查看: 399|回复: 8
[allegro16.6][8层]拉卡拉-刷银行卡POS机(GSM/L203+S3C6410+K4X1G323PE)原理图和...
发表于 2020-3-4 16:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]拉卡拉-刷银行卡POS机(GSM/L203+S3C6410+K4X1G323PE)原理图和pcb文件
文件描述:
1. 作品用途:拉卡拉-刷银行卡POS机
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:GSM/L203+S3C6410+K4X1G323PE
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
1011034-4-16-31011034-4-16-316PINKEYIC1J7
1011034-4-35-31011034-4-35-3JY-T32QH01T1IC1J3
ANT-LDA312GANT-LDA312GANT_WIFI_BTIC1ANT1
ANT_R300_150ANT_R300_150GNDIC4T1; T2; T3; T4
B-3528B-3528100uF/16VIC3C1; C9; C219
BAT3PIN_SMTBAT3PIN_SMTBATIC1J1
BM7525SBM7525SBUZZERIC1LS1
C0402C040210pFIC215C3; C5; C6; C8; C11; C13; C15; C16; C17; C19; C20; C21; C22; C23; C24; C25; C27; C28; C37; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C149; C151; C153; C154; C155; C157; C158; C160; C162; C163; C164; C165; C166; C167; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C194; C195; C197; C198; C200; C201; C202; C203; C204; C205; C206; C207; C209; C210; C212; C214; C215; C217; C221; C222; C224; C225; C227; C228; C229; C230; C231; C232; C233; C235; C236; C237; C238; C239; C240; C241; C243; C244; C245; C246; C247; C249; C251; C253; C255; C256; C257; C258; C259; C260; C261
C0603C06034_7uFIC39C2; C4; C7; C10; C12; C14; C18; C26; C29; C30; C32; C34; C36; C38; C122; C135; C148; C150; C152; C156; C159; C161; C168; C196; C199; C208; C211; C213; C216; C218; C220; C223; C226; C234; C242; C248; C250; C252; C254
C0805C0805NCIC4C31; C33; C35; C193
CON1X2_1D25CON1X2_1D252PIN_CONIC2J4; J17
CON5_1D25CON5_1D25FingerIC1J12
CON12_1D0_CM55CON12_1D0_CM55CON12 CM55IC1J6
CON-0D5A-12PLBCON-0D5A-12PLBUE988IC1J10
CRY-3215CRY-321532_768KIC2Y2; Y6
CRY-SMD3225CRY-SMD322548MhzIC5Y1; Y3; Y4; Y5; Y7
D0603D0603LED-GreenIC2D2; D3
DCT123JE1DCT123JE1DTC143ZEIC3U32; U33; U34
FBGA-90-8X13FBGA-90-8X13K4X1G323PEIC2U10; U11
FBGA-424-13X13FBGA-424-13X13S3C6410IC1U9
FH39-21S-03SHWFH39-21S-03SHWMT9V022-21IC1J9
GSM_L203GSM_L203GSM/L203IC1U31
HOLEC140NPHOLEC140NPH1IC1H2
HOLEC250H140HOLEC250H140H1IC5H1; H3; H4; H5; H10
HOLEC500H370HOLEC500H370H1IC4H6; H7; H8; H9
IRDA_RPM872IRDA_RPM872IRDA RPM872IC1U25
L0402L0402BLM15AG121SN1IC6FB2; FB3; FB4; FB5; FB6; L7
L0603L0603BLM18PG221IC1FB1
L-CD3D16-4X4L-CD3D16-4X42_2uHIC6L1; L2; L3; L4; L5; L6
LBEE1USJYC-TEMPLBEE1USJYC-TEMPWIFI_LBEE1USJYC-TEMPIC1U37
LQFP_48LQFP_48STM32F103C8IC1U16
MARKERMARKERH1IC6M1; M2; M3; M4; M5; M6
MINI-USB-BMINI-USB-Bmini-usb-4p_1IC1J2
MM9329-2700MM9329-2700U_F_L_R-SMTIC2J11; J13
MS412FE-FL26EMS412FE-FL26EMS621F-FL11IC1J8
MUP_C816_CARDMUP_C816_CARDICCARDIC1J5
PQFP20_0_5_3_5X4_5MMPQFP20_0_5_3_5X4_5MMIC1U2
PR9200PR9200PR9200IC1U30
QFN-32-5X5QFN-32-5X5WT6575FIC2U6; U35
R0402R04025_1MIC261R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R140; R141; R142; R143; R144; R145; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; RV1; RV2; RV3; RV4; RV5; RV6; RV7; RV8; RV9; RV10; RV11; RV12; RV13; RV14; RV15; RV16; RV17; RV18; RV19; RV20; RV21; RV22; RV23; RV24; RV25; RV26; RV27
R0603R06032_2RIC2R139; R146
SIM25-06F05-TP180SIM25-06F05-TP180SIM_CARDIC1J15
SLP4016P16SLP4016P16EClAMP2378PIC5U14; U17; U19; U26; U27
SMART_CARD_2X8PINSMART_CARD_2X8PINDUAL SIMIC1J16
SMBSMBB330BIC1D1
SO-8SO-8IRF7404IC1U1
SOD-323SOD-3235819IC11D4; D5; D6; D7; D8; D9; D10; D11; D12; D14; D15
SOP-8SOP-8DM2016IC1U4
SOT23SOT23S9013IC9Q1; Q2; Q4; Q5; Q6; Q7; U8; U21; U23
SOT23-5SOT23-5MP3410DJIC1U3
SOT-23SOT-23NTR2101PIC2Q8; Q9
SOT-23-5SOT-23-5XC6210A282MRIC8U7; U13; U22; U28; U29; U36; U38; U39
SOT-23-6LSOT-23-6LCP-2123IC1U15
SOT-666SOT-666USBLC6-2P6IC1U5
SOT_23_5SOT_23_5XC6221A332MRIC1U18
TCX3225TCX322520MHzIC2Y8; Y9
TFLASH-OPENTFLASH-OPENTF-CONIC1J14
TP1_0TP1_0B0IC52TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57
TSK-051510-FTSK-051510-FREC/DFUIC1RESET1
TSOP48-1220FTSOP48-1220FK9F2G08U0CIC1U12
TSSOP16TSSOP16MAX3232IC1U24
TSSOP28TSSOP28TDA8023TTIC1U20
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
9 t" f, ~# ?! h& k
发表于 2022-3-29 09:38 | 只看该作者
未来要做的东东
发表于 2022-3-29 09:42 | 只看该作者
看这里能不能下
“来自电巢APP”
发表于 2022-3-29 09:53 | 只看该作者
没有原理图,也不是16.6的PCB文件
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2022-9-17 16:53 | 只看该作者
    看看学习没与喜爱。% ~* S# B( G( X! I; F% F
    2022-9-29 15:42
  • 签到天数: 5 天
    [LV.2]偶尔看看I
    发表于 2022-9-20 09:13 | 只看该作者
    只有截图,没有源文件分享啊
    GMT+8, 2025-7-21 22:31 , Processed in 0.140625 second(s), 28 queries , Gzip On.
