 |
C402-25 | 0402_18PF_NPO_50V_5_C402-25_18P | 18pF | IC | 2 | C81; C82 |
C402-25 | 111-1002522_C402-25_DISCRETE_12 | 12pF | DISCRETE | 2 | C102; C103 |
C402-25 | 100NF-16V X7R_0_C402-25__0.01UF | 0.01uF | IC | 3 | C109; C170; C174 |
C402-25 | 111-1003687_C402-25_10UF | 10uF | IC | 4 | C129; C138; C142; C213 |
C402-25 | CAP_0402_560PF_COG_50V_5%_X_C40 | 560pF | IC | 2 | C151; C160 |
C402-25 | 1NF50V0402_C402-25_1NF | 1nF | IC | 2 | C152; C164 |
C402-25 | 111-1002743_0_C402-25_DISCRETE_ | 4.7UF | DISCRETE | 2 | C199; C210 |
C402-25 | 111-1003803_C402-25_DISCRETE_91 | 91pF | DISCRETE | 1 | C232 |
CONN2X10-4028 | HEADER10X2PIN_1_27MM_CONN2X10-4 | HEADER 10x2 | IC | 2 | J1; J4 |
CONN3-PWR-PJ102A | CONN_PWR1_2.5MM_CONN3-PWR-PJ102 | PJ-002A | IC | 1 | P3 |
CONN9-SMT-RT-190-009-263 | DSUB_FEMALE_SHORT_0_CONN9-SMT-R | 190-009-263R001 | IC | 1 | P4 |
DCK5 | TPS3803G15_0_DCK5_TPS3803G15 | TPS3803G15 | IC | 1 | U19 |
F603-41X39 | PGB0010603MR_0_F603-41X39_PGB00 | PGB0010603MR | IC | 4 | D4; D5; D6; D7 |
HDMI-SMT-W-FLANGE | CONN_HDMI_0_HDMI-SMT-W-FLANGE_C | CONN_HDMI_1 | IC | 2 | P1; P2 |
IND0806 | 111-1003740_IND0806_1.0UH_+/-30 | 1.0uH | IC | 1 | L16 |
IPC_7343_31 | 111-1002741_0_IPC_7343_31_47UF | 47uF | IC | 1 | C153 |
JUMP2-6040 | HEADER_0_JUMP2-6040_104350-1 | 104350-1 | IC | 5 | J10; J11; J13; J15; J19 |
JUMP2X5-6040-MIR | 111-1003411_1_JUMP2X5-6040-MIR_ | SLW-105-01-L-D | IC | 1 | J2 |
JUMP2X7-6040-K6 | EHDR_SM_14P | HDR 2x7 | IO | 1 | J8 |
JUMP2X14-6040-1 | EXP_HDR_28_JUMP2X14-6040-1_EXP_ | EXP_HDR_28 | IC | 2 | J3; J6 |
KINGCOMM_SDMM-X0-0011 | KINGCONN_SDMM-X0-0011_0_KINGCOM | SDMM-X0-0011 | IC | 1 | J14 |
L805-35X60 | 111-1002666_L805-35X60_1.0UH_+/ | 1.0uH | IC | 2 | L8; L9 |
L1210-70X102 | IND_1210_1.0UH_3A_20%_X_L1210-7 | 1.0uH | IC | 1 | L14 |
L2010-41X87 | 111-1003359_L2010-41X87_0.68UH_ | 0.68uH | IC | 1 | L12 |
LS240-WI-01-A20_LSR | 111-1003817_LS240-WI-01-A20_LSR | LSR-TiWi-BLE | IC | 1 | U3 |
LTST-C150GKT | LED_LTST-C150GKT_GRN | GRN | IC | 2 | D1; D2 |
MOLEX-56579-0576 | 111-1002717_MOLEX-56579-0576_56 | 56579-0567 | IC | 1 | J18 |
OMAP4440_SDC_SKT | IC_OMAP4440_SDC_SKT_PO0_4.42_X_ | OMAP4460 | IC | 1 | U10 |
OSC_CSXO_5X3P2 | 111-1003454_1_OSC_CSXO_5X3P2_7C | 7C38470004 | IC | 1 | Y3 |
PAP64-12X70 | TFP410_1_PAP64-12X70_TFP410 | TFP410 | IC | 1 | U1 |
PHOENIX-POWER | TMP_0_PHOENIX-POWER_PHOENIX PMI | Phoenix PMIC ES2 | IC | 1 | U11 |
POWERDI-123 | 111-1004104_POWERDI-123_DISCRET | DFLS130L-7 | DISCRETE | 1 | D8 |
PWP14-12X70 | TPS2141PWP_0_PWP14-12X70_TPS214 | TPS2141PWP | IC | 1 | U21 |
QFN32_5X5 | IC_USB3321C-GL-TR_1_QFN32_5X5_U | USB3320C-EZK | IC | 1 | U7 |
QFN64-11X27-SMSC | LAN9514_QFN64_QFN64-11X27-SMSC_ | LAN9514_QFN64 | IC | 1 | U8 |
R402-25 | 111-1001256_R402-25_0.5PF | 0.5pF | IC | 1 | C235 |
R402-25 | 0402_4R7K_1_R402-25_DISCRETE_4. | 4.7K | DISCRETE | 3 | R1; R18; R23 |
R402-25 | RES_272-0065-000_R402-25_DISCRE | 0 | DISCRETE | 36 | R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R14; R15; R16; R19; R20; R21; R27; R58; R61; R69; R70; R71; R121; R122; R144; R152; R153; R156; R157; R159; R160; R164; R176; R181; R182; R185 |
R402-25 | 0402_10K_1_R402-25_DISCRETE_10K | 10K | DISCRETE | 12 | R12; R22; R24; R25; R28; R29; R30; R31; R32; R33; R34; R149 |
R402-25 | 111-1003169_R402-25_12.4K | 12.4K | IC | 2 | R17; R105 |
R402-25 | RES_0_R402-25_DISCRETE_10K_1% | 10K | DISCRETE | 17 | R54; R55; R56; R57; R59; R81; R88; R95; R96; R97; R100; R111; R112; R142; R145; R150; R183 |
R402-25 | ERJ1GEYJ103C_0_R402-25_DISCRETE | 3.3K | DISCRETE | 13 | R90; R92; R99; R101; R108; R118; R123; R128; R136; R137; R138; R139; R143 |
R402-25 | 272-0421-000_R402-25_DISCRETE_3 | 330 | DISCRETE | 2 | R93; R98 |
R402-25 | 272-0775-000_R402-25_12K | 12K | IC | 1 | R103 |
R402-25 | 272-0457-000_R402-25_DISCRETE_4 | 49.9 | DISCRETE | 4 | R106; R110; R113; R130 |
R402-25 | 0402_180K_R402-25_DISCRETE_100_ | 100 | DISCRETE | 2 | R107; R134 |
R402-25 | RES_272-0065-000_R402-25_DISC_1 | 1Meg | DISCRETE | 2 | R109; R140 |
R402-25 | 272-0093-000_R402-25_DISCRETE_1 | 10 | DISCRETE | 1 | R135 |
R402-25 | RES1608 | 100K | DISCRETE | 9 | R151; R154; R158; R162; R167; R169; R171; R172; R173 |
R402-25 | 272-0766-000_R402-25_DISCRETE_1 | 15 | DISCRETE | 2 | R161; R163 |
R402-25 | RESISTOR_R402-25_33K | 33K | IC | 1 | R165 |
R402-25 | RES_272-0554-000_R402-25_DISCRE | 150K | DISCRETE | 1 | R168 |
R402-25 | 111-1003802_R402-25_DISCRETE_1. | 1.78K | DISCRETE | 1 | R170 |
R402-25 | 111-1003202_R402-25_620K | 620K | IC | 1 | R174 |
R402-25 | RES_272-0200-000_R402-25_DISCRE | 200K | DISCRETE | 1 | R175 |
R0402-25 | 0402_36R5K_0_R0402-25_DISCRETE_ | 36.5k | DISCRETE | 1 | R184 |
R1206-40X70 | 272-0349-000_R1206-40X70_390 | 390 | IC | 1 | R166 |
SC70-6 | SN74AVC1T45DCKR_SC70-6_IC_SN74A | SN74AVC1T45DCKR | IC | 1 | U4 |
SM-7351-CAP-0201 | 111-1002268_1_SM-7351-CAP-0201_ | 0.1uF | IC | 68 | C3; C5; C6; C18; C19; C25; C26; C27; C34; C36; C38; C39; C40; C42; C44; C45; C46; C47; C54; C55; C56; C57; C65; C68; C69; C72; C75; C78; C79; C85; C86; C92; C98; C101; C105; C110; C111; C118; C119; C121; C122; C123; C125; C127; C165; C171; C173; C177; C200; C201; C202; C204; C205; C206; C207; C211; C212; C214; C215; C217; C220; C221; C223; C225; C226; C227; C228; C229 |
SM-7351-CAP-0201 | 111-1003696_SM-7351-CAP-0201_DI | 1UF | DISCRETE | 11 | C41; C43; C77; C83; C84; C208; C209; C216; C218; C219; C224 |
SM-7351-CAP-0402 | CAP_0402_330PF_COG_50V_5%_X_SM- | 330pF | IC | 1 | C183 |
SM-7351-CAP-0402 | CAP_207-0054-000_SM-7351-CAP-04 | 0.01UF | DISCRETE | 1 | C185 |
SM-7351-CAP-0402 | 111-1002529_0_SM-7351-CAP-0402_ | 0.1uF | IC | 1 | C187 |
SM-7351-CAP-0603 | 207-0165-000_0_SM-7351-CAP-0603 | 4.7UF | DISCRETE | 5 | C21; C48; C178; C180; C182 |
SM-7351-CAP-0805 | 47UFCAPACITOR6.3V20%0805_SM-735 | 47uF | IC | 2 | C176; C237 |
SM-7351-CAP-0805 | 111-1002535_0_SM-7351-CAP-0805_ | 4.7UF | DISCRETE | 2 | C233; C234 |
SM-7351-CAP-0805-2 | 207-0000-075_0_SM-7351-CAP-0805 | 4.7uF | DISCRETE | 1 | C190 |
SM-7351-CAP-6032 | 111-1003206_0_SM-7351-CAP-6032_ | 100UF | IC | 4 | C20; C24; C66; C67 |
SM-7351-IND-0402 | 111-1002671_1_SM-7351-IND-0402_ | BLM15PD121SN1D | DISCRETE | 5 | L7; L10; L17; L19; L20 |
SM-7351-IND-0603 | 111-1002735_SM-7351-IND-0603_DI | BLM18KG221SN1D | DISCRETE | 9 | L1; L3; L4; L6; L11; L13; L15; L18; L22 |
SM-7351-RES-0201 | 111-1002559_0_SM-7351-RES-0201_ | 1K | DISCRETE | 14 | R26; R76; R77; R91; R94; R102; R104; R114; R117; R132; R133; R146; R147; R148 |
SM-7351-RES-0201 | RES0201 | 100K | DISCRETE | 1 | R35 |
SM-7351-RES-0201 | 111-1002664_SM-7351-RES-0201_10 | 10k | IC | 4 | R36; R37; R178; R180 |
SM-7351-RES-0201 | RES_0201_33.0_0.5A_0.05W_X_SM-7 | 33 | DISCRETE | 42 | R38; R39; R40; R41; R43; R44; R45; R46; R49; R50; R52; R53; R62; R63; R64; R65; R66; R67; R68; R72; R73; R74; R75; R78; R80; R82; R83; R84; R85; R86; R87; R115; R116; R119; R120; R124; R125; R126; R127; R129; R131; R141 |
SM-7351-RES-0201 | 272-0494-000_3_SM-7351-RES-0201 | 0 | DISCRETE | 6 | R47; R48; R51; R60; R177; R179 |
SM-7351-RES-0201 | 111-1003772_SM-7351-RES-0201_24 | 240 | IC | 2 | R79; R89 |
SM-7351-RES-0402 | RES_272-0554-000_SM-7351-RES-04 | 150K | DISCRETE | 1 | R155 |
SM-7351-RES-0603 | 10K-0603-5%_0_SM-7351-RES-0603_ | 510 | DISCRETE | 1 | R13 |
SM-7351-RES-0603 | RESISTOR_SM-7351-RES-0603_8.06K | 8.06K | IC | 1 | R42 |
SM-BGA-121-P5-6X6 | PHOENIX_AUDIO_0_0_SM-BGA-121-P5 | Phoenix_audio_1_1 | IC | 1 | U18 |
SM-CAP-0402 | 111-1001207_SM-CAP-0402_5.1NH | 5.1nH | IC | 1 | L2 |
SM-CAP-0603-CUSTOM | 0603_10UF_X5R_2.3V_20%_SM-CAP-0 | 10uF | IC | 6 | C115; C131; C134; C136; C169; C193 |
SM-IND-1210 | IND_1210_1.0UH_3A_20%_X_SM-IND- | 1.0uH | IC | 1 | L23 |
SM-LED-LX0603 | LED_RED_SML-LX0603IW_OCT0107_SM | SML-LX0603IW-TR | IC | 1 | D3 |
SM-PWR-RES-0603 | 111-1004108_SM-PWR-RES-0603_DIS | 0.02 | DISCRETE | 1 | R186 |
SM-QFN-10-P5-RSE | TPD6E001RSER_SM-QFN-10-P5-RSE_T | TPD6E001RSER | IC | 2 | U15; U17 |
SM-SO-8-DCU | TXS0102DCUR_1_SM-SO-8-DCU_IC_TX | TXS0102DCUR | IC | 1 | U2 |
SM-SO-SC70-5 | SN74LVC1G07DCKR_0_SM-SO-SC70-5_ | SN74LVC1G07DCKR | IC | 1 | U13 |
SM-SOT-6-P95-1P5 | FDC6330L_1_SM-SOT-6-P95-1P5_IC_ | FDC6330L | IC | 2 | U14; U16 |
SM-SOT-23 | TRANS_IRLML2402_SM-SOT-23_DISCR | PMV56XN | DISCRETE | 2 | Q1; Q2 |
SM-SOT-363 | RN1907_SM-SOT-363_RN1907 | RN1907 | IC | 1 | T1 |
SM-SW-BS3-1000P | B3S-1000P_2_SM-SW-BS3-1000P_BS3 | BS3-1000P | IC | 2 | S1; S2 |
SM-TP-5016 | CONN_TP_HOOP_SMT_SM-TP-5016_IO_ | SMT_CON_5016 | IO | 1 | GND1 |
SMD_16X44 | ANTENNA2_4GHZCHIP_SMD_16X44_2_4 | 2_4GHzAntenna | IC | 1 | ANT1 |
SMD_0402 | RES_272-0065-000_SMD_0402_DISCR | 0 | DISCRETE | 1 | R187 |
SMT_UMCCVERT | UMCC_VERT_SMT_UMCCVERT_UMCC_VER | UMCC_VERT | IC | 1 | J5 |
SM_BGA_P4_4X7_28 | IC_TPD12S015_0_SM_BGA_P4_4X7_28 | TPD12S015A | IC | 1 | U5 |
SM_CAP_0402_H_0_7 | 111-1002743_0_SM_CAP_0402_H_0_7 | 4.7UF | DISCRETE | 14 | C30; C32; C114; C130; C133; C135; C137; C139; C141; C158; C159; C163; C168; C236 |
SM_CON_FX6A-40P_0_8SV91 | 111-1003780_0_SM_CON_FX6A-40P_0 | FX6A-40P-0.8SV91 | IO | 1 | J7 |
SM_IND_LQM21P | LQM21PN1R0MC0_0_SM_IND_LQM21P_D | 1 uH | DISCRETE | 1 | L5 |
SM_LITTELFUSE_0435 | 111-1004093_SM_LITTELFUSE_0435_ | 1.5A_QuickBlow | IC | 1 | F1 |
SM_SW_CHS-01TA | 111-1003783_SM_SW_CHS-01TA_DISC | CHS-01TA | DISCRETE | 1 | SW1 |
SM_XTAL_CM315 | 111-1002526_0_SM_XTAL_CM315_32. | 32.768kHz | IC | 1 | Y2 |
SO16-25X75 | TPS2054BD_0_SO16-25X75_TPS2054B | TPS2054BD | IC | 1 | U6 |
SO16-25X75 | 111-1003389_0_SO16-25X75_IC_SN7 | SN75C3232EDR | IC | 1 | U23 |
SOT23-27X39-5 | TPS73633DBVT_0_SOT23-27X39-5_TP | TPS73633DBVT | IC | 1 | U9 |
TBD_TPS54320 | 111-1003800_TBD_TPS54320_TPS543 | TPS54320RHL | IC | 1 | U22 |
TBD_VLP8040 | 111-1003801_TBD_VLP8040_6.8UH_+ | 6.8uH | IC | 1 | L21 |
TFM-115-A | CONNECTORSAMTECTFM_0_TFM-115-A_ | TFM_30 | IC | 1 | J17 |
TH-TP-A-PL-1P1XP63 | TESTPT0_TH-TP-A-PL-1P1XP63_IO_T | TestPt0 | IO | 1 | TP7 |
TH_DUAL3_5MMSTK | DUAL3_5MMSTACKEDCONNECTOR_TH_DU | Dual_3.5mmConnectorStacked | IC | 1 | J16 |
TH_STKUSBX2RJ45 | USBAX2_RJ45_10_100_TH_STKUSBX2R | USBAx2_RJ-45 | IC | 1 | J9 |
TP1-20SMT | TESTPT0_TP1-20SMT_IO_TESTPT0 | TestPt0 | IO | 6 | TP1; TP2; TP3; TP4; TP5; TP6 |
TP_VIA_20RD8 | TP_VIA_20RD8_TP_VIA_20RD8_TP_VI | TP_VIA_20rd8 | IC | 12 | TP8; TP9; TP10; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP23; TP24 |
TP_VIA_20RD8 | TP_VIA_0_TP_VIA_20RD8_TP_VIA_0 | TP_VIA_0 | IC | 5 | TP11; TP19; TP20; TP21; TP22 |
U_6_DRY | TPD4S012DRYR_0_U_6_DRY_TPD4S012 | TPD4S012DRYR | IC | 1 | U24 |
XTAL2-NX8045GB | XTAL25MHZ_HC49U_0_XTAL2-NX8045G | 25.000MHz | IC | 1 | Y1 |
